Indicates an immediate danger.
Indicates a possibly dangerous situation.
Indicates the possibility of flawed results and damage to the equipment.
The WeldCube Connector is integrated into an existing welding system for data collection.
Therefore, all safety and warning notices relevant to the welding process apply to the WeldCube Connector.
Observe the Operating Instructions for all system components of the welding system, in particular the safety instructions and warning notices!
The Operating Instructions must always be kept to hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device:For the location of the safety and danger notices on the device, refer to the section headed "General Information" in the operating instructions for the device.
Before switching on the device, eliminate any faults that could compromise safety.
The device is intended exclusively for measuring welding data in the designated power range as shown on the rating plate.
The device must be properly installed and set up to ensure it functions as intended.
Utilization for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended purpose. The manufacturer accepts no liability for any damage resulting from improper use.
Intended use also meansThe manufacturer shall not be liable for faulty or incorrect work results.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
This may affect a number of device types in terms of:*) both at the interface with the public grid
See technical data
In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
IMPORTANT! Ensure secure grounding of the grid connection!
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Local regulations and national guidelines may mean that a residual current circuit breaker is required when connecting a device to the public grid.
The residual current circuit breaker recommended for the device by the manufacturer can be found in the technical data.
The device produces a maximum noise level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation in relation to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
A workplace-specific emission value for welding (and cutting) cannot be specified because this value depends on the welding process and the environmental conditions. It is influenced by a wide range of parameters, such as the welding process itself (MIG/MAG, TIG welding), the selected current type (direct current, alternating current), the power range, the type of weld metal, the resonance properties of the workpiece, the workplace environment, and many other factors.
The fumes produced during welding contain toxic gases and vapors.
Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
Use at-source extraction source and a room extraction system.
If possible, use a welding torch with an integrated extraction device.
Keep your head out of the welding fumes and gases.
Take the following precautionary measures for fumes and harmful gases:Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
Use a welding helmet with air supply if there is insufficient ventilation.
If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
The following components are factors that determine how toxic the welding fumes are:Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
Flying sparks can cause fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
Keep suitable, tested fire extinguishers on hand.
Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
Do not touch voltage-carrying parts inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wirespool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Before every use, check power connections for secure fit by hand.
In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
Do not wrap cables or leads around your body or parts of the body.
Concerning the electrode (rod electrode, tungsten electrode, welding wire, etc.)The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
Switch off unused devices.
When working at elevated heights, wear a safety harness to prevent falls.
Before working on the device, switch off the device and remove the grid plug.
Secure the device to prevent the grid plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
After opening the device:If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Covers and side panels must only be opened/removed during maintenance and repair work.
During operationThe protrusion of welding wire from the welding torch represents a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
Do not touch the workpiece during or after welding – risk of burns.
Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Leave the welding torch and other parts with a high operating temperature to cool before working on them.
Special regulations apply in areas at risk of fire or explosion
– follow the appropriate national and international regulations.
Power sources for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the power source may not be located in such areas.
Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
If the device is equipped with a carrier belt or handle, then this is used exclusively for transport by hand. The carrier belt is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
All lifting equipment (belts, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
The test interval and scope must at least comply with the respective valid national standards and guidelines.
There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
Use filters if necessary.
Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
Keep shielding gas cylinders away from welding or other electrical circuits.
Risk of explosion: Never weld on a compressed shielding gas cylinder.
Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
When no welding is taking place, close the valve of the shielding gas cylinder.
Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
Risk of asphyxiation due to uncontrolled shielding gas leak
Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
Do not lift or transport any active devices. Switch off devices before transport or lifting.
Before transporting the device, completely drain the coolant and dismantle the following components:It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is switched on.
Before switching on the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
Always secure the shielding gas cylinder well and remove before transporting by crane.
Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
Only use appropriate original coolant from the manufacturer.
Do not mix original coolant from the manufacturer with other coolants.
Only connect system components from the manufacturer to the cooling unit circuit.
If there is damage due to use of other system components or other coolants, the manufacturer accepts no liability for this and all warranty claims are forfeited.
Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
When the system is cool, always check the coolant level before starting welding.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating power sources within the same 12-month interval.
