en-US
      Operating instructionsFronius Smart Meter TS 100A-1
    • General information
      • Safety information
        • Safety instructions and important information
        • Environmental conditions
      • General
        • How information is presented in the document
        • Target group
        • Data security
        • Copyright
      • Fronius Smart Meter TS 100A-1
        • Device description
        • Information on the device
        • Intended use
        • Scope of supply
        • Positioning
    • Installation
      • Installation
        • Checklist for installation
        • Installation
        • Protective circuit
        • Cabling
        • Fitting the protective cover for the terminals
        • Connecting the data communication cable to the inverter
        • Terminating resistors - explanation of symbols
        • Connecting the terminating resistor
        • Mounting the connection cover
        • Multi meter system - Explanation of symbols
        • Modbus participant - Fronius SnapINverter
        • Multi-meter system - Fronius SnapINverter
        • Modbus participant - Fronius GEN24
        • Multi meter system - Fronius GEN24 inverter
        • Menu - Measured variables
        • Configuration menu - structure and parameters
        • Setting the address on the Fronius Smart Meter TS
        • Error messages
    • Commissioning
      • Fronius SnapINverter
        • General
        • Connect to Fronius Datamanager 2.0
        • Configuring the Fronius Smart Meter TS as the primary meter
        • Configuring the Fronius Smart Meter TS as a secondary meter
      • Fronius GEN24 inverter
        • General
        • Installation with the browser
    • Technical data
      • Technical data
      • Fronius manufacturer's warranty
    • 021-30102025
    download
    Cabling
    Start-up
    Technical data
    ContactImprintTerms of usePrivacy statementCookie policy
    General information
    link_horizontalLink copied
    Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. General information
    Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    WARNING!
    Incorrect operation or misuse
    IMPORTANT!
    In addition to the operating instructions, observe the following general and local rules:
    • Accident prevention
    • Fire protection
    • Environmental protection
    IMPORTANT!
    IMPORTANT!
    All safety and danger notices on the device:
    • Must be kept in a legible state
    • Must not be damaged/marked
    • Must not be removed
    • Must not be covered, have anything stuck on them, or painted over
    WARNING!
    Tampered-with and non-functioning protection devices
    WARNING!
    NOTE!
    The device may be damaged
    General
    Application notes
    Software
    Example: Click Save.
    Instructions for action
    1Action steps are displayed with consecutive numbering.
    ✓This symbol indicates the result of the action step or the entire instruction.
    2. General
    Application notes
    Software
    2. General
    Target group
    This document provides detailed information and instructions to ensure that all users can use the device safely and efficiently.
    • The information is intended for the following groups of people:
      • Technical specialists: People with appropriate qualifications and fundamental electronic and mechanical knowledge, who are responsible for the installation, operation, and maintenance of the device.
      • End users: People that use the device in daily operation and want to understand its basic functions.
    • Regardless of any qualifications, only perform the activities listed in this document.
    • All persons involved in the commissioning, maintenance, and servicing of the device must be appropriately qualified and have knowledge of working with electrical installations.
    • The definition of professional qualifications and their applicability are subject to national law.
    2. General
    Data security
    • Backing up any changes made to the factory settings
    • Saving and storing personal settings
    NOTE!
    Operate inverters and system components on a private, secure network.
    2. General
    Copyright
    Device description
    The Fronius Smart Meter is a bidirectional electricity meter for optimizing self-consumption and recording a household's load characteristic curve. Together with a Fronius inverter or Fronius Datamanager 2.0 and a Fronius data interface, the Fronius Smart Meter allows you to view your own power consumption. The meter measures the energy flow to the loads or to the public grid and forwards the information to the Fronius inverter or Fronius Datamanager 2.0 via the Modbus RTU/RS485 interface.
    CAUTION!
    Danger due to non-compliance with the safety instructions
    Risk of injury and damage to the device as a result.
    Follow all safety instructions.
    Switch off the power supply before establishing the mains connection.
    2. Fronius Smart Meter TS 100A-1
    Device description
    CAUTION!
    Technical data, labels, and safety symbols are located on the Fronius Smart Meter TS. This information must be kept in a legible condition and must not be removed, covered, pasted over, or painted over. It warns against incorrect operation, which may result in serious injury and property damage.
    Markings:
    The equipment complies with all the requisite and relevant standards and directives that form part of the relevant EU directive, and therefore is permitted to display the CE mark.
