en
      Operating instructionsiWave 300i - 500i
    • General information
      • General
        • Explanation of safety instructions
        • Obligations of the Operating Company
        • Obligations of Personnel
        • Safety symbols
        • Data security
        • Copyright
      • Utilization in accordance with "intended purpose"
        • Intended use
        • Foreseeable misuse
      • Information about the device
        • Device concept
        • Power source = welding machine
        • Operating principle
        • Application areas
        • Conformities
        • Bluetooth trademarks
        • Options
        • OPT/i Safety Stop PL d option
      • Notes on the device
    • Operating controls, connections and mechanical components
      • Control Panel
        • General
        • Control panel
        • Input options
      • Display
        • Display
        • Switching to full screen
        • Next page - previous page
        • Animated graphics
        • Grayed-out welding parameters
      • Connections, Switches, and Mechanical Components
        • Connections and mechanical components
    • Before installation and initial operation
        • Safety
        • Information on system components
        • Grid connection
        • Generator-powered operation
      • Connecting the Mains Cable
        • General
        • Safety grid cable connection
        • Specified mains cable
        • Connecting the mains cable for nc welding machines
        • Connecting the mains cable for MV welding machines
      • Transport and setup regulations
        • Transporting individual devices
        • Transporting welding systems
        • Checking lifting equipment
        • Setup regulations
      • Locking and unlocking the welding machine using the NFC key
        • General
    • Dangers when welding
      • Danger from incorrect operation or misuse
        • Danger from incorrect operation and misuse
      • Danger from grid current and welding current
        • Danger due to electromagnetic emissions
      • Danger from flying sparks, arc radiation, and noise
        • Danger from arc radiation
        • Danger due to noise
        • Data on noise emission values
        • Danger from welding operation
      • Danger from toxic gases and vapors
      • Danger due to missing safety equipment and moving components
        • Danger due to rotating parts
        • Danger due to missing covers
      • Danger from shielding gas cylinders and shielding gas supply
      • Danger due to hot parts and slag
    • TIG
      • System components
        • System components
        • Notes on the cooling unit
      • Minimum equipment for TIG welding
        • Minimum equipment for TIG AC welding
        • Minimum equipment for TIG DC welding
      • TIG welding processes
        • TIG DynamicWire
        • Powersharing
      • TIG Welding Packages
      • Commissioning
        • Safety
        • General
        • Assembling the system components (overview)
        • Connecting the gas cylinder
        • Connecting the welding torch to the welding machine and cooling unit
        • Establishing a ground earth connection to the workpiece
        • Other activities
      • TIG Operating Modes
        • Safety
        • Symbols and explanations
        • 2-step mode
        • 4-step mode
        • Special 4-step mode:
          Version 1
          Version 2
          Version 3
          Version 4
          Version 5
          Version 6
        • Spot welding
      • TIG welding
        • Danger due to incorrect operation and electric current
        • TIG welding
        • Welding parameters for TIG welding
      • Igniting the arc
        • General
        • Igniting the arc using high frequency
          (HF ignition)
        • Contact ignition
        • Igniting the arc using high-frequency contact
          (Touch-HF)
        • Electrode overload
        • End of welding
      • TIG special functions
        • Ignition timeout function
        • TIG pulsing
        • Tacking function
        • CycleTIG
      • TIG process parameters
        • Process parameters for TIG pulse
        • Process parameters for TIG AC
        • General TIG process parameters
        • Process parameters for ignition and operating mode
        • Process parameters for CycleTIG
        • Wire speed setting
        • TIG gas settings
        • Welding parameters for MIG/MAG standard synergic welding, LSC welding, and CMT welding
        • Conducting an R/L alignment
        • Process parameters for TIG plasma
        • Process parameters for TIG hot-wire welding
    • Plasma
      • Minimum equipment for plasma welding
      • Plasma welding
        • Preparation
        • Plasma welding
        • Igniting the arc
        • Welding and process parameters for plasma welding
    • Manual Metal Arc Welding, CEL, Arc air gouging
      • Minimum equipment for MMA and CEL welding and for arc air gouging
        • Minimum equipment for arc air gouging
      • Commissioning
        • Preparation
        • Manual metal arc welding
        • Welding parameters for manual metal arc welding and CEL welding
      • Hot-Start, Soft-Start, Anti-Stick Functions
        • Starting current > 100 % (HotStart)
        • Starting current < 100 %
          (SoftStart)
        • Anti-stick function
      • Stick electrode / CEL Process parameters
        • Process parameters for stick electrode
        • Process parameters for CEL
      • Arc air gouging (iWave 500 DC and iWave 500 AC/DC)
        • Gouging (Arc Air Gouging)
        • Preparation
        • Arc air gouging
    • Multiprocess PRO - MIG/MAG
      • Multiprocess PRO
        • General
        • System components
      • Minimum equipment for MIG/MAG welding
      • MIG/MAG welding processes
        • MIG/MAG pulse synergic welding
        • MIG/MAG standard synergic welding
        • PMC process
        • LSC process
        • SynchroPulse welding
        • CMT process
        • CMT Cycle Step welding process
        • SlagHammer
        • Stitch welding
        • WireSense
        • ConstantWire
      • MIG/MAG Welding Packages
        • General
        • Welding Packages
      • MIG/MAG welding characteristics
        • Welding characteristics
      • Status bar for MIG/MAG welding
        • Status bar
        • Status bar - current limit reached
      • MIG/MAG Operating Modes
        • General
        • 2-step mode
        • 4-step mode
        • Special 2-step mode
        • Spot welding
      • Preparing for MIG/MAG welding
        • Danger from electrical current
        • Correct routing of the interconnecting hosepack
        • Context
        • Setting up MIG/MAG system components (overview)
      • MIG/MAG and CMT welding
        • Setting the welding process and operating mode via the status bar
        • Setting the welding process and operating mode via the menu bar
        • Selecting the filler metal and shielding gas
        • Setting the welding parameters
        • Adjusting the quantity of shielding gas
        • MIG/MAG or CMT welding
      • Spot welding and stitch welding
        • Spot welding
        • Stitch welding
      • MIG/MAG and CMT welding parameters
        • Welding parameters for MIG/MAG pulse synergic welding and PMC welding
        • Welding parameters for MIG/MAG standard manual welding
        • Explanation of footnotes
      • MIG/MAG process parameters
        • Process parameters for weld start / weld end
        • Process parameters for gas setup
        • Process parameters for process control
        • Penetration stabilizer
        • Arc length stabilizer
        • Combination of penetration stabilizer and arc length stabilizer
        • Process parameters for VELO
        • Process parameters for SynchroPulse
        • Process parameters for Process Mix
        • Process parameters for additive welding process control
        • Process parameters for TWIN process control
        • Process parameters for CMT Cycle Step
        • Process parameters for AC setup
        • Process parameters for ConstantWire
        • Process parameters for spot welding
        • Process parameters for interval
        • Process parameters for manual setup
        • R/L alignment
    • Job Mode
      • EasyJob mode
        • General
        • Activating EasyJob mode
        • Storing EasyJob operating points
        • Retrieving EasyJob operating points
        • Deleting EasyJob operating points
        • Loading more EasyJobs
      • Job Mode
        • General
        • Saving settings as a job
        • Welding job - retrieving jobs
        • Optimizing a job
        • Renaming a job
        • Deleting a job
        • Loading a job
        • Job Mode with WF 25i Dual
      • Job process parameters
        • JOB process parameters
        • Process parameters for Optimize Job
        • Setting correction limits for a job
        • Pre-settings for "Save as Job"
    • Powersharing
      • Powersharing
        • Minimum equipment for Powersharing operation
        • Prerequisites for Powersharing operation
        • Powersharing mode
      • Overview
        • Overview
      • Process parameters - Components & monitoring
        • Process parameters - Components & Monitoring
        • Process parameters for components
        • Draining/filling the torch hosepack
        • System adjustment
        • Arc break watchdog
        • Wire stick contact tip
        • Wire stick workpiece
        • Welding circuit coupling
        • Wire end monitoring
        • Gas monitoring
        • Motor force monitoring
        • Wire buffer monitoring
    • Defaults
      • Defaults
        • General
        • Overview
      • Defaults - View
        • Defaults screen
        • Selecting the language
        • Selecting units/standards
        • Setting the date and time
        • Retrieving system data
        • Displaying characteristics
        • Parameter view TIG
        • Parameter view TIG iJob
        • Parameter view MIG/MAG
        • JobMaster MIG/MAG view
        • RC Panel TIG Favorite Parameters
      • Defaults - System
        • Defaults - System
        • Retrieving device information
        • Restoring factory settings
        • Restoring the website password
        • Setup mode
        • Service Connect
        • Network settings
        • Setting network parameters manually
        • Setting up WLAN
        • Bluetooth setup
        • WeldCube Air
        • Client authorization
        • USB port
        • Welding machine configuration
        • Wirefeeder setup
        • Interface setup
        • TWIN Setup
        • Powersharing Setup
      • Defaults - Documentation
        • Setting the sample rate
        • Viewing the logbook
        • Switching limit value monitoring on/off
      • Defaults Administration
      • User management
        • General
        • Explanation of terms
        • Predefined roles and users
        • User administration overview
      • Create administrator and roles
        • Recommendation for creating roles and users
        • Creating an administrator key
        • Creating roles
        • Copying roles
      • Creating users
        • Creating users
        • Copying users
      • Editing roles/users, deactivating user management
        • Editing roles
        • Deleting roles
        • Editing users
        • Deleting users
        • Deactivating user management
        • Lost administrator NFC key?
      • CENTRUM - Central User Management
        • Activating the CENTRUM server
    • SmartManager – the welding machine website
        • General
        • Opening and logging into the SmartManager for the welding machine
        • Help functions if logging in does not work
        • Changing the password/logging out
        • Settings
        • Language selection
        • Status indicator
        • Fronius
      • Current system data
      • Documentation logbook
        • Logbook
        • Basic settings
      • Job data
        • Job data
        • Job overview
        • Editing a job
        • Importing a job
        • Exporting a job
        • Exporting job(s) as ...
      • Welding machine settings
        • Designation & location
        • Parameter display
        • Date & time
        • Network settings
      • Save and restore
        • General
        • Save and restore
        • Automatic backup
      • Signal visualisation
        • Signal visualization
      • User management
        • General
        • Users
        • User roles
        • Export & import
        • CENTRUM Server
      • Overview
        • Overview
        • Expanding all groups/collapsing all groups
        • Export component overview as ...
      • Update
        • Update
        • Finding the update file (performing an update)
        • Fronius WeldConnect
      • Function packages
        • Function packages
        • Welding Packages
        • Options
        • Loading a function package
      • Synergic lines overview
        • Overview of characteristics
        • Show filter
      • Screenshot
        • Screenshot
      • Interface
        • Interface
    • Troubleshooting and Maintenance
      • Troubleshooting
        • General
        • Danger from electric current and insufficient ground conductor connection
        • MIG/MAG welding – current limit
        • Troubleshooting the welding machine
      • Service, maintenance and disposal
        • General
        • Original spare and wear parts
        • Safety - maintenance
        • At every start-up
        • Every 2 months
        • Every 6 months
        • Updating the firmware
        • Safety inspection
        • Disposal
    • Appendix
      • Average consumption values during welding
        • Average shielding gas consumption during TIG welding
        • Average shielding gas consumption during MIG/MAG welding
        • Average wire electrode consumption during MIG/MAG welding
      • Technical data
        • Explanation of the term duty cycle
        • Special Voltage
        • Overview with critical raw materials, year of production of the device
        • Environmental conditions
        • iWave 300i DC
        • iWave 300i DC /nc
        • iWave 300i DC /MV/nc
        • iWave 400i DC
        • iWave 400i DC /nc
        • iWave 400i DC /MV/nc
        • iWave 500i DC
        • iWave 500i DC /nc
        • iWave 500i DC /MV/nc
        • iWave 300i AC/DC
        • iWave 300i AC/DC /nc
        • iWave 300i AC/DC /MV/nc
        • iWave 400i AC/DC
        • iWave 400i AC/DC /nc
        • iWave 400i
          AC/DC /MV/nc
        • iWave 500i AC/DC
        • iWave 500i AC/DC /nc
        • iWave 500i AC/DC /MV/nc
        • China Energy Label
        • Radio parameters
        • Catalog C
      • Hazardous Substances
    • 009-19022026
    iWave 300i - 500i
    download
    Control panel
    TIG commissioning
    TIG welding
    Manual metal arc welding process parameters
    Defaults
    Technical data
    Spare parts
    ContactLegal NoticeGeneral Terms & ConditionsData Privacy StatementCookie Policy
    General information
    link_horizontalLink copied
    General
    DANGER!
    Indicates an immediate danger.
    Could result in major injury or death.
    Avoid the described danger.
    WARNING!
    Indicates a dangerous situation.
    Could result in serious injury or death.
    Avoid the dangerous situation.
    CAUTION!
    Indicates a harmful situation.
    Could result in injury and damage to property.
    Avoid the harmful situation.
    NOTE!
    Indicates the possibility of damage to property and adverse effects on work results, as well as necessary additional information, tips and tricks, recommendations, etc.
    1. General information
    General
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. General
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. General
    The operating company must only allow persons to work with the device if they
    • Are familiar with the basic occupational safety and accident prevention regulations and are trained in handling the device
    • Have read and understood these Operating Instructions, especially the section "Safety Rules," and have confirmed this with their signature
    • Are trained according to the requirements for the work results
    The safety-conscious work of the personnel must be checked regularly.
    2. General
    All persons who are assigned to work with the device must do the following before beginning the work:
    • Follow the basic regulations for occupational safety and accident prevention
    • Read these Operating Instructions, especially the section "Safety Rules," and confirm that they have understood and will follow them by signing
    Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
    2. General
    Safety symbols
    Devices with the CE label meet the requirements of all valid EU Directives, such as:
    • Directive 2014/30/EU on electromagnetic compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • and others
    The full text of the EU Declaration of Conformity is available at
    https://www.fronius.com .
    Devices bearing the CSA label satisfy the requirements of the relevant standards for Canada and the USA.
    2. General
    Data security
    • saving and storing personal settings.
    2. General
    Copyright
    Intended use
    The welding machine is only intended for TIG welding, MIG/MAG welding and MMA welding. Any other use shall be deemed to be not in accordance with the intended use.
    Intended use also means
    • Following all the instructions in these operating instructions
    • Carrying out all the specified inspection and maintenance work
    2. Utilization in accordance with "intended purpose"
    Intended use
    Foreseeable misuse
    IMPORTANT! Any use that does not comply with the intended use shall be deemed misuse.
    Impermissible misuse includes the following:
    • Using the device to thaw pipes
    • Using the device to charge batteries/rechargeable batteries
    • Using the device to start motors
    • Operation or storage of the device outside the environmental conditions specified in the technical data
    • Operation or storage of the device outside the protection class specified in the technical data
    Device concept
    iWave 300i / 400i / 500i DC and iWave 300i / 400i / 500i AC/DC welding machines
    The iWave 300i / 400i / 500i DC and iWave 300i / 400i / 500i AC/DC welding machines are fully digitized, microprocessor-controlled inverter welding machiness.
    A modular design and easy ability to extend the system guarantee a high degree of flexibility. The devices can be adapted to any situation.
    2. Information about the device
    Device concept
    Depending on the existing device firmware, "power source" may still be shown on the display in some cases.
    Operating principle
    The central control and regulation unit of the welding machines is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
    During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Rule algorithms ensure that the desired target state is maintained.
    This results in:
    • A precise welding process
    • Exact reproducibility of all results
    • Excellent weld properties
    Application areas
    The devices are used in commercial and industrial applications for manual and automated TIG and MIG/MAG welding of unalloyed and low-alloyed steel, high-alloyed chrome/nickel steel, aluminum, aluminum alloys, and magnesium. The welding machines are designed for:
    • Automotive and supply industry,
    • Mechanical engineering and rail vehicle manufacturing,
    • Chemical plant construction,
    • Machine construction,
    • Shipyards,
    • etc.
    Conformities
    FCC
    This device conforms to the limit values for an EMC device class A digital device, pursuant to Part 15 of the FCC regulations. These limit values are designed to provide reasonable protection against harmful interference when operating in a commercial environment. This device generates and uses high-frequency energy and, if not installed and used in accordance with the Operating Instructions, may interfere with radio communications.
    Operation of this device in residential areas is likely to cause harmful interference, in which case the user is required to correct the interference at his own expense.
    FCC ID: QKWSPBMCU2
    Industry Canada RSS
    This device complies with Industry Canada license-exempt RSS standards. Operation is subject to the following conditions:
    (1)
    The device must not cause any harmful interference.
    (2)
    The device must not be affected by external sources of interference, including interference that may impair operation.
    IC: 12270A-SPBMCU2
    EU
    Compliance with Directive 2014/53/EU - Radio Equipment Directive (RED)
    The antennas used for this transmitter must be installed in such a way that a minimum distance of 20 cm from all persons is maintained. They must not be installed or operated in conjunction with another antenna or transmitter. OEM integrators and end users must ensure the operating conditions of the transmitter comply with radio frequency exposure guidelines.
    ANATEL / Brazil
    This device is operated on a secondary basis. It does not claim to offer protection against harmful interference, even from devices of the same type.
    This device can not cause interference in primarily operated systems.
    This device complies with ANATEL's specific absorption rate limit values for exposure to high-frequency electrical, magnetic, and electromagnetic fields.
    IFETEL / Mexico
    Operation of this device is subject to the following two conditions:
    (1)
    The device must not cause any harmful interference;
    (2)
    The device must accept any interference, including interference that may cause undesired operation.
    NCC / Taiwan
    According to the NCC regulations for low-power equipment that generates radio frequency radiation:
    Article 12
    Certified low-power equipment that generates radio frequency radiation shall not change frequency, increase power or alter the characteristics and functions of the original design without approval.
    Article 14
    The use of low-power equipment that generates radio frequency radiation shall not adversely affect flight safety and legally operated communication equipment.
    An identified malfunction must be deactivated and corrected immediately. All malfunctions must be eliminated.
    The legal notice in the preceding paragraph refers to radio communications equipment operated in accordance with the provisions of the Telecommunications Act. Low-power equipment that generates radio frequency radiation must be able to withstand interference from legally operated communication channels or radiological, radiation electrical devices used in industrial, scientific and medical applications.
    Thailand
    The word mark Bluetooth® and the Bluetooth® logos are registered trademarks and property of Bluetooth SIG, Inc. and are used by the manufacturer under license. Other trademarks and trade names are the property of their respective owners.
    Options
    OPT/i TIG gas regulator
    OPT/i TIG 4 Switch SpeedNet
    Option if more than one additional SpeedNet connection is required.
    OPT/i TIG Gas flow rate sensor
    OPT/i TIG External sensor
    OPT/i TIG PowerConnector
    2nd current socket on the rear of the welding machine
    OPT/i TIG Gas changeover
    OPT/i TIG 2nd SpeedNet
    Second SpeedNet connection
    OPT/i TIG DC Multiprocess PRO
    OPT/i TIG AC Multiprocess PRO
    OPT/i TIG 2nd NT242
    When using a CU 1400 cooling unit, the OPT/i TIG 2nd NT242 option must be installed in the welding machines.
    OPT/i TIG NT601
    OPT/i TPS dust filter
    IMPORTANT! The use of the OPT/i TPS dust filter option on iWave welding machines will reduce the duty cycle!
    OPT/i CycleTIG
    Advanced TIG stitch welding
    OPT/i Synergic Lines *
    Option to enable all available special characteristics of welding machines;
    any special characteristics created in the future are thus automatically enabled.
    OPT/i GUN Trigger *
    Option for special functions in connection with the torch trigger
    OPT/i Jobs
    Option for Job Mode
    OPT/i Documentation
    Option for the documentation function
    OPT/i Puls Pro
    OPT/i Interface Designer Upload *
    Option for individual interface configuration
    OPT/i WebJobEdit
    Option to edit jobs using the SmartManager of the welding machine
    OPT/i Limit Monitoring
    Option to set limit values for welding current, welding voltage, and wire speed
    OPT/i Custom NFC - ISO 14443A
    Option to use a custom frequency band for key cards
    OPT/i CMT Cycle Step *
    Option for adjustable, cyclic CMT welding process
    OPT/i OPC-UA
    Standardized data interface protocol
    OPT/i MQTT
    OPT/i SpeedNet Repeater
    Signal amplifier if interconnecting hosepacks or connections from welding machine to wirefeeder exceed 50 m
    KRIS 13 Gouging MachineElectrode holder with compressed air connection for arc air gouging
    OPT/i Wire Sense *
    Seam tracking / edge detection using wire electrode for automated applications
    only in conjunction with CMT hardware
    OPT/i Synchropulse 10 Hz *To increase the SynchroPulse frequency from 3 Hz to 10 Hz
    OPT/i WeldCube Navigator
    Software for creating digital instructions for manual welding processes, which are processed by welders.
    The welder is guided through the welding instructions by WeldCube Navigator.
    OPT/i Touch Sense Adv. *
    This option provides access to the following functions:
    • Gas nozzle position search regardless of any faults or dirt
    • Detects whether the wire electrode or gas nozzle touched the component during the position search
    • Short-circuit monitoring between gas nozzle and contact tip
    • Automatic monitoring to detect whether the gas nozzle is touching the component or whether a short circuit between the gas nozzle and the contact tip occurs in welding mode/ during wire threading/ in teach mode / with WireSense
    OPT/i SenseLead *
    Additional hardware option for improved voltage measurement when welding multiple arcs on one component.
    OPT/i CU Interface *
    Interface for the CU 4700 and CU 1800 cooling units
    OPT/i Velo *
    Enables welding with the Velo system
    MIG/MAG options – only in conjunction with the options OPT/i TIG DC Multiprocess PRO or OPT/i TIG AC Multiprocess PRO
    IMPORTANT! The OPT/i Safety Stop PL d safety function was developed as Category 3 according to EN ISO 13849-1:2008 + AC:2009.
    A two-channel feed-in of the input signal is required for this.
    Bridging the two-channel capability (e.g., by means of a short-circuit bracket) is not permitted and results in the loss of the PL d.
    Function overview
    The OPT/i Safety Stop PL d option ensures a safety stop of the PL d welding machine with a controlled end of welding in less than a second.
    Each time the welding machine is switched on, the Safety Stop PL d safety function performs a self-test.
    IMPORTANT! This self-test must be performed at least once a year to check the function of the safety cut-out.
    If the voltage drops at least one of two inputs, the Safety Stop PL d stops the current welding operation; the wirefeeder motor and the welding voltage is switched off.
    The welding machine outputs an error code. Communication via the robot interface or bus system continues.
    In order to restart the welding system, the voltage must be applied again. An error must be acknowledged via the torch trigger, display or interface and the start of welding must be executed again.
    A non-simultaneous shutdown of the two inputs (> 750 ms) is output by the system as a critical, non-acknowledgeable error.
    The welding machine remains permanently switched off.
    A reset is performed by switching the welding machine off/on.
    Notes on the device
    Warning notices and safety symbols can be found on welding machines with the CSA test mark for use in the North American region (USA and Canada). These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and property damage.
    Safety symbols on the rating plate:
    Welding is dangerous. The following basic requirements must be met:
    • Adequate welding qualifications
    • Appropriate protective equipment
    • Exclusion of unauthorized persons
    • These operating instructions
    • All system component operating instructions, especially the safety rules
    2. Notes on the device
    Control Panel
    General
    NOTE!
    Because of firmware updates, certain functions may be available for your device but not described in these Operating Instructions or vice versa.
    In addition, individual figures may also differ slightly from the operating elements of your device. These operating elements function in exactly the same way, however.
    WARNING!
    Operating the device incorrectly can cause serious injury and damage to property.
    Do not use the functions described here until you have fully read and understood the Operating Instructions.
    Do not use the functions described here until you have fully read and understood all of the Operating Instructions for the system components, especially the safety rules.
    1. Operating controls, connections and mechanical components
    Control Panel
    General
    NOTE!
    WARNING!
    2. Control Panel
    General
    NOTE!
    WARNING!
    2. Control Panel
    Control panel
    43,0001,3547
    No.Function
    (1)
    USB port
    For connecting USB thumb drives (service dongle, license key, etc.).
    IMPORTANT! The USB port is not electrically isolated from the welding circuit. Devices that make an electrical connection to another device must therefore not be connected to the USB port!
    (2)
    Dial with rotary/push button function
    For selecting elements, setting values, and scrolling through lists
    (3)
    Display (with touch function)
    • For direct operation of the welding machine by touching the display
    • For displaying values
    • For navigating through the menu
    (4)
    Reading zone for NFC keys
    • For locking/unlocking the welding machine using NFC keys
    • For logging in different users (with active user management and assigned NFC keys)
    NFC key = NFC card or NFC key fob
    (5)
    Wire-threading button
    For threading the wire electrode / welding wire into the torch hosepack without gas or current
    (6)
    Gas-test button
    To set the required quantity of gas on the gas pressure regulator.
    After pressing the gas-test button, gas flows for 30 s. Pressing the button again ends the process early.
    2. Control Panel
    Input options
    Touching the display
    When you touch and thus select an element on the display, the element is highlighted.
    Turning the dial
    • Select items on the display
    • Change values
    For some parameters, a value that has been changed by turning the dial is automatically applied without having to press the dial.
    Pressing the dial
    • Apply selected elements, e.g., to change the value of a welding parameter.
    • Apply values of specific parameters.
    Pressing the buttons
    By pressing the wire threading key, the wire electrode or the welding wire is threaded into the torch hosepack without gas or current.
    An animated graphic with motor current, motor power, and wire length conveyed is shown on the display.
    Pressing the gas-test button releases gas for 30 s. Pressing it again ends the process prematurely.
    The display shows an animated graphic with the remaining gas flow duration.
    Display
    Display
    iWave welding machine display
    No.Function
    (1)
    Status bar
    Contains information about:
    • Currently set welding process
    • Currently set operating mode
    • Currently set polarity
    • Currently selected ignition procedure
    • Cap mode
    • Pulse mode
    • Electrode overcharge
    • Bluetooth status indicator
    • Powersharing mode
    • Currently logged in user (when user management is activated)
      or
      the key symbol when the welding machine is switched off (e.g., if profile/role "locked" is activated)
    • Time and date
    The content of the status bar varies according to the selected welding process.
    NOTE!
    The following functions can be selected and set directly in the status bar:
    Welding process
    Operating mode
    Touch the desired function in the status bar and set it in the window that opens.
    Select the welding process via the status bar, select the operating mode via the status bar
    (2)
    Left menu bar
    The left menu bar contains the menus:
    • Welding
    • Welding process
    • Defaults
    The left menu bar is operated by touching the display.
    (3)
    Indicator bar
    Overview of the currently available welding parameters;
    the individual welding parameters can be selected directly by touching the display. The currently selected parameter is highlighted in blue.
    Welding current curve symbol
    Balance symbol
    Balance (1)
    Electrode diameter symbol(s)
    Electrode diameter
    Cap mode symbol
    Cap mode (1)
    Polarity symbol
    Polarity (1)
    (1) only with iWave AC/DC welding machines
    (2) only with iWave AC/DC welding machines and if polarity is set to AC.
    (4)
    Main area
    The main area displays welding parameters, EasyJobs, graphics, lists or navigation elements. The main area is divided up differently depending on the application and populated with elements.
    The main area is operated
    • via the dial
    • by touching the display
    (5)
    Right menu bar
    The right menu bar can be used as follows, depending on the menu selected in the left menu bar:
    • as a function bar, consisting of application and function buttons
    • to navigate to the 2nd menu level
    The right menu bar is operated by touching the display.
    2. Display
    Display
    No.Function
    (1)
    Status bar
    • Cap mode
    • Pulse mode
    • Powersharing mode
      or
    • Time and date
    NOTE!
    Welding process
    Operating mode
    (2)
    Left menu bar
    • Welding
    • Welding process
    • Defaults
    (3)
    Indicator bar
    Balance symbol
    Balance (1)
    Electrode diameter
    Cap mode symbol
    Cap mode (1)
    Polarity symbol
    Polarity (1)
    (4)
    Main area
    • via the dial
    (5)
    Right menu bar
    2. Display
    The display is shown in full screen mode:
    2Exit full screen mode:
    NOTE!
    Hiding the EasyJobs realizes the optimal full-screen display:
    Defaults / View / EasyJobs / EasyJobs Off
    With a few defaults and the setting options via the status bar, the welding machine can be fully operated in manual applications in full-screen mode.
    2. Display
    NOTE!
    Depending on the device type, equipment, and available WeldingPackages, the number and sequence of the displayed parameters may vary.
    If there are more than six parameters in a menu, the parameters are divided into several pages.
    Navigation between several pages is done using the "Next page" and "Previous page" buttons:
    Example: Process parameters / Common - Next page
    Example: Process parameters / Common - Previous page
    2. Display
    Animated graphics
    For certain parameters, animated graphics are shown on the display.
    These animated graphics change when the value of the parameter is changed.
    Example: Welding parameters for pulse correction -10 / 0 / +10
    Example: Process parameters / Process control / Penetration stabilizer 0 / 0.1 / 10.0
    2. Display
    NOTE!
    In the menus, certain parameters are grayed out because they have no function with the currently selected settings.
    Grayed-out welding parameters can be selected and changed, but have no influence on the current welding process or the welding result.
    (a)
    Grayed-out parameter (e.g. penetration stabilizer)
    (b)
    Grayed-out parameter selected
    (c)
    Value of the grayed-out parameter is changed
    (d)
    Grayed-out parameter with changed value - no effect with current settings
    Front/back
    No.Function
    (1)
    TIG Multi Connector connection
    • For connecting the control plug of the TIG welding torch
    • For connecting foot-operated remote controls
    • For connecting remote controls
    (2)
    (-) current socket with integrated gas connection
    For connecting the TIG welding torch
    Symbols:
    (3)
    TIG Multi Connector 4-pin connection (option)
    For connecting a CrashBox line
    (4)
    Control panel with display and control panel cover
    For operating the welding machine
    (5)
    (-) current socket with bayonet latch
    HF-free current socket for manual metal arc welding
    Symbols:
    (6)
    Plasma connection (option)
    For connecting the plasma plug from the plasma welding torch hosepack
    (7)
    (+) current socket
    For connecting the TIG return lead cable
    Symbols:
    (8)
    SpeedNet connection
    For connecting
    • remote controls and external sensors
    • wirefeeders (for automated applications)
    Symbol:
    (9)
    Mains cable with strain relief
    Depending on version
    (10)
    Power switch
    For switching the welding machine on and off
    (11)
    Dummy cover/Robot interface RI FB Inside /i or SpeedNet connections or External sensor options
    (12)
    Ethernet connection
    (13)
    Dummy cover/second (-) current socket with bayonet latch (option)
    MIG/MAG ground to wirefeeder
    (14)
    TIG shielding gas connection socket
    Main gas solenoid valve
    (15)
    Dummy cover/auxiliary gas connection
    Additional gas solenoid valve
    (16)
    Dummy cover/second SpeedNet connection (option) or external sensor (option)
    (17)
    iWave 300i - 500i AC/DC
    (18)
    AC inverter
    (only with iWave AC/DC welding machines)
    2. Connections, Switches, and Mechanical Components
    Front/back
    No.Function
    (1)
    (2)
    Symbols:
    (3)
    (4)
    (5)
    Symbols:
    (6)
    (7)
    (+) current socket
    Symbols:
    (8)
    SpeedNet connection
    For connecting
    Symbol:
    (9)
    (10)
    Power switch
    (11)
    (12)
    Ethernet connection
    (13)
    (14)
    (15)
    (16)
    (17)
    (18)
    AC inverter
    Safety
    WARNING!
    Danger due to incorrect operation and work not carried out correctly.
    This may result in serious personal injury and damage to property.
    All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
    Read and understand all safety rules and user documentation for this equipment and all system components.
    1. Before installation and initial operation
    Safety
    WARNING!
    2. Before installation and initial operation
    Safety
    WARNING!
    The steps and activities described below include references to various system components, including:
    • Trolleys
    • Cooling units
    • Wire-feed unit holders
    • Wire-feed units
    • Interconnecting hosepacks
    • Welding torches
    • etc.
    For more detailed information about installing and connecting the system components, please refer to the appropriate operating instructions.
    Grid connection
    WARNING!
    Danger of electric shock due to poor grid connection.
    Only connect the device to a grid with a ground conductor.
    Only connect the device to the grid via a plug-in system with a ground conductor contact.
    If operating the device on a grid without a ground conductor and in a socket without a ground conductor contact, observe all national regulations for protection by electrical separation.
    CAUTION!
    An inadequately dimensioned electrical installation can cause serious property damage.
    The grid lead and its fuse protection should be designed to suit the existing power supply.
    The technical data on the rating plate must be observed.
    NOTE!
    Devices with a high output can influence the energy quality of the grid due to their current consumption.
    Before connecting the device to the grid, check with the grid operator whether or not the device is allowed to be connected.
    The maximum permissible grid impedance for a grid connection can be found in the technical data.
    • The devices are designed for the grid voltage stated on the rating plate.
    • Devices with a rated welding voltage of 3 x 575 V may only be operated on three-phase systems with ground neutral.
    • If the grid cable or grid plug has not been attached to your version of the appliance, these must be installed by qualified personnel according to national standards.
    • The fuse protection of the grid lead is specified in the technical data.
    IMPORTANT! Ensure secure grounding of the grid connection.
    Due to local regulations and national guidelines, a residual-current circuit breaker may be required when connecting a device to the public grid. The residual-current circuit breaker recommended for the device can be found in the technical data.
    The welding machine is generator-compatible.
    The maximum apparent power S1max of the welding machine must be known in order to select the correct generator output.
    The maximum apparent power S1max of the welding machine is calculated for 3-phase devices as follows:
    S1max = I1max x U1 x √3
    I1max and U1 according to the device rating plate and technical data
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator can be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the welding machine!
    NOTE!
    The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
    The mains voltage tolerance is specified in the "Technical data" section.
    General
    If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before start-up.
    A universal strain-relief device for cable diameters of 12-30 mm (0.47-1.18 in.) is mounted on the welding machine.
    Strain-relief devices for other cable cross-sections must be designed accordingly.
    2. Connecting the Mains Cable
    General
    WARNING!
    Danger from work that is not carried out properly.
    The work described below may only be performed by trained specialist personnel.
    Follow national standards and guidelines.
    CAUTION!
    Danger from improperly prepared grid cable.
    Short circuits and damage to property may result.
    Fit ferrules to all phase conductors and the ground conductor of the stripped grid cable.