A safety inspection by a certified electrician is recommended:For the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
To comply with European directives and national law, waste electrical and electronic equipment must be collected separately and sent for environmentally-friendly recycling. Used devices must be returned to a distributor or an approved collection and recycling facility in your area. Proper disposal of used devices promotes the sustainable recycling of material resources. Ignoring this may have potentially adverse effects on the environment and your health.
Packaging materials
Materials collected separately. Check the regulations in your area. Reduce the volume of cardboard.
Devices with the CE label satisfy the essential requirements of the low-voltage and electromagnetic compatibility directive (e.g., relevant product standards of the EN 60974 series).
Fronius International GmbH declares that the device complies with Directive 2014/53/EU. The full text of the EU Declaration of Conformity is available on the following website: http://www.fronius.com
The user is responsible for backing up any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
Copyright of these Operating Instructions remains with the manufacturer.
Text and illustrations were accurate at the time of printing. Fronius reserves the right to make changes. The contents of the Operating Instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the Operating Instructions, we will be most grateful for your comments.
With the WeldCube Connector, all welding systems involved in production can be integrated into the Fronius WeldCube Premium documentation system, regardless of manufacturer.
If the power supply is lost, the WeldCube Connector stores the last data and ensures a safe shutdown process.
The WeldCube Connector is available in the following versions:
WeldCube Connector U/I
4,044,056
Measurement of welding current and welding voltage
incl. voltage measurement adapter
WeldCube Connector U/I/WFS WSM
4,044,057
Measurement of welding current, welding voltage, and wire speed
incl. wire sensor
(for the power sources TransSteel 3000c Pulse, TransSteel 3500c, and the wirefeeder VR 5000)
WeldCube Connector U/I/WFS Euro
4,044,058
incl. Euro wire sensor
WeldCube Connector Advanced
4,044,067
Wire sensor optional (see options from page (→))
4,044,056
4,044,057
incl. wire sensor
4,044,058
4,044,067
The WeldCube Connector is used in manual and automated MIG/MAG, TIG, and MMA applications.
Regardless of the welding process, the WeldCube Connector is always integrated between the power source and the grounding cable.
The current is measured at the current sockets of the power source.
For functional system integration, the following components must be connected:
The WeldCube Connector is powered via the network cable using Power over Ethernet (PoE).
The power supply via PoE can be provided by the central IT infrastructure or a PoE injector on site. The PoE injector is then integrated into the data line between the network distributor and the WeldCube Connector.
Welding is dangerous. The following basic requirements must be met:
Installing and integrating the WeldCube Connector requires an understanding of network technology.
For detailed information, consult your network administrator.
PoE injector RJ45 30 W / 802.3at / PoE+ | 42,0411,0213 |
CE IEC power cable 2 m | 43,0004,2951 |
Network cable M12-X / RJ45, 5 m | 42,0411,0232 |
Network cable M12-X / RJ45, 10 m | 42,0411,0233 |
Network cable M12-X / RJ45, 15 m | 42,0411,0234 |
Network cable M12-X / RJ45, 20 m | 42,0411,0235 |
OPT/WCC Sensor Cable EXT 5m | 4,051,547 |
OPT/WCC Sensor Cable EXT 10m | 4,051,548 |
OPT/WCC Mounting Set TSt | 4,101,361 |
OPT/WCC Mounting Set 1 | 4,101,362 |
OPT/WCC Mounting Set 2 | 4,101,363 |
OPT/WCC Wire Sensor EUR | 4,101,372 |
OPT/WCC Wire Sensor WSM | 4,101,373 |
Holding magnet * | 4,100,265 |
| * | 2 holding magnets are required for the WeldCube Connector. |
FCC
This device conforms to the limits for a Class B digital device, pursuant to Part 15 of the FCC regulations. These limit values are designed to provide reasonable protection against harmful interference in a residential installation. This device generates and uses high frequency energy and, if not used in accordance with the instructions, may interfere with radio communications. However, there is no guarantee that interference will not occur in a particular installation.