    Insulated (safety class II)
    RCM (Regulatory Compliance Mark)
    All relevant regulatory requirements in Australia and New Zealand are complied with in terms of safety and electromagnetic compatibility, as well as special requirements for radio equipment.
    To comply with European Directive 2012/19/EU on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must be returned to your distributor, or you must locate the approved collection and recycling facilities in your area. Ignoring this European Directive may have potentially adverse effects on the environment and your health.
    RoHS (Restriction of Hazardous Substances)
    The restricted use of certain hazardous substances in electrical and electronic equipment has been complied with in accordance with the EU Directive 2011/65/EU.
    Safety symbols:
    Risk of serious injury and property damage due to incorrect operation.
    Dangerous electrical voltage.
    Intended use
    The Fronius Smart Meter TS is a fixed piece of equipment for public grids of TN/TT systems and records the self-consumption or individual loads in the system. The Fronius Smart Meter TS is required for systems with an installed battery storage system and/or a Fronius Ohmpilot for communication between the individual components. The Smart Meter must be installed indoors on a DIN rail with corresponding back-up fuses, which are selected to suit the cable cross-sections of the copper conductors and the maximum current of the meter. The Fronius Smart Meter TS must only be operated in accordance with the specifications in the enclosed documentation and in accordance with local laws, regulations, provisions, standards, and within the limits of technical possibilities. Any use of the product other than as described under intended use shall be deemed to be not in accordance with intended use. The available documentation forms part of the product and must be read, observed, and kept in good condition. It must also be accessible at all times at the place of installation. The available documents do not replace regional, state, provincial, federal, or national laws, or regulations or standards that apply to the installation, electrical safety, and use of the product. Fronius International GmbH assumes no responsibility for compliance with or non-compliance with these laws or regulations in connection with the installation of the product.
    Interventions in the Fronius Smart Meter TS, e.g., modifications and alterations, are not permitted. Unauthorized interventions will void the warranty and warranty claims and, as a rule, void the user's authority to operate the equipment.
    Reasonably foreseeable misuse:
    The Fronius Smart Meter TS is not suitable for the power supply of life-sustaining medical devices or for billing costs to subtenants.
    Scope of supply
    (1)
    2x seal wire
    (2)
    2x connection cover
    (3)
    Fronius Smart Meter TS 65A-3
    (4)
    1x protective cover
    (5)
    Quick Start Guide
    Positioning
    The Smart Meter can be installed in the following positions in the system:
    Positioning at the feed-in point
    Installation of the Fronius Smart Meter IP at the feed-in point
    Positioning at the consumption point
    Installation of the Fronius Smart Meter IP at the consumption point
    Installation
    Installation
    For installation information, see the following chapters:
    1Switch off the power supply before establishing a grid connection.
    2Mount the Fronius Smart Meter TS (see "Installation" on page (→)).
    3Connect automatic circuit breakers or automatic circuit breakers and disconnectors (see"Protective circuit" on page (→)).
    4Connect the mains cable to the Fronius Smart Meter TS (see "Cabling" on page (→)).
    5Fit the protective cover for the terminals (see "Fitting the protective cover for the terminals" on page (→)).
    6Connect the data communication connections of the Fronius Smart Meter TS to the Fronius system monitoring using a suitable cable (see "Connecting the data communication cable to the inverter" on page (→)).
    7If necessary, set terminating resistors (see "Connecting the terminating resistor" on page (→)).
    8Tug on each wire and plug to make sure that they are securely connected to the terminal blocks.
    9Switch on the power supply to the Fronius Smart Meter TS.
    10Check the firmware version of the Fronius system monitoring. To ensure compatibility between the inverter and the Fronius Smart Meter TS, the software must always be kept up to date. The update can be started via the inverter web page or using Solar.web.
    11If several Fronius Smart Meter TS are installed in the system, set the address (see "Setting the address" under "Setting the address on the Fronius Smart Meter TS" on page (→)).
    12Configure and commission the meter (see Commissioning on page (→)).
    1. Installation
    Installation
    1. Installation
    2. Installation
    1. Installation
    2. Installation
    Installation
    The Fronius Smart Meter TS can be mounted on a 35 mm DIN rail. The housing comprises 2 modules according to DIN 43880.
    1. Installation
    2. Installation
    Protective circuit
    The Fronius Smart Meter TS is a hard-wired device and requires a disconnecting device (circuit breaker, switch or disconnector) and overcurrent protection (automatic circuit breaker).