    Europe:
    Welding machine
    Mains voltage
    Mains cable
    iWave 300i /nc DC
    3 x 400 V
    3 x 460 V
    H07RN-F 4G4
    H07RN-F 4G4
    iWave 300i /MV/nc DC
    3 x 200 - 230 V
    3 x 400 - 575 V
    H07RN-F 4G6
    H07RN-F 4G4
    iWave 300i /nc AC/DC
    3 x 400 V
    3 x 460 V
    H07RN-F 4G4
    H07RN-F 4G4
    iWave 300i /MV/nc AC/DC
    3 x 200 - 230 V
    3 x 400 - 575 V
    H07RN-F 4G6
    H07RN-F 4G4
    iWave 400i /nc DC
    3 x 400 V
    3 x 460 V
    H07RN-F 4G4
    H07RN-F 4G4
    iWave 400i /MV/nc DC
    3 x 200 - 230 V
    3 x 400 - 575 V
    H07RN-F 4G10
    H07RN-F 4G4
    iWave 400i /nc AC/DC
    3 x 400 V
    3 x 460 V
    H07RN-F 4G4
    H07RN-F 4G4
    iWave 400i /MV/nc AC/DC
    3 x 200 - 230 V
    3 x 400 - 575 V
    H07RN-F 4G10
    H07RN-F 4G4
    iWave 500i /nc DC
    3 x 400 V
    3 x 460 V
    H07RN-F 4G4
    H07RN-F 4G4
    iWave 500i /MV/nc DC
    3 x 200 - 230 V
    3 x 400 - 575 V
    H07RN-F 4G10
    H07RN-F 4G4
    iWave 500i /nc AC/DC
    3 x 400 V
    3 x 460 V
    H07RN-F 4G4
    H07RN-F 4G4
    iWave 500i /MV/nc AC/DC
    3 x 200 - 230 V
    3 x 400 - 575 V
    H07RN-F 4G10
    H07RN-F 4G4
    USA & Canada:
    Welding machine
    Mains voltage
    Mains cable
    iWave 300i /nc DC
    3 x 400 V
    3 x 460 V
    4 x AWG 10
    4 x AWG 10
    3 x 200 - 230 V
    3 x 400 - 575 V
    4 x AWG 8
    4 x AWG 10
    3 x 400 V
    3 x 460 V
    4 x AWG 10
    4 x AWG 10
    3 x 200 - 230 V
    3 x 400 - 575 V
    4 x AWG 8
    4 x AWG 10
    iWave 400i /nc DC
    3 x 400 V
    3 x 460 V
    4 x AWG 10
    4 x AWG 10
    3 x 200 - 230 V
    3 x 400 - 575 V
    4 x AWG 6
    4 x AWG 10
    3 x 400 V
    3 x 460 V
    4 x AWG 10
    4 x AWG 10
    3 x 200 - 230 V
    3 x 400 - 575 V
    4 x AWG 6
    4 x AWG 10
    iWave 500i /nc DC
    3 x 400 V
    3 x 460 V
    4 x AWG 8
    4 x AWG 8
    3 x 200 - 230 V
    3 x 400 - 575 V
    4 x AWG 4
    4 x AWG 8
    3 x 400 V
    3 x 460 V
    4 x AWG 8
    4 x AWG 8
    3 x 200 - 230 V
    3 x 400 - 575 V
    4 x AWG 4
    4 x AWG 8
    GND - L1 - L2 - L3; 4x TX20, 1.5 Nm / 1.11 lb-ft
    5
    6
    Cut the strain-relief device to length according to the outer diameter of the mains cable
    IMPORTANT! When inserting the mains cable, ensure that the cable sheath protrudes approx. 5 - 10 mm beyond the strain-relief device into the device.
    5
    Only loosen the 4 TX20 screws, do not remove them
    6
    Push the mains cable toward the open side in order to access the strain-relief device clamping screw.
    7
    8
    9
    10
    WARNING!
    Serious personal injuries may result.
    Do not lift or transport any active devices.
    Switch off and disconnect devices from the grid before transport or lifting.
    Close ground earth connections before transport.
    WARNING!
    Danger from falling objects.
    Serious personal injury and damage to property may result.
    Only use suitable transportation equipment from the manufacturer to transport devices by crane.
    Attach chains or ropes to all designated attachment points on the transportation equipment.
    The chains or ropes must form the smallest angle possible from vertical.
    Observe and comply with valid national and regional guidelines for accident prevention and hazards during transport and shipment.
    CAUTION!
    Danger from damaged devices.
    This can result in personal injury and damage to property.
    After transport and before commissioning, visually inspect the device for damage.
    Have any damage repaired by trained service technicians before commissioning the device.
    NOTE!
    The carrying handle on the device is only to be used for transport by hand.
    The carrying handle is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
    2. Transport and setup regulations
    WARNING!
    WARNING!
    CAUTION!
    NOTE!
    Example of a welding system with the following components:
    • Trolley
    • Cooling unit
    • Welding machine
    • Wirefeeder mount
    • Wirefeeder
    • Gas cylinder holder
    • Shielding gas cylinder
    • Welding torch
    WARNING!
    Danger from devices or components falling.
    Before transporting the welding system, detach the wirefeeder and the shielding gas cylinder, and completely drain the coolant.
    Ensure that the remaining system components are securely seated on the trolley.
    Only use suitable transportation equipment from the manufacturer to transport welding systems by crane.
    WARNING!
    Danger from devices and components falling as a result of damaged lifting equipment.
    Regularly check all lifting equipment used for crane transport such as straps, buckles, chains, etc., for mechanical damage, corrosion, and changes due to other environmental influences.
    The inspection interval and scope of the inspection must comply with the relevant valid national standards and guidelines.
    Setup regulations
    WARNING!
    Danger from devices or welding systems toppling over.
    Set up the device securely on an even, solid surface.
    The maximum permitted tilt angle is 10°.
    Check all screw connections are tightly fastened after installation.
    WARNING!
    Danger from areas at risk of fire and explosion as well as from areas with increased electrical hazard.
    Follow national and international regulations for areas at risk of fire and explosion.
    Follow national and international regulations for areas with increased electrical hazard.
    CAUTION!
    Danger due to selecting an unsuitable installation location.
    Only set up and operate the device in accordance with the protection class shown on the rating plate.
    The ambient air must be free of dust, acids, corrosive gases or substances, and other similar substances.
    Do not set up and operate the device over 2000 m (6561 ft. 8.16 in.) above sea level.
    The device has been tested according to protection class IP23. This means:
    • Protection against solid foreign bodies larger than Ø 12.5 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° from the vertical
    The device can be set up and operated outdoors in accordance with protection class IP23. Direct moisture (e.g., from rain) must be avoided.
    General
    The welding machine can be locked by means of an NFC key, e.g., to prevent unauthorized access or the modification of welding parameters.
    Locking and unlocking is a contactless operation on the welding machine control panel.
    To lock and unlock the welding machine, the welding machine must be turned on.
    2. Locking and unlocking the welding machine using the NFC key
    General
    Locking the welding machine
    1Hold the NFC key over the reading zone for NFC keys
    The key symbol appears briefly on the display.
    The key symbol is then displayed in the status bar.
    The welding machine is now locked.
    Only the welding parameters can be viewed and set using the dial.
    If the operator attempts to access a locked function, a corresponding message is displayed.
    Unlocking the welding machine
    The crossed-out key symbol appears briefly on the display.
    The key symbol is no longer displayed in the status bar.
    All welding machine functions are available again without restriction.
    NOTE!
    Further information on locking the welding machine can be found in under "Defaults - Administration" starting on page (→).
    WARNING!
    Danger from incorrect operation or misuse.
    This can result in serious personal injury - including injury to third parties, damage to property, and impaired welding results.
    All persons involved in the commissioning, operation, maintenance, and servicing of the device must be appropriately qualified and have knowledge of welding.
    Observe generally applicable and regional regulations regarding accident prevention and environmental protection.
    1. Dangers when welding
    WARNING!
    2. Danger from incorrect operation or misuse
    WARNING!
    WARNING!
    Danger of electric shock.
    Do not touch live parts inside or outside the device.
    During MIG/MAG welding, the welding wire, the wirespool, the feed rollers, as well as any pieces of metal in contact with the welding wire, are live.
    Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder mount.
    Use a dry backing bar or cover with sufficient insulation against the ground potential.
    The backing bar or cover must completely cover the entire area between the body and the ground potential.
    Only use undamaged, insulated, and adequately dimensioned cables and leads.
    Do not wrap cables or leads around your body or parts of the body.
    Never touch the welding wire, tungsten electrode, or the stick electrode when the welding machine is switched on.
    Ground the workpiece.
    Switch off unused devices.
    Before working on the device, switch it off, remove the grid plug, and attach a clearly legible and understandable warning sign to prevent the grid plug from being connected and the device switched on again.
    After opening the device, ensure that all components are disconnected from the power supply – especially all electrically charged components.
    WARNING!
    Danger due to electromagnetic fields.
    These can damage your health and the health of persons in the vicinity, e.g., anyone fitted with a pacemaker or wearing a hearing aid.
    Keep distances between welding power-leads and the head/torso of the welder as great as possible.
    Do not carry welding power-leads and hosepacks over your shoulder or wrap them around your body or body parts.
    Anyone wearing a pacemaker must seek advice from their doctor before spending any time in the immediate vicinity of the device and the welding process.
    CAUTION!
    Danger due to stray welding currents.
    Overheating of components, fire, destruction of ground conductors, and damage to the device and other electrical equipment may result.
    Ensure that the workpiece clamp is securely connected to the workpiece.
    Secure the workpiece clamp as close to the spot to be welded as possible.
    Position the device so that it is sufficiently insulated against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
    Ensure that the unused welding torch / electrode holder is adequately insulated when using power distribution boards, twin-head mounts, etc.
    In automated MIG/MAG applications, the wire electrode must be insulated when feeding it from the welding wire drum, large spool, or wirespool to the wirefeeder.
    2. Danger from grid current and welding current
    WARNING!
    WARNING!
    CAUTION!
    Electromagnetic compatibility (EMC) describes the unwanted mutual influence of electrical/electronic devices.
    The EMC device classification is shown on the rating plate of the device or in the technical data.
    Despite compliance with the standardized emission limit values, electrical devices can, in certain cases, influence each other in the intended application area.
    Interference-prone equipment that could be affected by the device includes:
    • Safety devices
    • Grid leads, signal lines, and data transfer lines
    • IT and telecommunications equipment
    • Measuring and calibrating devices
    • Medical devices
    • etc.
    CAUTION!
    Danger due to electromagnetic emissions.
    Operational disruptions and malfunctions as well as resulting damage may result.
    Use suitable grid filters.
    Keep welding power-leads as short as possible, route them close together and far from other lines.
    Perform equipotential bonding.
    Ground the workpiece, e.g., using suitable capacitors.
    Shield the entire welding system.
    Shield other devices in the vicinity.
    WARNING!
    Danger from flying sparks.
    Could result in fires and explosions.
    Never undertake welding near flammable materials.
    Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected using a certified cover.
    Keep suitable, certified fire extinguishers on hand.
    Take appropriate measures to ensure that sparks and hot metal particles do not get into surrounding areas through small cracks and openings.
    Only undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes, if these have been prepared in accordance with corresponding national and international standards.
    Do not undertake welding on containers in which gases, fuels, mineral oils, etc. are/were stored.
    Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
    WARNING!
    Danger from flying sparks and flying hot metal particles.
    Could result in injury.
    Wear suitable protective clothing when working with the device.
    The protective clothing must be flame retardant, insulating, dry, and undamaged, must cover the whole body, and the pants must be cuffless.
    Wear rigid, wet-insulating footwear.
    Wear appropriate, electrically insulating, and heat protective gloves.
    Wear a safety helmet.
    2. Danger from flying sparks, arc radiation, and noise
    WARNING!
    WARNING!
    WARNING!
    Danger from arc radiation, UV radiation, heat, and flying sparks that pose a risk of injury to the eyes and skin
    Use a face guard with a regulation-compliant filter insert.
    Wear regulation-compliant protective goggles with side protection behind the face guard.
    Danger due to noise
    CAUTION!
    Danger due to increased noise exposure.
    Could result in hearing damage.
    Use hearing protection during welding.
    The device produces a maximum noise level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation in relation to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
    A workplace-specific emission value for welding (and cutting) cannot be specified because this value depends on the welding process and the environmental conditions. It is influenced by a wide range of parameters, such as the welding process itself (MIG/MAG, TIG welding), the selected current type (direct current, alternating current), the power range, the type of weld metal, the resonance properties of the workpiece, the workplace environment, and many other factors.
    WARNING!
    Danger from welding operation (blinding hazard, flying sparks, harmful welding fume, noise, etc.)
    Personal injury may result.
    Keep unauthorized people away during the operation of the devices and during the welding process.
    Inform people in the vicinity about all the dangers of the welding operation.
    Provide suitable protective equipment.
    Construct suitable protective walls and curtains.
    WARNING!
    Danger from toxic gases and vapors.
    Fumes produced during welding contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
    If possible, use a welding torch with an integrated extraction device.
    Keep your face out of the welding fume and gases produced.
    Do not breathe in fume or harmful gases.
    Ensure that there is a sufficient supply of fresh air.
    A ventilation flow rate of at least 20 m³/h (11.77 cfm) must be provided at all times.
    Use a welding helmet with air supply if there is insufficient ventilation.
    2. Danger from toxic gases and vapors
    WARNING!
    WARNING!
    Danger due to missing, defective or circumvented safety equipment.
    This can result in serious personal injury - including injury to third parties, damage to property, and undesired welding results.
    Only operate the device when all safety equipment is fully functional.
    Any safety equipment that is not fully functional must be repaired by an authorized specialist before the device is switched on.
    Never bypass or disable safety equipment.
    Before switching on the device, ensure that no one can be put in danger.
    2. Danger due to missing safety equipment and moving components
    WARNING!
    CAUTION!
    Danger due to rotating parts such as fans, gears, rollers, shafts or wirespools.
    Keep hands, hair, loose clothing, and tools away from moving parts.
    Do not reach into rotating gears of the wire drive or into rotating drive parts.
    CAUTION!
    Danger due to missing or opened covers.
    Before operation, ensure that all covers and side panels are present and have been correctly fitted.
    Ensure that all covers and side panels are closed during operation.
    Only open covers and side panels for the duration of assembly and maintenance activities.
    WARNING!
    Danger from pressurized shielding gas cylinders.
    Serious personal injury and damage to property can result from explosions.
    Protect pressurized shielding gas cylinders from high heat, mechanical impact, slag, open flames, sparks, and arcs.
    Do not weld pressurized shielding gas cylinders.
    Keep shielding gas cylinders away from welding or other circuits.
    Do not hang the welding torch on a shielding gas cylinder.
    Leave the protective cap on the valve of the shielding gas cylinder when the cylinder is not connected.
    Mount shielding gas cylinders vertically and secure them from falling in accordance with the instructions.
    Observe and follow the manufacturer's instructions and national and international provisions for shielding gas cylinders and accessories.
    Remove the shielding gas cylinder before transporting a welding system with trolley by crane.
    Observe the safety and maintenance information on the shielding gas cylinder or a central gas supply.
    WARNING!
    Danger from shielding gas escaping without notice.
    Shielding gas is colorless and odorless and, in the event of leaks, may replace the oxygen in the ambient air.
    Could result in serious injury or death due to suffocation.
    There must be a ventilation flow rate of at least 20 m³ per hour.
    Close the valve of the shielding gas cylinder or a central gas supply when no welding is taking place.
    Turn your face away from the outlet when a valve on a shielding gas cylinder is being opened.
    Check the shielding gas cylinder or central gas supply for uncontrolled gas leakage before each start-up.
    If an adapter is being used, use suitable Teflon tape to seal the thread of the shielding gas connection on the device side before installation.
    CAUTION!
    Danger due to contaminated shielding gas.
    This can result in damage to property and undesired weld results.
    The quality of the shielding gas must meet the following specifications:
    Solid particle size < 40 μm
    Pressure condensation point < -20 °C
    Max. oil content < 25mg/m³
    2. Danger from shielding gas cylinders and shielding gas supply
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    Danger due to hot components, parts, and liquids.
    Could result in burns and injury.
    Do not touch the workpiece during and after welding.
    Allow hot components, hot parts, and hot liquids to cool before touching (e.g., the welding torch).
    If a cooling unit is being used, switch it off before disconnecting coolant hoses.
    CAUTION!
    Danger due to slag flying off cooling workpieces.
    Also wear protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
    2. Danger due to hot parts and slag
    CAUTION!
    CAUTION!
    TIG
    System components
    System components
    (1)
    Cooling unit
    (2a)
    IWave DC welding machine
    (2b)
    (3)
    Return lead cable
    (4)
    Trolley and gas cylinder holder
    (5)
    Swivel pin holder
    (6)
    Cold wire feeder
    (7)
    Welding torch
    (8)
    Remote controls
    (9)
    Foot-operated remote controls
    Other system components (not shown):
    • Cold-wire feed
    • MIG/MAG wirefeeder
    • MIG/MAG welding torch
    • Twin-head wirefeeder holder
    • Extension hosepacks
    • Robot interface
    1. TIG
    System components
    System components
    (1)
    Cooling unit
    (2a)
    (2b)
    (3)
    Return lead cable
    (4)
    (5)
    Swivel pin holder
    (6)
    Cold wire feeder
    (7)
    Welding torch
    (8)
    Remote controls
    (9)
    • Cold-wire feed
    • Robot interface
    1. TIG
    2. System components
    System components
    (1)
    Cooling unit
    (2a)
    (2b)
    (3)
    Return lead cable
    (4)
    (5)
    Swivel pin holder
    (6)
    Cold wire feeder
    (7)
    Welding torch
    (8)
    Remote controls
    (9)
    • Cold-wire feed
    • Robot interface
    1. TIG
    A cooling unit is recommended for the following applications:
    • JobMaster TIG welding torch
    • Robot mode
    • Hosepacks over 5 m in length
    • TIG AC welding
    • General welding in the higher power range
    The cooling unit is supplied with power via the welding machine. If the welding machine's power switch is switched to position - I -, the cooling unit is ready for operation.
    For more information on the cooling unit, refer to the Operating Instructions for the cooling unit.
    1. TIG
    • iWave AC/DC welding machine
    • Return lead cable
    • TIG welding torch
    • Shielding gas supply with gas pressure regulator
    • Filler metal depending on application
    1. TIG
    2. Minimum equipment for TIG welding
    • Return lead cable
    • TIG welding torch
    1. TIG
    • Welding machine
    • Return lead cable
    • TIG welding torch
    1. TIG
    TIG DynamicWire
    With TIG DynamicWire, the voltage between the workpiece and the welding wire is measured, allowing the wirefeeder to be actively controlled.
    The wire speed automatically adapts to the amperage, arc length, weld seam profile, or the air gap to be bridged.
    TIG DynamicWire works in Synergic operation. Current and wire speed do not have to be set separately.
    The wire speed can be optimized via the "Wire speed correction" process parameter.
    The Welding Package TIG DynamicWire provides characteristics for the most common filler metals.
    1. TIG
    2. TIG welding processes
    TIG DynamicWire
    1. TIG
    Powersharing
    Powersharing is a welding operation with two welding machines, the Mainwelding machine and the 2ndwelding machine. The two welding machines are connected to each other using Powersharingcables.
    This results in
    1. a welding operation with higher welding currents (e.g., in conjunction with an ArcTIG robot welding torch)
      and
    2. maintenance of the duty cycle at higher ambient temperatures.
    The process is controlled from the Mainwelding machine.
    The Welding Packages required for the welding process only have to be installed on the Mainwelding unit.
    Powersharing can also be used in MIG/Mag applications (e.g., in conjunction with the WF 30i R HD robot wirefeeder).
    1. TIG
    The following TIG Welding Packages are available for the iWave welding machines:
    TIG DynamicWire Welding Package
    4,066,018
    (enables the TIG DynamicWireprocess)
    Plasma Welding Package 4,066,020
    (enables TIG plasma processes)
    To use a TIG plasma process, the OPT/i Plasma option must be installed on the welding machine.
    HotWire Welding Package
    4,066,022
    (enables hot-wire welding)
    ConstantWire
    Welding Package 4,066,019
    (enables constant current or constant voltage operation during brazing)
    1. TIG
    2. TIG Welding Packages
    4,066,018
    4,066,022
    ConstantWire
    1. TIG
    Commissioning
    Safety
    WARNING!
    Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
    Secure all these devices and components so they cannot be switched back on.
    WARNING!
    Danger of electrical current due to electrically conductive dust in the device.
    Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
    1. TIG
    2. Commissioning
    Safety
    WARNING!
    WARNING!
    1. TIG
    2. Commissioning
    General
    The start-up of the welding machines for TIG welding is described on the basis of a manual, water-cooled TIG application.
    The following diagrams provide an overview of how the individual system components are assembled.
    For detailed information about the individual steps, please refer to the corresponding Operating Instructions for the system components.
    1. TIG
    2. Commissioning
    NOTE!
    For more detailed information about installing and connecting the system components, please refer to the corresponding Operating Instructions for the system components.
    iWave DC welding machines
    1. TIG
    2. Commissioning
    WARNING!
    Danger from falling gas cylinders.
    Place gas cylinders on a solid, level surface so that they remain stable.
    Secure gas cylinders to prevent them from falling over: Secure the safety strap at the height of the upper part of a gas cylinder.
    Never secure the safety strap to the neck of the cylinder.
    Observe the safety rules of the gas cylinder manufacturer.
    1Place the gas cylinder on the base of the trolley
    2Attach the cylinder strap to the upper part of the gas cylinder (but not to the neck of the cylinder) to prevent the cylinder from falling over
    3Remove the protective cap from the gas cylinder
    4Briefly open the gas cylinder valve to remove any dirt
    5Inspect the seal on the gas pressure regulator
    6Screw the pressure regulator onto the gas cylinder and tighten it
    When using a TIG welding torch with integrated gas connection:
    7Use a gas hose to connect the gas pressure regulator and shielding gas connection to the rear of the welding machine
    8Tighten the union nut of the gas hose
    When using a TIG welding torch without integrated gas connection:
    6Connect the gas hose of the TIG welding torch to the gas pressure regulator
    NOTE!
    The gas connection when using a MultiControl (MC) cooling unit is described in the Operating Instructions for the cooling unit.
    1. TIG
    2. Commissioning
    Connecting the welding torch to the welding machine and cooling unit
    NOTE!
    Do not use pure tungsten electrodes for iWave DC welding machines (color code: green).
    NOTE!
    Before every start-up:
    Check the O-ring at the welding torch connection,
    Check the coolant level
    1Fit parts to the welding torch according to the Operating Instructions for the welding torch
    IMPORTANT! Check the coolant flow at regular intervals during welding.
    1. TIG
    2. Commissioning
    Establishing a ground earth connection to the workpiece
    NOTE!
    When establishing a ground earth connection, observe the following points:
    Use a separate return lead cable for each welding machine
    Keep the torch hosepack and return lead cable as close together as possible for as long as possible
    Physically separate the welding circuits of individual welding machines
    Do not route several return lead cables in parallel;
    if parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
    Keep the return lead cables as short as possible and use cables with a large cross-section
    Do not cross over return lead cables
    Avoid ferromagnetic materials between the return lead cables and the interconnecting hosepack
    Do not reel up long return lead cables—coil effect!
    Route long return lead cables in loops
    Do not route return lead cables in iron pipes, metal cable trays, or along steel beams, avoid cable ducts;
    (routing positive cables and return lead cables together in an iron pipe does not cause any problems)
    If several return lead cables are being used, separate the grounding points on the component as far as possible and do not allow crossed current paths between the individual arcs.
    Use compensated interconnecting hosepacks (interconnecting hosepacks with integrated return lead cable)
    1Set the power switch to - O -
    1. TIG
    2. Commissioning
    Other activities
    For a TIG cold wire feeder
    1Set up the components required for TIG welding on the trolley (e.g., swivel pin holder, etc.)
    2Connect the control line to the wirefeeder
    3Connect the control line to the TMC socket on the front of the welding machine
    4Only if the OPT/i CWF TMC welding torch option is present on the wirefeeder:
    Connect the wirefeeder to the welding machine using the interconnecting hosepack
    5Set up cold-wire feed on TIG welding torch
    6Connect wirefeeding hose to wirefeeder
    7Insert suitable feed rollers for the TIG application into the wirefeeder
    8Set up suitable wear parts for the TIG application on the welding torch
    9Insert wire spool or basket-type spool and its adapter into the wirefeeder
    NOTE!
    For details on mounting or connecting the TIG components, refer to the Installation Instructions and Operating Instructions of the respective system components.
    10Connect the welding machine to the grid and switch on
    11Feed in the welding wire
    12Setting the contact pressure
    13Adjust the brake
    14Perform R/L adjustment
    For details, see from page (→).
    1. TIG
    TIG Operating Modes
    Safety
    WARNING!
    Danger due to incorrect operation.
    Do not use the functions described here until you have fully read and understood the operating instructions.
    Do not use the functions described here until you have fully read and understood all of the operating instructions of the system components, especially the safety rules.
    Follow the guidelines referring to setting, setting range, and units of measurement for the available parameters in the "Setup Menu" section.
    1. TIG
    2. TIG Operating Modes
    Safety
    WARNING!
    1. TIG
    Symbols and explanations
    (1) Pull back and hold the torch trigger (2) Release the torch trigger (3) Briefly pull back the torch trigger (< 0.5 s)
    (4) Push the torch trigger forward and hold (5) Release the torch trigger
    GPr
    Gas pre-flow
    SPt
    Spot welding time
    IS
    Starting current:
    the temperature is raised gently at low welding current, so that the filler metal can be positioned correctly
    IE
    Final current:
    to avoid local overheating of the parent material caused by heat accumulation at the end of welding. This prevents possible sagging of the weld seam.
    tUP
    UpSlope:
    steady rise of the starting current to the main current (welding current) I1
    tDOWN
    DownSlope:
    steady lowering of the welding current until it reaches the final current
    I1
    Main current (welding current):
    uniform thermal input into the parent material, whose temperature is raised by the advancing heat
    I2
    Lowering current:
    intermediate lowering of the welding current to avoid local overheating of the parent material
    GPO
    Gas post-flow
    1. TIG
    2-step mode
    • Welding: Pull back the torch trigger and hold it in this position
    • End of welding: Release the torch trigger
    2-step mode
    1. TIG
    4-step mode
    • Start of welding with starting current IS: Pull back the torch trigger and hold it in this position
    • Welding with main current I1: Release the torch trigger
    • Lowering to final current IE: Pull back the torch trigger and hold it in this position
    4-step mode
    *) Intermediate lowering
    With intermediate lowering, the welding current is lowered to the set lowering current I2  during the main current phase.
    • To activate intermediate lowering, push the torch trigger forward and hold it in this position
    • Release the torch trigger to resume the main current
    1. TIG
    Special 4-step mode:
    Version 1
    Intermediate lowering to the set lowering current I2 is effected by briefly pulling back the torch trigger. Briefly pull back the torch trigger again to return to the main current I1.
    Special 4-step mode: Version 1
    Version 1 of special 4-step mode is activated by the following parameter setting:
    Process parameters / General / 2-step settings
    • Starting current time = off
    • Final current time = off
    Process parameters / General / 4-step settings
    • Lowering current slope 1 = off
    • Lowering current slope 2 = off
    Process parameters / Ignition & operating mode / Operating mode settings
    • I2 via torch trigger = on
    • Lowering current button function = I2
    1. TIG
    Version 2
    In version 2, intermediate lowering is also carried out using the set lowering current slope 1/2 values:
    • Push the torch trigger forward and hold it in this position: the welding current steadily falls using the set lowering current slope 1 to the set lowering current value I2. The lowering current I2 continues until the torch trigger is released.
    • After releasing the torch trigger: the welding current rises to the main current I1 using the set lowering current slope 2.
    Special 4-step mode: Version 2
    Version 2 of special 4-step mode is activated by the following parameter setting:
    • Lowering current slope 1 = on
    • Lowering current slope 2 = on
    • I2 via torch trigger = off
    1. TIG
    Version 3
    Intermediate lowering of the welding current in version 3 is triggered by pushing the torch trigger forward and holding it in this position. Following the release of the torch trigger, the main current I1 is once again available.
    Pull back the torch trigger to immediately end welding without a downslope and final current.
    Special 4-step mode: Version 3
    Version 3 of special 4-step mode is activated using the following parameter setting:
    • Final current time = 0.01 s
    1. TIG
    Version 4
    • Start of welding and welding: Briefly pull back the torch trigger and release - the welding current rises from the starting current IS to the main current I1 using the set UpSlope.
    • Push forward the torch trigger and hold it in this position for intermediate lowering
    • Following the release of the torch trigger, the main current I1 is once again available
    • End of welding: Quickly pull back the torch trigger and release
    Special 4-step mode: Version 4
    Version 4 of special 4-step mode is activated using the following parameter setting:
    • Starting current time = on
    • Final current time = on
    1. TIG
    Version 5
    Version 5 allows the welding current to be increased and decreased without an Up/Down torch.
    • The longer the torch trigger is pressed forward during welding, the further the welding current increases (up to the maximum).
    • After releasing the torch trigger, the welding current remains constant.
    • The longer the torch trigger is pressed forward again, the further the welding current is reduced.
    Special 4-step mode: Version 5
    Version 5 of special 4-step mode is activated using the following parameter setting:
    • I2 via torch trigger = off or on
    • Lowering current button function = I1
    1. TIG
    Version 6
    • Start of welding with starting currentIS and UpSlope: Pull back the torch trigger and hold it in this position
    • Intermediate lowering to I2 and change from I2 back to main current I1: briefly press (< 0.5 s) and release torch trigger
    • End the welding process: long press (> 0.5 s) and release the torch trigger.
    The process is automatically terminated after the DownSlope phase and the final current phase.
    If the torch trigger is pressed briefly (< 0.5 s) and released during the DownSlope or final current phase, an UpSlope to the main current is initiated and the welding process continues.
    Special 4-step mode: Version 6
    Version 6 of special 4-step mode is activated by the following parameter setting:
    1. TIG
    Spot welding
    link_horizontalLink copied
    • Welding: Briefly pull back the torch trigger
      The duration of welding corresponds to the value that was entered for the "Spot welding time" setup parameter.
    • Premature ending of the welding process: Pull the torch trigger back again
    1. TIG
    TIG welding
    Danger due to incorrect operation and electric current
    WARNING!
    WARNING!
    1. TIG
    2. TIG welding
    WARNING!
    WARNING!
    1. TIG
    2. TIG welding
    TIG welding
    CAUTION!
    Danger of injury and damage to property from electric shock.
    When the power switch is switched to position - I -, the tungsten electrode of the welding torch is live.
    Ensure that the tungsten electrode is not touching anyone or any electrically conductive or grounded parts (housing, etc.).
    1Set the power switch to - I -
    2Select "Welding process"
    3Select "Process"
    Alternatively, the welding process can be selected via the status bar (compare with the procedure described from page (→) onwards).
    An overview of available welding processes is displayed.
    4Select "TIG" or "TIG cold wire" or "DynamicWire"
    5Select "Mode"
    The overview of operating modes is displayed.
    6Select the desired operating mode
    7For cold wire and DynamicWire applications only:
    Select and set the "Filler metal"
    8Select "TIG welding"
    Alternatively, the operating mode can be selected via the status bar (compare with the procedure described from page (→) onwards).
    The TIG welding parameters are displayed.
    9Turn the selection dial (or touch the parameter symbol in the indicator bar): select parameters
    10Press the selection dial
    The value of the parameter is highlighted in blue and can now be changed.
    11Turn the selection dial: change the value of the parameter
    12If necessary, set the process parameters for user- or application-specific settings on the welding system
    13Open the gas cylinder valve
    14Press the gas-test button
    The gas pre-flow test lasts for 30 seconds at the most. Press again to end the process prematurely.
    The "Gas purging" dialog box appears on the display, indicating the remaining gas purging duration.
    If there is a gas regulator or gas sensor in the welding system, the actual gas value is also displayed.
    15Turn the adjusting screw on the bottom of the gas pressure regulator until the manometer displays the desired gas volume
    16Commence the welding process (ignite arc)
    NOTE!
    Under certain circumstances, it may not be possible to change the set welding parameters of a system component—such as wirefeeder or remote control—on the control panel of the welding machine.
    1. TIG
    2. TIG welding
    Welding parameters for TIG welding
    AC
    Welding parameters for TIG AC welding
    DC-
    Welding parameters for TIG DC- welding
    Start current (AC / DC-)
    Start current: 2-step mode | 4-step mode
    Setting range: 0 - 200% (of the main current)
    Factory setting: 50 %
    IMPORTANT! The start current is stored separately for TIG AC welding and TIG DC- welding.
    Up-Slope (AC / DC-)
    Up-Slope: 2-step mode and spot welding | 4-step mode
    Setting range: off;0.1 - 30.0 s
    Factory setting: 0.5 s
    IMPORTANT! The stored UpSlope value applies to the 2-step and 4-step modes.
    Main Current I1 (AC / DC-)
    Main current: 2-step mode and spot welding | 4-step mode
    Setting range:
    iWave 300i DC, iWave 300i AC/DC: 3 - 300 A
    iWave 400i DC, iWave 400i AC/DC: 3 - 400 A
    iWave 500i DC, iWave 500i AC/DC: 3 - 500 A
    Factory setting: -
    IMPORTANT! For welding torches with Up/Down function, the full setting range can be selected while the device is on standby.
    Drop current I2 (AC / DC-)
    only in 4-step mode
    Drop current I2 < Main current I1 | Drop current I2 > Main current I1
    Setting range: 0 - 250% (of the main current I1)
    I2 < 100%
    Brief, adapted reduction of the welding current
    (e.g., when changing the welding wire during the welding process)
    I2 > 100%
    Brief, adapted increase in the welding current
    (e.g., for welding over tacking points with a higher power level)
    The values for Slope1 and Slope2 can be set in the process parameters.
    Down-Slope (AC / DC-)
    Down-Slope: 2-step mode and spot welding | 4-step mode
    Factory setting: 1.0 s
    IMPORTANT! The stored Down-Slope value applies to the 2-step and 4-step modes.
    Final current (AC / DC-)
    Final current: 2-step mode and spot welding | 4-step mode
    Setting range: 0 - 100% (of the main current)
    Factory setting: 30 %
    AC Balance (AC)
    Balance = 15%
    Balance = 35%
    Balance = 50%
    Setting range: 15 - 50%
    Factory setting: 35 %
    15: Highest melting capacity, lowest cleaning effect
    50: Highest cleaning effect, lowest melting capacity
    Effect of balance on current flow:
    Electrode diameter (AC / DC-)
    Setting range: off; 1.0 - 6.4 mm
    Factory setting: 2.4 mm
    Cap shaping (AC)
    Setting range: off / on
    Factory setting: off
    off
    Automatic cap-shaping function is deactivated
    on
    The optimum cap for the entered diameter of the tungsten electrode is shaped during the start of welding.
    The automatic cap-shaping function is then reset and deactivated.
    (1) ... before ignition
    (2) ... after ignition
    Cap shaping must be activated separately for each tungsten electrode.
    NOTE!
    The automatic cap-shaping function is not required if a sufficiently large cap is formed on the tungsten electrode.
    Polarity (AC)
    WARNING!
    Danger due to applied welding potential with Multiprocess-PRO welding machines and with existing dual-head wirefeeder WF 25i Dual!
    Disconnect the dual-head wirefeeder from the welding system before setting the polarity to AC!
    Polarity
    Setting range: DC- / AC
    Factory setting: DC-
    NOTE!
    To add more parameters to the welding parameters, go to Defaults / View / Parameter view setup.
    More information can be found from page (→) onwards.
    1. TIG
    Igniting the arc
    General
    In order to ensure an optimal ignition sequence during TIG AC welding, the iWave AC/DC welding machines take into account:
    • The diameter of the tungsten electrode
    • The current temperature of the tungsten electrode, taking into account the previous welding time and break
    1. TIG
    2. Igniting the arc
    General
    1. TIG
    2. Igniting the arc
    Igniting the arc using high frequency
    (HF ignition)
    CAUTION!
    Risk of injury due to an electric shock
    Although Fronius devices comply with all the relevant standards, high frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
    Use prescribed protective clothing, especially gloves!
    Only use suitable, completely intact, and undamaged TIG hosepacks!
    Do not work in damp or wet environments!
    Take special care when working on scaffolding, work platforms, in tight, difficult to access or exposed places, or when welding out-of-position!
    HF ignition is activated when the "HF ignition" setup parameter is set to "on" under process parameters/ignition parameters.
    The HF ignition indicator lights up on the status bar.
    Unlike contact ignition, there is no risk of contaminating the tungsten electrode and workpiece during HF ignition.
    Procedure for HF ignition:
    1Position the gas nozzle at the ignition point so that there is a gap of approximately 2 to 3 mm (5/64-1/8 in.) between the tungsten electrode and the workpiece.
    2Increase the tilt angle of the welding torch and press the torch trigger according to the selected operating mode
    The arc ignites without coming into contact with the workpiece.
    3Tilt the welding torch to the normal position
    4Carry out welding
    1. TIG
    2. Igniting the arc
    Contact ignition
    When the "HF ignition" setup parameter is set to "off", HF ignition is deactivated. The arc ignites when the workpiece makes contact with the tungsten electrode.
    Procedure for igniting the arc using contact ignition:
    1Position the gas nozzle at the ignition point so that there is a gap of approximately 2 to 3 mm (5/64 to 1/8 in.) between the tungsten electrode and the workpiece.
    2Press the torch trigger
    Shielding gas flows
    3Gradually tilt the welding torch up until the tungsten electrode touches the workpiece
    4Raise the welding torch and rotate it into its normal position
    The arc ignites.
    5Carry out welding
    1. TIG
    2. Igniting the arc
    Igniting the arc using high-frequency contact
    (Touch-HF)
    CAUTION!