If this device does cause harmful interference to radio or television reception, which can be determined by turning the device off and on again, the user is encouraged to try to correct the interference using one or more of the following measures:FCC ID: QKWSPB209A
Industry Canada RSS
This device complies with Industry Canada license-exempt RSS standards. Operation is subject to the following conditions:
| (1) | This device must not cause any harmful interference. |
| (2) | This device must not be affected by external sources of interference, including interference that may impair operation. |
IC: 12270A-SPB209A
EU
Compliance with directive 2014/53/EU - Radio Equipment Directive (RED)
The antennas used for this transmitter must be installed in such a way that a minimum distance of 20 cm from all persons is maintained. They must not be installed or operated in conjunction with another antenna or transmitter. OEM integrators and end users must ensure the operating conditions of the transmitter comply with radio frequency exposure guidelines.
The word mark Bluetooth® and the Bluetooth® logos are registered trademarks and property of Bluetooth SIG, Inc. and are used by the manufacturer under license. Other trademarks and trade names are the property of their respective owners.
MIG/MAG
| (1) | Computer for access to WeldCube Premium |
| (2) | Ethernet switch with PoE |
| (3) | Power supply via PoE (Power over Ethernet) |
| (4) | WeldCube Premium Server (physical or VM) |
| (5) | Voltage measurement adapter |
| (6) | Wirefeeder |
| (7) | Power source |
| (8) | WeldCube Connector U/I |
| (9) | Grounding cable |
| (10) | Welding torch |
MIG/MAG with wire drive integrated in the power source
| (6) | Power source |
| (7) | WeldCube Connector U/I |
| (8) | Grounding cable |
| (9) | Welding torch |
TIG-DC, TIG-AC
MMA (with TIG power source)
| (9) | Electrode holder |
MIG/MAG
| (6) | Wirefeeder |
TIG-DC, TIG-AC
MIG/MAG
| (5) | Power source |
| (6) | Wirefeeder |
| (7) | Euro wire sensor |
| (9) | Return lead cable |
| (5) | Euro wire sensor |
| (8) | Return lead cable |
The system configuration for TransSteel welding systems with WeldCube Connector U/I/WFS WSM is the same as the system configuration for WeldCube Connector U/I/WFS Euro, except that instead of the Euro wire sensor, a wire sensor is integrated into the power source or wirefeeder itself.
The wire sensor is either installed at the factory or can be retrofitted by suitably trained and qualified personnel.
For details on installing the wire sensor, refer to the "WeldCube Connector wire sensor TransSteel" Installation Instructions - 42,0410,2663.
The system configuration for welding systems with WeldCube Connector Advanced is the same as the system configuration for WeldCube Connector U/I/WFS Euro.
Euro wire sensor or a wire sensor integrated into the TransSteel power sources are optionally available.
| (1) | M12 socket, X-coding For connecting a network cable |
| (2) | M5 threaded bushing 4 pieces per side For mounting the WeldCube Connector for the welding system |
| (3) | Status LED Warnings, errors, and current operating states are output via the status LED |
| (4) | Power LED Information on the electrical supply to the WeldCube Connector is output via the Power LED The LEDs are described in the following section |
| (5) | Return lead cable with bayonet connector For connecting to the ground current socket of the power source NOTE!The ground connection on the power source depends on the welding process and does not necessarily have to coincide with the (-) current socket! |
| (6) | Ground current socket with bayonet latch For connecting the welding circuit return lead cable |
| (7) | Sensor connection Laboratory socket (for WeldCube Connector U/I) For connecting the voltage measurement adapter 19-pin sensor socket (for WeldCube Connector U/I/WFS WSM, WeldCube Connector U/I/WFS Euro, and WeldCube Connector Advanced) For connecting the wire sensor |
| No. | Function |
| (8) | Measuring cable For connecting to the laboratory socket for WeldCube Connect U/I |
| (9) | (+) Current socket with bayonet latch For connecting the (+) welding circuit cable from the interconnecting hosepack |
| (10) | (+) cable with bayonet connector For connecting to the (+) current socket of the power source |
| No. | Function |
| (11) | Measuring cable For connecting to the 19-pin sensor socket on WeldCube Connector U/I/WFS WSM, WeldCube Connector U/I/WFS Euro, and WeldCube Connector Advanced |
| (12) | Euro adapter For connecting to the power source |
| (13) | Euro torch connector For connecting the welding torch |
| No. | Function |
| No. | Function |
Power LED
lights up green:
electrical supply available
lights up orange:
no electrical supply available - power is currently being supplied internally, until all data is saved
does not light up:
Status LED
When the electrical supply is on, the status LED may light up or flash in the following colors:
lights up green:
device ready for operation, everything OK
flashes green (at 5 Hz):
initial connection established between WeldConnect app and WeldCube Connector, e.g., for commissioning or configuration purposes
lights up orange:
warning
flashes orange (at 0.5 Hz):
device not yet in operation
lights up red:
error
a pending error can be checked in the SmartManager or WeldCube Premium logbook.