    The Fronius Smart Meter TS consumes 10 - 30 mA, the nominal capacity of the disconnecting devices and the overcurrent protection is determined by the wire thickness, the mains voltage, and the required breaking capacity.
    • Disconnecting devices must be mounted within sight and as close as possible to the Fronius Smart Meter TS; they must also be easy to use.
    • The disconnecting devices must satisfy the requirements of IEC 60947-1 and IEC 60947-3, as well as all national and local regulations for electrical systems.
    • Use overcurrent protection rated for max. 100 A.
    • To monitor more than one mains voltage, use connected automatic circuit breakers.
    • The overcurrent protection must protect the grid terminal marked L1. In rare cases, the neutral conductor has an overcurrent protection, which must interrupt both neutral and non-grounded cables concurrently.
    1. Installation
    2. Installation
    Cabling
    IMPORTANT!
    Always switch off the power supply before connecting the mains voltage inputs to the Fronius Smart Meter TS.
    Recommended thickness of stranded mains voltage cables for the terminals of the measuring input and measuring output:
    • Wire: 1 - 25 mm²
    • Recommended torque: max. 2.8 Nm
    Recommended thickness of stranded wires for data communication terminals:
    • Wire: min. 0.05 mm²
    • Recommended torque: max. 0.5 Nm
    Connect each voltage cable to the terminal strip as shown in the graphics below.
    1 phase, 2 conductors
    1. Installation
    2. Installation
    Insert the protective cover into the guide and press firmly.
    WARNING!
    Danger due to electrical voltage from missing or improperly fitted protective cover.
    An electric shock can be fatal and/or cause serious damage to property.
    Fit the protective cover immediately after installing the live cables.
    Fit the protective cover properly and check that it is secure.
    1. Installation
    2. Installation
    Connect the data communication connections of the Fronius Smart Meter TS to the Modbus interface of the Fronius inverter using a network cable (type CAT5 or higher).
    Several Smart Meters can be installed in the system, see chapter Multi-meter system - Fronius SnapINverter on page (→).
     To avoid interference, the terminating resistor must be used (see chapter Connecting the terminating resistor on page (→)).
    IMPORTANT!
    Further information for successful commissioning.
    Observe the following information on connecting the data communication cable to the inverter.
    • Use network cables of type CAT5 or higher.
    • The maximum cable length between the Fronius inverter and Fronius Smart Meter is 300 meters.
    • Use a mutual twisted cable pair for corresponding data lines (D+/D-, M0+/M0-).
    • On Fronius GEN24 inverters, the M0 and M1 inputs can be selected for this purpose.
    • If the data lines are close to the mains cabling, use wires or cables that are designed for 300 to 600 V (never less than the operating voltage).
    • Use double-insulated or sheathed data lines when they are close to bare conductors.
    • Use shielded twisted pair cables to avoid faults.
    • Two wires can be installed in each terminal; the wires are twisted first, inserted into the terminal, and tightened.
      Note: A loose wire can disable an entire area of the network.
    • The data communication connections of the Fronius Smart Meter TS are electrically isolated from hazardous voltages.
    1. Installation
    2. Installation
    Inverter in the system
    e.g., Fronius Symo
    Meter - Fronius Smart Meter TS
    Terminating resistor R 120 Ohm is set with a wire jumper between M- and T.
    Modbus RTU, third-party device
    e.g., Fronius Ohmpilot, battery, etc.
    R 120 Ohm
    1. Installation
    2. Installation
    The terminating resistor is integrated in the Fronius Smart Meter TS and is manufactured with a bridge between the M and T connections (T = termination).
    1. Installation
    2. Installation
    Due to interference, it is recommended that terminating resistors are used as illustrated below to ensure proper functioning.
    * The terminating resistor is integrated in the Fronius Smart Meter TS and is manufactured with a bridge between the M and T connections (T = termination).
    1. Installation
    2. Installation
    Insert the connection covers into the guides and press firmly.
    IMPORTANT!
    When fitting the connection covers, ensure that the cables are not kinked, pinched, crushed, or otherwise damaged.
    1. Installation
    2. Installation
    Grid
    Supplies the loads in the system if insufficient power is being generated by the PV modules or supplied by the battery.
    e.g. Fronius Primo, Fronius Symo, etc.