    Although Fronius devices comply with all relevant standards, the high-frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
    Only use suitable, completely intact and undamaged TIG hosepacks!
    Take special care when working on scaffolds, work platforms, in forced positions, in tight, difficult to access or exposed places!
    The welding process is initiated by briefly touching the workpiece with the tungsten electrode. The high-frequency ignition is performed after the set HF ignition delay time has elapsed.
    1. TIG
    2. Igniting the arc
    Electrode overload
    If the tungsten electrode is overloaded, this can result in material detachment on the electrode, which can cause contamination to enter the weld pool.
    If the tungsten electrode is overloaded, the "Electrode overloaded" indicator lights up on the status bar of the control panel.
    The "Electrode overloaded" indicator depends on the set electrode diameter and the set welding current.
    1. TIG
    2. Igniting the arc
    End of welding
    1Depending on the set operating mode, end welding by releasing the torch trigger
    2Wait for the set gas post-flow and hold the welding torch in position over the end of the weld seam.
    1. TIG
    TIG special functions
    Ignition timeout function
    The welding machine has an ignition timeout function.
    If the torch trigger is pressed, gas pre-flow begins immediately and the ignition procedure is then initiated. If no arc forms during one of the time periods specified under the ignition parameters, the welding machine automatically switches off.
    The setting of the "Ignition timeout" parameter is described in the Process parameters/ignition and operating mode settings section starting on page (→).
    1. TIG
    2. TIG special functions
    1. TIG
    TIG pulsing
    The welding current set at the start of welding may not always be ideal for the entire welding process:
    • If the amperage is too low, the parent material will not be sufficiently melted,
    • If overheating occurs, there is a danger that the liquid weld pool may drip.
    The TIG pulsing function is able to help with this (TIG welding with a pulsing welding current):
    A low base current (2) rises steeply to a significantly higher pulse current and falls again in line with the set duty cycle (5) to the base current (2).
    During TIG pulsing, small sections of the welding area are quickly melted and then allowed to quickly solidify again.
    During manual applications, the welding wire is applied in the maximum current phase during TIG pulsing (only possible in the low-frequency range from 0.25 - 5 Hz). Higher pulse frequencies are mostly used in automated applications and mainly serve to stabilize the arc.
    TIG pulsing is used to weld steel pipes when welding out-of-position or to weld thin sheet metal.
    TIG pulsing in operation with TIG DC welding selected:
    TIG pulsing - welding current curve
    Key:
    (1) Main current, (2) Base current, (3) Starting current, (4) UpSlope, (5) Pulse frequency *)
    (6) Duty cycle, (7) DownSlope, (8) Final current
    *) (1/F-P = Time between two pulses)
    1. TIG
    Tacking function
    The tacking function is used for the TIG DC welding process.
    Whenever a period of time is set for the "Tacking" (4) parameter under process parameters/TIG DC settings, the tacking function is assigned to the 2-step and 4-step modes. The sequence of operating modes remains unchanged.
    The Tacking (TAC) indicator lights up on the status bar:
    During this time, a pulsed welding current is available, which optimizes the merging of the weld pool when tacking two components.
    How the tacking function works during TIG DC welding:
    Tacking function - welding current curve
    Key:
    (1) Main current, (2) Starting current, (3) UpSlope, (4) Duration of pulsed welding current for tacking process, (5) DownSlope, (6) Final current
    NOTE!
    When using a pulsed welding current:
    The welding machine automatically controls the pulse parameters according to the set main current (1).
    No pulse parameters need to be set.
    The pulsed welding current starts
    • After the starting-current phase (2) has finished
    • With the UpSlope phase (3)
    Depending on the set tacking duration, the pulsed welding current can be stopped up to and including the final current phase (6) ("Tacking" (4) TIG DC parameter to "on").
    After the tacking time has passed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
    1. TIG
    CycleTIG
    The CycleTIG stitch welding process is available for TIG DC welding.
    The welding result is influenced and controlled by different parameter combinations.
    The main advantages of CycleTIG are easy control of the weld pool, targeted heat input and fewer temper colors.
    CycleTIG variations
    CycleTIG + low base current
    • For out-of-position welding, edge build-up and orbital welding
    • Suitable for thick/light-gauge sheet joins
    • Excellent weld characteristics
    • HF ignition only at start of welding
    • Long electrode service life
    • Good control of the weld pool
    • Targeted heat input
    CycleTIG + RPI = on + base current = off
    • For repair work (e.g., edge build-up)
    • Biggest advantage in combination with HF ignition setting = touch HF
    • HF ignition at every cycle (!)
    • Very short electrode service life (!)
    Recommendation: iWave AC/DC with reversed polarity ignition setting = auto
    CycleTIG + tacking
    • For tacking light-gauge sheets, orbital applications and for thick/light-gauge sheet joins
    • Excellent seam appearance
    • Tacking function generates automatic pulse setting
    CycleTIG + Pulse
    CycleTIG can be used individually with all pulse settings. This allows pulsing in both the high current and low current phases.
    • For tacking light-gauge sheets and for cladding applications
    • For thick/light-gauge sheet joins
    • Individual pulse settings possible
    • More welding parameters to set
    1. TIG
    TIG process parameters
    TIG process parameters:
    TIG pulse, AC, General, Ignition & Trigger mode, CycleTIG, Wirefeeder setup, Gas, R/L-check / alignment, Plasma, HotWire
    Process parameters for Components and Monitoring, see page (→).
    1. TIG
    2. TIG process parameters
    1. TIG
    Process parameters for TIG pulse
    Tacking
    Tacking function - duration of the pulsed welding current at the start of the tacking process
    off / 0.1 - 9.9 s / on
    off
    Tacking function is switched off
    0.1 - 9.9 s
    The selected time begins with the UpSlope phase. After the selected time has passed, further welding is carried out at a constant welding current. The set pulse parameters are available if applicable.
    on
    The pulsed welding current remains present until the end of the tacking process
    The Tacking (TAC) indicator lights up on the display if a value has been set.
    Pulse frequency
    off / 0.20 - 2000 Hz (10,000 Hz with OPT/I-Puls Pro option)
    IMPORTANT! If the pulse frequency is set to "off", the base current and duty cycle parameters cannot be selected.
    The set pulse frequency is also applied for the lowering current.
    The Pulsing indicator lights up in the status bar if a value for the pulse frequency has been entered.
    Base current *
    0 - 100% (of the main current I1)I
    Factory setting: 50%
    Duty cycle *
    Relationship between pulse duration and base current duration at the set pulse frequency
    10 - 90%
    Pulse waveform *
    For optimizing the arc pressure
    Hard rectangle/Soft rectangle/Sine
    Factory setting: Hard rectangle
    Hard rectangle:
    Purely rectangular curve;
    Slightly louder arc noise, rapid current changes
    Used, for example, in orbital welding
    Soft rectangle:
    Rectangular curve with reduced edge steepness, for reduced noise in comparison with the purely rectangular curve;
    universal use
    Sine:
    Sinusoidal shape (default setting for low-noise and stable arc);
    Used, for example, for corner seams and cladding applications
    Optimizing the arc pressure results in:
    • A better flow out of the weld pool (improved welding of butt welds or corner seams)
    • A slow rise or fall in current (for fillet welds, high-alloy steels or cladding applications in particular, the filler material or weld pool is not pushed away)
    • A reduction in the noise level during welding thanks to rounded waveforms
    Base current waveform *
    For optimizing arc pressure
    Hard rectangle:
    Soft rectangle:
    universal use
    Sine:
    The parameters are available if the OPT/I-Puls Pro option is present on the welding machine.
    1. TIG
    Process parameters for TIG AC
    AC frequency
    Syn/40 - 250 Hz
    Factory setting: 60 Hz
    Syn
    Setting for synchronous welding (double-side, simultaneous welding with 2 welding machines)
    For synchronous welding, the AC frequency must be set to "Syn" for both welding machines.
    Synchronous welding is used for thick materials, to achieve a high deposition rate and to minimize inclusions during welding.
    IMPORTANT! Due to the phasing of the input voltage, in some cases the synchronization of the two welding machines cannot be carried out correctly.
    In this case, disconnect the mains plug of the welding machines, turn 180°, and reconnect to the grid.
    Low frequency
    Soft, wide arc with shallow heat input
    High frequency
    Focused arc with deep heat input
    Effect of AC frequency on current flow:
    AC current offset
    -70 to +70%
    Factory setting: 0%
    +70%
    Wide arc with shallow heat input
    -70%
    Narrow arc, deep heat input, higher welding speed
    Effect of AC current offset on current flow:
    * Factory setting: 0 (corresponds to a 10% shift to negative)
    Positive half-wave waveform
    Hard rectangle/Soft rectangle/Triangle/Sine
    Factory setting: Sine
    Hard rectangle
    Purely rectangular curve (stable but loud arc)
    Soft rectangle:
    Triangle
    Triangular curve
    Sine
    Sinusoidal curve (default setting for low-noise arc)
    Negative half-wave waveform
    Factory setting: Soft rectangle
    Hard rectangle
    Soft rectangle:
    Triangle
    Triangular curve
    Sine
    Sinusoidal curve (default setting for low-noise and stable arc)
    Phase synchronization
    Synchronizes two AC welding machines (simultaneously on both sides)
    0 - 5
    Factory setting: 0
    1. TIG
    General TIG process parameters
    Welding start / welding end settings
    The starting current time indicates the duration of the starting-current phase .
    The setting of the Starting current time parameter also influences versions 1 - 6 of special 4-step mode (see page (→) onwards).
    off / 0.01 - 30.0 s
    IMPORTANT! The starting current time is only valid for 2-step mode and spot welding. In 4-step mode, the duration of the starting-current phase is determined  by the torch trigger.
    Final current time
    The final current time indicates the duration of the final current phase.
    The setting of the Final current time parameter also influences versions 1 - 6 of special 4-step mode (see page (→) onwards).
    off / 0.01 - 30 s
    IMPORTANT! The final current time is only valid for 2-step mode and spot welding. In 4-step mode, the duration of the final current phase is determined by the torch trigger (section "TIG operating modes").
    4-mode settings
    Lowering current Slope 1
    The setting of the Lowering current slope 1 parameter also influences versions 1 - 6 of special 4-step mode (see page (→) onwards).
    off / 0.01 - 30 s
    If a time value has been entered for the Lowering current Slope 1 parameter, the brief current reduction or current increase is not abrupt, but slow and adapted.
    This reduces negative influences on the weld and part, especially with aluminum applications.
    Lowering current Slope 2
    The setting of the Lowering current slope 2 parameter also influences versions 1 - 6 of special 4-step mode (see page (→) onwards).
    off / 0.01 - 30 s
    If a time value has been entered for the Lowering current Slope 2 parameter, the adaptation from the lowering current to the welding current is not abrupt, but slow and adapted.
    In the case of a current increase, for example, the weld pool is heated slowly and not abruptly. This facilitates outgassing of the weld pool and reduces pores during aluminum welding.
    Spot welding settings
    Spot welding time
    (only if the mode is set to spot welding)
    0.02 - 120 s
    Factory setting: 5.0 s
    1. TIG
    Process parameters for ignition and operating mode
    Ignition parameters
    HF ignition
    on/off/Touch-HF/external
    Factory setting: on
    on
    High-frequency ignition at the start of welding is activated
    off
    No high-frequency ignition at the start of welding.
    In this case, welding is started by means of contact ignition.
    Touch-HF
    The welding process is initiated by briefly touching the workpiece with the tungsten electrode. High-frequency ignition is performed after the set HF ignition delay time has elapsed.
    External
    Start with an external ignition device, e.g., plasma welding
    The HF ignition indicator lights up in the status bar if HF ignition has been set to on.
    CAUTION!
    Period of time after touching the workpiece with the tungsten electrode after which high-frequency ignition takes place.
    0.1 - 5.0 s
    Reversed polarity ignition
    To ensure an optimum ignition sequence during TIG DC welding, the polarity is reversed briefly at the start of the welding process. Electrons emerge from the workpiece and hit the tungsten electrode. This results in rapid heating of the tungsten electrode - an essential prerequisite for optimum ignition properties.
    off/on/auto
    off:
    Short ignition delay, stable ignition when the electrode is hot
    on:
    Arc forms at the electrode tip, low heat input during ignition
    auto:
    Very short ignition delays, automatic adjustment of the ignition setting by the welding machine, safe ignition
    Reversed polarity ignition is recommended for welding light-gauge sheets up to 1.5 mm thick.
    Arc monitoring
    Ignition timeoutPeriod of time until the safety cut-out following failed ignition.
    0.1 - 9.9 s
    Factory setting: 5 s
    IMPORTANT! Ignition timeout is a safety function and cannot be deactivated.
    The ignition timeout function is described in the "TIG welding" section.
    Arc break filter timePeriod of time until the safety cut-out following an arc break
    If no current flows during the set period of time following an arc break, the welding machine automatically switches off.
    Press any button on the control panel or the torch trigger to restart the welding process.
    0.00 - 2.00 s
    Factory setting: 0.20 s
    Arc break watchdog
    Reaction if no current flows within the arc break time
    ignore/error
    Factory setting: ignore
    ignore
    The interruption is ignored.
    error
    An error message is displayed on the welding machine and must be acknowledged.
    Torch trigger
    Start welding by pressing the torch trigger
    on/off
    Factory setting: on
    on
    Welding is started using the torch trigger
    off
    Welding is started by touching the workpiece with the tungsten electrode;
    especially suitable for welding torches without torch triggers, ignition sequence depends on ignition parameters
    The symbol for the deactivated torch trigger is shown in the status bar of the display, the option for selecting the operating mode is deactivated.
    I2 using torch trigger
    To activate/deactivate whether it is possible to switch over to the drop current I2 using the torch trigger
    The setting of the I2 using torch trigger parameter also influences options 1 - 6 of special 4-step mode (see page (→) onwards).
    on / off
    Drop current button function
    The setting of the drop current button function parameter also influences options 1 - 6 of special 4-step mode (see page (→) onwards).
    I1 / I2
    Factory setting: I2
    Arc break voltage
    To set a voltage value at which the welding process can be ended by lifting the TIG welding torch slightly.
    The higher the break voltage value, the higher the arc can be lifted.
    The arc break voltage values for 2-step mode, 4-step mode and operation with a foot-operated remote control are all stored together.
    If the "Torch trigger" parameter is set to "off", the values are stored separately.
    off / 6.0 - 90.0 V
    Comfort stop sensitivity
    The parameter is only available if the "Torch trigger" parameter is set to "off".
    off / 0.1 - 10.0 V
    At the end of the welding process, an automatic shutdown of the welding current follows a significant increase of the arc length. This prevents the arc from having to be unnecessarily lengthened when lifting the TIG welding torch.
    Process:
    1Welding
    2Briefly lift the welding torch at the end of welding
    The arc lengthens significantly.
    3Lower the welding torch
    • The arc shortens significantly
    • The Comfort stop function has been activated
    4Maintain the height of the welding torch
    • The welding current ramps down continuously (DownSlope).
    • The arc goes out.
    IMPORTANT! The DownSlope is fixed and cannot be adjusted.
    5 Lift the welding torch from the workpiece
    1. TIG
    Process parameters for CycleTIG
    CycleTIG
    To activate / deactivate the CycleTIG function
    (extended stitch welding process for DC welding)
    Setting range: on / off
    (1) Interval timeT
    o set how long the welding current I1 is active
    Setting range: 0.02 - 2.00 s
    (2) Interval pause time
    To set how long the base current (4) is active
    (3) Interval cycles
    To set how many cycles are to be repeated
    Setting range: Constant / 1 - 2000
    Factory setting: Constant
    (4) base current (DC-)
    To set the interval base current (4) to which the current is reduced during the interval pause time (2)
    Setting range: off / 3 - max. A
    NOTE!
    For more details on CycleTIG, see page (→) onwards.
    1. TIG
    Wire speed setting
    Wire speed correctionFor fine adjustment of the wire speed with TIG DynamicWire
    The correction value indicates how quickly the welding wire re-enters the weld pool after the short circuit is broken.
    -10 - +10
    Factory setting: 0
    -10 = slow immersion, +10 =fast immersion
    Wire speed 1
    Set value for wire speed
    off / 0.1 - 50.0 m/min
    Factory setting: 5 m/min
    Wire speed 2
    Wire speed 2
    0 - 100% (of wire speed 1)
    If a value is set for each of the "Wire speed 2" and "Pulse frequency" setup parameters, the wire speed changes between wire speed 1 and wire speed 2 synchronously with the pulse frequency of the welding current.
    Main current
    Welding current I1
    Factory setting: -
    Pulse frequency
    off / 0.20 - 5000 Hz, 5000 - 10000 Hz
    Wire start-up delay
    Feed delay of welding wire from start of main current phase
    off / 0.1 - 9.9 s
    Wire end delay
    Feed delay of welding wire from end of main current phase
    off / 0.1 - 9.9 s
    Wire retraction end
    How far the welding wire is retracted after the end of welding
    off / 1 - 50 mm
    Factory setting: 3 mm
    Wire position start
    How far the welding wire is from the workpiece before welding starts
    off / 1 - 50 mm
    Feeder inching speed
    0.5 - 100.0 m/min
    Factory setting: 5.0 m/min
    1. TIG
    TIG gas settings
    Gas pre-flow
    To set the gas flow time before ignition of the arc
    0.0 - 9.9 s
    Factory setting: 0.4 s
    Gas post-flow
    To set the gas flow time after the end of the arc
    auto / 0 - 60 s
    Factory setting: auto
    auto
    Depending on the electrode diameter and welding current, the welding machine calculates and automatically adjusts the optimal gas post-flow time.
    TIG gas changeover
    For individual gas shield selection
    auto / 1 / 2
    auto:
    • The shielding gas (gas 1) is used during the starting-current phase and during the UpSlope.
    • When the main current phase is reached, working gas (gas 2) is used.
    • When the welding process is finished, the shielding gas (gas 1) is used during the DownSlope and the final current phase.
    1:
    Shielding gas (gas 1) is used for the entire welding process.
    2:
    Working gas (gas 2) is used for the entire welding process.
    Gas regulator 1
    Gas set value 1 - TIG shielding gas
    Shielding gas flow
    (only in conjunction with the OPT/i TIG gas flow sensor option)
    off / 0.5 - 30.0 l/min
    Factory setting: 15.0 l/min
    NOTE!
    To ensure the gas regulator is functioning correctly, the inlet pressure at the wirefeeder or welding machine must be at least 4.5 bar (65 psi) when the target flow rate is maintained.
    In order to reach the minimum inlet pressure of 4.5 bar (65 psi), it may be necessary to remove existing flow regulators.
    Gas factor 1 - TIG shielding gas
    Depends on the shielding gas used
    (only in conjunction with the OPT/i TIG gas regulator option)
    auto / 0.90 - 20.00
    Gas regulator 2
    Gas set value 2 - TIG working gas
    Gas factor 2 - TIG working gas
    0.90 - 20.0
    Factory setting: 11.82
    Trailing gas regulator
    Trailing gas set value
    Trailing gas factor
    0.90 - 20.00
    1. TIG
    Welding parameters for MIG/MAG standard synergic welding, LSC welding, and CMT welding
    For MIG/MAG standard synergic welding, LSC welding, and CMT welding, the following welding parameters can be set and displayed in the "welding parameters" menu item:
    Wire speed 1)
    0.5 - max 2) 3) m/min / 19.69 - max 2) 3) ipm.
    Material thickness 1)
    0.1 - 30.0 mm 2) / 0.004 - 1.18 2) in.
    Current 1) [A]
    Setting range: depends on the selected welding process and welding program
    Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding.
    Arc length correction
    For correcting the arc length
    -10 - +10
    Factory setting: 0
    - ... shorter arc length
    0 ... neutral arc length
    + ... longer arc length
    When the arc length correction is adjusted, the welding voltage changes while the welding current and the wire speed remain constant.
    The display shows the voltage value with unchanged arc length correction (1), the voltage value corresponding to the currently set arc length correction (2), and the active arc length correction symbol (3).
    NOTE!
    For certain PMC characteristics, the arc length correction cannot be adjusted when the arc length stabilizer is active.
    In this case, the arc length correction is not displayed in the welding parameters.
    Dynamic correction
    for setting the short circuit current and the current to short-circuit breakup
    -10 - +10
    Factory setting: 0
    -10
    harder arc (higher current in case of short circuit breakup, increased welding spatter)
    +10
    softer arc (lower current in case of short circuit breakup, reduced welding spatter formation)
    NOTE!
    SynchroPulse can be activated via the status bar.
    (see page (→))
    If SynchroPulse is activated, the SynchroPulse parameters are also displayed with the welding parameters.
    1. TIG
    Conducting an R/L alignment
    NOTE!
    The R/L alignment must be carried out separately for each welding process.
    Welding circuit resistance R [mOhm]
    The welding circuit resistance is calculated to provide information about the total resistance of the torch hosepack, welding torch, workpiece and grounding cable.
    If, for example, the welding circuit resistance increases after the welding torch has been changed, the following components may be faulty:
    • Torch hosepack
    • Welding torch
    • Ground earth connection to the workpiece
    • Grounding cable
    Welding circuit inductance L [µH]
    The routing of the hosepack has a significant impact on the weld properties.
    A high degree of welding circuit inductance can occur, especially during pulsing and AC welding, depending on the length and routing of the hosepack. The increase in current is limited.
    The welding result can be optimized by changing the routing of the torch hosepack.
    The hosepack must always be routed as shown.
    Perform R/L alignment
    1Process parameters / General / R/L-check / alignment
    The current values are displayed.
    2Select Next
    The 2nd R/L alignment screen is displayed.
    3Follow the instructions on the screen
    4Select Next
    The 3rd R/L alignment screen is displayed.
    5Follow the instructions on the screen
    6Select Next
    The current values are determined.
    After R/L alignment has been performed, a confirmation and the current values are displayed.
    1. TIG
    Process parameters for TIG plasma
    The plasma process parameters are available if the welding machine has the WP Plasma Welding Package and if the OPT/i TIG Plasma option is installed in the welding machine.
    Plasma
    To activate /deactivate a TIG plasma welding process
    on / off
    Plasma gas set value
    Plasma gas flow
    0.1 - 9.0 l/min
    Factory setting: 1 l/min
    Plasma gas factor
    Depends on the plasma gas used
    0.90 - 10.0
    Factory setting: 1.72
    Plasma gas pre-flowTo set the plasma gas flow time before ignition of the pilot arc
    0.0 - 9.9 s
    Plasma gas post-flow
    To set the plasma gas flow time after the end of the pilot arc
    0.0 - 9.9 s
    Pilot current
    Current for the pilot arc
    3.0 - 30.0 A
    Factory setting: 10.0 A
    Plasma gas pre-flow/post-flow value
    To set the plasma gas volume for pre-flow and post-flow
    0.1 - 9.0 l/min
    Factory setting: 3.0 l/min
    1. TIG
    Process parameters for TIG hot-wire welding
    The TIG hot-wire process parameters are available where there is a second welding machine with the WP HotWire Welding Package in the welding system.
    Hot-wire amperage
    3 - 500 A
    Factory setting: 50 A
    Hot wire voltage limitation
    0.3 - 30.0 V
    Factory setting: 12.0 V
    Hot-wire polarity
    To change the polarity without having to reconnect the power cables
    DC- / DC
    Hot-wire AC current offset
    To set the arc blow
    -70 - +70%
    Factory setting: 0 %
    Hot-wire AC wave shape
    To set the hot-wire AC wave shape
    Hard rectangle:
    Soft rectangle:
    Plasma
    Minimum equipment for plasma welding
    • iWave welding machine
      + OPT/i TIG Plasma
      + WP Plasma
    • Cooling unit
    • Return lead cable
    • Plasma welding torch
    • Plasma gas supply with gas pressure regulator
    1. Plasma
      + OPT/i TIG Plasma
      + WP Plasma
    • Cooling unit
    • Return lead cable
    1. Plasma
    2. Minimum equipment for plasma welding
      + OPT/i TIG Plasma
      + WP Plasma
    • Cooling unit
    • Return lead cable
    1. Plasma
    Plasma welding
    WARNING!
    Danger due to incorrect operation and work not carried out correctly.
    This may result in serious personal injury and damage to property.
    All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
    Read and understand all safety rules and user documentation for this equipment and all system components.
    WARNING!
    1. Plasma
    2. Plasma welding
    WARNING!
    WARNING!
    1. Plasma
    2. Plasma welding
    Preparation
    NOTE!
    The gas supply for plasma welding processes via gas cylinders requires a separate gas cylinder for the plasma gas and a separate gas cylinder for the shielding gas.
    Do not take plasma gas and shielding gas from the same gas bottle.
    Only pure argon may be used for the plasma gas.
    Use only an inert gas for the shielding gas (e.g. argon)
    The grinding angle of the tungsten electrode should be approx. 30°.
    1Set the power switch to - 0 - and disconnect the welding machine from the grid
    2Disconnect the TIG welding torch from the welding machine
    3Connect the plasma welding torch to the welding machine
    4Connect the plasma gas
    5Insert the tungsten electrode in the plasma welding torch
    6Check the gap between the plasma nozzle and the tungsten electrode using a setting gauge (approx. 1-2.5 mm or 0.04-0.1 in.)
    7Connect the welding machine to the grid and set the power switch to - I -
    1. Plasma
    2. Plasma welding
    Plasma welding
    8Select "Process parameters / Common TIG/MMA/CEL / next page"
    9Select "Plasma"
    10Activate plasma (Plasma = ON)
    11Set plasma process parameters
    12Select "OK"
    13Select "Welding process"
    14Select "Plasma" or "Cold wire" or "DynamicWire "
    15Select "Mode"
    16Select the desired operating mode
    17For cold wire and DynamicWire applications only:
    18Activate HF ignition:
    Select Process parameters / Common/TIG/MMA/Plasma / Ignition- & Trigger mode and set the HF ignition parameter to "on"
    If the welding system has an OPT/i external HF (external high-frequency) device, set the HF ignition parameter to "External".
    19Set the "Reversed polarity ignition (RPI)" parameter to "off"
    20Select OK
    21Activate cooling unit:
    Select Process parameters / Components & monitoring / Components / Cooling unit and set the cooling circuit operating mode parameter to "eco, auto or on"
    22Select OK
    23Select "Plasma Welding"
    The plasma welding parameters are displayed.
    24Turn the selection dial (or touch the parameter symbol in the indicator bar): select parameters
    25Press the selection dial
    26Turn the selection dial: change the value of the parameter
    27If necessary, set the process parameters for user- or application-specific settings on the welding system
    28Open the gas cylinder valves
    29Purge the shielding gas and plasma gas for at least 30 seconds
    Press the Gas-test button
    The "Gas purging" dialog box appears on the display, indicating the remaining gas purging time.
    30Turn the adjusting screw on the bottom of the gas pressure regulator until the manometer displays the desired gas volume
    31Commence the welding process (ignite arc)
    NOTE!
    1. Plasma
    2. Plasma welding
    Igniting the arc
    CAUTION!
    1Press the torch trigger forwards for 4 seconds.
    Alternatively, the pilot arc can be ignited via a robot control unit.
    The pilot arc ignites
    2Start plasma welding by pressing the torch trigger or via a start signal from the robot control unit
    NOTE!
    Operating instructions:
    To reduce wear, the pilot arc should burn throughout the operation.
    Shielding gas volume during operation: at least 12 l/min (25.71 cfh)
    1. Plasma
    2. Plasma welding
    Welding and process parameters for plasma welding
    The welding parameters for plasma welding mirror those for TIG welding, see from page(→) onwards.
    Plasma process parameters:
    Process parameters / Common/TIG/MMA/Plasma / next page / Plasma
    see page (→)
    Manual Metal Arc Welding, CEL, Arc air gouging
    Minimum equipment for MMA and CEL welding and for arc air gouging
    In addition to the iWave welding machine, the following components are required for MMA and CEL welding:
    • Return lead cable
    • Electrode holder with welding power-lead
    • Stick or cellulose electrodes
    1. Manual Metal Arc Welding, CEL, Arc air gouging
    • Return lead cable
    2. Minimum equipment for MMA and CEL welding and for arc air gouging
    • Return lead cable
    Minimum equipment for arc air gouging
    In addition to the iWave welding machine, the following components are required for arc air gouging:
    • The built-in OPT/i TIG PowerConnector option on the welding machine
    • Return lead cable 120i PC
    • PowerConnector - Dinse adapter
    • KRIS 13 arc air gouging torch
    • Compressed air supply
    Commissioning
    Preparation
    NOTE!
    All TIG components connected to and set up on the welding machine can remain on the welding machine.
    The TIG components do not have to be isolated for MMA welding.
    NOTE!
    Check the packaging or labeling on the stick electrode to determine whether the stick electrodes are to be welded on the positive pole (+) or the negative pole (-)
    iWave AC/DC welding machines can reverse polarity automatically.
    For iWave DC welding machines, the current socket for MMA welding is always polarized to DC-.
    2Unplug the mains plug
    3Insert the bayonet connector of the electrode holder cable into the current socket for manual metal arc welding and twist it clockwise to lock
    4Insert the mains plug
    2. Commissioning
    Preparation
    NOTE!
    NOTE!
    WARNING!
    WARNING!
    2. Manual Metal Arc Welding
    WARNING!
    WARNING!
    Manual metal arc welding
    CAUTION!
    Danger of injury and damage from electric shock.
    When the power switch is in position - I -, the stick electrode in the electrode holder is live.
    Ensure that the stick electrode is not touching anyone or any electrically conductive or grounded parts (housing, etc.)
    Alternatively, the welding process can also be selected via the status bar (compare with the procedure described from page (→)).
    An overview of the welding processes is displayed.
    Various welding processes are available depending on the type of welding machine or the function package installed.
    3Select the MMA or CEL welding process
    The welding voltage is applied to the welding socket with a three second delay.
    If the MMA or CEL welding process is selected, a cooling unit, if present, is automatically deactivated. It is not possible to turn it on.
    NOTE!
    4Select "MMA welding"
    The MMA welding parameters are displayed.
    5Turn the dial and select the desired welding parameter
    6Press the dial to change the parameter
    7Turn the dial and adjust the parameter
    8If necessary, set the process parameters for user- or application-specific settings on the welding system
    9Initiate welding process
    Welding parameters for manual metal arc welding and CEL welding
    Hot start current
    Factory setting: 150%
    Main current
    Setting range:
    3 - 300 A
    3 - 400 A
    3 - 500 A
    Factory setting:-
    Dynamic
    To obtain the best possible welding results, the arc-force dynamic will sometimes need to be adjusted.
    Factory setting: 20
    0 ... soft and low-spatter arc
    100 ... harder and more stable arc
    Functional principle:
    At the moment of droplet transfer or in event of a short circuit, a short-term increase in the amperage will occur. To maintain a stable arc, the welding current temporarily rises. If the stick electrode is at risk of sinking into the weld pool, this action prevents the weld pool from solidifying, as well as reducing the duration of the arc's short circuit. The risk of the stick electrode sticking is therefore largely ruled out.
    Polarity
    Setting range: DC- / DC+ / AC
    Hot-Start, Soft-Start, Anti-Stick Functions
    Starting current > 100 % (HotStart)
    Advantages
    • Improved ignition properties, even when using electrodes with poor ignition properties
    • Better fusion of parent material in the start phase, therefore less neutralization
    • Slag inclusions largely avoided
    Example of a starting current > 100% (HotStart)
    (1)
    0-2 s, factory setting 0.5 s
    (2)
    Starting current
    0-200%, factory setting 150%
    (3)
    Main current = set welding current I1
    Operation
    During the set starting current time (1), the welding current I1 (3) rises to the starting current (2).
    The starting current time is set in the Setup menu.
    2. Hot-Start, Soft-Start, Anti-Stick Functions
    Advantages
    (1)
    (2)
    Starting current
    (3)
    Operation
    Starting current < 100 %
    (SoftStart)
    A starting current of < 100% (SoftStart) is suitable for basic electrodes. Ignition is carried out with a low welding current. As soon as the arc is stable, the welding current increases until it reaches the set welding current command value.
    Example of a starting current < 100% (SoftStart)
    Advantages:
    • Improvement of ignition properties with electrodes that ignite at a low welding current
    • Reduction of welding spatter
    (1)
    Starting current
    (2)
    (3)
    Main current
    The starting current time is set in the MMA menu.
    Anti-stick function
    As the arc becomes shorter, the welding voltage may also fall so that the stick electrode is more likely to stick to the workpiece. This may also cause the stick electrode to burn out.
    Electrode burn-out is prevented by activating the anti-stick function. If the stick electrode begins to stick, the welding machine immediately switches the welding current off. The welding process can be resumed without problems once the stick electrode has been detached from the workpiece.
    The anti-stick function is activated and deactivated under:
    Process parameters / Common TIG/MMA/CEL / Electrode.
    Stick electrode / CEL Process parameters
    Stick electrode / CEL Process parameters:
    Electrode, CEL
    Process parameters for Components and Monitoring see page (→).
    2. Stick electrode / CEL Process parameters
    Electrode, CEL
    Process parameters for stick electrode
    HotStart
    0.0 - 2.0 s
    To obtain the best possible welding result, the HotStart function will sometimes need to be adjusted
    .Advantages:
    • Better fusion of base material in the start phase, therefore less neutralization
    Characteristic
    For selecting the electrode characteristic
    I-constant / 0.1 - 20.0 A/V / P-constant / Arc air gouging (iWave 500 DC and AC/DC only)
    Factory setting: I-constant
    (1)
    Working line for stick electrode
    (2)
    Working line for stick electrode with increased arc length
    (3)
    Working line for stick electrode with reduced arc length
    (4)
    Characteristic for selected parameter "I-constant" (constant welding current)
    (5)
    Characteristic for selected parameter "0.1 -20" (drooping characteristic with adjustable gradient)
    (6)
    Characteristic for selected parameter "P-constant" (constant welding power)
    (7)
    Example of set arc-force dynamic with selected characteristic (4)
    (8)
    Example of set arc-force dynamic with selected characteristic (5) or (6)
    I-constant (constant welding current)
    • If the "I-constant" parameter is set, the welding current is kept constant regardless of the welding voltage. The result is a vertical characteristic (4).
    • The "I-constant" parameter is particularly suitable for rutile electrodes and basic electrodes.
    0.1 - 20.0 A/V (drooping characteristic with adjustable slope)
    • A drooping characteristic (5) can be set using parameter "0.1 - 20". The setting range is from 0.1 A/V (very steep) to 20 A/V (very flat).
    • Setting a flat characteristic (5) is only recommended for cellulose electrodes.
    P-constant (constant welding power)
    • If the "P-constant" parameter is set, the welding power is kept constant regardless of the welding voltage and current. The result is a hyperbolic characteristic (6).
    • The "P-constant" parameter is particularly suitable for cellulose electrodes.
    Arc air gouging
    • Special characteristic for arc air gouging with a carbon electrode
      (for iWave 500 DC and iWave 500 AC/DC only)
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (7)
    (8)
    Possible current change with selected characteristic (5) or (6) depending on the welding voltage (arc length)
    (a)
    Operating point with high arc length
    (b)
    Operating point with set welding current IH
    (c)
    Operating point with low arc length
    The characteristics (4), (5) and (6) shown apply when using a stick electrode whose characteristic at a certain arc length corresponds to the working line (1).
    Depending on the set welding current (I), the intersection (operating point) of the characteristics (4), (5) and (6) is shifted along the working line (1). The operating point provides information about the current welding voltage and current welding current.
    With a fixed welding current (IH), the operating point can travel along the characteristics (4), (5) and (6) depending on the current welding voltage. The welding voltage U depends on the arc length.
    If the arc length changes, e.g., according to the working line (2), the operating point is the point where the corresponding characteristic (4), (5) or (6) intersect the working line (2).
    Applies to characteristics (5) and (6): Depending on the welding voltage (arc length), the welding current (I) is also lower or higher, with a constant value for IH.
    Anti-stick
    on / off
    Factory setting: on
    Break voltage
    Limitation of the welding voltage
    20 - 90 V
    Factory setting: 20 V
    In principle, the arc length depends on the welding voltage. To end the welding process, a significant lifting of the stick electrode is usually required. The parameter allows the welding voltage to be limited to a value, which permits the welding process to be ended by only slightly lifting the stick electrode.
    NOTE!