flashes in the current color (at 2.5 Hz):
welding detected
| (3) | WeldCube Premium Server |
| (4) | Power supply via PoE (Power over Ethernet) |
| (5) | Network cable |
| (6) | WeldCube Connector |
| (7) | Ground connection on the power source |
| (2) | Ethernet switch |
| (4) | WLAN AccessPoint |
| (5) | Power supply via PoE (Power over Ethernet) |
The WeldCube Connector suppresses HF high voltage pulses!
If a TIG welding process with integrated WeldCube Connector needs to be ignited by means of HF high-voltage pulses, HF ignition will not take place.
If available, only connect cable to an HF-free current socket (e.g. for manual metal arc welding).
If an HF-free current socket is not available, deactivate HF ignition.
HF = high frequency
Before each use of the WeldCube Connector:When measuring TIG-AC welds, an arithmetically rectified value is documented.
Part designation, part serial number and weld seam number can be sent to the WeldCube Connector via the Fronius Data Channel.
The Fronius Data Channel is a TCP / IP server that runs on the WeldCube Connector administration port. This port is used for documentation and communication as well as servicing purposes and this interface is monitored on TCP port 4714.
A PC program or a higher-level controller establishes a TCP socket connection to the IP address of the WeldCube Connector at TCP port 4714. The parameters are transmitted as key or set value text lists separated by semicolons.
The following parameters are supported:
| No. | Parameter |
| 1 | Process active During an active welding process (from gas pre-flow at the start of welding to gas post-flow at the end of welding), the WeldCube Connector outputs the process active signal = 1 to the controller. |
| 2 | Current flow When the current flow is active during welding, the WeldCube Connector outputs the current flow signal = 1 to the controller. |
| 3 | Part item number The controller gives the WeldCube Connector the item number of the part being welded using ASCII characters A-Z, a-z and 0-9. |
| 4 | Part serial number The controller gives the WeldCube Connector the serial number of the part being welded using ASCII characters A-Z, a-z and 0-9. |
| 5 | Seam number The controller gives the WeldCube Connector the seam being welded (welding position) using ASCII characters 0-9. |
Data transfer via the Fronius Data Channel can be tested using the following programs:
A TCP socket connection must first be established for the data transfer.
Read and understand all safety rules and user documentation for this equipment and all system components.
The WeldCube Connector is commissioned using a smartphone and the Fronius WeldConnect app.
If the power source has a function for determining the welding circuit resistance R, determine the welding circuit resistance of the welding system before commissioning using the WeldCube Connector that is in place.
The welding circuit resistance value must be correct to get accurate measurement results!
Enter the welding circuit resistance value found using the Installation Wizard at Setup 5/6.
If there is no function for determining the welding circuit resistance on the power source, use the calculation tool in the Installation Wizard at Setup 5/6.
For data analysis with WeldCube Premium:
The recorded welding operations are then available in the Fronius WeldCube Premium documentation system under Machines / WeldCube Connector.
With the SmartManager, the WeldCube Connector has its own website.
Once the WeldCube Connector is connected to a computer via a network cable or WLAN or is integrated into a network, the SmartManager of the WeldCube Connector can be accessed via the IP address.
IE 10 or higher or another modern browser is required in order to access the SmartManager.
The following entries are available for the WeldCube Connector:
The SmartManager of the WeldCube Connector is displayed.
When logging into the SmartManager, the unlock function can be used to unlock a WeldCube Connector that was unintentionally locked and enable it for all functions.