    Utility meter
    Measures the metering data relevant for the billing of electricity quantities (primarily the kilowatt hours of grid purchases and grid power feed). On the basis of the data relevant for billing, the electricity retailer invoices a grid purchase and the purchaser of the surplus pays for the grid power feed.
    Primary meter
    Records the load curve of the system and makes the measured data available for energy profiling in Fronius Solar.web. The primary meter also regulates the dynamic feed-in control.
    Secondary meter
    Records the load curve of individual loads and producers (e.g. washing machine, lights, television, heat pump, etc.) in the consumption branch and makes the measured data available for energy profiling in Fronius Solar.web.
    Modbus RTU, Third-party device
    e.g. Fronius Ohmpilot, battery, etc.
    Loads in the system
    e.g. washing machine, lamps, TV, etc.
    Additional loads in the system
    e.g. heat pump
    Additional producers in the system
    e.g. wind power plant
    R 120 Ohm
    1. Installation
    2. Installation
    A maximum of 4 Modbus stations can be connected to the Modbus connection terminal.
    IMPORTANT!
    Only one primary meter, one battery and one Ohmpilot can be connected per inverter. Due to the high data transfer of the battery, the battery occupies 2 subscribers.
    Example:
    Input
    Battery
    Fronius
    Ohmpilot
    Number
    of primary meters
    Number
    of secondary meters
    Modbus
    0
    1. Installation
    2. Installation
    If several Fronius Smart Meter TS are installed, a separate address must be set for each (see Setting the address on the Fronius Smart Meter TS on page (→)). The primary meter is always assigned address 1. All the other meters are numbered consecutively with the address range from 2 to 14. Different Fronius Smart Meter power categories can be used in combination.
    IMPORTANT!
    Max. Use 3 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to chapter Connecting the terminating resistor on page (→).
    Location of the primary meter in the consumption branch. *Terminating resistor R 120 Ohm
    Location of the primary meter at the feed-in point. *Terminating resistor R 120 Ohm
    The following must be observed in a multi-meter system:
    • Only assign each Modbus address once.
    • Terminating resistors must be positioned individually for each channel.
    1. Installation
    2. Installation
    The inputs M0 and M1 can be freely selected. A maximum of 4 Modbus participants can be connected to the Modbus terminal on the inputs M0 and M1.
    IMPORTANT!
    Example 1:
    Input
    Battery
    Fronius
    Ohmpilot
    Number
    of primary meters
    Number
    of secondary meters
    Modbus 0
    (M0)
    0
    0
    0
    Modbus 1
    (M1)
    Example 2:
    Input
    Battery
    Fronius
    Ohmpilot
    Number
    of primary meters
    Number
    of secondary meters
    Modbus 0
    (M0)
    Modbus 1
    (M1)
    0
    0
    0
    1. Installation
    2. Installation
    If several Fronius Smart Meter TS are installed, a separate address must be set for each one (see Setting the address on the Fronius Smart Meter TS on page (→)). The primary meter always receives the address 1. All other meters are numbered consecutively in the address range from 2 to 14. Different Fronius Smart Meter power categories can be used together.
    IMPORTANT!
    Use no more than 7 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to the chapter Connecting the terminating resistor on page (→).
    3 secondary meters with connected generators and loads, primary meter in the consumption branch, third-party device Modbus RTU connected to the inverter
    Position of the primary meter in the consumption branch. *Terminating resistor R 120 Ohm
    3 secondary meters with connected generators and loads, primary meter at the feed-in point, third-party device Modbus RTU connected to the inverter.
    Position of the primary meter at the feed-in point. *Terminating resistor R 120 Ohm
    The following must be observed in a multi meter system:
    • Connect the primary meter and the battery to different channels (recommended).
    • Distribute the remaining Modbus participants evenly.
    • Each Modbus address is assigned only once.
    • Place the terminating resistors individually for each channel.
    1. Installation
    2. Installation
    Screen
    Description
    00
    1. Total active energy drawn*
    2. Effective power
    01
    1. Total active energy supplied**
    2. Effective power
    02
    2. Voltage
    03
    2. Current
    04
    2. Power factor (L = inductive, C = capacitive)
    05
    2. Frequency
    06
    1. Total reactive energy drawn*
    2. Reactive power
    07
    1. Total reactive energy supplied**
    2. Reactive power
    08
    2. Average demanded power (dMd = demand), calculated for the set interval. The value remains unchanged for the entire interval. It is "0" in the first interval after the start.