    If the welding process regularly comes to an unintentional end, set the break voltage parameter to a higher value.
    AC frequency
    Only for AC manual metal arc welding ("Polarity" welding parameter = AC)
    40 - 250 Hz
    Process parameters for CEL
    HotStart
    0.0 - 2.0 s
    .Advantages:
    Anti-stick
    on / off
    Factory setting: on
    Break voltage
    20 - 90 V
    NOTE!
    Arc air gouging (iWave 500 DC and iWave 500 AC/DC)
    Gouging (Arc Air Gouging)
    In arc air gouging, an arc is ignited between a carbon electrode and the workpiece; the base material is melted and blown out with compressed air.
    The operating parameters for arc air gouging are defined in a special characteristic.
    Applications:
    • Removal of shrink holes, pores, or slag inclusions from workpieces
    • Detaching sprues or the processing of entire workpiece surfaces in foundries
    • Edge preparation for heavy plates
    • Preparation and repair of weld seams
    • Finishing of roots or defects
    • Production of air gaps
    IMPORTANT! Arc air gouging is only possible with steel materials!
    2. Arc air gouging (iWave 500 DC and iWave 500 AC/DC)
    Applications:
    WARNING!
    WARNING!
    Preparation
    IMPORTANT! A grounding cable with a PowerConnector and a cable cross-section of 120 mm² is required for arc air gouging. For other return lead cables without a PowerConnector, the OPT/i TPS 2nd positive socket option must be installed on the welding machine.
    Furthermore, a Dinse PowerConnector adapter is required to connect the arc air gouging torch.
    3Remove the MIG/MAG welding torch
    4Insert the return lead cable into the (-) current socket and lock
    5Connect the other end of the grounding cable to the workpiece
    6Attach the Dinse PowerConnector adapter to the (+) current socket
    7Insert the bayonet connector of the arc air gouging torch into the (+) current socket and twist it clockwise to lock
    8Connect the compressed air connection of the arc air gouging torch to the compressed air supply
    Working pressure: 5 - 7 bar (constant)
    9Clamp the carbon electrode so that the electrode tip protrudes approx. 100 mm from the arc air gouging torch;
    the air outlet openings of the arc air gouging torch must be at the bottom
    10Insert the mains plug
    Arc air gouging
    CAUTION!
    When the power switch is switched to position - I -, the electrode in the arc air gouging torch is live.
    Ensure that the electrode is not touching anyone or any electrically conductive or grounded parts (housing, etc.)
    CAUTION!
    Risk of personal injury due to loud operating noise.
    Use suitable hearing protection during arc air gouging!
    2Under Process parameters / Common / TIG / Electrode setup, set the "Characteristic" parameter to "Gouging" (last entry)
    NOTE!
    The settings for break voltage and starting current time are ignored.
    3Select OK
    4Under Welding process / Process, select Electrode
    If the MMA welding process is selected, any cooling unit that is present is automatically deactivated. It is not possible to turn it on.
    NOTE!
    5Select "MMA welding"
    The arc air gouging parameters are displayed.
    6Set the main current depending on the electrode diameter as specified on the electrode packaging
    NOTE!
    At higher amperages, use both hands to guide the arc air gouging torch!
    Use a suitable welding helmet.
    7Open the compressed air valve on the arc air gouging torch handle
    8Initiate the gouging operation
    The contact angle of the carbon electrode and gouging speed determine the depth of an air gap.
    The parameters for arc air gouging correspond to the welding parameters for MMA welding, see page (→).
    Multiprocess PRO - MIG/MAG
    Multiprocess PRO
    General
    If the OPT/i TIG Multiprocess PRO option is installed on the welding machine, MIG/MAG welding processes are available without restriction in addition to TIG and MMA welding processes.
    Switching between the individual welding processes takes place either:
    • Using jobs
    • On the welding machine control panel,
      or
    • Using the torch trigger.
    1. Multiprocess PRO - MIG/MAG
    Multiprocess PRO
    General
    • Using jobs
      or
    2. Multiprocess PRO
    General
    • Using jobs
      or
    2. Multiprocess PRO
    System components
    A Multiprocess-PRO-compatible welding machine can be operated with all iWave system components and, for the MIG/MAG welding process, with all TPSi system components.
    Example:
    iWave 500i AC/DC
    + OPT/i TIG AC Multiprocess PRO
    + CU 1400i Pro/MC cooling unit
    + installation set for front water connection
    + dual head distributor
    + WF 25i MIG/MAG-wirefeeder
    + MHPi MIG/MAG welding torch
    + MHP CON interconnecting hosepack
    + CWF 25i TIG cold wire wirefeeder
    + SpeedNet control cable
    + cold-wire feed TIGi
    + TTB / THP TIG welding torch
    + electrode holder with welding power-lead
    + return lead cable
    + TU Car4 Pro trolley
    + OPT/TU extension cylinder holder TU Car4 Pro
    NOTE!
    For water-cooled welding systems, the coolant connections on the cooling unit must be doubled: 2x flow connections, and 2x return connections.
    The total hosepack length must not exceed 14 m / 45 feet 11 inches for Multiprocess welding systems.
    A Multiprocess-PRO welding system requires only one return lead cable.
    With iWave AC welding machines, the polarity is reversed automatically when the welding process is changed.
    IMPORTANT! For iWave DC welding machines, the return lead cable must be reconnected manually when changing processes.
    WARNING!
    Danger due to live wire electrode and current sockets!
    With Multiprocess-PRO machines, the wire electrode and current sockets of a connected MIG/MAG wirefeeder are live even during TIG operation!
    If touched this can result in serious personal injury and damage to property.
    Do not touch the wire electrode and current sockets.
    Ensure that the wire electrode and current sockets cannot be touched.
    Minimum equipment for MIG/MAG welding
    In addition to the iWave welding machine, the following components are required for MIG/MAG welding:
    • OPT/i TIG Multiprocess PRO
    • MIG/MAG wirefeeder
    • MHP CON MIG/MAG interconnecting hosepack
    • MTG MIG/MAG welding torch
    • Wire electrode
    • MIG/MAG shielding gas supply
    • Return lead cable
    Additionally required for CMT applications:
    • Standard, Pulse, and CMT Welding Packages enabled on the welding machine
    • CMT welding torch incl. CMT drive unit
    • CMT wire buffer
    • OPT/i PushPull installed in the MIG/MAG wirefeeder
    • CMT interconnecting hosepack
    Additionally required for water-cooled applications:
    • Cooling unit with double coolant connections
    The TIG components can remain connected to the welding machine during MIG/MAG welding.
    2. Minimum equipment for MIG/MAG welding
    • Wire electrode
    • Return lead cable
    • CMT wire buffer
    MIG/MAG pulse synergic welding
    MIG/MAG pulse synergic welding is a pulsed arc process with a controlled material transfer.
    In the base current phase, the energy input is reduced to such an extent that the arc barely burns steadily and the surface of the workpiece is preheated. In the pulsing current phase, an accurately timed current pulse guarantees a precise detachment of the weld material droplet.
    This principle guarantees low-spatter welding and precise operation throughout the entire power range.
    2. MIG/MAG welding processes
    MIG/MAG standard synergic welding is a MIG/MAG welding process covering the entire power range of the welding machine with the following arc types:
    Dip transfer arc
    Droplet transfer occurs in the lower power range during the short circuit.
    Intermediate arc
    The intermediate arc alternates irregularly between short circuits and spray transfers. This results in increased spatters. It is not possible to use this arc effectively, so it is better to avoid it.
    Spray arc.
    A short-circuit-free transfer of material in the high power range.
    PMC process
    PMC = Pulse Multi Control
    PMC is a pulsed arc welding process with fast data processing, precise process condition detection, and improved droplet detachment. Faster welding with a stable arc and uniform penetration is possible.
    LSC process
    LSC = Low Spatter Control
    LSC is a low-spatter dip transfer arc process. Before the short-circuit bridge is broken, the current is lowered and reignition occurs at significantly lower welding current values.
    SynchroPulse welding
    SynchroPulse is available for all process (Standard / Pulse / LSC / PMC).
    The cyclic change of the welding power between two operating points with SynchroPulse achieves a finely rippled weld appearance and a non-continuous heat input.
    CMT process
    CMT = Cold Metal Transfer
    A special CMT drive unit is required for the CMT process.
    The reversing wire movement in the CMT process results in droplet detachment with improved dip transfer arc properties.
    The advantages of the CMT process are:
    • Low heat input
    • Reduced spattering
    • Emissions reduction
    • High process stability
    The CMT process is suitable for:
    • Joint welding, overlay welding, and brazing, specifically with high demands in terms of heat input and process stability
    • Light gauge sheet welding with low distortion
    • Special joints, e.g., copper, zinc, steel/aluminum
    NOTE!
    A CMT reference book with sample applications is available,
    ISBN 978-3-8111-6879-4.
    CMT Cycle Step welding process
    CMT Cycle Step is a further development of the CMT welding process. It also requires a special CMT drive unit.
    CMT Cycle Step is the welding process with the lowest heat input.
    The CMT Cycle Step welding process alternates cyclically between CMT welding and pauses of an adjustable duration.
    The welding pauses mean there is less heat input, while the continuity of the weld is maintained.
    Individual CMT cycles are also possible. The size of the CMT welding spots is determined by the number of CMT cycles.
    SlagHammer
    The SlagHammer function is implemented in all steel characteristics.
    In conjunction with a CMT drive unit WF 60i CMT, slag is knocked off the weld seam and wire electrode end by a reversing wire movement without arc before welding.
    Knocking off the slag ensures reliable and precise ignition of the arc.
    A wire buffer is not required for the SlagHammer function.
    The SlagHammer function is automatically executed if a CMT drive unit is present in the welding system.
    An active SlagHammer function is displayed in the status bar below the SFI icon.
    Stitch welding
    With stitch welding, all welding processes can be interrupted cyclically. As such, the heat input is controlled in a targeted manner.
    The welding time, pause time and the number of interval cycles can be set individually (e.g. for producing a rippled weld seam, for tacking thin sheets or, in the case of longer pause times, for simple, automatic spot welding operation).
    Stitch welding is possible with every operating mode.
    In special 2-step mode and special 4-step mode, no interval cycles are executed during the start and end phases. The interval cycles are only executed in the main process phase.
    WireSense
    WireSense is an assistance process for automated applications in which the wire electrode acts as a sensor.
    The wire electrode can be used to check the component position before each weld, real sheet edge heights and their position are reliably detected.
    Advantages:
    • Respond to real component deviations
    • No re-teaching means time and cost savings
    • No calibration of TCP and sensor necessary
    WireSense requires CMT hardware:
    WF 60i Robacta Drive CMT, SB 500i R with wire buffer or SB 60i R, WFi REEL unreeling device
    The CMT Welding Package is not required for WireSense.
    ConstantWire
    ConstantWire is used in laser brazing and other laser welding applications.
    The welding wire is fed to the soldering or weld pool, ignition of an arc is prevented by controlling the wire speed.
    Applications in constant current (CC) and constant voltage (CV) operation are possible.
    The welding wire can be fed either energized for hot wire applications or de-energized for cold wire applications.
    MIG/MAG Welding Packages
    General
    The welding machines have a number of different Welding Packages, welding characteristics and welding processes so that the broadest range of materials can be effectively processed.
    2. MIG/MAG Welding Packages
    General
    Welding Packages
    The following Welding Packages are available for the iWave welding machines:
    Welding Package Standard
    4,066,012
    (enables MIG/MAG standard synergic welding)
    Welding Package Pulse
    4,066,013
    (enables MIG/MAG pulse-synergic welding)
    Welding Package LSC *
    4,066,014
    (enables the LSC process)
    Welding Package PMC **
    4,066,015
    (enables the PMC process)
    Welding Package CMT ***
    4,066,016
    (enables the CMT process)
    Welding Package ConstantWire
    4,066,019
    (enables constant current or constant voltage operation during brazing)
    only in combination with Welding Package Standard
    only in combination with Welding Package Pulse
    only in combination with Welding Package Standard and Welding Package Pulse
    IMPORTANT! On a welding machine without any Welding Packages, only MIG/MAG standard manual welding is available.
    MIG/MAG welding characteristics
    Welding characteristics
    Depending on the welding process and shielding gas combination, various process-optimized welding characteristics are available when selecting the filler metal.
    Examples of welding characteristics:
    • MIG/MAG 3700 PMC Steel 1,0mm M21 - arc blow *
    • MIG/MAG 3450 PMC Steel 1,0mm M21 - dynamic *
    • MIG/MAG 3044 Puls AlMg5 1.2 mm I1 - universal *
    • MIG/MAG 2684 Standard Steel 0.9 mm M22 - root *
    The welding process suffix (*) provides information about special properties and the use of the welding characteristic.
    The characteristics are described as follows:
    Name
    Process
    Properties
    AC additive 1)
    PMC, CMT
    Bead to bead welding characteristic for adaptive structures
    The characteristic changes polarity cyclically to keep heat input low and achieve more stability with a higher deposition rate.
    AC heat control 1)
    PMC, CMT
    The characteristic curve changes polarity cyclically to keep the heat input into the component low. The heat input into the component can be additionally controlled by appropriate correction parameters.
    AC universal 1)
    PMC, CMT
    The characteristic changes polarity cyclically to keep the heat input into the component low and is highly suitable for all common welding tasks.
    additive
    CMT
    Characteristics with reduced heat input and more stability with higher deposition rate for bead to bead welding of adaptive structures
    ADV 2)
    CMT
    Also required:
    Inverter module for an alternating current process
    Negatively poled process phase with less heat input and higher deposition rate
    ADV 2)
    LSC
    Also required:
    Electronic switch for current interruption
    Maximum current reduction by opening the circuit in any desired process phase
    only in conjunction with TPS 400i LSC ADV
    ADV braze
    CMT
    Characteristics for brazing processes (reliable wetting and good flow of braze material).
    Minimal welding spatter is produced in the dip transfer arc area. The characteristic is suitable for long hosepacks and return lead cables.
    arc blow
    PMC
    Characteristic for avoiding arc breaks due to arc blow.
    ADV root
    LSC Advanced
    Characteristics for root passes with powerful arc.
    ADV universal
    LSC Advanced
    Characteristic for all common welding tasks, with minimal welding spatter in the dip transfer arc area. The characteristic is suitable for long hosepacks and return lead cables.
    arcing
    Standard
    Characteristics for a special form of hardfacing on dry and wet substrates
    (e.g., on crushing rollers in the sugar and ethanol industries)
    base
    Standard
    braze
    CMT, LSC, PMC
    Characteristic for brazing processes (reliable wetting and good flow of braze material)
    braze+
    CMT
    Characteristic for brazing processes with the special Braze+ gas nozzle and high brazing speed (gas nozzle with narrow opening and high flow rate)
    CC/CV
    CC/CV
    Constant current or constant voltage characteristic for power supply operation of the welding machine, a wirefeeder is not required.
    cladding
    CMT, LSC, PMC
    Characteristics for overlay welding with low penetration, low dilution, and wide weld seam flow for improved wetting
    constant current
    PMC
    Constant current characteristic
    For applications where no arc length control is required (no compensation adjustment for stick out changes)
    CW additive
    PMC, ConstantWire
    Characteristic with constant wire speed curve for the additive manufacturing process
    With this characteristic, no arc is ignited, the welding wire is only fed as filler metal.
    dynamic
    CMT, PMC, Puls, Standard
    Characteristic for deep penetration and reliable root formation at high welding speeds
    dynamic +
    PMC
    Characteristic with short arc length for high welding speeds with arc length control irrespective of the material surface.
    edge
    CMT
    Characteristic for welding corner seams with targeted energy input and high welding speed
    flanged edge
    CMT
    Characteristic for welding flange welds with targeted energy input and high welding speed
    galvanized
    CMT, LSC, PMC, Puls, Standard
    Characteristics for galvanized sheet surfaces (low risk of zinc pores and reduced penetration)
    galvannealed
    PMC
    Characteristics for iron-zinc coated material surfaces
    gap bridging
    CMT, PMC
    Characteristic for best gap-bridging ability due to very low heat input
    hotspot
    CMT
    Characteristic with hot start sequence, especially for plug welds and MIG/MAG spot welds
    mix 2) / 3)
    PMC
    Also required:
    Pulse and PMC Welding Packages
    Characteristic for the generation of a rippled weld seam.
    The heat input into the component is specifically controlled by the cyclic process change between pulse and dip transfer arc.
    LH fillet weld
    PMC
    Characteristics for LaserHybrid fillet weld applications
    (laser + MIG/MAG process)
    LH flange weld
    PMC
    Characteristics for LaserHybrid corner weld applications
    LH Inductance
    PMC
    Characteristics for LaserHybrid applications with high welding circuit inductance
    LH lap joint
    PMC, CMT
    Characteristics for LaserHybrid lap joint applications
    marking
    Characteristics for marking conductive surfaces
    Characteristic for marking electrically conductive surfaces.
    Marking is performed by low power spark erosion and reversing wire movement.
    mix 2) / 3)
    CMT
    Additionally required:
    CMT drive unit WF 60i Robacta Drive CMT
    Pulse, Standard and CMT Welding Packages
    Characteristic for creating a rippled weld seam.
    The heat input into the component is specifically controlled by the cyclic process change between pulsed arc and CMT.
    mix drive 2)
    PMC
    PushPull drive unit WF 25i Robacta Drive or WF 60i Robacta Drive CMT
    Characteristic for producing a rippled weld seam by cyclic process interruption of the pulse arc and an additional wire movement
    multi arc
    PMC
    Characteristic for components being welded by multiple interacting arcs. Well suited for increased welding circuit inductance or mutual welding circuit coupling.
    open root
    LSC, CMT
    Characteristic with powerful arc, especially suitable for root pass with air gap
    PCS 3)
    PMC
    The characteristic changes directly from the pulsed arc to a concentrated spray arc above a certain power. The advantages of pulsed and spray arcs are combined in one characteristic.
    PCS mix
    PMC
    The characteristic changes cyclically between a pulsed or spray arc and a dip transfer arc, depending on the power range. It is especially suitable for vertical-up seams due to the alternating hot and cold supporting process phase.
    pin
    CMT
    Characteristic for welding wire pins to an electrically conductive surface
    The path transition of the wire electrode and the set current curve progression define the appearance of the pin.
    pin picture
    CMT
    Characteristic for welding wire pins with spherical ends onto an electrically conductive surface, especially for creating pin pictures.
    pin print
    CMT
    Characteristic for writing texts, patterns or markings on electrically conductive component surfaces
    Writing takes place by placing individual dots the size of a welding droplet.
    pin spike
    CMT
    Characteristic for welding wire pins with pointed ends onto an electrically conductive surface.
    pipe
    PMC, Puls, Standard
    Characteristics for pipe applications and positional welding on narrow gap applications
    pipe cladding
    PMC, CMT
    Characteristics for the overlay welding of outer pipe claddings with low penetration, low dilution, and wide seam flow
    retro
    CMT, Puls, PMC, Standard
    The characteristic has the same weld properties as the predecessor TransPuls Synergic (TPS) device series.
    ripple drive 2)
    PMC
    Characteristic for producing a rippled weld seam by a cyclic process interruption of the pulsed arc and an additional wire movement.
    The seam rippling is similar to that of TIG welds.
    root
    CMT, LSC, Standard
    seam track
    PMC, Puls
    Characteristic with amplified current control, especially suitable for the use of a seam tracking system with external current measurement.
    TIME
    PMC
    Characteristic curve for welding with very long electrode extension and TIME shielding gases to increase the deposition rate.
    (TIME = Transferred Ionized Molten Energy)
    TWIN cladding
    PMC
    MIG/MAG tandem welding characteristics for overlay welding with low penetration, low dilution and wide weld flow for improved wetting.
    TWIN multi arc
    PMC
    MIG/MAG tandem characteristic for components being welded by multiple interacting arcs. Well suited for increased welding circuit inductance or mutual welding circuit coupling.
    TWIN PCS
    PMC
    The MIG/MAG tandem characteristic changes from the pulsed arc directly to a concentrated spray arc above a certain power. The two arcs are not synchronized.
    TWIN universal
    PMC, Puls, CMT
    MIG/MAG tandem characteristic for all common welding tasks, optimized for the mutual magnetic interaction of the arcs. The two arcs are not synchronized.
    universal
    The characteristic is very well suited for all common welding tasks.
    weld+
    CMT
    Characteristics for welding with short electrode extension and the Braze+ gas nozzle (gas nozzle with small orifice and high flow rate)
    1)
    Only in conjunction with iWave AC/DC MultiProcess welding machines
    2)
    Welding characteristics with special properties due to additional hardware
    3)
    Mixed process characteristics
    2. MIG/MAG welding characteristics
    link_horizontalLink copied
    Name
    Process
    Properties
    AC additive 1)
    PMC, CMT
    AC heat control 1)
    PMC, CMT
    AC universal 1)
    PMC, CMT
    additive
    CMT
    ADV 2)
    CMT
    Also required:
    ADV 2)
    LSC
    Also required:
    ADV braze
    CMT
    arc blow
    PMC
    ADV root
    LSC Advanced
    ADV universal
    LSC Advanced
    arcing
    Standard
    base
    Standard
    braze
    CMT, LSC, PMC
    braze+
    CMT
    CC/CV
    CC/CV
    cladding
    CMT, LSC, PMC
    constant current
    PMC
    CW additive
    PMC, ConstantWire
    dynamic
    dynamic +
    PMC
    edge
    CMT
    flanged edge
    CMT
    galvanized
    galvannealed
    PMC
    gap bridging
    CMT, PMC
    hotspot
    CMT
    mix 2) / 3)
    PMC
    Also required:
    LH fillet weld
    PMC
    LH flange weld
    PMC
    LH Inductance
    PMC
    LH lap joint
    PMC, CMT
    marking
    mix 2) / 3)
    CMT
    mix drive 2)
    PMC
    multi arc
    PMC
    open root
    LSC, CMT
    PCS 3)
    PMC
    PCS mix
    PMC
    pin
    CMT
    pin picture
    CMT
    pin print
    CMT
    pin spike
    CMT
    pipe
    PMC, Puls, Standard
    pipe cladding
    PMC, CMT
    retro
    ripple drive 2)
    PMC
    root
    CMT, LSC, Standard
    seam track
    PMC, Puls
    TIME
    PMC
    TWIN cladding
    PMC
    TWIN multi arc
    PMC
    TWIN PCS
    PMC
    TWIN universal
    PMC, Puls, CMT
    universal
    weld+
    CMT
    1)
    2)
    3)
    Status bar for MIG/MAG welding
    Status bar
    The status bar is divided into segments and contains the following information:
    (1)
    Currently set welding process
    (2)
    Currently set operating mode
    (3)
    Currently set welding program
    (material, shielding gas, characteristic, wire diameter)
    (4)
    Display process functions
    Arc length stabilizer
    Penetration stabilizer
    SynchroPulse
    Spatter Free Ignition, SlagHammer, SFI Hotstart
    CMT Cycle Step (only in conjunction with CMT welding process)
    Interval
    Symbol lights up green:
    Process function is active
    Symbol is gray:
    Process function is available but not used for welding
    (5)
    Bluetooth/WLAN status display (only on certified devices)
    • Symbol lights up blue:
      Active connection to a Bluetooth participant
    • Symbol is gray:
      Bluetooth participant detected, no active connection
    or
    Display intermediate arc
    (6)
    Only in TWIN mode:
    Welding machine number, LEAD / TRAIL / SINGLE
    Only in operation with a dual-head wirefeeder WF 25i Dual:
    currently selected welding process line
    When operating with a Velosystem:
    the Velostatus
    In Powersharing mode:
    With Teachen, Touchsensing, and WireSense:
    Teaching - active operation
    Teaching - contact with workpiece detected
    TouchSensing - active operation
    TouchSensing - contact with workpiece detected
    WireSense - active operation
    WireSense - edge detected
    (7)
    Currently logged in user (when user management is activated)
    or
    the key symbol when the welding machine is switched off
    (e.g., if profile/role "locked" is activated)
    (8)
    Time and date
    NOTE!
    The following functions can be selected and set directly in the status bar:
    (1) Welding process
    (2) Operating mode
    (3) Property of the welding characteristic (e.g., dynamic, root, universal, etc.)
    (4) SynchroPulse, Spatter Free Ignition, Interval, CMT Cycle Step, penetration stabilizer, arc length stabilizer
    Velo function
    Touch the desired function in the status bar and set it in the window that opens.
    For the welding curve characteristic (3) and for SynchroPulse, SFI, etc. (4), additional information can be called up via the respective buttons.
    2. Status bar for MIG/MAG welding
    Status bar
    (1)
    (2)
    (3)
    (4)
    SynchroPulse
    Interval
    Symbol is gray:
    (5)
    • Symbol is gray:
    or
    (6)
    Only in TWIN mode:
    the Velostatus
    (7)
    or
    (8)
    Time and date
    NOTE!
    (1) Welding process
    (2) Operating mode
    Velo function
    Status bar - current limit reached
    If the characteristic-dependent current limit is reached during MIG/MAG welding, a corresponding message is displayed in the status bar.
    1Select the status bar for detailed information
    The information is displayed.
    2Select "Hide information" to exit
    3Reduce wire speed, welding current, welding voltage or material thickness
    or
    increase distance between contact tip and workpiece
    For more information on the current limit, refer to the section Fault diagnosis / troubleshooting on page (→)
    MIG/MAG Operating Modes
    General
    WARNING!
    Danger due to incorrect operation.
    Do not use the functions described here until you have fully read and understood the operating instructions.
    Do not use the functions described here until you have fully read and understood all of the operating instructions of the system components, especially the safety rules.
    Follow the guidelines referring to setting, setting range, and units of measurement for the available parameters in the Setup menu.
    2. MIG/MAG Operating Modes
    General
    WARNING!
    Symbols and explanations
    Press the torch trigger | Hold the torch trigger | Release the torch trigger
    GPr
    Gas pre-flow time
    I-S
    Starting-current phase: rapid heating of the base material despite high heat dissipation at the start of welding
    t-S
    Starting current duration
    Starting arc length correction
    SL1
    Slope 1: continuous reduction of the starting current to the welding current
    I
    Welding current phase: even heat input into the base material whose temperature is raised by the advancing heat
    I-E
    Final current phase: to avoid local overheating of the base material caused by heat accumulation at the end of welding. This prevents possible sagging of the weld seam.
    t-E
    Final current duration
    End arc length correction
    SL2
    Slope 2: continuous reduction of the welding current to the final current
    GPo
    Gas post-flow
    SPt
    Spot welding time
    Detailed explanation of the parameters in the chapter Process parameters.
    2-step mode
    "2-step mode" is suitable for
    • Tacking work
    • Short weld seams
    • Automatic and robot operation
    4-step mode
    "4-step mode" is suitable for longer weld seams.
    Special 4-step mode
    "Special 4-step mode" is ideal for welding aluminum materials. The high thermal conductivity of aluminum is taken into account by the special welding current profile.
    Special 2-step mode
    "Special 2-step mode" is ideal for welding in higher power ranges. In special 2-step mode, the arc starts at a lower power, which makes it easier to stabilize.
    Spot welding
    The "Spot welding" mode is suitable for welded joints on overlapped sheets.
    Preparing for MIG/MAG welding
    WARNING!
    Secure all these devices and components so they cannot be switched back on.
    WARNING!
    Danger of electrical current due to electrically conductive dust in the device.
    Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
    2. Preparing for MIG/MAG welding
    WARNING!
    WARNING!
    Correct routing of the interconnecting hosepack
    CAUTION!
    Risk of damage to welding system components due to overheating caused by an incorrectly routed interconnecting hosepack.
    Do not form any loops when routing the interconnecting hosepack
    Do not cover the interconnecting hosepack
    Do not wind the interconnecting hosepack next to the gas cylinder and do not wrap it around the gas cylinder
    IMPORTANT!
    • The duty cycle values (ED) of the interconnecting hosepacks can only be achieved if the hosepacks are correctly routed.
    • If the routing of an interconnecting hosepack changes, carry out an R/L alignment (see page (→))!
    • Magnetically compensated interconnecting hosepacks enable routing changes to be made without changing the welding circuit inductance.
      Magnetically compensated interconnecting hosepacks are available from Fronius in lengths of 10 m and longer.
    Context
    The welding machine is built for TIG welding:
    • Cooling unit, welding machine, and trolley options are assembled on the trolley.
    • The TIG welding torch is connected to the welding machine and to the front of the cooling unit.
    • The return lead cable is connected to the welding machine.
    • The TIG shielding gas supply is connected to the welding machine.
    NOTE!
    The TIG components do not need to be terminated for MIG/MAG welding.
    Setting up MIG/MAG system components (overview)
    NOTE!
    For details on mounting or connecting the MIG/MAG components, refer to the Installation Instructions and Operating Instructions of the respective system components.
    1Switch off the welding machine, disconnect it from the grid, and secure it against being switched on again
    2Set up components required for MIG/MAG welding on the trolley (e.g., swivel pin holder, Duo gas cylinder holder, etc.)
    3Fix the strain-relief devices of the interconnecting hosepack to the trolley and to the wirefeeder
    4Connect the MIG/MAG wirefeeder to the welding machine using the interconnecting hosepack
    (current, SpeedNet, coolant)IMPORTANT! Observe the correct routing of the interconnecting hosepack!
    For details see from page (→).
    5Connect MIG/MAG shielding gas supply to wirefeeder
    When using gas cylinders:
    WARNING!
    Danger of severe injury and damage to property if gas cylinders fall over.
    Place gas cylinders on a solid, level surface so that they remain stable. Secure gas cylinders to prevent them from falling over.
    Observe the safety rules of the gas cylinder manufacturer.
    If the MIG/MAG gas cylinder is to be mounted on the trolley in addition to the TIG gas cylinder, the Duo gas cylinder holder option is required.
    6Connect MIG/MAG welding torch to wirefeeder
    7Insert feed rollers corresponding to the MIG/MAG application into the wirefeeder
    8Set up suitable wear parts for the MIG/MAG application on the welding torch
    9Insert wire spool or basket-type spool and its adapter into the wirefeeder
    10Establish the ground earth connection
    For iWave AC/DC welding machines, use the connected return lead cable.
    The welding machine automatically reverses the polarity of the return lead cable when the welding process is changed.
    For iWave DC welding machines, manually reconnect the return lead cable to the second current socket on the rear of the welding machine.
    IMPORTANT! For optimum weld properties, route the return lead cable as close as possible to the interconnecting hosepack.
    CAUTION!
    Impaired welding results due to a ground earth connection being shared by several welding machines!
    If several welding machines are all welding one component, a common ground earth connection can have a significant effect on the welding results.
    Disconnect welding circuits!
    Provide a separate ground earth connection for each welding circuit!
    Do not use a common return lead cable!
    Further details on the correct routing of the return lead cable from page (→).
    11Connect the welding machine to the grid and switch on
    12Feeding in the wire electrode
    13Setting the contact pressure
    14Adjust the brake
    15Perform R/L adjustment
    For details, see from page (→).
    MIG/MAG and CMT welding
    Danger due to incorrect operation and electric current
    WARNING!
    WARNING!
    Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
    2. MIG/MAG and CMT welding
    WARNING!
    WARNING!
    Setting the welding process and operating mode via the status bar
    1Select the symbol for the welding process in the status bar
    NOTE!
    Depending on the device type, equipment, and available WeldingPackages, the number and sequence of the welding processes displayed may vary.
    2Select the desired welding process
    3Select the symbol for the operating mode in the status bar
    An overview of the operating modes is displayed.
    NOTE!
    Depending on the device type, equipment, and available WeldingPackages, the number and sequence of the operating modes displayed may vary.
    4Select the desired operating mode
    Setting the welding process and operating mode via the menu bar
    The welding process and operating mode can alternatively be set via the menu bar.
    NOTE!
    1Select "Welding process"
    2Select "Process"
    3Select the desired welding process
    4Select "Mode"
    An overview of operating modes is displayed:
    • 2-step mode
    • 4-step mode
    • Special 2-step mode
    • Special 4-step mode
    • Spot welding
    5Select the desired operating mode
    Selecting the filler metal and shielding gas
    2Select "Filler metal"
    3Select "Change material settings"
    4Turn the selection dial and select the desired filler metal
    5Select "Next"/press the selection dial
    6Turn the selection dial and select the desired wire diameter
    7Select "Next"/press the selection dial
    8Turn the selection dial and select the desired shielding gas
    9Select "Next"/press the selection dial
    NOTE!
    The available characteristics for each process are not displayed if only one characteristic is available for the selected filler metal.
    The confirmation step of the filler metal wizard follows directly, steps 10 - 14 are omitted.
    10Turn the selection dial and select the desired process
    11Press the selection dial to select the desired characteristic (blue background)
    12Turn the selection dial and select the desired characteristic
    13Press the selection dial and accept the selected characteristic (white background)
    14Select "Next"
    The confirmation step of the filler metal wizard is displayed:
    15Select "Save"/press the selection dial
    The selected filler metal and associated characteristics for each process are saved.
    Setting the welding parameters
    1Select "Welding"
    2Turn the selection dial to select the desired welding parameter
    3Press the selection dial to change the parameter
    The value of the parameter is displayed as a horizontal scale, the parameter is illustrated by means of an animated graphic:
    e.g., parameter welding current
    The selected parameter can now be changed.
    4Change the parameter by turning the selection dial
    The new parameter value is applied immediately.
    If one of the wire feed speed, sheet thickness, welding current, or welding voltage parameters is changed during Synergic welding, all the other parameters are immediately modified accordingly.
    5Press the selection dial to access the welding parameters overview
    6If necessary, set the process parameters for user- or application-specific settings on the welding system
    NOTE!
    If there is a WF 25i Dual dual-head wirefeeder in the welding system, set the welding parameters and process parameters for both welding process lines separately.
    1Select the currently selected welding process line in the status bar
    2Set welding parameters and process parameters for both welding process lines
    Adjusting the quantity of shielding gas
    1Open the gas cylinder valve
    2Press the Gas-test button
    Gas flows out.
    The "Gas purging" dialog box appears on the display, indicating the remaining gas purging duration. If there is a gas regulator or gas sensor in the welding system, the actual gas value is also displayed.
    3Turn the adjusting screw on the bottom of the gas pressure regulator until the manometer displays the desired quantity of shielding gas
    4Press the Gas-test button
    The gas flow stops.
    MIG/MAG or CMT welding
    1Select "Welding" to display the welding parameters
    CAUTION!
    Danger due to emerging wire electrode.
    Personal injury may result.
    Hold the welding torch so that the tip of the welding torch points away from the face and body.
    Wear suitable protective goggles.
    Do not point the welding torch at people.
    Ensure that the wire electrode can only intentionally make contact with electrically conductive objects.
    2Press the torch trigger and start welding
    Each time at the end of welding, the welding data are saved depending on the setting; Hold or Mean is shown on the display (see also page (→)).
    NOTE!
    Under certain circumstances, it may not be possible to change the set welding parameters of a system component – such as a wirefeeder or remote control – on the control panel of the welding machine.
    Spot welding and stitch welding
    Spot welding
    Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
    1Select the desired welding process:
    • via the status bar / Operating mode - see from page(→), work step 3, onwards
      or
    • via the menu bar - see from page (→) onwards
    2Activate spot welding:
    1. Select the symbol for the operating mode in the status bar
    2. Select spot welding
      or
    1. Select Welding process / Operating mode / Spot welding
    3Select "Process parameters"
    4Select "Common"
    5Select "Spot welding"
    The spot welding time parameter is displayed.
    6Enter the desired value for the spot welding time: Press and turn the selection dial
    Setting range: 0.1 - 10.0 s
    Factory setting: 1.0 s
    7Apply value with OK
    NOTE!
    4-step mode is set by default for spot welding.
    Press torch trigger - the spot welding process runs until end of the spot welding time - pressing again stops spot welding prematurely
    The spot welding parameter can be changed to 2-step under Defaults / System / Setup mode
    (further information on 2-step and 4-step mode for spot welding can be found from page (→) onwards)
    8Select filler metal, wire diameter, and shielding gas
    9Open the gas cylinder valve
    10Adjust the shielding gas volume
    CAUTION!
    11Spot welding
    Procedure for creating a welding spot:
    1Keep the welding torch vertical
    2Press and release the torch trigger
    3Maintain the position of the welding torch
    4Wait for the gas post-flow time
    5Raise the welding torch
    NOTE!