A .txt file with the following file name is saved in the computer's download folder:
unlock_SN[serial number]_YYYY_MM_DD_hhmmss.txt
Fronius will reply by e-mail with a one-time unlock file with the following file name:
response_SN[serial number]_YYYY_MM_DD_hhmmss.txt
The Admin password of the WeldCube Connector is reset once to factory settings.
Click on this symbol to
Changing the password for the SmartManager:
By clicking on this symbol, the units and standards for the WeldCube Connector can be set.
The settings depend on the user who is logged in.
Click on the language abbreviation to display the languages available for the SmartManager.
To change the language, click on the desired language.
The current status of the WeldCube Connector is displayed between the Fronius logo and the displayed WeldCube Connector.
Caution/warning | Error on the WeldCube Connector * |
Welding in progress | WeldCube Connector is ready for operation (online) |
WeldCube Connector is not ready for operation (offline) |
| * | In the event of an error, a red error line with the error number appears above the line with the Fronius logo. After clicking on the error line, an error description is displayed. |
Click on the Fronius logo to open the Fronius homepage: www.fronius.com
Any current WeldCube Connector data is displayed:
Machine name | Hall Cell | Additional information |
ACTUAL | ||
Welding current | Welding voltage | Wire speed * |
Current arc power | ||
Current arc energy | ||
Arc time | Total operating hours | |
* Only for WeldCube Connector U/I/WFS WSM and WeldCube Connector U/I/WFS Euro
ACTUAL | ||
The Documentation logbook entry shows the last 100 logbook entries. These logbook entries can be welds, errors, warnings, notifications and events.
The "Time filter" button can be used to filter the displayed data by a specific time period. This is entered with date (yyyy MM dd) and time (hh mm), each from - to.
An empty filter reloads the most recent welding operations.
The display of welding operations, errors, and events can be deactivated.
The following data is displayed:
| (1) | Log type |
| (2) | Seam number |
| (3) | Part item number |
| (4) | Part serial number |
| (5) | Start time (local time) |
| (6) | Welding duration |
| (7) | Welding current in A (rectified average) |
| (8) | Welding voltage in V (rectified average) |
| (9) | Wire speed in m/min * |
| (10) | IP - arc power in W (based on real-time values according to ISO/TR 18491) |
| (11) | IE - arc energy in kJ (as the total throughout the entire welding process according to ISO/TR 18491) |
| (12) | reserved for other data |
| * | Only for WeldCube Connector U/I/WFS WSM and WeldCube Connector U/I/WFS Euro |
Additional values can be also displayed by clicking on the "Insert column" button:
| (1) | Log type |
| (2) | Seam number |
In the Documentation logbook entry, the sampling rate for the documentation and rules for hiding the ignition phase can be set under Basic settings.
Sampling rate
0.1 - 100 s / off
Factory setting: 0.1 s
0.1 - 100.0 s
Documentation is saved at the set sampling rate.
off
Sampling rate is deactivated, only average values are stored.
Hide ignition phase
Period of time for which the ignition phase of the weld is to be hidden
(e.g. in order to prevent the ignition phase from affecting the measurement results in the case of short welds)
0.1 - 2 s / off
0.1 - 2 s
The welding data is not documented until the set time value has elapsed.
off
The ignition phase is documented at the same time.
The welding circuit resistance can be adjusted under the default settings.
The currently set resistance is displayed.
The power source configuration can be viewed and modified under Designation & location.
Under Date and Time, the time zone, date, and time can be set.
The setting can be made manually or automatically.
Under Network settings, the data for integrating the WeldCube Connector into a network can be entered:
ManagementStarting a backup
Finding a recovery file
Starting a backup
If you have any questions about configuration, contact your network administrator.
Under the User administration entry
User management is created on one WeldCube Connector and can then be saved with the export/import function and transferred to other WeldCube Connectors.
Existing users can be viewed, changed and deleted, new users can be created.
Viewing/changing a user:
Deleting a user:
Creating a user:
Existing user roles can be viewed, changed and deleted, new user roles can be created.
Viewing/changing a user role:
The "Administrator" role cannot be changed.