    3. Maximum demanded power (P = Peak demand) that has been reached since the last reset
    09
    • Not used
    10
    • Not used
    Displayed when easy connection mode is activated (measurement = A). This value indicates the total energy without considering the direction.
    Factory setting - displayed when drawn and delivered energy are measured separately (measurement = b).
    1. Installation
    2. Installation
    Screen
    Code
    Description
    Values
    PASS***
    P1
    Enter the current password
    2633*
    nPASS
    P2
    Password change **
    Four digits (0000-9999)
    MEASurE
    P3
    Measurement mode **
    A: easy connection, measures all energy without taking the direction into account.
    B*: measures imported and exported energy separately.
    P int
    P4
    Average power calculation interval (minutes)
    1* - 30
    MOdE
    P5
    Display mode **
    Full*: full display
    Easy: reduced display. The values that are not displayed are still transmitted via the serial interface.
    tArIFF
    P6
    Tariff management **
    On: activated
    Off*: deactivated
    HoME
    P7
    Screen showing measured variables displayed at startup and after 120 seconds of inactivity **
    For full display (Mode = Full): 0 - 10*
    AddrESS***
    P10
    Modbus address
    1* - 247
    bAUd
    P11
    Baud rate (kBit/s) **
    9.6* / 19.2 / 38.4 / 57.6 / 115.2
    PArITY
    P12
    Parity **
    Even/No*
    STOP bit
    P12-2
    Only if parity = No. Stop bit. **
    1* / 2
    rESET
    P13
    Activation of the reset function for energy tariffs, maximum requested power, and part values of active and reactive energy (the latter are only transmitted via the serial interface) **
    No*: reset function deactivated.
    Yes: reset function activated.
    End
    P14
    Returns to the measured variables start screen
    None
    Factory settings
    The settings can be protected by changing the default password (password cannot be reset).
    Settings that need to be configured.
    1. Installation
    2. Installation
    Symbol
    Name
    Event
    Function
    Up
    1x
    Scroll one screen forward, increase the value by 1
    Down/
    Enter
    1x
    Scroll one screen back, decrease the value by 1
    2 seconds
    Call up settings, confirm value
    1Press and hold "Down/Enter" for 2 seconds.
    2Press "Up" or "Down/Enter" to access the P1 screen.
    3Set password "2633" with "Up" and "Down/Enter" and confirm each individual value with "Down/Enter".
    4Note down the password.
    IMPORTANT!
    The password cannot be reset.
    1Press "Up" or "Down/Enter" to access the P10 screen.
    2Press and hold "Down/Enter" for 2 seconds.
    3Set the address with "Up" and "Down/Enter" and confirm each individual value with "Down/Enter".
    4Press "Up" to access the P14 screen and press and hold "Enter" for 2 seconds to exit the settings.
    1. Installation
    2. Installation
    Error messages
    If the measured signal exceeds the permissible limit values of the meter, a corresponding message or symbol appears on the display:
    • EEE flashes: the measured signal value is outside the limit values.
    • EEE on: the measurement depends on a value that is outside the limit values.
    •   Direction of rotation of the power supply is incorrect
    •   Current direction of a phase (here phase 1) is incorrect
    Note: Active and reactive energy measurements are displayed but do not change.
    Commissioning
    General
    IMPORTANT! Settings under the "Meter" menu item are only to be made by trained and qualified personnel!
    The service password must be entered in order to access the "Meter" menu item.
    Three-phase or single-phase Fronius Smart Meter TS can be used. In both cases, the selection is made under the "Fronius Smart Meter" item. The Fronius Datamanager automatically identifies the meter type.
    A primary meter and several secondary meters can be selected. The primary meter needs to be configured first before a secondary meter can be selected.
    1. Commissioning
    General
    1. Commissioning
    2. Fronius SnapINverter
    General
    1. Commissioning
    Access Point:
    Activate the WiFi access point of the inverter:
    1.
    Navigate to settings (Setup).
    2.
    Navigate to WiFi Access Point.
    ✓Network and password are displayed.
    3.
    Activate WiFi access point with the Enter    key.
    1Select the Setup menu on the inverter display.
    2Navigate to WiFi Access Point.
    ✓Network (SS) and password (PW) are displayed.
    3Activate the WiFi Access Point with the Enter    key.