    The selected weld start and weld end parameters are also active when spot welding.
    The weld start/weld end treatment for spot welding can thus be stored under Process parameters / Common MIG/MAG / Weld-Start/Weld-End.
    If final current time is active, the end of welding is not after the set spot welding time, but only after the set slope and final current times have elapsed.
    2. Spot welding and stitch welding
    Spot welding
      or
      or
    4Select "Common"
    NOTE!
    CAUTION!
    11Spot welding
    NOTE!
    Stitch welding
    • via the status bar - see from page (→)onwards
      or
    2Select the operating mode for stitch welding:
      or
    3Select the filler metal, wire diameter, and shielding gas
    4Set the desired welding parameters depending on the selected welding process
    5Activate stitch welding:
    1. Select the process functions display in the status bar
    2. Select interval
      or
    1. Under Process parameters / Common / Interval set the Interval parameter to "on"
      Stitch welding is activated, the Interval display lights up in the status bar.
    6Set the other parameters for stitch welding:
    Stitch welding time, interval pause time, interval cycles
    7Open the gas cylinder valve
    8Adjust the shielding gas volume
    CAUTION!
    9Stitch welding
    Procedure for stitch welding:
    2Depending on the set operating mode:
    Press and hold the torch trigger (2-step mode)
    Press and release the torch trigger (4-step mode)
    4Wait for the welding interval
    5Position the welding torch at the next point
    6To stop stitch welding, depending on the set operating mode:
    Release the torch trigger (2-step mode)
    7Wait for the gas post-flow time
    8Raise the welding torch
    Notes on stitch welding
    For PMC characteristics, the setting of the SFI parameter influences the re-ignition behavior in interval operation:
    SFI = on
    Re-ignition occurs with SFI.
    SFI = off
    Re-ignition takes place by means of touchdown ignition.
    For aluminum alloys, SFI is always used for pulse and PMC ignition. SFI ignition cannot be deactivated.
    If the SlagHammer function is stored on the selected characteristic, faster and more stable SFI ignition takes place in conjunction with a CMT drive unit and a wire buffer.
    MIG/MAG and CMT welding parameters
    Welding parameters for MIG/MAG pulse synergic welding and PMC welding
    For MIG/MAG pulse synergic welding and PMC welding, the following welding parameters can be set and displayed under "welding":
    Wire speed 1)
    Current 1) [A]
    -10 - +10
    Factory setting: 0
    NOTE!
    Pulse correction
    For correcting the pulse energy in the pulsed arc
    -10 – +10
    Factory setting: 0
    - ... lower droplet detachment force
    0 ... neutral droplet detachment force
    + ... increased droplet detachment force
    NOTE!
    (see page (→))
    2. MIG/MAG and CMT welding parameters
    Wire speed 1)
    Current 1) [A]
    -10 - +10
    Factory setting: 0
    NOTE!
    Pulse correction
    -10 – +10
    Factory setting: 0
    NOTE!
    (see page (→))
    Welding parameters for MIG/MAG standard manual welding
    For MIG/MAG standard manual welding, the following welding parameters can be set and displayed in the "Welding" menu item:
    Voltage 1) [V]
    Wire speed 1)
    To set a harder and more stable arc
    0.5 - max 2) m/min / 19.69 - max 2) ipm.
    Arc-force dynamic:
    For influencing the short-circuiting dynamic at the instant of droplet transfer
    0 - 10
    Factory setting: 1.5
    10 ... softer and low spatter arc
    Explanation of footnotes
    1)
    Synergic parameters
    If a synergic parameter is changed, all other synergic parameters are automatically set as well due to the synergic function.
    The actual setting range depends on the welding machine and wire speed, as well as which welding program was selected.
    2)
    The actual setting range depends on the selected welding program.
    3)
    The maximum value depends on the actual wire speed.
    MIG/MAG process parameters
    MIG/MAG process parameters:
    Weld-Start / Weld-End, Gas-Setup, Process control, Velo parameters, Synchropulse, Process mix, Process control additive welding, TWIN process control, CMT Cycle Step, AC setup, ConstantWire, Spot welding, Interval setup, Manual setup, R/L-check / alignment
    Process parameters for Components and Monitoring, see page (→).
    2. MIG/MAG process parameters
    Process parameters for weld start / weld end
    The following process parameters can be set and displayed for the start and end of welding:
    Special 2/4-step mode parameters
    Starting current
    To set the starting current for MIG/MAG welding (e.g., start of welding for aluminum)
    0 - 400  % (of the welding current)
    Factory setting: 135%
    Start arc length correction
    For correcting arc length at weld start
    -10 - -0.1 / auto / 0.0 - 10.0
    Factory setting: auto
    - ... shorter arc length
    0 ... neutral arc length
    + ... longer arc length
    auto:
    The value set in the welding parameters is adopted
    Starting current time
    For specifying how long the starting current is to be active 
    off / 0.1 - 10.0 s
    Factory setting: off
    Slope 1
    To set the time during which the starting current is reduced or increased to the welding current
    0.0 – 9.9 s
    Slope 2
    To set the time during which the welding current is reduced or increased to the final current.
    0.0 – 9.9 s
    Final current
    To set the final current in order to
    1. prevent a build-up of heat at the end of welding and
    2. fill the end-crater in the case of aluminum
    0 – 400% (of the welding current)
    Factory setting: 50%
    For correcting the arc length at the end of welding
    auto:
    Final current time
    For specifying how long the final current is to be active
    off / 0.1 - 10.0 s
    SFI parameter
    SFI
    to activate / deactivate the function SFI (Spatter Free Ignition of the arc)
    SFI causes an almost spatter-free ignition of the arc due to a controlled starting current curve with synchronized wire retraction movement.
    off/on
    NOTE!
    SFI is permanently integrated in certain welding processes and cannot be deactivated.
    If SH is displayed in the status bar for SFI, the SlagHammer function is active in addition to SFI.
    SFI and SH cannot be deactivated.
    SFI Hotstart
    To set a HotStart time in conjunction with SFI ignition
    During SFI ignition, a spray arc phase runs within the set HotStart time. This increases the heat input regardless of the operating mode and thus ensures a deeper penetration from the start of welding.
    off / 0.01 - 2.00 s
    Manual welding parameters
    Ignition current (manual)
    To set the ignition current for MIG/MAG standard manual welding
    100 - 550 A (iWave 300i)
    100 - 600 A (iWave 400i)
    100 - 650 A (iWave 500i)
    Factory setting: 500 A
    Wire retraction (manual)
    To set the wire retraction value (= combined value from wire retraction and a time) during MIG/MAG standard manual welding
    The wire retraction depends on the equipment on the welding torch.
    0.0 – 10.0
    Factory setting: 0.0
    Wire retraction
    Wire retraction
    0.0 – 10.0
    Process parameters for gas setup
    The following process parameters can be set and displayed for gas setup:
    Gas pre-flow  To set the gas flow time before the arc is ignited
    0 - 9.9  s
    Factory setting: 0.1 s
    Gas post-flow  To set the gas flow time after the arc has gone out
    0 - 60 s
    Factory setting: 0.5 s
    Gas factor
    Depends on the shielding gas used
    (only in conjunction with the OPT/i gas controller option)
    auto / 0.90 - 20.00
    (for standard gases from the Fronius welding database, the correction factor is set automatically)
    Gas set value
    Shielding gas flow rate
    (only in conjunction with OPT/i gas flow sensor option in the wirefeeder)
    off / auto / 0.5 - 30.0 l/min
    Factory setting: 15.0 l/min
    NOTE!
    To ensure the gas regulator is functioning correctly, the inlet pressure at the wirefeeder must be at least 4.5 bar / 65 psi when the set flow rate is maintained.
    In order to reach the minimum inlet pressure of 4.5 bar / 65 psi, remove existing flow regulators if necessary.
    Settings for gas set value "auto"
    When set to "auto", the gas set value automatically adjusts to the actual welding current within a set current range.
    Lower current
    To set the lower current range limit
    0 - max. A
    Factory setting: 50 A
    Gas set value at lower current
    0.5 - 30.0 l/min
    Factory setting: 8.0 l/min
    Upper current
    To set the upper current range limit
    0 - max. A
    Factory setting: 400 A
    Gas set value at upper current
    0.5 - 30.0 l/min
    Factory setting: 25.0 l/min
    In Job Mode, the values of the above parameters can be saved individually for each job.
    Process parameters for process control
    The following process parameters can be set and displayed for process control:
    • Penetration stabilizer
    • Arc length stabilizer
    • Combination of penetration stabilizer and arc length stabilizer
    The penetration stabilizer is used to set the max. permissible wire speed change in order to keep the welding current and thereby the penetration stable or constant with variable stickout.
    The penetration stabilizer parameter is only available if the WP PMC (Welding Process Pulse Multi Control) option or the WP LSC (Welding Process Low Spatter Control) option is enabled on the welding machine.
    auto / 0.0 – 10.0 m/min (ipm)
    Factory setting: 0 m/min
    auto
    A value of 10 m/min is stored for all characteristics, the penetration stabilizer is activated.
    0
    The penetration stabilizer is not activated.
    The wire speed remains constant.
    0.1 – 10.0
    The penetration stabilizer is activated.
    The welding current remains constant.
    Application examples
    Penetration stabilizer = 0 m/min (not activated)
    A change in the contact tube distance (h) causes a change in resistance in the welding circuit due to longer electrode extension (s2).
    The constant voltage control for constant arc length causes a reduction of the average current and thus a smaller penetration depth (x2).
    Penetration stabilizer = n m/min (activated)
    Value presetting for the penetration stabilizer causes a constant arc length without large current changes in the event of a stickout change (s1 ==> s2).
    The penetration (x1, x2) remains approximately the same and stable.
    Penetration stabilizer = 0.5 m/min (activated)
    In order to keep the change in welding current as low as possible during a stickout change (s1 ==> s3), the wire speed is increased or reduced by 0.5 m/min.
    In the example shown, the stabilizing effect is maintained up to the set value of 0.5 m/min (position 2) without any change in current.
    I ... Welding current vD  ... Wire speed
    The arc length stabilizer uses short-circuit control to force short arcs that are advantageous for welding and keeps them stable even with a variable electrode extension or in the event of external disturbances.
    The arc length stabilizer parameter is only available if the WP PMC (Welding Process Pulse Multi Control) option is enabled on the welding machine.
    0.0 / auto / 0.1 - 5.0 (action of the stabilizer)
    0.0
    The arc length stabilizer is deactivated.
    auto
    • For inert gases (100% Ar, He, etc.) a value = 0 is stored.
    • For the remaining materials / gas combinations, a characteristic-dependent value between 0.2 - 0.5 is stored.
    • From a wire speed of 16 m/min a value = 0 is stored
    0.1 - 5.0
    The arc length stabilizer is activated.
    The arc length is reduced until short circuits occur.
    NOTE!
    If the arc length stabilizer is activated, the normal arc length correction is only effective at weld start.
    The arc length correction is then no longer displayed in the welding parameters.
    Arc length stabilizer = 0 / 0.5 / 2.0
      Arc length stabilizer = 0.5
      Arc length stabilizer = 2
    Activating the arc length stabilizer reduces the arc length until short circuits occur. This allows the advantages of a short, stably controlled arc to be better exploited.
    Increasing the arc length stabilizer causes a further shortening of the arc length (L1 ==> L2 ==> L3). The advantages of a short, stably controlled arc can be better exploited.
    Arc length stabilizer for weld seam profile and position changes
    Arc length stabilizer not activated
    Weld seam profile or welding position changes can negatively influence the welding result
    Arc length stabilizer activated
    Since the number and duration of the short circuits are controlled, the properties of the arc remain the same when the weld seam profile or welding position is changed.
    I ... Welding current vD ... Wire speed U ... Welding voltage
    * ... Number of short circuits
    Example: Stick out change
    Arc length stabilizer without penetration stabilizer
    The advantages of a short arc are maintained even if the stick out is changed, since the short-circuit properties stay the same.
    Arc length stabiliser with penetration stabilizer
    If the stick out is changed with the penetration stabilizer activated, the penetration also stays the same.
    The short circuit behaviour is controlled by the arc length stabilizer.
    * ... Number of short circuits Δs ... Stick out change
    Process parameters for VELO
    The following process parameters can be set when welding with a Velosystem:
    Velo
    for activating / deactivating the Velo system
    off / on
    Welding speed "Velo"
    to set the welding speed for the Velo system
    10 - 300 cm/min
    Factory setting: 35 cm/min
    Wire retraction "Velo"
    for specifying how far the Velo welding wire is retracted from the welding point when welding is finished
    off / auto / 0.0 - 25.0 mm
    Process parameters for SynchroPulse
    The following process parameters can be set for SynchroPulse welding:
    (1) SynchroPulse
    To activate/deactivate SynchroPulse
    off / on
    Factory setting: on
    (2) Wire speed
    To set the average wire speed and therefore the welding power for SynchroPulse
    For example: 2 - 25 m/min (ipm)
    (Depending on wire speed and welding characteristic)
    Factory setting: 5.0 m/min
    (3) Delta wire feed
    To set the delta wire feed:
    With SynchroPulse, the set wire speed is alternately increased/decreased by the delta wire feed. The parameters concerned are modified accordingly to match the acceleration/deceleration of the wire speed.
    0.1 – 6.0 m/min / 5 – 235 ipm
    Factory setting: 2.0 m/min
    NOTE!
    The maximum adjustable delta wire feed of 6 m/min (235 ipm) is only possible up to a frequency of approx. 3 Hz.
    In the frequency range of 3 - 10 Hz, the adjustable delta wire feed decreases.
    (4) Frequency
    To set the SynchroPulse frequency
    0.5 - 10.0 Hz
    Factory setting: 3.0 Hz
    NOTE!
    In TWIN operation, the frequency setting on the lead welding machine also affects the trail welding machine.
    Adjusting the frequency on the trail welding machine has no effect.
    (5) Duty Cycle (high)
    For weighting the duration of the higher operating point in a SynchroPulse period
    10 – 90%
    Factory setting: 50 Hz
    NOTE!
    In TWIN operation, the Duty Cycle (high) setting on the lead welding machine also affects the trail welding machine.
    Setting the Duty Cycle (high) on the trail welding machine has no effect.
    (6) Arc correction high
    For correcting the arc length with SynchroPulse at the higher operating point (= average wire speed plus delta wire feed)
    -10.0 – +10.0
    - ... short arc
    0 ... uncorrected arc length
    + ... longer /arc
    NOTE!
    If SynchroPulse is activated, the normal arc length correction has no effect on the welding process.
    (7) Arc correction low,
    For correcting the arc length with SynchroPulse at the lower operating point (= average wire speed less delta wire feed)
    -10.0 – +10.0
    - ... short arc
    + ... longer /arc
    Example: SynchroPulse, duty cycle (high) = 25%
    Process parameters for Process Mix
    For mixing processes, the following process parameters can be set under Process Mix:
    Wire speed vD *Wire feed speed
    1.0 - 25.0 m/min / 40 - 985 ipm
    The wire speed value is taken from the welding parameters or can be specified and changed in the Process Mix parameters.
    Arc length correction
    -10.0 - +10.0
    The arc length correction value is taken from the welding parameters or can be specified and changed in the Process Mix parameters.
    Pulse correction
    For changing the pulse energy in the pulsed arc process phase
    -10.0 - +10.0
    The pulse correction value is taken from the welding parameters or can be specified and changed in the Process Mix parameters.
    Upper power time correction (3) *
    To set the duration of the hot process phase in a mixed process
    -10.0 - +10.0
    Factory setting: 0
    Upper and lower power time correction is used to define the relationship between the hot and cold process phases.
    If the upper power time correction is increased, the process frequency reduces and the PMC process phase becomes longer.
    If the lower power time correction is reduced, the process frequency increases and the PMC process phase becomes shorter.
    Lower power time correction (2) *
    To set the duration of the cold process phase in a mixed process
    -10.0 - +10.0 / 1 - 100 CMT cycles (for CMT mix characteristics)
    Factory setting: 0
    If the lower power time correction is increased, the process frequency reduces and the LSC process phase becomes longer or, in the case of CMT mix, the CMT process phase becomes longer.
    If the lower power time correction is reduced, the process frequency increases and the LSC process phase becomes shorter or, in the case of CMT mix, the CMT process phase becomes shorter.
    Lower power correction (1) *
    To set the energy input in the cold process phase in a mixed process
    -10.0 - +10.0
    Factory setting: 0
    If the lower power correction is increased, this results in a higher wire speed and therefore higher energy input in the cold LSC process phase or the cold CMT process phase.
    * Representation of the parameters in the following diagrams
    Mixed process between PMC and LSC welding process. A cold LSC process phase follows a hot PMC process phase as part of a cycle.
    Mixed process between PMC and wire movement reversal using a PushPull drive unit. A cold low power phase with calibration movement follows a hot PMC process phase.
    Mixed process between CMT and PMC welding process. Cold CMT process phases follow hot PMC process phases.
    (1)
    (2)
    (3)
    vD
    Wire speed
    Process parameters for additive welding process control
    Wire speed
    Wire feed speed
    1.0 – 30.0 m/min / 40 – 1181 ipm
    The wire speed value is taken from the welding parameters or can be specified and changed in the parameters for additive welding.
    -10.0 to +10.0
    Power correction
    to adjust the welding power at a constant wire speed to ensure a constant weld seam structure
    -10.0 - +10.0
    Factory setting: 0
    Arc-on time stabilizer
    on / 0.1 - 10.0 m/min / off
    Factory setting: on
    Arc-on time stabilizer dynamics
    auto / 10.0 - 0.0
    Process parameters for TWIN process control
    The process parameters for TWIN process control are only available in TWIN mode.
    Wire speed
    Wire feed speed
    The wire speed value is applied or can be specified and changed in the TWIN parameters.
    -10.0 - +10.0
    The arc length correction value is applied or can be specified and changed in the TWIN parameters.
    Pulse correction or dynamic correction
    (depending on the set welding process)
    • To change the pulse energy in the pulsed arc process phase
    • To set the short circuit current and the current to short-circuit breakup
    -10.0 - +10.0
    The pulse correction or the dynamic correction value is applied or can be specified and changed in the TWIN parameters.
    For details, see page (→)
    0.0 / auto / 0.1 - 10.0 m/min
    For details see page (→)
    auto / 0.0 / 10.0
    Factory setting: 0
    Pulse synchronization ratio
    To set widely differing lead and trail arc wire speeds
    auto, 1/1, 1/2, 1/3
    Lead/trail phase shift
    To set a time offset between lead droplet detachment and trail droplet detachment
    auto, 0 - 95%
    Trail ignition delay
    To set an ignition delay between the lead and trail arc
    auto / off / 0 - 2 s
    Process parameters for CMT Cycle Step
    CMT Cycle Step
    To activate / deactivate the function CMT Cycle Step
    On/Off
    Wire feed
    Wire speed, defines the deposition rate in the welding process phase and thus the size of the welding spot;
    Setting range: in m/min (ipm), depending on the welding characteristic
    The value for the wire speed is applied; it can also be specified or changed in the CMT Cycle Step parameters.
    Cycles (spot size)
    To set the number of CMT cycles (welding droplets) for a spot;
    The number of CMT cycles and the set wire speed define the size of the welding spot.
    1 - 2000
    Interval pause time
    To set the time between the individual welding spots
    0.01 - 2.00 s
    The higher the value for the interval pause time, the cooler the welding process (coarser rippling).
    Interval cycles
    To set the number of CMT cycle repetitions incl. pause until the end of welding
    Continuous / 1 - 2000
    Continuous
    The repetitions are continued continuously; end of welding e.g., via "Arc Off"
    Process parameters for AC setup
    AC power balance
    for adjusting the ratio of positive to negative cycle time in a process phase
    -10.0 - +10.0
    The AC power balance can be adjusted for PMC-AC characteristics and for CMT-AC characteristics for aluminum.
    AC cycles negative
    for setting the number of negative process cycles
    Negative process phases introduce less heat into the component.
    constant / auto / 1 - 100
    Factory setting: 10
    Negative process cycles can only be set for CMT-AC processes.
    AC cycles positive
    for setting the number of positive process cycles
    Positive process phases introduce more heat into the component.
    Factory setting: 10
    Positive process cycles can only be set for CMT-AC processes.
    Process parameters for ConstantWire
    Wirefeeder
    0.0 - max. m/min (depending on the wirefeeder used)
    Current
    0 - max. A (depending on the welding machine used)
    Voltage limitation
    auto / 1 - 50 V
    When set to auto, the voltage limitation is defined by the set characteristic.
    Contact stabilizer
    off / on
    If the welding wire unintentionally lifts out of the soldering/weld pool, the welding wire is speeded up in order to immediately re-establish contact.
    This stabilizes the soldering process and compensates for short-term processing faults.
    Ground earth connection
    yes / no
    Factory setting: yes
    When set to yes, the circuit is closed by a ground earth connection, e.g., for hot-wire applications and to enable enhanced process signals.
     Wire retraction
    Distance covered during the backward movement of the welding wire
    0.0 - 10.0
    Setting the distance covered during the backward movement of the welding wire prevents the wire being welded stuck at the end of the process.
    Process parameters for spot welding
    Spot welding time
    0.1 - 10.0  s
    Process parameters for interval
    Stitch
    To activate/deactivate stitch welding
    off/on
    Wirefeeder
    Stitch welding time
    0.01 – 9.9 s
    Factory setting: 0.3 s
    Stitch pause time
    off / 0.01 – 9.9 s
    Stitch cycles
    constant / 1 – 99
    Factory setting: constant
    Process parameters for manual setup
    Ignition current
    100 - 550 A (TPS 320i, TPS 320i C)
    100 - 600 A (TPS 400i)
    100 - 650 A (TPS 500i, TPS 600i)
    Wire retraction
    0.0 – 10.0
    Characteristic curve slope
    auto / U constant / 1000 – 8 A/V
    R/L alignment
    Align the welding circuit resistance (R) and inductance (L) if one of the following welding system components is changed:
    • Torch hosepacks
    • Interconnecting hosepacks
    • Return lead cables, welding power-leads
    • Wirefeeders
    • Welding torches, electrode holders
    • PushPull units
    Prerequisites for R/L alignment:
    The welding system must be complete: closed welding circuit with welding torch and torch hosepack, wirefeeders, grounding cable, interconnecting hosepacks.
    Perform R/L alignment:
    1Select Process parameters / Common / R/L-check / alignment
    The actual values for welding circuit inductance and welding circuit resistance are displayed.
    2Select "Next" / press selection dial / press torch trigger
    The second step of the R/L alignment wizard is displayed.
    3Follow the on-screen instructions
    IMPORTANT! Contact between the earthing clamp and the workpiece must be made on a cleaned workpiece surface.
    4Select "Next" / press selection dial / press torch trigger
    The third step of the R/L alignment wizard is displayed.
    5Follow the on-screen instructions
    6Select "Next" / press selection dial / press torch trigger
    The fourth step of the R/L alignment wizard is displayed.
    7Follow the on-screen instructions
    8Press torch trigger / select "Next" / press selection dial
    The actual values are displayed when the measurement is complete.
    9Select "End" / press selection dial
    Alternatively, the R/L alignment can also be performed via a JobMaster welding torch.
    Job Mode
    EasyJob mode
    General
    When EasyJob mode is activated, the display shows 5 additional buttons that enable fast saving of up to 5 operating points.
    The current welding-relevant settings are saved.
    If there is a robot interface in the welding system, the EasyJob buttons are not displayed, the EasyJob mode is grayed out and cannot be activated.
    1. Job Mode
    EasyJob mode
    General
    1. Job Mode
    2. EasyJob mode
    General
    1. Job Mode
    2. EasyJob mode
    Activating EasyJob mode
    1Select "Defaults"
    2Select "View"
    3Select "EasyJobs"
    The overview for activating/deactivating EasyJob mode is displayed.
    4Select "EasyJobs On"
    5Select "OK"
    EasyJob mode is activated, the defaults are displayed.
    6Select "Welding"
    The five EasyJob buttons are displayed with the welding parameters.
    1. Job Mode
    2. EasyJob mode
    Storing EasyJob operating points
    NOTE!
    The EasyJobs are stored under job numbers 1 - 5 and can also be retrieved via job mode.
    Storing an EasyJob overwrites a job stored under the same job number!
    1Touch one of the EasyJob buttons for approx. 3 seconds to store the current welding settings
    The button initially changes in size and color. After approx. 3 seconds, the button changes color again.
    The settings have now been stored.
    The most recently stored settings are enabled. An active EasyJob is displayed by a check mark on the EasyJob button.
    Unused EasyJob buttons are shown in dark gray.
    Example:
    EasyJobs 1 and 4 are occupied;
    EasyJobs 2, 3 and 5 are not occupied;
    EasyJob 1 is active
    1. Job Mode
    2. EasyJob mode
    Retrieving EasyJob operating points
    1To retrieve a stored EasyJob operating point, briefly touch the corresponding EasyJob button (< 3 seconds)
    The button briefly changes in size and color and is then displayed with a check mark:
    If no check mark is displayed after touching an EasyJob button, an operating point is not stored under this button.
    1. Job Mode
    2. EasyJob mode
    Deleting EasyJob operating points
    1To delete an EasyJob operating point, touch the corresponding EasyJob button for approx. 5 seconds
    The button
    • initially changes in size and color;
    • color changes again after approx. 3 seconds
      The stored operating point is overwritten with the current settings.
    • is highlighted in red after a total of approx. 5 seconds (= delete).
    The EasyJob operating point has been deleted.
    1. Job Mode
    2. EasyJob mode
    Loading more EasyJobs
    With this function, any saved job can be loaded as an EasyJob in the welding menu without switching to Job Mode.
    1Select Defaults / View / EasyJobs
    2"Select "Load more EasyJobs"
    3Select "OK"
    Advanced EasyJob mode is activated, the defaults are displayed.
    4Select "Welding"
    In the welding parameters, the "Load job" button is also displayed in the right menu bar.
    5Select "Load Job"
    The list of stored jobs is displayed.
    6Use the dial to select the desired job
    7Select "Load" or press the dial
    The job is loaded in the welding menu, the welding machine is not in Job Mode.
    1. Job Mode
    Job Mode
    General
    Up to 1000 jobs can be stored and reproduced on the welding machine.
    This eliminates the need to manually document the welding parameters.
    Job mode thereby increases the quality of automated and manual applications.
    Jobs can only be saved during welding mode. In addition to the current welding settings, the process parameters and certain machine defaults are also taken into account when saving jobs.
    1. Job Mode
    2. Job Mode
    General
    1. Job Mode
    2. Job Mode
    Saving settings as a job
    1Set the parameters to be saved as a job:
    • Welding parameters
    • Welding process
    • Process parameters
    • Machine defaults, if applicable
    2Select "Save as Job"
    The list of jobs is displayed.
    To overwrite an existing job, select the job by turning and pressing the selection dial (or select "Next page").
    After a prompt appears, the selected job can be overwritten.
    For a new job, select "Create a new Job"
    3Press the selection dial/select "Next page"
    The next free job number is displayed.
    4Turn the selection dial and select the desired storage location
    5Press the selection dial/select "Next page"
    The keyboard is displayed.
    6Enter a job name
    7Select "OK" and confirm the job name/press the selection dial
    The name is applied and confirmation that the job has been saved is displayed.
    8Select "Exit" to exit/press the selection dial
    1. Job Mode
    2. Job Mode
    Welding job - retrieving jobs
    NOTE!
    Before retrieving a job, ensure that the welding system is set up and installed according to the job in question.
    2Select "Process"
    3Select "JOB"
    Alternatively, the welding process can also be selected via the status bar (compare with the selection method described from page (→)).
    Job mode is activated.
    "Welding job" and the data for the last job retrieved are displayed.
    4Select "Welding job"
    5Turn the selection dial and select "Job number" (white background)
    6Press the selection dial to select the desired job (blue background)
    7Turn the selection dial and select the desired job number (blue background)
    The name of the selected job is displayed above the actual value display.
    8Press the selection dial and accept the selected job number (white background)
    9Initiate welding process
    IMPORTANT! In job mode, only the "Job number" welding parameter can be changed; the remaining welding parameters can only be viewed.
    1. Job Mode
    2. Job Mode
    Optimizing a job
    1Select "Process parameters"
    2Select "JOB"
    3Select "Optimize Job"
    The overview of the last optimized job is displayed.
    4Turn the selection dial and select either the job or the parameters of the job to be modified
    You can also select between job and job parameters by touching the "Job number/Job parameter" button.
    Select a job:
    • Press the selection dial
      The job number is highlighted in blue and can now be changed.
    • Turn the selection dial to select the job to be changed
    • Press the selection dial to change the job
    Select a job parameter:
    • Turn the selection dial and select the parameter to be changed
      The value of the parameter is highlighted in blue and can now be changed.
    • Turn the selection dial; the change of value is applied immediately
    • Press the selection dial to select other parameters
    5Select "Exit"
    1. Job Mode
    2. Job Mode
    Renaming a job
    1Select "Save as Job"
    (also works in job mode)
    2Turn the selection dial and select the job to be renamed
    3Select "Rename Job"
    4Use the keyboard to change the job name
    5Select "OK" and confirm the changed job name/press the selection dial
    The job name has been changed and the list of jobs is displayed.
    6Select "Cancel" to exit
    NOTE!
    As an alternative to the procedure described above, the job can also be renamed in the process parameters:
    Process parameters / Job / Optimize job / Rename job
    1. Job Mode
    2. Job Mode
    Deleting a job
    2Turn the selection dial and select the job to be deleted
    3Select "Delete Job"
    The prompt to delete the job is displayed.
    4Select "Yes" to delete the selected job
    The job has been deleted and the list of jobs is displayed.
    5Select "Cancel" to exit
    NOTE!
    As an alternative to the procedure described above, the job can also be deleted in the process parameters:
    Process parameters / Job / Optimize job / Delete job
    1. Job Mode
    2. Job Mode
    Loading a job
    Use the Load Job function to load the data for a stored job or EasyJob into the Welding area. The corresponding data for the job is displayed in the welding parameters and can be welded, modified or saved as a new job or EasyJob.
    2Turn the selection dial and select the job to be loaded
    3Select "Load Job"
    The Load Job information is displayed.
    4Select "Yes"
    The data for the selected job is loaded in the Welding area.
    The data for the loaded job can now be welded (no job mode), modified or saved as a new job or EasyJob.
    1. Job Mode
    2. Job Mode
    Job Mode with WF 25i Dual
    If a WF 25i Dual dual-head wirefeeder is in the welding system, the following parameters are also available:
    • Welding process line
      Process parameters / Job / Optimize job / Welding process parameters
    • Ignore welding process line
      Process parameters / Job / Pre-settings for "Save as job" / Dual-head wirefeeder
    The parameter assigns a welding process line to the job:
    The job can only be welded on welding process line 1.
    The job can only be welded on welding process line 2.
    ignore
    The job can be used by both welding process lines.
    The welding process line is selected using the torch trigger, status bar, keys on the WF Dual or remote control.
    Selecting a job automatically activates the associated welding process line.
    The job can be selected from both welding process lines.
    For jobs created on a firmware version < 4.0.0, the parameter is automatically set to "ignore" during a firmware update.
    If another robot dual-head option is in the system instead of the WF Dual in automated applications, the parameter is not available.
    The welding process line is selected via the robot interface.
    The parameter specifies which default value is used for the weld process line when creating a job.
    No
    The welding process line is taken from the currently active welding process line when a job is created (can be changed).
    Yes
    The welding process line is initially filled with "ignore" when a job is created (can be changed).
    The parameter is set to "No" by default; when a job is created, the currently active welding process line is always adopted.
    The parameter is not displayed for automated welding systems and has no effect.
    NOTE!
    A JobMaster welding torch is recommended for Job Mode with a WF 25i Dual.
    1. Job Mode
    Job process parameters
    JOB process parameters
    Process parameters for Components and Monitoring see page (→).
    1. Job Mode
    2. Job process parameters
    1. Job Mode
    Process parameters for Optimize Job
    The following process parameters can be set for Optimize Job:
    Working parameters
    Starting current
    [% of main current]
    see page (→)
    UpSlope [s]
    see page (→)
    Main current [A]
    see page (→)
    Drop current
    for 4-step mode
    [% of main current]
    see page (→)
    DownSlope
    [s]
    see page (→)
    Final current
    [% of main current]
    see page (→)
    AC Balance
    iWave AC/DC welding machines only
    see page (→)
    Electrode diameter
    [mm]
    see page (→)
    Welding process settings
    Polarity
    [DC-/AC]
    see page (→)
    TIG welding torch mode
    [2-step mode/4-step mode/spot welding]
    see page (→)
    TIG pulse settings
    Tacking
    [s]
    see page (→)
    Pulse frequency
    [Hz]
    see page (→)
    Base current
    [% of main current]
    see page (→)
    Duty cycle
    see page (→)
    Pulse waveform
    [rectangle/triangle/sine]
    see page (→)
    Base current waveform
    see page (→)
    TIG AC Settings
    (iWave AC/DC welding machines only)
    AC frequency
    [Hz]
    see page (→)
    AC current offset
    see page (→)
    Positive half-wave waveform
    see page (→)
    Negative half-wave waveform
    see page (→)
    Wire speed settings
    TIG wire correction
    -10 - 10
    Factory setting: 0
    Wire speed 1
    [m/min]
    see page (→)
    Wire speed 2
    see page (→)
    Start-up delay wire
    [s]
    see page (→)
    End delay wire
    [s]
    see page (→)
    Wire retraction end
    [mm]
    see page (→)
    Wire position Start
    [mm]
    see page (→)
    Feeder inching speed
    [m/min]
    see page (→)
    Ignition & operating mode settings
    HF ignition [on/off/Touch-HF/external]
    see page (→)
    HF ignition delay
    [s]
    see page (→)
    Reversed polarity ignition
    [off/on/auto]
    see page (→)
    Arc monitoring
    Ignition timeout
    [s]
    see page (→)
    Arc break filter time
    [s]
    see page (→)
    Arc break watchdog
    [ignore/error]
    see page (→)
    Drop current for 4-step mode
    [% of main current]
    see page (→)
    DownSlope
    [s]
    see page (→)
    Final current
    [% of main current]
    see page (→)
    AC Balance
    see page (→)
    Electrode diameter
    [mm]
    see page (→)
    Operating mode defaults
    Arc break voltage
    [V]
    see page (→)
    Comfort stop sensitivity
    [V]
    see page (→)
    TIG - General settings
    [s]
    see page (→)
    Final current time
    [s]
    see page (→)
    Drop current Slope 1
    [s]
    see page (→)
    Drop current Slope 2
    [s]
    see page (→)
    Spot welding time
    [s]
    see page (→)
    Gas pre-flow
    [s]
    see page (→)
    Gas post-flow
    [s]
    see page (→)
    Gas regulator 1
    Gas set value 1
    [l/min]
    see page (→)
    Gas factor 1
    see page (→)
    Gas regulator 2
    Gas set value 2
    [l/min]
    see page (→)
    Gas factor 2
    see page (→)
    Trailing gas regulator
    Trailing gas set value
    [l/min]
    see page (→)
    Trailing gas factor
    see page (→)
    TIG job correction limits
    Upper main current limit
    0 - 50%
    Factory setting: 0%
    Lower main current limit
    -50 - 0%
    Factory setting: 0%
    Job slope
    Defines the time between the currently selected job and the next job
    [s]
    0.0 - 10.0 s
    Factory setting: 0 s
    Documentation
    Sampling rate
    see page (→)
    CycleTIG
    CycleTIG activated
    see page (→)
    Interval time
    [s]
    see page (→)
    Interval pause time
    [s]
    see page (→)
    Interval cycles
    see page (→)
    Base current
    [A]
    see page (→)
    Plasma
    Plasma
    see page (→)
    Pilot current
    [A]
    see page (→)
    Plasma gas set value
    [l/min]
    see page (→)
    Plasma gas factor
    see page (→)
    Plasma gas pre-flow
    [s]
    see page (→)
    Plasma gas post-flow
    [s]
    see page (→)
    Plasma gas pre-flow/post-flow value
    [l/min]
    see page (→)
    Limit Monitoring
    Voltage setpoint
    [V]
    0.0 - 100.0 V
    Factory setting: 100.0 V
    Lower voltage limit
    [V]
    -10.0 - 0.0 V
    Factory setting: -1.0 V
    Upper voltage limit
    [V]
    0.0 - 10.0 V
    Factory setting: 1.0 V
    Maximum time of voltage deviation
    [s]
    off / 0.1-10.0 s
    Current setpoint
    [A]
    0.0 - 1000.0 A
    Factory setting: -
    Lower current limit
    [A]
    -100 - 0 A
    Factory setting: - 10 A
    Upper current limit
    [A]
    0 - 100 A
    Factory setting: 10 A
    Maximum time for current deviation[s]
    off / 0.1-10.0 s
    Wire speed setpoint
    [m/min]
    see page (→)
    Lower wire speed limit
    [m/min]
    -10.0 - 0.0 m/min
    Factory setting: -1.0 m/min
    Upper wire speed limit
    [m/min]
    0.0 - 10.0 m/min
    Factory setting: 1.0 m/min
    Maximum time of wire feed deviation
    [s]
    off / 0.1-10.0 s
    Welding time setpoint
    [s]
    0.0 - 999.9 s
    Factory setting: 5.0 s
    Lower welding time limit
    [s]
    -50.0 - 0.0 s
    Factory setting: -1.0 s
    Upper welding time limit
    [A]
    0.0 - 50.0 s
    Monitor welding time
    off/on
    Energy setpoint
    [kJ]
    0.0 - max. kJ
    Factory setting: 1.0 kJ
    Lower energy limit
    [kJ]
    -100.0 - 0.0 kJ
    Factory setting: 0.0 kJ
    Upper energy limit
    [kJ]
    0.0 - 100.0 kJ
    Monitor energy
    off/on
    Reaction if exceeded
    ignore/warning/error
    Factory setting: ignore
    1. Job Mode
    Setting correction limits for a job
    For each job, individual correction limits can be set for welding power and arc length.