Deleting a user role:
The "Administrator" and "locked" roles cannot be deleted.
Creating a user role:
Exporting users and user roles from a WeldCube Connector
User management for the WeldCube Connector is stored in the computer's download folder.
File format: userbackup_SNxxxxxxxx_YYYY_MM_DD_hhmmss.user
SN = serial number, YYYY = year, MM = month, DD = day
hh = hour, mm = minute, ss = second
Importing users and user roles into a WeldCube Connector
User management is stored on the WeldCube Connector.
To activate a CENTRUM server
(CENTRUM = Central User Management)
The Overview entry displays the components of the WeldCube Connector with all the available information, e.g., firmware version, item number, serial number, production date, etc.
Click on the "Expand all groups" button to see further details about the individual components.
Example SCU1:
Click on the "Collapse all groups" button to hide the details of the system components.
Click on the "Export component overview as" button to create an XML file from the details of the system components. This XML file can either be opened or saved.
Under the Update entry, the firmware of the WeldCube Connector can be updated.
The current firmware version is displayed.
To update the firmware of the WeldCube Connector:
After the update has been successfully completed, a confirmation message is displayed.
The SmartManager is not available during the restart.
After the restart, the SmartManager may no longer be available.
If you select No, the new software functions will be activated the next time the power is turned on/off.
After a successful update, a confirmation and the current firmware version is displayed.
Then log into the SmartManager again.
Under the Update entry, the Fronius WeldConnect mobile application can also be called up. |
WeldConnect can be used to perform the following functions:
Fronius WeldConnect is available as follows:
For more information on Fronius WeldConnect, visit:
An error is indicated by a red lit or red flashing status LED on the WeldCube Connector.
The error can be checked in the SmartManager or WeldCube Premium logbook.
| Cause: | Connection error to the sensor PC board |
| Remedy: | Contact the Fronius service team |
| Cause: | The backup supply is defective. |
NOTE!If the backup supply is not available, a disconnection of the electrical supply may result the recorded welding data of the last 24 hours being lost! A permanent connection of the WeldCube Connector to WeldCube Premium can reduce the loss of recorded welding data in the event of a fault. | |
| Cause: | Internal temperature of the WeldCube Connector is too low or too high |
| Remedy: | Change the position of the WeldCube Connector |
| Cause: | Poor contact due to oxidized or damaged contact surfaces on the power plugs |
| Remedy: | Clean or replace power plugs |
| Cause: | Time and date are not set |
| Remedy: | Set the time and date (e.g. in the SmartManager or using the Fronius WeldConnect app.) |
Before starting work, switch off all devices and components involved, and disconnect them from the grid.
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
Check Euro wire sensor or wire sensor installed in TransSteel/VR 5000 monthly; if necessary, clean with compressed air up to max. 5 bar
The WeldCube Connector should be calibrated once a year by Fronius according to IEC 60974-14.
Materials should be disposed of according to valid local and national regulations.
Welding current measuring range |
Duty cycle Continuous current Pulse current |
500 A / 60 % ED max. 700 A |
Welding voltage measurement range | 0 - 141 V |
Measurement frequency * | 10 kHz |
Threshold values for recording welding data | > 8 A / > 100 ms ** |
Electrical power supply | PoE+ / 30 W |
Protection class | IP 44 |
Insulation class | B |
EMC device class | B |
Housing dimensions L x W x H | 225 x 140 x 90 mm |
Grounding cable length (housing - outer edge of bayonet connector, without pin) | 125 cm |
Weight | 3 kg |
Mark of conformity | CE, CSA |
| * | Measurements are logged as average values at the set sampling rate. To set the sampling rate, see page (→). |
| ** | The total welding time should be > 100 ms. |
| *** | Arc breaks are not detected by the WeldCube Connector. An arc break > 0.5 s is regarded as a separate weld. |
| ED | = Duty cycle |
Weight | 3 kg |
| ED | = Duty cycle |
Wire diameter | 0.8 - 2.0 mm |
Wire speed | max. 30 m/min |
Duty cycle | 500 A / 60 % ED |
Measuring cable length | 2 m |
| ED | = Duty cycle |