    Establish the connection from the inverter's WiFi access point to the PC:
    1Establish the connection to the inverter in the network settings (the inverter is displayed with the name "Fronius_240.XXXXXX").
    2Enter and confirm the password from the inverter display.
    3In the browser's address bar, enter the IP address http://192.168.250.181 and confirm.
    ✓The Fronius Datamanager 2.0 start page is displayed.
    LAN:
    1Connect the Fronius Datamanager and computer with a LAN cable.
    2Place the Fronius Datamanager 2.0 IP switch in the "A" position.
    3In the browser's address bar, enter the IP address http://169.254.0.180 and confirm.
    1. Commissioning
    1Go to the Fronius Datamanager website.
    - Open the web browser.
    - In the address bar of the browser, enter the IP address (IP address for WLAN: 192.168.250.181, IP address for LAN: 169.254.0.180) or the host and domain name of the Fronius Datamanager and confirm.
    - The Fronius Datamanager website will be displayed.
    2Click the "Settings" button.
    3Log in to the login area with the "service" user and the service password.
    4Open the "Meter" menu area.
    5Select the primary meter from the drop-down list.
    6Click the "Settings" button.
    7In the pop-up window, set the position of the meter (feed-in point or consumption point). For more information on the position of the Fronius Smart Meter TS, see Positioning on page (→).
    8Click the "Ok" button when the OK status is displayed. If the Timeout status is displayed, try again.
    9Click the    button to save the settings.
    The Fronius Smart Meter TS is configured as a primary meter.
    The "Current general view" menu area displays the power of the PV modules, self-consumption, the energy fed into the grid, and the battery charge (if available).
    1. Commissioning
    5Select the secondary meter from the drop-down list.
    6Click the "Add" button.
    7Enter the name of the secondary meter in the "Name" input field.
    8Enter the previously assigned address in the "Modbus address" input field.
    9Add meter description.
    10Click the    button to save the settings.
    The Fronius Smart Meter TS is configured as a secondary meter.
    1. Commissioning
    General
    IMPORTANT! Settings under the "Device configuration" menu item are only to be made by trained and qualified personnel!
    The service password must be entered in order to access the "Device configuration" menu item.
    Three-phase or single-phase Fronius Smart Meter TS can be used. In both cases, the selection is made under the "Components" menu area. The meter type is determined automatically.
    1. Commissioning
    2. Fronius GEN24 inverter
    General
    1. Commissioning
    WLAN:
    1Open the access point by touching the sensor
    ✓Communications LED flashes blue.
    2Establish the connection to the inverter in the network settings (the inverter is displayed with the name "FRONIUS_" and the serial number of the device).
    3Enter the password from the rating plate and confirm.
    IMPORTANT!
    To enter the password in Windows 10, first select the Connect using a security key instead link to be able to establish the connection with the password.
    4Enter the IP address 192.168.250.181 in the address bar of the browser and confirm. The installation wizard opens.
    5Follow the installation wizard and complete the installation in the individual areas.
    6Add the system components in Fronius Solar.web and commission the PV system.
    Ethernet:
    1Establish a connection to the inverter (LAN1) using a network cable (min. CAT5 STP).
    2Open the access point by touching the sensor once
    3Enter the IP address 169.254.0.180 in the address bar of the browser and confirm. The installation wizard opens.
    4Follow the installation wizard and complete the installation in the individual areas.
    5Add the system components in Fronius Solar.web and commission the PV system.
    1. Commissioning
    1Access the inverter website.
    - In the address bar of the browser, enter the IP address (IP address for WLAN: 192.168.250.181, IP address for LAN: 169.254.0.180) or the host and domain name of the inverter and confirm.
    - The inverter website is displayed.
    2Click the "Device configuration" button.
    3Log in to the login area with the "Technician" user and the technician password.
    4Access the "Components“ menu area.
    5Click the "Add component" button.
    6In the "Position" drop-down list, set the position of the meter (feed-in point or consumption point). For more information on the position of the Fronius Smart Meter TS, see Positioning on page (→).
    7Click the "Add" button.
    8Click the "Save" button to save the settings.
    1. Commissioning
    6In the "Position" drop-down list, select the meter type (producer/load meter).
    7Enter the previously assigned address in the "Modbus address" input field.
    8Enter the name of the meter in the "Name" input field.
    9In the "Category" drop-down list, select the category (producer or load).
    10Click the "Add" button.