    If correction limits are set for a job, the welding power and arc length of the job can be corrected within the specified limits.
    2Select "JOB"
    3Select "Correction limits"
    An overview of job correction limits for the most recently accessed job is displayed.
    4Turn the selection dial and select either the job or the limits of the job to be modified
    You can also select between job and job limits by tapping the "Job number/Job parameter" button.
    Select a job:
    • Press the dial to change the job
    Select job limits:
    • Turn the selection dial and select the desired limit group
    • Press the dial
      The selected limit group is opened.
    • Turn the dial and select the upper or lower limit
    • Press the dial
      The value of the limit parameter is highlighted in blue and can now be changed.
    • Press the dial to select other limit parameters
    5Select "Exit"
    1. Job Mode
    Pre-settings for "Save as Job"
    Under "Pre-settings for "Save as Job", you can set default values that are applied to each new job you create.
    2Select "JOB"
    3Select "Pre-settings for "Save as Job"
    4Confirm the displayed information
    The pre-settings for saving new jobs are displayed.
    5Turn the selection dial and select the desired parameter
    7Turn the selection dial and adjust the value
    9Select "Exit"
    Powersharing
    Powersharing
    Minimum equipment for Powersharing operation
    • Welding machine with OPT/i TIG Powersharing option
    • Second welding machine (of the same type)
    • Cooling unit
    • Return lead cable
    • Water-cooled welding torches
    • Shielding gas supply
    • Wirefeeder *
    • Interconnecting hosepack *
    • Wire electrode * or tungsten electrode
    • Powersharing cable
    • Power cable
    • 2 x grounding cable
    * for MIG/MAG applications only
    1. Powersharing
    Powersharing
    • Cooling unit
    • Return lead cable
    • Wirefeeder *
    • Power cable
    1. Powersharing
    2. Powersharing
    • Cooling unit
    • Return lead cable
    • Wirefeeder *
    • Power cable
    1. Powersharing
    2. Powersharing
    Prerequisites for Powersharing operation
    • Firmware version V.4.3.0 or above on both welding machines.
    • The OPT/i TIG PowerSharing option must be installed ON the main welding machine.
    • iWave 400i or 500i only
    • The welding machines must be the same, e.g.,
      2x iWave 400i DC
      or
      2x iWave 500i AC/DC
      or
      2x iWave 500i DC /MV/nc
    • The two welding machines must be connected to each other by means of a Powersharingcable.
    Schematic representation of the Powersharing connection:
    MAIN
    Main welding machine
    2nd
    2nd welding machine
    SMB
    Power stage set PC board
    MCU
    Control panel
    SCRAT
    PC board for OPT/i TPS 4x Switch SpeeedNet option
    WF
    Wirefeeder
    RI
    Robot interface
    PSC
    Powersharing cable
    1. Powersharing
    2. Powersharing
    Powersharing mode
    WARNING!
    Danger due to under-dimensioned system components.
    This may result in serious personal injury and damage to property.
    When assembling the system components, observe the maximum welding currents, duty cycles and any other limitations of the system components.
    The system components must be designed for Powersharing operation.
    1Set the power switch to - O -
    2Unplug the grid plug
    3Set up and connect the system components for Powersharing operation
    4Insert the grid plug
    5Set the power switch to - I -
    As soon as the two welding machines are connected by a Powersharingcable, the Powersharing symbol is displayed in the status bar of the Main welding machine:
    On the 2nd welding machine, the large Powersharing symbol is displayed in the welding parameters:
    During Powersharingoperation, the settings on the 2nd welding machine are ignored. The only settings that are relevant are those on the Main welding machine.
    6On the Main welding machine, activate the "Powersharing Main parameter under Defaults / System /Powersharing setup (check mark in the checkbox)
    7Select OK
    8On the 2nd welding machine, check that the "Powersharing Main parameter under Defaults / System /Powersharing setup is not active (NO check mark in the checkbox)
    9Select OK
    10Before starting welding on the Main welding machine, carry out an R/L alignment
    Details for the R/L alignment can be found on page (→).
    The welding machines are now ready for Powersharing operation.
    Process parameters
    Overview
    Overview
    Process parameters / Common TIG/MMA/CEL ... see page (→)
    Process parameters / Common MIG/MAG ... see page (→)
    Process parameters / Components & Monitoring ... see page (→)
    Process parameters / JOB ... see page (→)
    1. Process parameters
    Overview
    Overview
    2. Overview
    Overview
    Process parameters - Components & monitoring
    Process parameters - Components & Monitoring
    NOTE!
    Depending on the device type, equipment, and available WeldingPackages, the display and the sequence of the process parameters may vary.
    2. Process parameters - Components & monitoring
    NOTE!
    Process parameters for components
    Cooling unit
    Cooling unit operating mode
    For controlling a cooling unit
    eco / auto / on / off
    auto
    When welding starts, the cooling unit starts to operate (fan and coolant pump running).
    After the end of welding, the cooling unit continues to operate for 2 minutes. When the 2 minutes have elapsed, the cooling unit also switches off.
    on
    Continuous operation
    As soon as the welding machine is switched on, the cooling unit starts to operate (fan and coolant pump running continuously)
    off
    No operation, even when welding starts
    eco
    The coolant pump starts to operate when welding starts.
    The fan starts to operate from a coolant return temperature of 40 °C (104 °F) (only in conjunction with the flow temperature sensor option).
    When filling the torch hosepack, the coolant pump will run for 10 seconds as soon as the flow reaches > 0.7 l/min.
    After the end of welding, the cooling unit continues to operate for at least 15 seconds. As soon as the coolant return temperature reaches < 40 °C the cooling unit shuts down.
    The maximum after-run time is 2 minutes.
    Flow sensor filter time
    (only if the flow temperature sensor option is available on the cooling unit)
    To set the time from when the flow sensor is triggered until a warning message is output
    5 - 25 s
    Factory setting: 10 s
    Cooler flow warning limit
    If the parameter is activated, a warning is generated when the value entered is undershot.
    off / 0.75 / 0.8 / 0.85 / 0.9 / 0.95
    Wirefeeder
    To set the wire speed at which the wire electrode or welding wire is fed into the torch hosepack
    For example: 2 - 25 m/min / 20 - 3935 ipm
    (depending on wire speed)
    Factory setting: 10 m/min
    NOTE!
    The feeder inching speed can also be set in the window that opens when the wire threading key is pressed:
    Press the wire threading key
    Press and turn the dial to change the feeder inching speed value
    Select "Close" or press the dial to accept the value
    Welding machine
    Ignition timeout
    Length of wire that is fed before the safety cut-out trips
    off / 5 - 100 mm (0.2 - 3.94 in.)
    NOTE!
    The Ignition timeout process parameter is a safety function.
    At high wire speeds in particular, the length of wire fed until the safety cut-out trips can deviate from the set wire length.
    How it works:
    If the torch trigger is pressed, the gas pre-flow begins immediately. Wirefeeding and the ignition process then begin. If there is no current flow within the specified fed wire length, the system switches off automatically.
    Press the torch trigger again for a further attempt.
    Sense line
    To enable/disable the sense line function
    off / on
    Factory setting: on
    The sense line is additional hardware for direct voltage measurement on the workpiece. The function is used for correct determination of the actual value when several welding processes are welding simultaneously on one component and there is a risk of coupled interference voltages due to unfavorable hosepack routing or common grounding cables.
    Robot settings
    TouchSensing sensitivity
    For setting the sensitivity during TouchSensing in connection with the OPT/i WF gas nozzle position search option installed in the wirefeeder for different component surfaces and external interference
    Setting the TouchSensing sensitivity has no effect on the OPT/i Touch Sense Adv option.
    TouchSensing = Locating the seam position by means of applied sensor voltage during automated welding
    TouchSensing is performed via the gas nozzle or the wire electrode.
    TouchSensing by means of gas nozzle only works if:
    • the OPT/i WF gas nozzle position search option is installed in the robot wirefeeder,
      or
    • the OPT/i Touch Sense Adv. option is installed in the robot wirefeeder or welding machine.
    • With existing robot interface.
    0 - 10
    Factory setting: 1
    0
    for bare surfaces, long and dead short circuit, robust and immune to interference
    10
    for scaled surfaces, high measurement-related interference sensitivity
    Not suitable for welding with multiple welding machines on one component!
    Insulated surfaces cannot be detected.
    Procedure for determining TouchSensing sensitivity:
    • Start with the factory-set value 1
    • If no trigger signal is generated, increase TouchSensing sensitivity
    IMPORTANT! A higher TouchSensing sensitivity also increases the susceptibility to interference!
    Edge detection "WireSense"
    To activate / set edge detection using WireSense (option)
    off / 0.5 - 20.0 mm
    "WireSense" edge detection only works
    • On automated applications
    • If the OPT/i WireSense is present on the welding machine (software enable)
    • In combination with the CMT system components WF 60i Robacta Drive CMT, SB 500i R with wire buffer or SB 60i R and WFi Reel.
    WireSense is usually activated via a robot controller. As soon as a value > 0.5 mm is specified by the robot controller, the value set manually on the welding machine is overwritten.
    If the Ignition timeout parameter is activated, this also applies to WireSense.
    For higher-level robot controllers with a small signal range (e.g., linear trolleys), WireSense can be set manually on the welding machine.
    Example Economy-Image:
    • Start / Stop comes from the controller.
    • The edge height is specified on the welding machine.
    Draining/filling the torch hosepack
    link_horizontalLink copied
    Requirements for draining/filling the torch hosepack:
    • The OPT/i Torch Deflate option must be available on the cooling unit
    • Cooling unit operating mode = eco or auto
    • The welding machine must not be in welding mode.
    • The torch hosepack must not be filled at this time.
    • The torch body must be assembled.
    • The torch hosepack must be correctly connected.
    NOTE!
    When draining long hosepacks > 4 m, a fully filled coolant tank can overflow—risk of slipping!
    Observe the Operating Instructions and safety instructions for the cooling unit!
    Draining the torch hosepack
    1Select Process parameters / Components / Drain/fill torch hosepack
    2Follow the on-screen instructions
    3Select "Start" and follow the on-screen instructions
    or
    * Press the intermediate lowering button to stop the process
    3Press and hold the LED button on the welding torch
    4Press the Down (-) button and hold for 2 seconds
    If the coolant temperature is too high, a cooling phase is executed. During the cooling phase, the LED on the welding torch flashes approx. 2 x per second.
    The draining process is then started. The draining process takes approx. 30 seconds. During the draining process, the LED on the welding torch flashes approx. 1 x per second
    A confirmation is displayed after the draining process has been completed.
    The torch body can now be changed.
    If the torch hosepack is to be changed, the welding machine must be switched off first.
    IMPORTANT! Welding is not possible if the torch hosepack has been drained.
    Filling the torch hosepack
    1Press the gas-test button and follow the on-screen instructions
    or
    1Press and hold the LED button on the welding torch
    2Press the Down (-) button and hold for 2 seconds
    A confirmation is displayed after the filling process has been successfully completed.
    4Complete filling process by pressing OK
    System adjustment
    If two motors are being used in a welding system, they must be calibrated to maintain process stability.
    For welding systems with PushPull units or unreeling wirefeeders, a system adjustment must be carried out whenever the wirefeeders are installed or replaced.
    A corresponding message is displayed.
    1Select "OK" and start the system adjustment
    The System adjustment wizard is started.
    The system adjustment can also be started manually.
    Perform system adjustment:
    1Select Process parameters / Components & Monitoring / System adjust
    If a system adjustment is required, the System adjustment wizard is started. The first step of the System adjustment wizard is displayed:
    3To call up each step of the System adjustment wizard in sequence, select "Next page" / press the selection dial
    A confirmation message is displayed once the system adjustment has finished.
    4To exit the System adjustment wizard, select "Exit" / press the selection dial
    Arc break watchdog
    1Select Process parameters / Components & Monitoring / Arc break watchdog settings
    The "Arc break watchdog" overview is displayed.
    2Turn the dial and select the desired parameter
    3Press the dial (blue background)
    4Turn the dial and change the value of the parameter (blue background)
    Arc break reaction = ignorieren (deactivated):
    The welding machine remains in operation and no error message is displayed.
    Arc break reaction = Fehler (activated):
    If the arc breaks and there is no current flow within a set arc break time period, the system switches off automatically and an error message is displayed.
    Factory setting = ignorieren
    Arc break time = 0 - 2.00 s
    If the set time period is exceeded, an error is displayed.
    Factory setting = 0.2 s
    5Select "OK" to activate the arc break watchdog
    Wire stick contact tip
    1Select Process parameters / Components & Monitoring / Wire stick contact tip
    The "Wire stick contact tip - Setup menu" is displayed.
    2Turn the selection dial and select the desired parameter
    3Press the selection dial (blue background)
    4Turn the selection dial and change the value of the parameter (blue background)
    Wire stick on contact tip = ignore:
    Monitoring of a wire stick on the contact tip is deactivated.
    Wire stick on contact tip = Fehler (activated):
    If the wire is sticking to the contact tip, the welding process is interrupted.
    IMPORTANT! Monitoring is only possible with dip transfer arc processes.
    Filter time = 0.5 - 5.0 s
    Maximum period without arc short circuit until the welding process is interrupted.
    Factory setting = 0.5 s
    5Select "OK" to confirm the settings
    Wire stick workpiece
    1Select Process parameters / Components & Monitoring / Wire stick work piece
    The "Wire stick workpiece - Setup menu" is displayed.
    Wire stick on workpiece = ignorieren:
    Monitoring of a wire stick on the workpiece is deactivated.
    Wire stick on workpiece = Fehler (activated):
    If the wire is sticking to the workpiece, the welding process is interrupted.
    Welding circuit coupling
    This function can be used to measure the inductances present in the welding circuit.
    Inductances can lead to welding problems, for example when several systems are welding on one component.
    With the help of inductance measurement and appropriate cable management, welding problems can be promptly prevented when commissioning a welding system.
    Selecting the "Welding circuit coupling" button starts a corresponding wizard.
    1To measure the inductances in the welding circuit, follow the instructions in the wizard.
    Measurement results:
    Result
    Rcoupling
    (common ground)
    Kcoupling
    (inductive coupling)
    Very good
    0 mOhm
    0 %
    Good
    1 - 2.5 mOhm
    2 - 15%
    On average
    3 - 15 mOhm
    16 - 30%
    Poor
    16 - 100 mOhm
    31 - 100%
    The measurement results are stored in the logbook.
    Details on the welding circuit coupling are described in the operating instructions "Cable Management Guide" - 42,0426,0420,xx.
    The operating instructions are available as an HTML file at the following link:
    https://manuals.fronius.com/html/4204260420
    Wire end monitoring
    1Select Process parameters / Components & Monitoring / Wire end monitoring
    The "Wire end monitoring setup menu" overview is displayed.
    2Turn the selection dial and select the desired parameter depending on the existing wire end monitoring:
    (1)
    Wire end reaction for
    OPT/i WF R WE ring sensor
    4,100,878,CK
    (2)
    OPT/i WF R WE drum
    4,100,879,CK
    (3)
    OPT/i WF R wire end
    4,100,869,CK
    Reaction = Error:
    Wire end error, the welding process is interrupted immediately. The error is shown on the display.
    Reaction = After seam end:
    The wire end error is shown on the display once the current welding process is complete.
    Reaction = Ignore (deactivated):
    No reaction on wire end detection
    Factory setting = Error
    Gas monitoring
    The gas monitoring parameters are only available if the OPT/i gas flow sensor option is present on the wirefeeder or SplitBox.
    A lower gas flow limit can be defined for gas monitoring. If the gas flow drops below a specified level for a defined time, an error message is immediately displayed and the welding process stops.
    1Select Process parameters / Components & Monitoring / Gas monitoring
    The "Gas monitoring" overview is displayed.
    2Turn the selection dial and select the desired parameter:
    Lower gas flow limit
    Setting range: 0.5 - 30.0 l/min
    Factory setting: 7.0 l/min
    Maximum time of gas deviation
    Setting range: off / 0.1 - 10.0 s
    Factory setting: 2.0 s
    Sensor gas factor
    Setting range: auto / 0.90 - 20.00
    Overview of important gas factors:
    1.00 - C1 (CO2)
    1.52 - M21 ArC-18
    1.69 - M12 ArC-2.5
    1.72 - I1 (Argon)
    11.8 - I2 (Helium)
    NOTE!
    An incorrectly set gas factor can have a massive influence on the shielding gas quantity and thus on the welding result.
    Under the "auto" setting, all standard gases from the Fronius welding database are taken into account.
    Manual adjustment of the gas factor is only recommended for special gases and only after a discussion with Fronius.
    Motor force monitoring
    1Select Process parameters / Components & Monitoring / Motor force monitoring
    The "Motor force monitoring" overview is displayed.
    Wirefeed force monitoring
    Setting range:
    Ignore (no reaction)
    Warning (a warning is displayed)
    Error (welding process is interrupted, an error message is displayed)
    Factory setting: Ignore
    Maximum force
    Setting range: 0 - 999 N
    Factory setting: 0 N
    Maximum time of force deviation
    Factory setting: 3 s
    Wire buffer monitoring
    The parameters for wire buffer monitoring are available if there is a wire buffer in the welding system.
    1Select Process parameters / Components & Monitoring / Wire buffer monitoringIt is possible to set the reaction in case of an empty wire buffer:Error / After seam end / Ignore
    Factory setting: Error
    Error
    If the wire buffer is empty, welding is interrupted and an error message is displayed.
    After seam end
    An error message is displayed after current welding is complete, and starting further welding is prevented.
    Ignore
    No reaction when wire buffer is empty
    2Press and turn the dial and select the desired parameter
    3Select "OK" to confirm the settings
    Defaults
    Defaults
    General
    NOTE!
    Because of firmware updates, certain functions may be available for your device that are not described in these operating instructions or vice versa.
    In addition, individual figures may also differ slightly from the operating elements of your device. However, these operating elements function in exactly the same way.
    WARNING!
    Danger due to incorrect operation and work not carried out correctly.
    All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
    Read and understand all safety rules and user documentation for this equipment and all system components.
    1. Defaults
    Defaults
    General
    NOTE!
    WARNING!
    1. Defaults
    2. Defaults
    General
    NOTE!
    WARNING!
    1. Defaults
    2. Defaults
    Overview
    The "Defaults" contain the following options:
    • Display
    • System
    • Documentation
    • Management
    1. Defaults
    Defaults - View
    Defaults screen
    1. Defaults
    2. Defaults - View
    Defaults screen
    1. Defaults
    2. Defaults - View
    Selecting the language
    1Select Defaults / View / Language
    2Turn the selection dial and select the desired language
    3Select "OK"/press the selection dial
    1. Defaults
    2. Defaults - View
    Selecting units/standards
    1Select Defaults / View / Units/Standards
    2Select the desired unit
    3Select the desired standard:
    EN
    Designation of the filler metal according to European standards
    (e.g., AlMg 5, CuSi3, steel, etc.)
    AWS
    Designation of the filler metal according to specifications of the American Welding Standard
    (e.g., ER 5356, ER CuSi-A, ER 70 S-6, etc.)
    4Select the desired display of the welding data at the end of welding
    Hold
    The current actual values at the end of welding are displayed.
    Mean
    The average values over the entire main current phase are displayed.
    5Select OK
    The overview of units and standards is displayed.
    1. Defaults
    2. Defaults - View
    Setting the date and time
    The date and time can be assigned via NTP (Network Time Protocol) or set manually.
    1Select Defaults / View / Time & Date
    Setting the date and time via NTP
    A DNS server must be reachable or must be configured when manually setting the network parameters (see Setting network parameters manually, page (→)).
    2Turn the dial and select "Time & Date Automatic"
    3Enter the address of the local time server
    The address of the local time server can be obtained from your IT administrator or via the Internet (e.g., pool.ntb.org).
    4Enter the time zone
    The time zone must match the location of the welding machine.
    5Select "Time Server Test" to start time synchronization
    The time of the NTP server is synchronized with the welding machine. If NTP is set, the time is also synchronized after the welding machine is restarted, provided a connection to the time server can be established.
    6Select "Transfer"
    Setting the date and time manually
    To set the date and time manually, "Automatic date & time" must not be selected.
    2Turn the dial and select the desired parameter:
    Year/Month/Day/Hour/Minute
    (white background)
    3Press the dial to change the parameter (blue background)
    4Turn the dial and set the desired value (blue background)
    5Press the dial and apply the set value (white background)
    6Select "OK"/press the dial
    The View defaults are displayed.
    1. Defaults
    2. Defaults - View
    Retrieving system data
    1Select Defaults / View / System data
    The current system data is displayed.
    Real-time arc power in kW
    IP provides the correct average arc power as a result of the high measurement sampling rate for non-continuous welding processes.
    If the welding speed is known, the electrical energy per unit length can be calculated:
    E = IP / vs
    E
    Electrical energy per unit length in kJ/cm
    IP
    Arc power in kW
    vs
    Welding speed in cm/s
    Arc energy in kJ
    IE provides the correct total arc energy as a result of the high measurement sampling rate for non-continuous welding processes.
    Arc energy is the accumulated arc power over the entire welding time.
    If the weld length is known, the electrical energy per unit length can be calculated:
    E = IE / L
    E
    IE
    Arc energy in kJ
    L
    Length of weld in cm
    Arc energy is generally used in manual welding to calculate the energy per unit length.
    Current welding speed in cm/min
    Currently set job
    Current weld
    Duration of weld in s
    Present motor current in A, wirefeeder 1
    (wirefeeder closest to the arc)
    Present motor current in A, wirefeeder 2
    (e.g., the rear wirefeeder in a push/pull system)
    Present motor current in A, wirefeeder 3
    (e.g., an unreeling wirefeeder in a push/pull system with an unreeling wirefeeder)
    Present motor force in N, wirefeeder motor 1
    Present motor force in N, wirefeeder motor 2
    Present motor force in N, wirefeeder motor 3
    Present flow rate in l/min at the cooling unit
    (if OPT/i CU flow temperature sensor option is installed)
    Error output if the flow rate is < 0.7 l/min
    Present shielding gas flow
    (if OPT/i gas regulator option is available)
    Total shielding gas consumption
    Present coolant temperature in °C at the cooling unit
    Error output if the coolant temperature is > 70 °C
    (measured at coolant return)
    Arc time in h
    Total operating hours of the welding machine in h
    2Select "OK" to exit the system data
    1. Defaults
    2. Defaults - View
    Displaying characteristics
    1Select Defaults / View / Characteristic
    The options for displaying the characteristics are displayed.
    2Select the desired display option
    Show current characteristics:
    Only the current characteristics are displayed in the material settings.
    Show replaced characteristics:
    In addition to the current characteristics, replaced, older characteristics are also displayed in the material settings. These can also be selected while completing the material settings.
    3Select OK
    1. Defaults
    2. Defaults - View
    Parameter view TIG
    This function enables additional parameters or settings for the TIG welding parameters to be displayed.
    • Working parameters:
      AC Balance, electrode diameter
    • Welding process parameters:
      cap mode, polarity, TIG torch operating mode
    • TIG pulse settings:
      tacking, pulse frequency, base current, duty cycle, waveform pulse, waveform base current
    • AC settings:
      AC frequency, AC current offset, waveform positive half-wave, waveform negative half-wave
    • Ignition parameters:
      HF ignition, HF ignition delay, reversed polarity ignition
    • Operating mode - default settings:
      torch trigger, arc break voltage, comfort stop sensitivity
    • Start/end settings:
      starting current time, final current time
    • 4-step settings:
      lowering current slope 1, lowering current slope 2
    • Spot welding settings:
      spot welding time
    • Gas defaults:
      gas pre-flow, gas post-flow
    • Cycle TIG:
      CycleTIG activated, interval time, interval pause time, interval cycles, base current
    • Wirefeeder settings:
      wire speed 1/2, wire start-up delay, wire end delay, wire retract end, wire position start
    • Dynamic Wire:
      wire speed correction
    Expand parameter view:
    1Select Defaults / View / Parameter view TIG
    4Select "OK" to exit Parameter view TIG setup
    The parameter is displayed in the welding parameters, from where it can also be changed.
    1. Defaults
    2. Defaults - View
    Parameter view TIG iJob
    This function can be used to define the functions and parameters available on a TIG JobMaster welding torch.
      Job number, EasyJobs, starting current, UpSlope, lowering current, DownSlope, final current, AC balance, electrode diameter
      cap mode, polarity
    • AC settings:
      AC frequency, waveform positive half-wave, waveform negative half-wave
    • 4-step settings:
      spot welding time
    • CycleTIG:
    • Wire speed settings:
      Wire speed 1
    • Dynamic Wire:
      TIG wire correction
    Expand parameter view TIG iJob:
    1Select Defaults / View / Parameter view TIG iJob
    4Select "OK" to quit Parameter view iJob
    The parameter is displayed on the TIG JobMaster welding torch and can also be changed there.
    1. Defaults
    2. Defaults - View
    Parameter view MIG/MAG
    This function enables additional parameters or settings for the MIG/MAG welding parameters to be displayed.
    Working parameters
    Current, voltage, material thickness, power, arc length correction, pulse correction or dynamic correction
    VELO
    Velo, "Velo" welding speed, "Velo" wire retraction
    SFI parameters
    SFI, SFI Hotstart
    Process control
    Penetration stabilizer, arc length stabilizer
    SynchroPulse settings
    SynchroPulse, delta wirefeed, frequency, duty cycle (high), arc correction high, arc correction low
    Interval settings
    Interval, interval cycles, interval pause time, stitch welding time
    Process Mix
    Upper power time correction, lower power time correction, lower power correction
    CycleStep
    CMT cycle step, cycles (welding spot size), interval pause time, interval cycles
    AC settings
    AC power balance, AC cycles negative, AC cycles positive
    Start/end of welding settings
    Starting current, starting arc length correction, starting current time, slope 1, slope 2, final current, final arc length correction, final current time
    Spot welding time
    Gas defaults
    Gas set value, gas pre-flow, gas post-flow
    Pulse synchronization ratio, phase shift lead/trail, ignition delay trail
    Process control additive welding
    Power correction, deposition rates stabilizer, deposition rates stabilizer dynamics
    1Select Defaults / View / Parameter view MIG/MAG
    4Select "OK" to exit Parameter view MIG/MAG setup
    1. Defaults
    2. Defaults - View
    JobMaster MIG/MAG view
    This function can be used to define the functions and parameters available on a JobMaster welding torch.
    Working parameters
    Job number, EasyJobs, current, wire speed, voltage, material thickness, power, arc length correction, pulse correction or dynamic correction
    Process, characteristic property, welding torch operating mode
    VELO
    SFI parameters
    SFI, SFI Hotstart
    Process control
    Interval settings
    Process Mix
    Cycle Step
    AC settings
    Spot welding time
    Gas defaults
    General settings
    R/L alignment, wire forwards/back, gas test
    Setting JobMaster welding torch parameters:
    1Select Defaults / View / JobMaster MIG/MAG view
    4Select "OK" to quit the iJob parameter view
    The parameter is displayed on the JobMaster welding torch, from where it can also be changed.
    1. Defaults
    2. Defaults - View
    RC Panel TIG Favorite Parameters
    This function is used to define the favorite parameters that can be called up on the RC Panel TIG remote control.
    TIG - DC
    Tacking, pulse frequency*, base current, duty cycle, spot welding time, gas pre-flow, gas post-flow, pulse waveform, base current waveform, arc break voltage, comfort stop sensitivity
    TIG CW - DC
    Tacking, pulse frequency, base current, duty cycle, spot welding time, gas pre-flow, gas post-flow, pulse waveform, base current waveform, arc break voltage, comfort stop sensitivity, wire feed 1*
    TIG Dynamic Wire - DC
    Tacking, pulse frequency, base current, duty cycle, spot welding time, gas pre-flow, gas post-flow, pulse waveform, base current waveform, arc break voltage, comfort stop sensitivity, wire feed correction*
    TIG - AC
    AC frequency*, positive half-wave waveform, negative half-wave waveform, spot welding time, gas pre-flow, gas post-flow, arc break voltage, comfort stop sensitivity
    TIG CW _ AC
    AC frequency, positive half-wave waveform, negative half-wave waveform, spot welding time, gas pre-flow, gas post-flow, arc break voltage, comfort stop sensitivity, wire feed 1*
    TIG DynamicWire - AC
    AC frequency, positive half-wave waveform, negative half-wave waveform, spot welding time, gas pre-flow, gas post-flow, arc break voltage, comfort stop sensitivity, wire feed correction*
    CW
    = Cold Wire
    = Factory settings
    Define favorite parameters for the RC Panel TIG remote control:
    1Select Defaults / View / RC panel TIG Favorite Parameters
    2Turn the selection dial and select the desired process
    4Turn the selection dial and select the desired parameter
    6Select "OK" to quit Favorite Parameters
    1. Defaults
    Defaults - System
    Defaults - System
    NOTE!
    Depending on the device type, equipment, and available WeldingPackages, the display and the sequence of the system defaults may vary.
    1. Defaults
    2. Defaults - System
    Defaults - System
    NOTE!
    1. Defaults
    Retrieving device information
    1Select Defaults / System / Information
    The device information is displayed:
    serial number, image version, software version, IP address
    2Select "OK" to quit the device information
    1. Defaults
    Restoring factory settings
    1Select Defaults / System / Restore factory settings
    The confirmation prompt for the factory settings appears.
    2Select "Yes" to reset the values to their factory settings
    The process parameter and machine default values are reset to their factory settings and the overview of system defaults is displayed.
    1. Defaults
    Restoring the website password
    1Select Defaults / System / Website password
    The confirmation prompt for resetting the website password appears.
    2Select "Yes" to reset the website password to the factory setting
    The website password is reset to its factory setting.
    The overview of system defaults is displayed.
    Factory settings
    1. For devices shipped with firmware version ≥ 4.3.15:Username = admin
      Password = 20-digit number on the rating plate of the welding machine (Unique Password)
    2. For devices that were shipped with an earlier firmware version:
      Username = admin
      Password = admin
      For these earlier devices, the factory settings are always admin/admin, regardless of any firmware update.
    1. Defaults
    Setup mode
    1Select Defaults / System / Setup mode
    2Turn dial and select
    MIG/MAG welding torch setup
    or
    TIG welding torch setup
    5Press the selection dial to change the parameter
    6Press the selection dial to adjust the value of the parameter
    7Press the selection dial to apply the value
    8Select OK to accept the setting and to exit Setup mode
    Special 4-step = Guntrigger
    In conjunction with a JobMaster welding torch and with the special 4-step mode selected, this function enables the torch trigger to be used to switch between jobs during welding. Job switching takes place within defined job groups.
    A job group is defined by the next non-programmed job.
    Example:
    Job group 1: Job no. 3 / 4 / 5
    Job no. 6 is not occupied ==> End of job group1
    Job group 2: Job no. 7 / 8 / 9
    • When welding is started, the job with the lowest number within the job group is automatically selected.
    • Switching within a job group to the job with the next higher number is done by briefly pressing the torch trigger (< 0.5 seconds).
    • To end the welding process, press the torch trigger for more than 0.5 seconds.
    • To change to the next job group, press the parameter setting button on the Jobmaster welding torch for more than 5 seconds.
    Spot welding
    2-step = Spot welding in 2-step mode:
    The spot welding process runs while the torch trigger remains pressed and ends at the latest after the spot welding time has elapsed.
    Releasing the torch trigger stops the spot welding process before the spot welding time has elapsed.
    4-step = Spot welding in 4-step mode:
    The spot welding process starts when the torch trigger is pressed and ends at the latest when the spot welding time has elapsed.
    Pressing the torch trigger again stops the spot welding process before the spot welding time has elapsed.
    For more information about spot welding:
    • Page (→) (spot welding in general)
    • Page (→) (spot welding time)
    Special JobMaster display = on
    The following items can now be set and implemented on the Jobmaster welding torch:
    • Operating mode
    • SynchroPulse
    • Gas test
    NOTE!
    The parameter "special JobMaster display" is no longer available as of firmware version 4.0.0.
    The corresponding settings can be implemented as follows:
    (see page (→))
    Torch trigger job selection = on
    The function enables the torch trigger to be used to switch to the next job. Switching takes place within defined job groups.
    Example:
    • To switch to the next job group, briefly double-press the torch trigger
      (< 0.3 s, 2 x).
    Switching can take place when idle or during welding.
    Activate / deactivate cap mode via torch trigger
    Torch trigger I2 - cap mode = on:
    Cap mode can be activated by a long press of the torch trigger
    Torch trigger I2 - cap mode = off:
    Cap mode cannot be activated by a long press of the torch trigger.
    1. Defaults
    Service Connect
    Service Connect is a remote maintenance tool for fault diagnosis and troubleshooting, data analysis, and process optimization on the welding machine.
    After accepting the terms and conditions of use once directly on the control panel of the welding machine, a Fronius technician can remotely access the welding machine.
    Procedure when a problem arises on the welding machine for which remote diagnostics are requested from Fronius:
    1Select Defaults / System / Service Connect
    2Follow the displayed instructions and select "Next"
    The welding machine establishes a secure VPN connection to Fronius.
    Once the connection has been successfully established, a code is shown on the display and the green double arrow symbol appears in the status bar.
    3Pass this code on to Fronius by telephone
    4Select "Finish"
    Fronius support can begin.
    The remote operation carried out by the Fronius technician is recorded by Fronius using a video log.
    End remote operation:
    The prompt to disconnect the connection is displayed.
    2Select "Next"
    The connection is disconnected, the Fronius technician no longer has access to the welding machine.
    Confirmation of network disconnection is displayed, the double arrow symbol in the status bar disappears.
    1. Defaults
    Network settings
    The network settings contains the following entries:
    • Network
    • WLAN
    • Bluetooth setting
    • WeldCube Air
    • Client authorization
    • USB port
    1. Defaults
    1Select Defaults / System / Network Settings
    2Select "Network"
    The overview of network settings is displayed.
    If DHCP is activated, the IP Address, Network Mask and Default Gateway network parameters are grayed out and cannot be set.
    3Turn the selection dial and select DHCP
    4Press the selection dial
    DHCP is deactivated and the network parameters can now be set.
    5Turn the selection dial and select the desired network parameter
    The numeric keypad for the selected network parameter is displayed.
    7Enter a value for the network parameter
    8Select "OK" and confirm the value for the network parameter/press the selection dial
    The value for the network parameter is applied and the overview of network settings is displayed.
    9Select "Save" to apply the changes to the network settings
    1. Defaults
    Setting up WLAN
    1Select Defaults / System / Network settings
    2Select WLAN
    The overview of WLAN settings is displayed.
    Setting the country code
    1Select "Set Country Code"
    2Press the selection dial
    3Turn the selection dial and select the appropriate country
    4Select OK
    Activating WLAN
    1Select "Activate WLAN"
    When WLAN is activated, a check mark appears in the button, and the "Add Network" and "Delete Network" buttons are active.
    Adding a network
    1Select "Add Network"
    The available WLAN networks are displayed.
    2Turn the selection dial and select the desired WLAN network
    3Press the selection dial or select "Insert"
    4Enter data:
    • Activate DHCP
      or
    • Manual entry of IP address, network mask, default gateway, DNS server 1 and DNS server 2:
      Turn the selection dial and select the desired element,
      press the selection dial,
      enter the data using the numeric keypad,
      confirm by pressing "OK"
    5Select "OK" and add the WLAN network
    Deleting a network
    1Turn the selection dial and select the WLAN network you want to delete
    2Select "Delete Network"
    3Confirm the prompt
    The WLAN network is deleted.
    1. Defaults
    Bluetooth setup
    General
    Each Bluetooth device has its own MAC address. The MAC address allows the device to be assigned to a specific welding machine, thus preventing any mix-ups.
    The welding machine can communicate with the following Bluetooth devices:
    • RC Panel Basic /BT remote control
    • RC Pedal TIG /BT foot-operated remote control
    • Vizor Connect /BT welding helmet
    An active Bluetooth connection is indicated in the status bar of the display by a blue Bluetooth symbol.
    In the case of Bluetooth devices of the same type, only one device can be actively connected to the welding machine for safety reasons.
    Active Bluetooth connections to several Bluetooth devices of different types are possible.
    An existing, active Bluetooth connection cannot be interrupted or influenced by another Bluetooth device.
    Bluetooth remote controls have priority over wired remote controls or manual welding torches.
    If the connection between wired or Bluetooth remote controls and the welding machine is interrupted during the welding process, the welding process is terminated.
    Configuring the Bluetooth setup
    2Select "Bluetooth setting"
    The Bluetooth setup screen appears.
    Activating or deactivating the Bluetooth function on the welding machine
    • Select the "Activate Bluetooth" button
    Adding a Bluetooth device
    • Turn on the Bluetooth device
    • Select the "Add Device" button
      A list of all detected Bluetooth devices is displayed with their names, MAC addresses, and other info.
    • Use the dial to select the desired Bluetooth device
    • Compare the displayed MAC address with the MAC address on the device
      Select the "Add" button to establish an active connection to the selected device
    • Select the "Save" button
      The active connection is displayed under Info.
    Symbols displayed under Info:
    An active change can be made to the welding machine via the Bluetooth device.
    Depending on the availability of the data, additional information such as battery status, signal strength, etc. of the Bluetooth device is displayed.
    Paired
    A Bluetooth device has already been actively connected to a welding machine and appears in the list of Bluetooth devices.
    Inactive
    A new Bluetooth device was found or the Bluetooth device was removed by the user.
    Deleting a Bluetooth device
    • Use the dial to select the Bluetooth device to be deleted
    • Select the "Delete Device" button
    • Confirm the prompt to delete the device by pressing "OK"
    3Select "OK" to exit the Bluetooth setup
    1. Defaults
    WeldCube Air
    WeldCube Air is a cloud-based, centralized solution for recording welding data, process metrics, and other functionalities.
    WeldCube Air is provided as an online service.
    NOTE!
    Knowledge of the network environment is needed to set up WeldCube Air. Contact your IT department.
    Before establishing a connection to WeldCube Air:
    Enable the following ports and domains
    https://dps.prod.air.az.weldcube.com/ Port 443 (HTTPS)
    https://stpwwcpcprod001.blob.core.windows.net/ Port 443 (HTTPS)
    https://stpwwcashared.blob.core.windows.net/ Port 443 (HTTPS)
    Port 8883 (MQTT)
    Activate the time server
    Select Defaults / Display / Date & Time / Automatic Time & Date
    The maximum permitted time deviation when setting the time manually is 2 minutes.
    1Select Defaults / System / Network settings / WeldCube Air
    2Select "Enable WeldCube Air"
    3Grant permission for data transfer
    The device code and QR code are displayed:
    4Scan the QR code
    or
    open the website air.weldcube.com and select Add machine / Continue and enter the device code
    The welding machine is paired with WeldCube Air.
    Disabling WeldCube Air
    The welding machine remains paired with WeldCube Air, but no data is transferred.
    Unpairing the device
    The welding machine is disconnected from WeldCube Air—no data transfer takes place, the devices are not paired.
    For more information on WeldCube Air, see:
    https://www.weldcube.com
    1. Defaults
    Increased connection security
    To increase the connection security between WeldCube Premium and the welding system, an existing connection to WeldCube Premium can be confirmed under Client authorization.
    Confirm connection:
    1Select Defaults / System / Network settings / Client authorization
    The existing connections to WeldCube Premium are displayed with WeldCupe Premium ID, URL, and the connection security status.
    Status of the extended connection unknown
    Extended connection pending
    Extended connection permitted
    2Select the desired WeldCub Premium connection by turning the dial
    3Press the dial or select "OK"
    4Confirm the prompt
    1. Defaults
    USB port
    1Select Defaults / System / Network settings / USB port
    3Turn the selection dial to select the desired setting for the USB port on the control panel:
    off:
    No data exchange possible at the USB port
    limited:
    Licence-Key and Service-Dongle possible
    on:
    No restriction at the USB port
    4Press the dial or select "OK"
    The setting is applied.
    1. Defaults
    Welding machine configuration
    1Select Defaults / System / Welding machine configuration
    The welding machine configuration is displayed.
    2Turn the dial and select a configuration point
    3Press the dial
    4Enter the desired text using the keyboard (max. 20 characters)
    5Select "OK" to apply the text/press the dial
    The text is applied and the welding machine configuration is displayed.
    6Select "Save" to apply the changes
    1. Defaults
    Wirefeeder setup
    In the wirefeeder setup, potentiometers present on a wire feeder can be activated or deactivated.
    1Select Defaults / System / Wire feeder setup
    3Turn dial and activate or deactivate potentiometer
    4Select OK
    1. Defaults
    Interface setup
    The interface setup allows the user to define whether the welding parameters are specified externally by the robot controller or internally by the welding machine.
    1Select Defaults / System / Next page
    2Select Interface setup
    3Set the "Welding parameters" parameter to "External" or "Internal"
    External:
    All parameter settings are made via the robot controller (including the welding parameters).
    Internal:
    The welding parameter settings are made via the welding machine, the control signals run via the robot controller.
    Factory setting:
    External
    4Select OK
    1. Defaults
    TWIN Setup
    In TWIN Setup, welding lines 1 and 2 are assigned to the welding machines.
    1Switch on welding machine 2, leave welding machine 1 switched off
    2Place sticker 2 in a clearly visible location on welding machine 2
    3For welding machine 2, select Defaults / System / Next page
    4Select TWIN Setup
    5Change the parameter to 2, select Next
    6Switch on welding machine 1
    7Place sticker 1 in a clearly visible location on welding machine 1
    8For welding machine 1, select Defaults / System / Next page
    9Select TWIN Setup
    10Check that the parameter is set to 1
    1. Defaults
    Powersharing Setup
    The Main welding machine for the Powersharingprocess is defined in Powersharing Setup.
    1On the welding machine with the built-in OPT/i TIG PowerSharing option: Select
    Defaults / System /Powersharing Setup
    2To specify the main welding machine, activate the "Powersharing Main" parameter (check mark in the checkbox).
    Do not put a check mark in the checkbox for the second (2nd) welding machine.
    3Select "OK"
    1. Defaults
    Defaults - Documentation
    1. Defaults
    2. Defaults - Documentation
    1. Defaults
    Setting the sample rate
    1Select Defaults / Documentation / Basic settings
    3Turn the selection dial and change the sample rate value:
    off
    Sample rate is deactivated, only mean values are saved.
    0.1 - 100.0 s
    Documentation is saved at the set sample rate.
    4Select "OK" to apply the sample rate
    The documentation overview is displayed.
    1. Defaults
    Viewing the logbook
    1Select Defaults / Documentation / Logbook
    The logbook is displayed.
    The buttons can be used to display welds, events, errors, warnings or notifications.
    The following data is logged:
    (1)
    Number of the weld
    (2)
    Date (ddmmyy)
    (3)
    Time (hhmmss)
    (4)
    Duration of welding in s
    (5)
    Welding current in A (average)
    (6)
    Welding voltage in V (average)
    (7)
    Wire speed in m/min
    (8)
    Arc energy in kJ (for details see page (→))
    (9)
    Job No.
    Turn the selection dial to scroll through the list.
    2Select "OK" to exit the logbook
    1. Defaults
    Switching limit value monitoring on/off
    Limit value monitoring is only available in conjunction with the OPT/i LimitMonitoring option.
    1Select Defaults / Documentation / Limit monitoring
    3Turn the selection dial and change the value for Limit Monitoring:
    off:
    Limit value monitoring is deactivated.
    on:
    The limit values are monitored according to the settings
    Factory setting:
    off
    4Select OK to apply the settings for limit value monitoring
    1. Defaults
    Defaults Administration
    1. Defaults
    2. Defaults Administration
    1. Defaults
    User management
    General
    User management is useful if multiple users are working with the same welding machine.
    User management is carried out using different roles and with the help of NFC keys.
    Users are assigned different roles depending on their level of training or qualification.
    1. Defaults
    2. User management
    General
    1. Defaults
    2. User management
    Explanation of terms
    Administrator
    An administrator has full access to all welding machine functions. An administrator's tasks include:
    • Creating roles
    • Setting up and managing user data
    • Assigning access rights
    • Updating the firmware
    • Backing up data, etc.
    User management
    User management includes all users registered on the welding machine. Users are assigned different roles depending on their level of training or qualification.
    NFC card
    An NFC card or and NFC key fob is assigned to a specific user who is registered on the welding machine.
    NFC cards and NFC key fobs are commonly referred to as an NFC key in these Operating Instructions.
    IMPORTANT! Each user should be assigned their own NFC key.
    Role
    Roles are used to manage registered users (= user management). The roles define access rights and the work activities that users can perform.
    1. Defaults
    2. User management
    Predefined roles and users
    Two roles are predefined in the factory under Defaults / Administration / User management:
    Administrator
    with all rights and options
    The "Administrator" role cannot be deleted, renamed, or edited.
    The "Administrator" role contains the predefined "admin" user, which cannot be deleted. The "Admin" user can be assigned a name, language, unit, web password, and NFC key.
    Once "admin" has been assigned an NFC key, user management is activated.
    Locked
    Preset in the factory with access rights to the welding processes, without process parameters and defaults
    The role "Locked":
    • Cannot be deleted or renamed,
    • Can be edited in order to activate various functions as required,
    NFC keys cannot be assigned to the "Locked" role.
    If no NFC key is assigned to the predefined "Admin" user, each NFC key functions to lock and unlock the welding machine (no user management, see also section "Locking and unlocking the welding machine using an NFC key", page (→)).
    1. Defaults
    2. User management
    User administration overview
    User management contains the following sections:
    • Creating administrator and roles
    • Creating users
    • Editing roles/users, deactivating user management
    1. Defaults
    Create administrator and roles
    Recommendation for creating roles and users
    A systematic procedure is required when creating roles and NFC keys.
    Fronius recommends that you create one or two administrator keys. In the worst case scenario, a welding machine can no longer be operated without administrator rights.
    Procedure
    NOTE!
    The loss of an administrator NFC key may affect welding machine usability, depending on your settings. Store one of the two administrator NFC keys in a safe place.
    1In the "Administrator" role, create two equivalent users
    This ensures that access to the administrator function is retained even if an administrator NFC key is lost.
    2Consider other roles:
    • How many roles are required?
    • Which rights are assigned to the respective roles?
    • How many users are there?
    3Create roles
    4Assign users to roles
    5Check whether the created users have access to the respective roles with their NFC keys.
    1. Defaults
    2. Create administrator and roles
    Procedure
    NOTE!
    3Create roles
    1. Defaults
    Creating an administrator key
    NOTE!
    If an NFC key is assigned to the predefined "Admin" user under Defaults / Administration / User management / Administrator, then user management is activated.
    1Select Defaults / Administration / User management
    User management is displayed, "Administrator" is selected.
    3Turn the selection dial and select "Admin"
    5Turn the selection dial and select NFC card
    The info for transferring the NFC card is displayed.
    7Follow the on-screen instructions
    (hold the new NFC key on the reading zone for NFC keys and wait for confirmation that it has been recognized)
    8Select OK
    The message confirming that user management is activated is displayed.
    9Select OK
    The number of the assigned NFC key is displayed under Admin / NFC card.
    To create a 2nd administrator key:
    • Copy "Admin" (Create new from selection - see also page (→))
    • Enter a user name
    • Assign a new NFC card
    1. Defaults
    Creating roles
    User management is displayed.
    2Select "Create role"
    The keyboard is displayed.
    3Enter the desired role name using the keyboard (max. 20 characters)
    4Select "OK" to apply the role name/press the selection dial
    The functions that can be executed within a role are displayed.
    Symbols:
    ... hidden
    ... read only
    ... read and write
    5Specify functions that a user can execute with this role
    • Select functions by turning the selection dial
    • Select settings from the list
    6Select OK
    1. Defaults
    Copying roles
    2Turn the selection dial and select the role to be copied
    3Select "new from"
    4Enter the name of the new role using the keyboard
    5Select OK
    6Specify the functions that can be executed within the role
    • Select the function by turning the selection dial
    • Press the selection dial
    • Select settings for the functions from the list
    7Select OK
    1. Defaults
    Creating users
    Creating users
    NOTE!
    For data privacy reasons, only personal ID numbers and no full names should be entered when creating users.
    2Select "create user"
    3Enter the desired user name using the keyboard (max. 20 characters)
    4Select "OK" to apply the user name/press the selection dial
    5Enter additional user data
    - Select the parameter by turning the selection dial
    - Press the selection dial
    - Select Role, Language, Unit, and Standard from the list
    - Enter first name, last name and web password using the keyboard
    6Turn the selection dial and select NFC card
    8Follow the on-screen instructions
    1. Defaults
    2. Creating users
    Creating users
    NOTE!
    1. Defaults
    2. Creating users
    Copying users
    NOTE!
    2Turn the selection dial and select the role to which the user to be copied is assigned
    4Turn the selection dial and select the user to be copied
    5Select "new from"
    6Enter the name of the new user using the keyboard
    7Select OK
    8Enter additional user data
    9Assign a new NFC key
    10Select OK
    1. Defaults
    Editing roles
    2Turn the selection dial and select the desired role
    3Select "Edit user/role"
    The role opens, the functions can be changed:
    • Change the role name using the keyboard
    4Select OK
    If no user is stored for a role, the editing of the role can also be started by pressing the selection dial.
    1. Defaults
    2. Editing roles/users, deactivating user management
    Editing roles
    4Select OK
    1. Defaults
    Deleting roles
    2Turn the selection dial and select the role to be deleted
    3Select "Delete user/role"
    4Confirm the prompt
    The role and all assigned users are deleted.
    1. Defaults
    Editing users
    2Turn the selection dial and select the role to which the user to be edited is assigned
    The users assigned to the role are displayed.
    4Turn the selection dial and select the user to be edited
    5Select "Edit user/role" (or press the selection dial)
    • Select the parameter by turning the selection dial
    • Change the name and web password using the keyboard
    • Select other settings from the list
    Replacing the NFC card:
    • Turn the selection dial and select "NFC card"
    • Select "Replace"
    • Hold the new NFC key on the reading zone for NFC keys and wait for confirmation that it has been recognized
    • Select OK
    6Select OK
    1. Defaults
    Deleting users
    2Turn the selection dial and select the role to which the user to be deleted is assigned
    4Turn the selection dial and select the user to be deleted
    5Select "Delete user/role"
    6Confirm the prompt
    The user is deleted.
    1. Defaults
    Deactivating user management
    1Select the predefined "Admin" user under Defaults / Administration / User management / Administrator
    2Turn the dial and select NFC card
    3Press the dial
    The prompt to delete or replace the NFC card is displayed.
    NOTE!
    If the NFC card for the predefined "Admin" user is deleted, user management is deactivated.
    4Select "Delete"
    User management is deactivated, the welding machine is locked.
    The welding machine can be unlocked and locked again with any NFC key (see also page (→)).
    1. Defaults
    Lost administrator NFC key?
    Procedure if
    • user management is activated
    • the welding machine is locked
      , and
    • the administrator NFC key has been lost:
    1Touch the key symbol in the status bar on the display
    The information regarding the loss of the administrator card is displayed.
    2Note down the IP address of the welding machine
    3Open the SmartManager for the welding machine (enter the IP address of the welding machine in a browser)
    4Inform the Fronius service team
    1. Defaults
    CENTRUM - Central User Management
    Activating the CENTRUM server
    CENTRUM is a piece of software used for central user management. For detailed information, refer to the CENTRUM Operating Instructions (42,0426.0338,xx).
    THE CENTRUM server can also be activated directly on the welding machine as follows:
    1Select Defaults / Administration / CENTRUM Server
    The Central User Management Server is displayed.
    2Activate CENTRUM Server (press dial)
    3Select CENTRUM Server, press the dial and enter the address of the CENTRUM server using the keyboard
    4Select the Verify CENTRUM button
    5Save
    1. Defaults
    2. CENTRUM - Central User Management
    5Save
    SmartManager – the welding machine website
    General
    With the SmartManager, the welding machines have their own website.
    Once the welding machine is connected to a computer via WLAN or a network cable, or is integrated into a network, the SmartManager of the welding machine can be accessed via the IP address of the welding machine.
    IE 10 or higher or another modern browser is required in order to access the SmartManager.
    The entries displayed on the SmartManager may vary depending on the system configuration, software extensions and options available.
    Examples of displayed entries:
    • Current system data
    • Documentation logbook
    • Job data
    • Welding machine settings
    • Save and restore
    • User administration
    • Overview
    • Update
    • Function packages
    • Screenshot
    1. SmartManager – the welding machine website
    General
    • Job data
    • Save and restore
    • Overview
    • Update
    • Function packages
    • Screenshot
    2. SmartManager – the welding machine website
    General
    • Job data
    • Save and restore
    • Overview
    • Update
    • Function packages
    • Screenshot
    Opening and logging into the SmartManager for the welding machine
    1Defaults / System / Information ==> note down the IP address of the welding machine.
    2Enter the IP address into the search field of the browser.
    3Enter the username and password.
    Factory settings for username and password
      Username = admin
      Password = admin
    4Confirm the displayed message.
    There is no need to change the Unique Password when you log in to the SmartManager for the first time.
    The SmartManager for the welding machine is displayed.
    Help functions if logging in does not work
    There are two help functions when logging into the SmartManager:
    • Start unlock function?
    • Forgot your password?
    This feature allows you to unlock an unintentionally locked welding machine and enable it for all functions.
    1Click on "Start unlock function?"
    2Create a verification file:
    click on "Store"
    A .txt file with the following file name is saved in the computer's download folder:
    unlock_SN[serial number]_YYYY_MM_DD_hhmmss.txt
    3Send this verification file via e-mail to the Fronius tech support team at:
    welding.techsupport@fronius.com
    Fronius will reply by e-mail with a one-time unlock file with the following file name:
    response_SN[serial number]_YYYY_MM_DD_hhmmss.txt
    4Save the unlock file to the computer
    5Click on "Find unlock file"
    6Save the unlock file
    7Click on "Load unlock file"
    The welding machine is temporarily unlocked.
    After clicking on "Forgot your password?", a note appears indicating that the password can be reset on the welding machine (see also "Restoring the website password", page (→)).
    Changing the password/logging out
    Click on this symbol to
    • change the user password
    • log out of the SmartManager
    Changing the SmartManager password:
    1Enter the old password
    2Enter a new password *
    3Repeat the new password
    4Click on "Save"
    A password must satisfy the following criteria:
    • The password must be between 10 and 16 characters in length.
    • It must contain three of the following four features:
      uppercase letters A - Z
      lowercase letters a - z
      digits 0 - 9
      special characters , . @ = + - * / ~ " ° _ # ( ) ! ? & % : ;
    Settings
    Click on this symbol to expand the display of characteristics, material specifications and certain welding parameters on the SmartManager for the welding machine.
    The settings depend on the user who is logged in.
    Language selection
    Click on the language abbreviation to display the languages available for the SmartManager.
    To change the language, click on the desired language.
    Status indicator
    The current status of the welding machine is displayed between the Fronius logo and the selected welding machine.
    Caution/warning
    Error on the welding machine *
    Welding machine is welding
    Welding machine is ready for use (online)
    Welding machine is not ready for use (offline)
    In the event of an error, a red error line with the error number appears above the line with the Fronius logo.
    After clicking on the error line, an error description is displayed.
    Fronius
    Click on the Fronius logo to open the Fronius homepage: www.fronius.com
    Current system data
    Current system data
    Current welding system data is displayed.
    NOTE!
    Depending on the welding process, equipment, and existing WeldingPackages, the system data displayed will vary.
    e.g., system data for TIG AC:
    (1)
    Device type
    (2)
    Device name
    (3)
    Factory
    (4)
    Hall
    (5)
    Cell
    (6)
    Welding process
    (7)
    Actual values / HOLD or Average values (depending on setting)
    (8)
    Welding current
    (9)
    Welding voltage
    (10)
    Arc time
    (11)
    Arc energy
    (12)
    Arc power
    (13)
    Welding current command value
    (14)
    AC balance
    (15)
    Starting current set value
    (16)
    Final current set value
    (17)
    Electrode diameter
    (18)
    UpSlope
    (19)
    DownSlope
    (20)
    Polarity
    (21)
    Total arc energy
    (22)
    (23)
    Total arc time
    (24)
    (25)
    Operating mode
    (26)
    AC or DC
    (27)
    HF ignition
    (28)
    Pulse frequency
    (29)
    CyclTIG
    (30)
    Full screen mode
    2. Current system data
    Current system data
    NOTE!
    (1)
    Device type
    (2)
    Device name
    (3)
    Factory
    (4)
    Hall
    (5)
    Cell
    (6)
    Welding process
    (7)
    (8)
    Welding current
    (9)
    Welding voltage
    (10)
    Arc time
    (11)
    Arc energy
    (12)
    Arc power
    (13)
    (14)
    AC balance
    (15)
    (16)
    (17)
    Electrode diameter
    (18)
    UpSlope
    (19)
    DownSlope
    (20)
    Polarity
    (21)
    Total arc energy
    (22)
    (23)
    Total arc time
    (24)
    (25)
    Operating mode
    (26)
    AC or DC
    (27)
    HF ignition
    (28)
    Pulse frequency
    (29)
    CyclTIG
    (30)
    Full screen mode
    Logbook
    The documentation entry in the logbook shows the last 100 entries. These logbook entries can be welds, errors, warnings, notifications, and events.
    The "Time filter" button can be used to filter the displayed data by a specific time period. This is entered with date (yyyy MM dd) and time (hh mm), each from – to.
    An empty filter reloads the most recent welding operations.
    The display of welding operations, errors, warnings, notifications, and events can be deactivated.
    The following data is displayed:
    (1)
    Number of the weld
    (2)
    Start time (date and time)
    (3)
    (4)
    (5)
    (6)
    Wire speed in m/min
    (7)
    IP - arc power in W (based on real-time values according to ISO/TR 18491)
    (8)
    IE - arc energy in kJ (as the total throughout the entire welding process according to ISO/TR 18491)
    If present in the system, robot speed and jobs are also displayed.
    Clicking on a logbook entry will display the details for that entry.
    Details for welds:
    Section No.
    (9)
    Duration of the welding section in s
    (10)
    (11)
    (12)
    Wire speed in m/min
    (13)
    Welding speed (cm/min)
    (14)
    Arc power from instantaneous values in W (for details see page (→))
    (15)
    (16)
    Job No.
    (17)
    Process
    Additional values can be also displayed by clicking on the "Insert column" button:
    • I max / I min: maximum/minimum welding current in A
    • Power max / Power min: maximum/minimum arc power in W
    • Start time (welding machine time); date and time
    • U max / U min: maximum/minimum welding voltage in V
    • Vd max / Vd min: maximum/minimum wire speed in m/min
    If the OPT/i documentation option is present on the welding machine, individual sections of welds can also be displayed.
    The documentation can be exported in the desired format using the "PDF" and "CSV" buttons.
    For CSV exports, the OPT/i documentation option must be present on the welding machine.
    2. Documentation logbook
    Logbook
    (1)
    Number of the weld
    (2)
    (3)
    (4)
    (5)
    (6)
    Wire speed in m/min
    (7)
    (8)
    Details for welds:
    Section No.
    (9)
    (10)
    (11)
    (12)
    Wire speed in m/min
    (13)
    (14)
    (15)
    (16)
    Job No.
    (17)
    Process
    Basic settings
    The sampling rate for documentation can be activated and set in the basic settings.
    In addition, the motor force M1 – M3, gas flow actual value and welding speed can be activated for documentation.
    Job data
    Job data
    If the OPT/i Jobs option is available on the welding machine, the following can be carried out under the Job data entry:
    • Existing jobs in the welding system can be viewed *
    • Existing jobs in the welding system can be optimized
    • Externally stored jobs can be transferred to the welding system
    • Existing jobs in the welding system can be exported as PDF * or CSV files
    Viewing and exporting as a PDF also works if the OPT/i Jobs option is not available on the welding machine.
    2. Job data
    Job data
    2. Job data
    Job overview
    The job overview lists all jobs stored in the welding system.
    After clicking on a job, the data and parameters stored for this job are displayed.
    Job data and parameters can only be viewed in the job overview. The column width for parameters and values can be easily adjusted by dragging with the mouse pointer.
    Further jobs can be easily added to the list with the displayed data by clicking on the "Add column" button.
    All added jobs are compared with the selected job.
    2. Job data
    Editing a job
    Existing jobs in the welding machine can be optimized, provided the OPT/i Jobs option is available on the welding machine.
    1Click on "Edit job"
    2In the list of existing jobs, click on the job to be edited.
    The selected job opens and the following job data is displayed:
    • Parameters
      Parameters currently stored in the job
    • Value
      Parameter values currently stored in the job
    • Change value to
      For entering the new parameter value
    • Setting range
      Possible setting range for the new parameter values
    3Change the values accordingly
    4Save/discard your changes, save job as/delete
    To help when editing the job, further jobs can be easily added to the list with the displayed data by clicking on "Add job".
    Creating a new job
    1Click on "Create new job"
    2Enter job data
    3Click on "OK" to apply the new job
    2. Job data
    Importing a job
    This function allows externally stored jobs to be transferred into the welding system, provided the OPT/i Jobs option is available on the welding machine.
    1Click on "Find job file"
    2Select the desired job file
    In the preview of the job import list, you can select individual jobs and assign new job numbers.
    3Click on "Import"
    If the import is successful, a confirmation is displayed and the imported jobs are displayed in the list.
    2. Job data
    Exporting a job
    This function allows the welding machine to store jobs externally, provided the OPT/i Jobs option is available on the welding machine.
    1Select the jobs to be exported
    2Click on "Export"
    The jobs are exported as an XML file to the computer's download folder.
    2. Job data
    Exporting job(s) as ...
    Under Job overview and Edit job, existing jobs in the welding machine can be exported as PDF or CSV files.
    For CSV export, the OPT/i Jobs option must be available on the welding machine.
    1Click on "Export job(s) as..."
    The PDF settings or CSV settings are displayed.
    2Select the job(s) to be exported:
    Current job/all jobs/job numbers
    3Click on "Save PDF" or "Save CSV"
    A PDF or CSV file of the selected jobs is created and saved depending on the settings for the browser used.
    Process parameters
    Under Process parameters, you can view and modify general process parameters and process parameters for components & monitoring of a welding machine.
    Changing process parameters
    1Click on Parameter Group/Parameters
    2Change the value of the parameter directly in the display field
    3Save changes
    2. Welding machine settings
    Process parameters
    3Save changes
    Designation & location
    The welding machine configuration can be viewed and modified under Designation & location.
    Parameter display
    Welding parameters and special functions for welding machine and JobMaster welding torch can be set under Parameter display.
    1Select parameter/function (tick)
    2Save changes
    The selected parameters / functions are:
    • shown on the welding machine's display in the welding parameters,
    • available on the JobMaster welding torch.
    Date & time
    The date & time can be set automatically or manually.
    Network settings
    The following parameters can be set under Network settings:
    Management
    • MAC address and current IP address are displayed.
    • If DHCP is not selected, the IP address, network mask, default gateway, DNS server 1 and 2 can be set manually.
    WLAN
    • The WLAN country code can be set.
    • Configured networks are displayed
    • Available networks are displayed
    WeldCube Air
    Connect welding machine to WeldCubeAir
    (alternatively click on the cloud icon at the top right)
    Save and restore
    General
    Under the Save and restore entry
    • all welding system data can be saved as a backup (e.g. current parameter settings, jobs, user curves, defaults, etc.)
    • existing backups can be saved again in the welding system
    • data can be configured for automatic backup
    2. Save and restore
    General
    2. Save and restore
    Save and restore
    Starting a backup
    1Click on "Start backup" to save the welding machine data as a backup
    By default, the data is saved in the format MCU1-YYYYMMDDHHmm.fbc at the selected location.
    YYYY = year
    MM = month
    DD = day
    HH = hour
    mm = minute
    Date and time information according to the settings on the welding machine.
    Finding a recovery file
    1Click on "Find recovery file" to transfer an existing backup to the welding machine
    2Select the file and click on "Open"
    The selected backup file appears in the SmartManager for the welding machine under Restore.
    3Click on "Start restore"
    Once the data has been successfully restored, a confirmation is displayed.
    2. Save and restore
    Automatic backup
    1Enable interval settings
    2Enter the interval settings for the times at which the automatic backup should take place:
    • Interval:
      daily/weekly/monthly
    • at:
      time (hh:mm)
    3Enter the data for the backup destination:
    • Protocol:
      SFTP (Secure File Transfer Protocol) / SMB (Server Message Block)
    • Server:
      Enter the IP address of the destination server
    • Port:
      Enter port number; if no port number is entered, the standard port 22 is automatically used.
      If SMB is set under Protocol, leave the Port field blank.
    • Storage location:
      Used to configure the subfolder where the backup will be stored.
      If no location is entered, the backup is stored in the server root directory.
      IMPORTANT! For SMB and SFTB, always enter the location with a slash "/".
    • Domain/user, password:
      User name and password - as configured on the server;
      When entering a domain, first enter the domain, then backslash "\" and then the user name (DOMAIN\USER)
    4If a connection via proxy server is required, activate and enter the proxy settings:
    • Server
    • Port
    • User
    • Password
    5Save changes
    6Activate automatic backup
    If you have any questions about configuration, contact your network administrator.
    Signal visualisation
    link_horizontalLink copied
    Signal visualization
    Signal visualization is only available if a robot interface is present.
    To display the signal visualization correctly, IE 10 or another modern browser is required as a minimum.
    The signals and commands transferred via a robot interface are displayed.
    IN ... Signals from the robot control to the welding machine
    OUT ... Signals from the welding machine to the robot control unit
    The displayed signals can be searched, sorted, and filtered at any time.
    To sort the characteristics in ascending or descending order, click on the arrow next to the respective information. The column widths can be dragged and adjusted with the cursor.
    The following information is required for a detailed description of the signals:
    • Bit position
    • Signal name
    • Value
    • Data type
    2. Signal visualisation
    • Bit position
    • Signal name
    • Value
    • Data type
    User management
    General
    Under the User administration entry
    • Users can be viewed, changed, and created.
    • User roles can be viewed, changed, and created.
    • Users and user roles can be exported or imported into the welding machine.
      During import, existing user management data on the welding machine is overwritten.
    • A CENTRUM server can be activated.
    User management is created on one welding machine and can then be saved with the export/import function and transferred to other welding machines.
    2. User management
    General
    2. User management
    Users
    Existing users can be viewed, changed and deleted, new users can be created.
    Viewing/changing a user:
    1Select a user
    2Change user data directly in the display field
    3Save the changes
    Deleting a user:
    1Select a user
    2Click on the "Delete user" button
    3Confirm the prompt with "OK"
    Creating a user:
    1Click on the "Create new user" button
    2Enter user data
    3Confirm with OK
    2. User management
    User roles
    Existing user roles can be viewed, changed and deleted, new user roles can be created.
    Viewing/changing a user role:
    1Select a user role
    2Change user role data directly in the display field
    3Save the changes
    The "Administrator" role cannot be changed.
    Deleting a user role:
    1Select a user role
    2Click on the "Delete user role" button
    The "Administrator" and "locked" roles cannot be deleted.
    Creating a user role:
    1Click on the "Create new user role" button
    2Enter a role name, apply values
    3Confirm with OK
    2. User management
    Export & import
    Exporting users and user roles from a welding machine
    1Click on "export"
    User management for the welding machine is stored in the computer's download folder.
    File format: userbackup_SNxxxxxxxx_YYYY_MM_DD_hhmmss.user
    SN = serial number, YYYY = year, MM = month, DD = day
    hh = hour, mm = minute, ss = second
    Importing users and user roles into a welding machine
    1Click on "Find user data file"
    2Select the file and click on "open"
    3Click on "import"
    User management is stored on the welding machine.
    2. User management
    CENTRUM Server
    To activate a CENTRUM server
    (CENTRUM = Central User Management)
    1Activate CENTRUM Server
    2In the input field, enter the domain name or IP address of the server on which Central User Management has been installed.
    If a domain name is used, a valid DNS server must be configured under the welding machine network settings.
    3Click on the "Verify server" button.
    The availability of the specified server is checked.
    4Save changes
    Overview
    Overview
    The Overview entry displays the components and options in the welding system with all the available information, e.g. firmware version, item number, serial number, production date, etc.
    2. Overview
    Overview
    2. Overview
    Expanding all groups/collapsing all groups
    Click on the "Expand all groups" button to see further details about the individual system components.
    Example welding machine:
    • TPSi Touch: Item number
      MCU1: Item number, version, serial number, production date
      Bootloader: Version
      Image: Version
      Licenses: WP Standard, WP Pulse, WP LSC, WP PMC, OPT/i Guntrigger, etc.
    • SC2: Item number
      Firmware: Version
    Click on the "Collapse all groups" button to hide the details of the system components.
    2. Overview
    Export component overview as ...
    Click on the "Export component overview as" button to create an XML file from the details of the system components. This XML file can either be opened or saved.
    Update
    Update
    Under the Update entry, the firmware of the welding machine can be updated.
    The welding machine's current firmware version is displayed.
    To update the firmware of the welding machine:
    Firmware link:
    The update file can be downloaded via the link provided:
    Firmware TPS/i_iWAVE
    1Organize and save the update file
    2Click on "Find update file" to start the update process
    3Select the update fileClick on "Update"
    After the update has been completed, the welding machine may need to be restarted.
    After the update has been successfully completed, a confirmation message is displayed.
    2. Update
    Update
    Firmware link:
    2. Update
    Finding the update file (performing an update)
    1After clicking on "Find update file", select the desired firmware (*.ffw)
    2Click on "Open"
    The selected update file appears in the SmartManager for the welding machine under Update.
    3Click on "Update"
    The progress of the update process is displayed.
    Once this reaches 100%, the prompt to restart the welding machine appears.
    The SmartManager is not available during the restart.
    After the restart, the SmartManager may no longer be available.
    If you select No, the new software functions will be activated the next time the power is turned on/off.
    4To restart the welding machine, click on "Yes"
    The welding machine restarts, the display goes dark for a short time.
    During the restart, the welding machine display shows the Fronius logo.
    After the update has been successfully completed, a confirmation and the current firmware version are displayed.
    Then log into the SmartManager again.
    2. Update
    Fronius WeldConnect
    Under the Update entry, the Fronius WeldConnect mobile application can also be called up.
    WeldConnect is an app for wireless interaction with the welding system.