    11Click the "Save" button to save the settings.
    Technical data
    Technical data
    Modbus transmission speed: 9600 baud
    Parity bit:none
    Software version:
    • Fronius Datamanager 2.0 (from version 3.16.1 onwards)
    • Fronius Symo Hybrid (from version 1.16.1 onwards)
    Measuring input
    Nominal voltage (1-phase)
    Operating range
    230 V
    161 - 276 V
    Self-consumption - voltage path (max. voltage)
    ≤ 8 VA
    Nominal frequency
    Tolerance
    50 - 60 Hz
    45 - 65 Hz
    Nominal current, lb
    5 A
    Maximum current, Imax
    100 A
    Starting current
    40 mA
    Short-time overload
    (EN IEC 62053-21, EN IEC 62053-23)
    30 lmax / 0.001 s
    Self-consumption - current path (max. current)
    ≤ 1 W
    Power factor
    Operating range
    cosφ 0.5 ind - 0.8 cap,
    Current total harmonic distortion
    In acc. with EN 62053-21
    Data output
    RS485 communication
    Electrically isolated from measuring input
    Standard
    RS485 - 3 conductors
    Transmission
    Serial, asynchronous
    Protocol
    Compatible with Modbus RTU
    Addresses
    1 - 255
    Number of bits
    8
    Stop bit
    Parity bit
    None - odd - even
    Baud rate
    9600, 19,200 bit/s
    Response time
    ≤ 200 ms
    Insulation (EN IEC 62052-11, EN IEC 62053-21)
    Installation category
    III
    Pollution degree
    Insulation voltage
    4000 VAC RMS (1 min)
    Electromagnetic compatibility
    Emission test
    In acc. with EN IEC 62052-11, EN 50470-3
    Immunity test
    Operating conditions
    Reference temperature
    25 °C (±5 °C)
    Operating range
    -25 - 65 °C
    Temperature limit for storage and transport
    -30 - 80 °C
    Mechanical environment
    Electromechanical environment
    M2
    E2
    Housing
    Housing
    Sealable housing/terminal cover
    Connection
    Screw connection
    Mounting
    Can be snapped onto 35 mm DIN rail
    Housing material
    Noryl, self-extinguishing
    Degree of protection (EN 60529)
    IP51 housing, IP20 connections
    Weight
    160 grams
    Communication LED signals
    red, flashing
    Pulse light according to EN50470-3, EN62052-11, 1000 pulse/kWh (min. frequency 90 ms)
    orange, lights up permanently
    Negative total efficiency
    This check is only carried out if Configuration menu - structure and parameters measurement mode "B" is active. In this case, the device measures drawn and delivered energy.
    Terminals
    Measuring input
    Wire
    max. 25 mm²
    Recommended torque
    max. 2.8 Nm
    Data output
    Wire
    min 0.05 mm²
    Recommended torque
    max. 0.5 Nm
    1. Technical data
    Technical data
    Parity bit:none
    Software version:
    Measuring input
    Operating range
    230 V
    161 - 276 V
    ≤ 8 VA
    Nominal frequency
    Tolerance
    50 - 60 Hz
    45 - 65 Hz
    Nominal current, lb
    5 A
    100 A
    Starting current
    40 mA
    Short-time overload
    30 lmax / 0.001 s
    ≤ 1 W
    Power factor
    Operating range
    Data output
    RS485 communication
    Standard
    Transmission
    Protocol
    Addresses
    1 - 255
    Number of bits
    8
    Stop bit
    Parity bit
    None - odd - even
    Baud rate
    9600, 19,200 bit/s
    Response time
    ≤ 200 ms
    III
    Pollution degree
    Insulation voltage
    Emission test
    Immunity test
    25 °C (±5 °C)
    Operating range
    -25 - 65 °C
    -30 - 80 °C
    M2
    E2
    Housing
    Housing
    Connection
    Screw connection
    Mounting
    Housing material
    Weight
    160 grams
    red, flashing
    Terminals
    Measuring input
    Wire
    max. 25 mm²
    Recommended torque
    max. 2.8 Nm
    Data output
    Wire
    min 0.05 mm²
    Recommended torque
    max. 0.5 Nm
    1. Technical data
    Detailed, country-specific warranty conditions are available at www.fronius.com/solar/warranty.
    To obtain the full warranty period for your newly installed Fronius product, please register at www.solarweb.com.