    WeldConnect can be used to perform the following functions:
    • Current device configuration at a glance
    • Mobile access to the SmartManager of the welding machine
    • Automatic determination of output parameters for MIG/MAG and TIG
    • Cloud storage and wireless transmission to the welding machine
    • Component identification
    • Log on and off the welding machine without NFC card
    • Save and share parameters and jobs
    • Data transfer from one welding machine to another by means of backup, restore
    • Firmware update
    Fronius WeldConnect is available as follows:
    • As an app for Android
    • As an app for Apple/IOS
    For more information on Fronius WeldConnect, visit:
    https://www.fronius.com/en/welding-technology/innovative-solutions/weldconnect
    Function packages
    Function packages
    The following data can be displayed under function packages:
    • At the welding machine, existing Welding Packages
      (e.g., WP STANDARD, WP PULSE, WP LSC, etc.)
    • DB /i (databases)
    • Options available on the welding machine (OPT/i ...)
    • CFG /i (robot interface configurations)
    2. Function packages
    Function packages
    • DB /i (databases)
    Welding Packages
    Under Welding Packages, the welding packages available on the welding machine are displayed with the respective item numbers, e.g.:
    • WP Standard (MIG/MAG standard synergic welding)
    • WP Pulse (MIG/MAG pulsed synergic welding)
    • WP LSC (Low Spatter Control, low-spatter dip transfer arc process)
    • WP PMC (Pulse Multi Control, advanced pulsed arc welding process)
    Possible extensions:
    • WP CMT
    • etc.
    Options
    Under Options, the options available on the welding machine are displayed with the respective item numbers and possible extensions, e.g.,
    Options
    • OPT/i GUN Trigger
    • etc.
    Possible extensions
    • OPT/i Jobs
    • OPT/i Interface Designer...
    • etc.
    Loading a function package
    1Organize and save the function package
    2Click on "Find function package file"
    3Select the desired function package file (*.xml)
    4Click on "Open"
    The selected function package file appears in the SmartManager for the welding machine Function package.
    5Click on "Load function package"
    Once the function package has been successfully loaded, a confirmation is displayed.
    Synergic lines overview
    Overview of characteristics
    In the Overview of characteristics entry:
    • available characteristics in the welding system can be displayed:
      Available characteristics button
    • possible characteristics in the welding system can be displayed:
      Possible characteristics button
    • characteristics for the welding system can be preselected:
      Characteristic preselection button
    • saved characteristic preselections can be exported and imported:
      Export & import button
    You can search for, sort and filter the displayed characteristics at any time.
    The following information is displayed for the characteristics:
    • Status
    • Material
    • Diameter
    • Gas
    • Property
    • Process
    • ID
    • replaced by
    • SFI
    • SFI HotStart
    • Penetration stabilizer
    • Arc length stabilizer
    • CMT Cycle Step
    • Special
    • Requirements
    To sort the characteristics in ascending or descending order, click on the arrow next to the corresponding information.
    The column widths can be easily adjusted by dragging with the mouse cursor.
    2. Synergic lines overview
    • Status
    • Material
    • Diameter
    • Gas
    • Property
    • Process
    • ID
    • replaced by
    • SFI
    • SFI HotStart
    • CMT Cycle Step
    • Special
    • Requirements
    Show filter
    Click on the "Show filter" symbol to display the possible filter criteria. With the exception of "ID" and "Replaced by", the characteristics can be filtered by all information.
    First selection box = select all
    To hide the filter criteria, click on the "Hide filter" symbol.
    Screenshot
    Screenshot
    Under the Screenshot entry, a digital image of the welding machine display can be created at any time, regardless of navigation or set values.
    1Click on "Take screenshot" to take a screenshot of the display
    The screenshot is taken with the settings currently displayed on the display.
    Depending on the browser you are using, different functions are available for saving the screenshot, and the display may vary.
    2. Screenshot
    Screenshot
    Interface
    Interface
    If a robot interface is available, the name of the interface will be displayed as an entry on the website of the welding machine.
    The following welding parameters can be displayed, edited, saved or deleted:
    • Characteristic assignment (current allocation of program numbers to characteristics)
    • Module configuration (network settings)
    Factory settings can be restored and the module can be restarted.
    2. Interface
    Interface
    Troubleshooting and Maintenance
    Troubleshooting
    General
    The welding machines are equipped with an intelligent safety system, making it possible to dispense with nearly all fuses. After correcting any errors, the welding machine can be operated properly again.
    Possible malfunctions, warning notices or status codes are shown on the display as plain text dialogs.
    1. Troubleshooting and Maintenance
    Troubleshooting
    General
    2. Troubleshooting
    General
    2. Troubleshooting
    Danger from electric current and insufficient ground conductor connection
    WARNING!
    This may result in serious personal injury and damage to property.
    Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
    Secure all these devices and components so they cannot be switched back on.
    CAUTION!
    Danger due to insufficient ground conductor connection.
    This can result in personal injury and damage to property.
    The housing screws provide a suitable ground conductor connection for grounding the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    2. Troubleshooting
    MIG/MAG welding – current limit
    “Current limit” is a safety function for MIG/MAG welding, whereby
    • it is possible to operate the welding machine at the power limit and
    • process reliability is ensured.
    If the welding power is too high, the arc gets continuously smaller and may be extinguished. To stop the arc from being extinguished, the welding machine reduces the wire speed and therefore the welding power.
    A corresponding message appears on the status bar of the display.
    Remedial measures
    • Reduce one of the following welding power parameters:
      Wire speed
      Welding current
      Welding voltage
      Material thickness
    • Increase the distance between the contact tip and workpiece
    2. Troubleshooting
    Troubleshooting the welding machine
    Welding machine not working
    Power switch is switched on; displays and indicators do not illuminate
    Cause:Mains lead damaged or broken, mains plug not inserted
    Remedy:Check mains lead, if necessary insert mains plug
    Cause:Mains socket or mains plug faulty
    Remedy:Replace faulty parts
    Cause:Mains fuse
    Remedy:Replace mains fuse
    Cause:Short circuit on the 24 V power supply of the SpeedNet connection or external sensor
    Remedy:Disconnect connected components
    No welding current
    Power switch is on, overtemperature is displayed
    Cause:Overload, duty cycle exceeded
    Remedy:Observe the duty cycle
    Cause:Thermal automatic circuit breaker has tripped
    Remedy:Wait until the welding machine automatically comes back on after the end of the cooling phase
    Cause:Limited supply of cooling air
    Remedy:Ensure accessibility to cooling air ducts
    Cause:Fan in the welding machine defective
    Remedy:Contact After-Sales Service
    No welding current
    Power source switched on; displays and indicators light up
    Cause:Incorrect ground connection
    Remedy:Check ground connection and terminal for polarity
    Cause:Power cable in welding torch damaged or broken.
    Remedy:Replace the welding torch
    No function after pressing torch trigger
    Power switch switched on; displays and indicators light up
    Cause:Control plug not plugged in
    Remedy:Plug in control plug
    Cause:Welding torch or welding torch control line faulty
    Cause:Interconnecting hosepack defective or not correctly connected
    (not in the case of welding machines with integrated wire drive)
    Remedy:Check interconnecting hosepack
    No shielding gas
    All other functions are OK
    Cause:Gas cylinder empty
    Remedy:Change gas cylinder
    Cause:Gas pressure regulator faulty
    Remedy:Replace the gas pressure regulator
    Cause:Gas hose is not fitted or is damaged
    Remedy:Fit or change gas hose
    Cause:Welding torch faulty
    Remedy:Change welding torch
    Cause:Gas solenoid valve faulty
    Poor-quality weld properties
    Cause:Wrong welding parameters, wrong correction parameters
    Remedy:Check settings
    Cause:Poor ground earth connection
    Remedy:Establish good contact with workpiece
    Cause:Several welding machines welding one part
    Remedy:Increase distance between hosepacks and return lead cables;
    Do not use a common ground.
    Cause:Too little or no shielding gas
    Remedy:Check pressure regulator, gas hose, gas solenoid valve, welding torch gas connection, etc.
    Cause:Welding torch leaks
    Cause:Incorrect or heavily worn contact tip
    Remedy:Change contact tip
    Cause:Incorrect wire alloy or incorrect wire diameter
    Remedy:Check wire electrode in use
    Remedy:Check the weldability of the base material
    Cause:Shielding gas not suitable for wire alloy
    Remedy:Use correct shielding gas
    Excessive weld spatter
    Cause:Shielding gas, wirefeeder, welding torch or workpiece contaminated or magnetically charged
    Remedy:Perform R/L alignment;
    Adjust arc length;
    Check shielding gas, wirefeeder, welding torch position or workpiece for contamination or magnetic charge
    Wirefeed problems
    when using long welding torch hosepacks
    Cause:Incorrect arrangement of welding torch hosepack
    Remedy:Arrange the welding torch hosepack in as straight a line as possible, avoiding tight bends
    Irregular wire speed
    Cause:Braking force has been set too high
    Remedy:Loosen the brake
    Cause:Contact tip hole too narrow
    Remedy:Use suitable contact tip
    Cause:Inner liner in the welding torch faulty
    Remedy:Check the inner liner for kinks, dirt, etc. and replace if necessary
    Cause:Feed rollers not suitable for wire electrode used
    Remedy:Use suitable feed rollers
    Cause:Feed rollers have the wrong contact pressure
    Remedy:Optimize contact pressure
    Welding torch gets very hot
    Cause:Welding torch is inadequately sized
    Remedy:Observe duty cycle and load limits
    Cause:For water-cooled systems only: Coolant flow too low
    Remedy:Check coolant level, coolant flow rate, coolant contamination, etc.;
    coolant pump blocked: Switch on the shaft of the coolant pump at the gland using a screwdriver
    Cause:For water-cooled systems only: The "Cooling unit operating mode" setup parameter is set to "off".
    Remedy:In the Setup menu, set the "Cooling unit operating mode" parameter to "eco", "on" or "auto" in the component settings.
    Service, maintenance and disposal
    General
    The welding machine only requires minimal service and maintenance under normal operating conditions. However, some important points must be noted to ensure that the welding system remains in a usable condition for many years.
    2. Service, maintenance and disposal
    General
    Original spare and wear parts
    It is impossible to guarantee that third-party parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements.
    • Use only original spare and wear parts (also applies to standard parts).
    • Do not carry out any alterations, installations, or modifications to the device without first obtaining the manufacturer's permission.
    • Components that are not in perfect condition must be changed immediately.
    • When ordering, specify the exact name and part number according to the spare parts list, as well as the serial number of your device.
    Safety - maintenance
    WARNING!
    CAUTION!
    CAUTION!
    Danger due to hot components and parts.
    These can cause burns.
    Leave hot components and parts such as welding torches to cool before working with them.
    At every start-up
    • Check mains plug, mains cable, welding torch, interconnecting hosepack and grounding (earthing) connection for damage
    • Check whether the all-round clearance of 0.5 m (1 ft. 8 in.) is kept to ensure that the cooling air can easily flow and escape.
    NOTE!
    Air inlets and outlets must never be covered, not even partially.
    Every 2 months
    • If present: clean air filter
    Every 6 months
    CAUTION!
    Danger due to the effect of compressed air.
    Do not clean electronic components with compressed air from a short distance.
    • Open the device
    • Blow out the inside of the device with dry and reduced compressed air
    • Also clean the cooling air ducts if there is a large accumulation of dust
    IMPORTANT! To update the firmware, you need a PC or laptop that is connected to the welding machine via an Ethernet network.
    1Get the latest firmware (e.g. from the DownloadCenter)
    File format: official_TPSi_X.X.X-XXXX.ffw
    2Establish an Ethernet connection between the PC/laptop and welding machine
    3Open the welding machine SmartManager (see page(→))
    4Transfer the firmware to the welding machine (see page(→))
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
    The manufacturer recommends calibrating welding machines within the same 12-month interval.
    A safety inspection by a qualified electrician is recommended
    • After alterations
    • After repair, service, and maintenance
    When performing the safety inspection, follow the appropriate national and international standards and guidelines.
    You can obtain more information about the safety inspection and calibration from your Fronius branch or your Fronius partner, who will provide the necessary documents upon request.
    Disposal
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Crush cardboard boxes
    Appendix
    Average consumption values during welding
    Average shielding gas consumption during TIG welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    2. Average consumption values during welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    Average shielding gas consumption during MIG/MAG welding
    Wire electrode diameter
    1.0 mm
    1.2 mm
    1.6 mm
    2.0 mm
    2 x 1.2 mm (TWIN)
    Average consumption
    10 l/min
    12 l/min
    16 l/min
    20 l/min
    24 l/min
    1. Appendix
    Average wire electrode consumption during MIG/MAG welding
    Average wire electrode consumption at a wire speed of 5 m/min
    1.0 mm wire electrode diameter
    1.2 mm wire electrode diameter
    1.6 mm wire electrode diameter
    Steel wire electrode
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    Aluminum wire electrode
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    Average wire electrode consumption at a wire speed of 10 m/min
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    Technical data
    Explanation of the term duty cycle
    The duty cycle (ED) is the period of a ten minute cycle in which the device may be operated at the stated power without overheating.
    NOTE!
    The ED values cited on the rating plate relate to an ambient temperature of 40 °C.
    If the ambient temperature is higher, the ED or power must be lowered accordingly.
    Example: Welding with 150 A at 60% ED
    • Welding phase = 60% of 10 mins = 6 mins
    • Cool-down phase = rest time = 4 mins
    • Following the cool-down phase, the cycle begins again.
    To use the device without interruptions:
    1Search for a 100% ED value in the technical data, which corresponds to the existing ambient temperature.
    2Reduce the power or amperage value correspondingly so that the device can operate without a cool-down phase.
    1. Appendix
    2. Technical data
    NOTE!
    1. Appendix
    2. Technical data
    Special Voltage
    For devices designed for special voltages, the technical data on the rating plate applies.
    The following applies for all devices with a permitted grid voltage of up to 460 V: The standard mains plug allows the user to operate with a grid voltage of up to 400 V. For grid voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
    1. Appendix
    2. Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address:
    Find downloads: critical
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    1. Appendix
    2. Technical data
    Environmental conditions
    Temperature range of ambient air:
    during operation
    during transport and storage
    -10 °C to + 40 °C / 14 °F to 104 °F
    -20 °C to +55 °C / -4 °F to 131 °F
    Relative humidity of ambient air:
    at 40 °C / 104 °F
    at 20 °C / 68 °F
    max. 50%
    max. 90%
    1. Appendix
    2. Technical data
    iWave 300i DC
    Mains voltage (U1)
    3 x 400 V
    Max. effective primary current (I1eff)
    12.7 A
    Max. primary current (I1max)
    16.9 A
    Mains fuse
    16 A slow-blow
    Mains voltage tolerance
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    Max. permitted grid impedance Zmax on PCC1)
    156 mOhm
    Recommended residual-current circuit breaker
    Type B
    Welding current range (I2)
    TIG
    3 – 300 A
    MIG/MAG
    3 – 300 A
    MMA
    10 – 300 A
    Welding current
    at 10 min/40 °C (104 °F)
    40% / 300 A
    60% / 260 A
    100% / 240 A
    Output voltage range according to standard characteristic (U2)
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 29.0 V
    MMA
    20.4 – 32.0 V
    Open circuit voltage
    (U0 peak / U0 r.m.s)
    99 V
    Striking voltage (UP)
    10 kV
    The arc ignition device is suitable for manual operation.
    Protection class
    IP 23
    EMC emission class
    A 2)
    Dimensions l x w x h
    706 x 300 x 510 mm
    27.8 x 11.8 x 20.1 in.
    Weight
    46.4 kg / 102.29 lb.
    Max. noise emission (LWA)
    75 dB (A)
    Idle state power consumption at 400 V
    39.7 W
    Welding machine efficiency at 300 A / 32.0 V
    87%
    Max. shielding gas pressure
    7 bar/102 psi
    1)
    Interface to a 230/400-V and 50-Hz public grid
    2)
    A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid.
    The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies.
    1. Appendix
    2. Technical data
    iWave 300i DC /nc
    Mains voltage (U1)
    3 x 380 / 400 / 460 V
    3 x 380 V
    13.57 A
    3 x 400 V
    12.7 A
    3 x 460 V
    11.2 A
    3 x 380 V
    18.1 A
    3 x 400 V
    16.9 A
    3 x 460 V
    14.8 A
    Mains fuse
    16 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    156 mOhm
    Type B
    TIG
    3 – 300 A
    MIG/MAG
    3 – 300 A
    MMA
    10 – 300 A
    Welding current
    40% / 300 A
    60% / 260 A
    100% / 240 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 29.0 V
    MMA
    20.4 – 32.0 V
    99 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    45.1 kg / 99.43 lb.
    75 dB (A)
    39.7 W
    87%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 300i DC /MV/nc
    Mains voltage (U1)
    3 x 200/230/240/380/400/460/600 V
    3 x 200 V
    26.1 A
    3 x 230 V
    22.5 A
    3 x 240 V
    20.9 A
    3 x 380 V
    13.5 A
    3 x 400 V
    12.7 A
    3 x 460 V
    11.2 A
    3 x 600 V
    11.6 A
    3 x 200 V
    35.2 A
    3 x 230 V
    30.2 A
    3 x 240 V
    28.2 A
    3 x 380 V
    18.1 A
    3 x 400 V
    16.9 A
    3 x 460 V
    14.8 A
    3 x 600 V
    14.8 A
    Mains fuse
    3 x 200/230/240 V
    3 x 380/400/460/600 V
    35 A slow-blow
    16 A slow-blow
    -10 / +6%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    172 mOhm
    Type B
    TIG
    3 – 300 A
    MIG/MAG
    3 – 300 A
    MMA
    10 – 300 A
    Welding current
    40% / 300 A
    60% / 260 A
    100% / 240 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 29.0 V
    MMA
    20.4 – 32.0 V
    104 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    46.5 kg / 102.52 lb.
    75 dB (A)
    39.7 W
    87%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 400i DC
    Mains voltage (U1)
    3 x 400 V
    18.4 A
    24.9 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    ~ 92 mOhm
    Type B
    TIG
    3 – 400 A
    MIG/MAG
    3 – 400 A
    MMA
    10 – 400 A
    Welding current
    40% / 400 A | 60% / 360 A | 100% / 320 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 34.0 V
    MMA
    20.4 – 36.0 V
    99 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    49.9 kg / 110.01 lb.
    75 dB (A)
    40.9 W
    Welding machine efficiency at 400 A / 36.0 V
    87%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 400i DC /nc
    Mains voltage (U1)
    3 x 380 V
    19.3 A
    3 x 400 V
    18.4 A
    3 x 460 V
    16.1 A
    3 x 380 V
    26.2 A
    3 x 400 V
    24.9 A
    3 x 460 V
    21.7 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    ~ 92 mOhm
    Type B
    TIG
    3 – 400 A
    MIG/MAG
    3 – 400 A
    MMA
    10 – 400 A
    Welding current
    40% / 400 A
    60% / 360 A
    100% / 320 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 34.0 V
    MMA
    20.4 – 36.0 V
    99 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    48.0 kg / 105.82 lb.
    75 dB (A)
    40.9 W
    87%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 400i DC /MV/nc
    Mains voltage (U1)
    3 x 200 V
    37.8 A
    3 x 230 V
    34.1 A
    3 x 240 V
    30.7 A
    3 x 380 V
    19.3 A
    3 x 400 V
    18.4 A
    3 x 460 V
    16.1 A
    3 x 600 V
    15.7 A
    3 x 200 V
    53.3 A
    3 x 230 V
    45.6 A
    3 x 240 V
    41.7 A
    3 x 380 V
    26.2 A
    3 x 400 V
    24.9 A
    3 x 460 V
    21.7 A
    3 x 600 V
    20.8 A
    Mains fuse
    3 x 200/230/240 V
    63 A slow-blow
    3 x 380/400/460 V
    35 A slow-blow
    3 x 600 V
    16 A slow-blow
    -10 / +6%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    97 mOhm
    Type B
    TIG
    3 – 400 A
    MIG/MAG
    3 – 400 A
    MMA
    10 – 400 A
    Welding current
    40% / 400 A
    60% / 360 A
    100% / 320 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 34.0 V
    MMA
    20.4 – 36.0 V
    104 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    49.3 kg / 108.69 lb.
    75 dB (A)
    40.9 W
    Welding machine efficiency at 400 A / 36 V
    87%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 500i DC
    Mains voltage (U1)
    3 x 400 V
    21.9 A
    34.4 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    55 mOhm
    Type B
    TIG
    3 – 500 A
    MIG/MAG
    3 – 500 A
    MMA
    10 – 500 A
    Welding current
    40% / 500 A
    60% / 430 A
    100% / 360 A
    TIG
    10.1 – 30.0 V
    MIG/MAG
    14.2 – 36.5 V
    MMA
    20.4 – 40.0 V
    99 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    51.5 kg / 113.54 lb.
    75 dB (A)
    40.5 W
    Welding machine efficiency at 500 A / 40.0 V
    88%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 500i DC /nc
    Mains voltage (U1)
    3 x 380 V
    22.8 A
    3 x 400 V
    21.9 A
    3 x 460 V
    19.2 A
    3 x 380 V
    36.0 A
    3 x 400 V
    34.4 A
    3 x 460 V
    30.0 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    55 mOhm
    Type B
    TIG
    3 – 500 A
    MIG/MAG
    3 – 500 A
    MMA
    10 – 500 A
    Welding current
    40% / 500 A
    60% / 430 A
    100% / 360 A
    TIG
    10.1 - 30 V
    MIG/MAG
    14.2 – 36.5 V
    MMA
    20.4 – 40.0 V
    99 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    49.7 kg / 109.57 lb.
    75 dB (A)
    40.5 W
    88%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 500i DC /MV/nc
    Mains voltage (U1)
    3 x 200 V
    43.1 A
    3 x 230 V
    38.9 A
    3 x 240 V
    36.2 A
    3 x 380 V
    22.8 A
    3 x 400 V
    21.9 A
    3 x 460 V
    19.2 A
    3 x 600 V
    18.4 A
    3 x 200 V
    68.1 A
    3 x 230 V
    62.0 A
    3 x 240 V
    57.3 A
    3 x 380 V
    36.0 A
    3 x 400 V
    34.4 A
    3 x 460 V
    30.0 A
    3 x 600 V
    27.2 A
    Mains fuse
    3 x 200/230/240 V
    63 A slow-blow
    35 A slow-blow
    -10 / +6%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    71 mOhm
    Type B
    TIG
    3 – 500 A
    MIG/MAG
    3 – 500 A
    MMA
    10 – 500 A
    Welding current
    U1 = 200 - 240 V
    TIG, MIG/MAG
    40% / 500 A
    60% / 430 A
    100% / 360 A
    U1 = 200 - 240 V
    MMA
    40% / 450 A
    60% / 390 A
    100% / 320 A
    U1 = 380 - 600 V
    40% / 500 A
    60% / 430 A
    100% / 360 A
    TIG
    10.1 – 30.0 V
    MIG/MAG
    14.2 – 36.5 V
    MMA
    20.4 – 40.0 V
    104 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 510 mm
    Weight
    51.3 kg / 113.10 lb.
    75 dB (A)
    40.5 W
    88%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 300i AC/DC
    Mains voltage (U1)
    3 x 400 V
    15.5 A
    18.4 A
    Mains fuse
    16 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    143 mOhm
    Type B
    TIG
    3 – 300 A
    MIG/MAG
    3 – 300 A
    MMA
    10 – 300 A
    Welding current
    40% / 300 A
    60% / 260 A
    100% / 240 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 29.0 V
    MMA
    20.4 – 32.0 V
    101 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    27.8 x 11.8 x 28.41 in.
    Weight
    64.4 kg / 141.98 lb.
    77 dB (A)
    48.5 W
    83%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 300i AC/DC /nc
    Mains voltage (U1)
    3 x 380 V
    16.3 A
    3 x 400 V
    15.5 A
    3 x 460 V
    13.6 A
    3 x 380 V
    19.4 A
    3 x 400 V
    18.4 A
    3 x 460 V
    16.2 A
    Mains fuse
    16 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    143 mOhm
    Type B
    TIG
    3 – 300 A
    MIG/MAG
    3 – 300 A
    MMA
    10 – 300 A
    Welding current
    40% / 300 A
    60% / 260 A
    100% / 240 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 29.0 V
    MMA
    20.4 – 32.0 V
    101 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    63.1 kg / 139.11 lb.
    75 dB (A)
    48.5 W
    83%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 300i AC/DC /MV/nc
    Mains voltage (U1)
    3 x 200 V
    31.0 A
    3 x 230 V
    26.7 A
    3 x 240 V
    23.5 A
    3 x 380 V
    16.3 A
    3 x 400 V
    15.5 A
    3 x 460 V
    13.6 A
    3 x 600 V
    12.3 A
    3 x 200 V
    37.9 A
    3 x 230 V
    32.5 A
    3 x 240 V
    28.8 A
    3 x 380 V
    19.4 A
    3 x 400 V
    18.4 A
    3 x 460 V
    16.2 A
    3 x 600 V
    14.9 A
    Mains fuse
    3 x 200/230/240 V
    35 A slow-blow
    16 A slow-blow
    -10 / +6%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    121 mOhm
    Type B
    TIG
    3 – 300 A
    MIG/MAG
    3 – 300 A
    MMA
    10 – 300 A
    Welding current
    40% / 300 A
    60% / 260 A
    100% / 240 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 29.0 V
    MMA
    20.4 – 32.0 V
    102 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    64.5 kg / 142.20 lb.
    77 dB (A)
    48.5 W
    83%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 400i AC/DC
    Mains voltage (U1)
    3 x 400 V
    22.7 A
    30.8 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    97 mOhm
    Type B
    TIG
    3 – 400 A
    MIG/MAG
    3 – 400 A
    MMA
    10 – 400 A
    Welding current
    40% / 400 A
    60% / 360 A
    100% / 320 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 34.0 V
    MMA
    20.4 – 36.0 V
    101 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    68.8 kg / 151.68 lb.
    77 dB (A)
    46.7 W
    84%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 400i AC/DC /nc
    Mains voltage (U1)
    3 x 380 V
    23.9 A
    3 x 400 V
    22.7 A
    3 x 460 V
    19.8 A
    3 x 380 V
    32.3 A
    3 x 400 V
    30.8 A
    3 x 460 V
    27.1 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    97 mOhm
    Type B
    TIG
    3 – 400 A
    MIG/MAG
    3 – 400 A
    MMA
    10 – 400 A
    Welding current
    40% / 400 A
    60% / 360 A
    100% / 320 A
    TIG
    10.1 – 26.0 V
    MIG/MAG
    14.2 – 34.0 V
    MMA
    20.4 – 36.0 V
    101 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    66.9 kg / 147.49 lb.
    77 dB (A)
    46.7 W
    84%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 400i
    AC/DC /MV/nc
    Mains voltage (U1)
    3 x 200 V
    45.7 A
    3 x 230 V
    39.4 A
    3 x 240 V
    34.6 A
    3 x 380 V
    23.9 A
    3 x 400 V
    22.7 A
    3 x 460 V
    19.8 A
    3 x 600 V
    18.0 A
    3 x 200 V
    63.3 A
    3 x 230 V
    54.5 A
    3 x 240 V
    47.1 A
    3 x 380 V
    32.3 A
    3 x 400 V
    30.8 A
    3 x 460 V
    27.1 A
    3 x 600 V
    25.1 A
    Mains fuse
    3 x 200/230/240 V
    63 A slow-blow
    35 A slow-blow
    -10 / +10%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    approx. 90 mOhm
    Type B
    TIG
    3 - 400 A
    MIG/MAG
    3 - 400 A
    MMA
    10 - 400 A
    Welding current
    40% / 400 A
    60% / 360 A
    100% / 320 A
    TIG
    10.1 - 26.0 V
    MIG/MAG
    14.2 - 34.0 V
    MMA
    20.4 - 36.0 V
    102 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    Dimensions L x W x H
    706 x 300 x 720 mm
    Weight
    68.4 kg / 150.80 lb.
    77 dB (A)
    46.7 W
    Power source efficiency at
    400 A / 36.0 V
    84%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 500i AC/DC
    Mains voltage (U1)
    3 x 400 V
    24.8 A
    39.2 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    50 mOhm
    Type B
    TIG
    3 – 500 A
    MIG/MAG
    3 – 500 A
    MMA
    10 – 500 A
    Welding current
    40% / 500 A
    60% / 430 A
    100% / 360 A
    TIG
    10.1 – 30.0 V
    MIG/MAG
    14.2 – 36.5 V
    MMA
    20.4 – 40.0 V
    101 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    69.6 kg / 153.44 lb.
    77 dB (A)
    48.5 W
    85%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 500i AC/DC /nc
    Mains voltage (U1)
    3 x 380 V
    26.0 A
    3 x 400 V
    24.8 A
    3 x 460 V
    21.6 A
    3 x 380 V
    41.0 A
    3 x 400 V
    39.2 A
    3 x 460 V
    34.2 A
    Mains fuse
    35 A slow-blow
    +/- 15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    50 mOhm
    Type B
    TIG
    3 – 500 A
    MIG/MAG
    3 – 500 A
    MMA
    10 – 500 A
    Welding current
    40% / 500 A
    60% / 430 A
    100% / 360 A
    TIG
    10.1 – 30.0 V
    MIG/MAG
    14.2 – 36.5 V
    MMA
    20.4 – 40.0 V
    101 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    67.8 kg / 149.47 lb.
    77 dB (A)
    48.5 W
    85%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    iWave 500i AC/DC /MV/nc
    Mains voltage (U1)
    3 x 200 V
    44.6 A
    3 x 230 V
    44.0 A
    3 x 240 V
    43.1 A
    3 x 380 V
    26.0 A
    3 x 400 V
    24.8 A
    3 x 460 V
    21.6 A
    3 x 600 V
    18.9 A
    3 x 200 V
    70.5 A
    3 x 230 V
    69.9 A
    3 x 240 V
    65.5 A
    3 x 380 V
    41.0 A
    3 x 400 V
    39.2 A
    3 x 460 V
    34.2 A
    3 x 600 V
    29.8 A
    Mains fuse
    3 x 200/230/240 V
    63 A slow-blow
    35 A slow-blow
    -10 / +6%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    52 mOhm
    Type B
    TIG
    3 – 500 A
    MIG/MAG
    3 – 500 A
    MMA
    10 – 500 A
    Welding current
    U1 = 200 - 240 V
    TIG, MIG/MAG
    40% / 500 A
    60% / 430 A
    100% / 360 A
    U1 = 200 - 240 V
    MMA
    40% / 450 A
    60% / 390 A
    100% / 320 A
    U1 = 380 - 600 V
    40% / 500 A
    60% / 430 A
    100% / 360 A
    TIG
    10.1 – 30.0 V
    MIG/MAG
    14.2 – 36.5 V
    MMA
    20.4 – 40.0 V
    102 V
    10 kV
    Protection class
    IP 23
    EMC emission class
    A 2)
    706 x 300 x 720 mm
    Weight
    69.2 kg / 152.56 lb.
    77 dB (A)
    48.5 W
    85%
    7 bar/102 psi
    1)
    2)
    1. Appendix
    2. Technical data
    China Energy Label
    iWave 300i DC /nc
    iWave 400i DC /nc
    iWave 500i DC /nc
    1. Appendix
    2. Technical data
    Radio parameters
    Compliance with directive 2014/53/EU - Radio Equipment Directive (RED)
    The following table provides information on the frequency bands used and the maximum HF transmission power of Fronius wireless radio products sold in the EU, in accordance with Articles 10.8 (a) and 10.8 (b) of the RED.
    Frequency range
    Channels used
    Power
    Modulation
    2412 - 2462 MHz
    Channel: 1 - 11 b, g, n HT20
    Channel: 3 - 9 HT40
    < 16 dBm
    802.11b: DSSS
    (1 Mbps DBPSK, 2 Mbps DQPSK, 5.5/11 Mbps CCK)
    802.11 g: OFDM
    (6/9 Mbps BPSK, 12/18 Mbps QPSK, 24/36 Mbps 16-QAM, 48/54 Mbps 64-QAM)
    802.11n: OFDM
    (6.5 Mbps BPSK, 13/19 Mbps QPSK, 26/39 Mbps16-QAM, 52/58.5/65 Mbps 64-QAM)
    13.56 MHz
    -14.6 dBµA/m at 10 m
    Functions:
    R/W, card emulation and P2P
    Protocol standards:
    ISO 14443A/B, ISO15693, ISO18092,
    NFCIP-2,
    Data rate:
    848 kbps
    Reader/writer, card emulation, peer to peer modes
    2402 - 2482 MHz
    0 - 39
    < 4 dBm
    GFSK
    1. Appendix
    2. Technical data
    Catalog C
    Template for No. 52 regulation warning sentences
    Micropower equipment shall indicate the following contents in its product operation instructions (including those with electronic display) in Chinese:
    (1)
    The specific provisions and use scenarios which comply with "Catalog and Technical Requirements of Micropower Short-Range Radio Transmission Equipment"; the type and performance of the antenna used, the control, adjustment and switching methods;
    Specific provisions:
    Class C equipment:
    1. Frequency: 13553-13567KHz
    2. Magnetic field intensity at 10 m: no more than 42dB ?A /m
      (quasi-peak detection)
    3. Frequency tolerance: 100×10-6.
    4. Special frequency band radiation emission: for 13553-13567KHz frequency band equipment, the magnetic field intensity at 10 meters at both ends of the frequency band offset 140KHz frequency range is no more than 9dB microA /m (quasi-peak detection).
      Usage scenario: Lock and unlock
      Antenna type: frame antenna
      Antenna performance: 1
      Control, adjustment and switch product use method: only one version available
    (2)
    It is not allowed to change the use scene or use conditions, expand the range of transmission frequency, or increase the transmission power (including the amount) without authorization Install a radio frequency power amplifier outside), and do not change the transmitting antenna without authorization;
    (3)
    It shall not cause harmful interference to other lawful radio stations, nor shall it claim protection from such harmful interference;
    (4)
    It shall be subjected to interference by equipment for industrial, scientific and medical (ISM) applications radiating radio frequency energy or otherwise legally Radio (station) interference;
    (5)
    If harmful interference is caused to other legitimate radio stations, the radio station shall stop using them immediately and take measures Eliminate interference before continuing to use;
    (6)
    Radio observatories and meteorological radars set up in the aircraft or in accordance with laws and regulations, relevant State regulations and standards
    Electromagnetism of military and civilian radio stations (stations) and airports, such as stations, satellite earth stations (including measurement and control, ranging, receiving and navigation stations) The use of micro-power equipment within the environmental protection area shall comply with the provisions of the competent authorities for electromagnetic environmental protection and related industries;
    (7)
    It is forbidden to use all kinds of model remote controls in an area with a radius of 5000 meters and the center of the airport runway as the center of the circle;
    (8)
    environmental conditions of the temperature and voltage when the micro-power equipment is in use.
    Temperature when the product is used: -40/+85
    Voltage when the product is in use: +24V DC
    1. Appendix
    Hazardous Substances
    Part Name
    Lead
    (Pb)
    Mercury
    (Hg)
    Cadmium
    (Cd)
    hexavalent
    chromium
    (Cr (VI))
    polybrominated
    biphenyls
    (PBB)
    polybrominated
    diphenyl ethers
    (PBDE)
    diethylhexyl phthalate
    (DEHP)
    benzyl butyl phthalate
    (BBP)
    dibutyl phthalate
    (DBP)
    di-isobutyl phthalate
    (DOBP)
    Packaging
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Housing
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Metal Parts
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    PCB
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Cables and Cable Assemblies
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    This table is prepared in accordance with the provisions of SJ/T 11364.
    O
    Indicates that the hazardous substance contained in all of the homogeneous materials for this part is below the limit requirement of GB/T 26572.
    X
    Indicates that the hazardous substance contained in at least one of the homogeneous materials used for this part is above the limit requirement of GB/T 26572.
    All parts in this table marked with an "X" comply with the European Union's RoHS legislation.
    Part Name
    Lead
    (Pb)
    Mercury
    (Hg)
    Cadmium
    (Cd)
    hexavalent
    chromium
    (Cr (VI))
    polybrominated
    biphenyls
    (PBB)
    polybrominated
    diphenyl ethers
    (PBDE)
    (DEHP)
    (BBP)
    dibutyl phthalate
    (DBP)
    (DOBP)
    Packaging
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Housing
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Metal Parts
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    PCB
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    X
