en
      Operating instructionsWF 25i Dual
    • Safety Instructions
      • General
      • Intended Use
      • Environmental Conditions
      • Obligations of the Operating Company
      • Obligations of Personnel
      • Grid Connection
      • Personal Protection and Protection of Others
      • Danger from toxic gases and vapors
      • Danger from Flying Sparks
      • Risks from mains current and welding current
      • Stray welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Particular hazard areas
      • Requirement for the shielding gas
      • Danger from Shielding Gas Cylinders
      • Danger Posed by Shielding Gas Leak
      • Safety Measures at the Setup Location and during Transport
      • Safety Measures in Normal Operation
      • Maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
    • General
      • Device concept
      • System requirements
      • Description of the warnings on the device
    • Options and components
      • Trolley options
    • System configurations
      • Setup on the trolley
      • Setup on the welding boom (Welding-Boom)
      • Setup on the crane
      • System limits
    • Crane transport
      • Crane transport safety sticker
      • Crane transport of the WF 25i Dual with D300 spool holder
      • Crane transport of the WF 25i Dual with D450 spool holder without spool cover
      • Crane transport of the WF 25i Dual mounted on the trolley
    • Operating controls, connections and mechanical components
      • Safety
      • WF 25i Dual with D300 spool holder
      • WF 25i Dual with D450 spool holder
      • Wirefeeder rear
      • Wirefeeder side
      • Function of the gas-test, wire-return, and wire-threading buttons
    • Before installation and initial operation
      • Safety
      • Intended use
      • Setup regulations
    • Installing optional equipment
      • Safety
      • Mounting the D300 spool holder with cover
      • Mounting the D450 spool holder without cover
      • Mounting the crane transport option
      • Mounting the hosepack holder option
      • Mounting the tool tray option
      • Mounting the boom mounting kit option
    • Connecting the wirefeeder to the welding machine
      • Safety
      • General
      • Connecting the wirefeeder to the power source
      • Connecting the extension hosepack
    • Connecting the welding torch
      • Safety
      • Connecting a MIG/MAG welding torch
    • Inserting/changing feed rollers
      • Safety
      • General
    • Remounting the D450 brake for operation with a D300 wirespool
    • Inserting the wirespool/basket-type spool
      • Safety
      • Inserting the D300 wirespool
      • Inserting the D300 basket-type spool
      • Inserting the D450 wirespool
    • Threading the Wire Electrode
      • General
      • Preparation
      • Threading the wire electrode
      • Setting the contact pressure
    • Adjusting the brake
      • General
      • Adjusting the D300 brake
      • Design of the brake
      • Adjusting the brake on the WF 25i Dual D450
      • Design of the D450 brake
    • Commissioning
      • Safety
      • Warning of electrically live (hot), exposed parts on WF 25i Dual with spool holder D450 without spool cover
      • Requirements for commissioning
      • Commissioning
      • Note for TIG AC applications
    • Selecting the welding process line
        process line
      • Selecting the
        welding process line using the torch trigger
      • Selecting the
        welding process line using the button/LED on the wirefeeder
      • Selecting the
        welding process line using the gas-test, wire-return, and wire-threading buttons
        line on the power source or using RC Panel Pro remote control
      • Selecting the
        welding process line using the RC Panel Standard remote control
    • Troubleshooting
      • Safety
      • Troubleshooting
    • Service, maintenance and disposal
      • General
      • Safety
      • At every start-up
      • Every 6 months
      • Disposal
    • Technical data
      • WF 25i Dual
      • D300 spool holder with cover
      • D450 spool holder without cover
      • HP 70i
      • HP 95i
    • 003-10122025
    WF 25i Dual
    download
    Operating controls
    Selecting the welding process lines
    Maintenance
    Technical data
    Spare parts
    ContactLegal NoticeGeneral Terms & ConditionsData Privacy StatementCookie Policy
    Safety Instructions
    link_horizontalLink copied
    General
    The device has been manufactured using state-of-the-art technology and according to recognized safety standards. If used incorrectly or misused, however, it can cause
    • Injury or death to the operator or a third party
    • Damage to the device and other material assets belonging to the operating company
    • Inefficient operation of the equipment
    All persons involved in the commissioning, operation, maintenance, and servicing of the device must
    • Be suitably qualified
    • Have knowledge of welding
    • Have completely read and followed these Operating Instructions
    The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
    All safety and danger notices on the device must
    • Be kept in a legible state
    • Not be damaged/marked
    • Not be removed
    • Not be covered, pasted, or painted over
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
    Before switching on the device, remove any faults that could compromise safety.
    1. Safety Instructions
    General
    • Not be removed
    Intended Use
    The device is intended exclusively for the welding process specified on the rating plate.
    Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose."
    Proper use also means
    • Completely reading and obeying all instructions in the Operating Instructions
    • Completely reading and obeying all safety instructions and danger notices
    • Carrying out all the specified inspection and servicing work
    Never use the device for the following applications:
    • Thawing pipes
    • Charging batteries
    • Starting motors
    The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
    The manufacture shall also not be liable for faulty or incorrect work results.
    Temperature range of the ambient air:
    • During operation: -10°C to +40°C (14°F to 104°F)
    • During transport and storage: -20°C to +55°C (-4°F to 131°F)
    Relative humidity:
    • Up to 50% at 40°C (104°F)
    • Up to 90% at 20°C (68°F)
    Ambient air: free of dust, acids, corrosive gases or substances, etc.
    Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
    The operating company must only allow persons to work with the device if they
    • Are familiar with the basic occupational safety and accident prevention regulations and are trained in handling the device
    • Have read and understood these Operating Instructions, especially the section "Safety Rules," and have confirmed this with their signature
    • Are trained according to the requirements for the work results
    The safety-conscious work of the personnel must be checked regularly.
    All persons who are assigned to work with the device must do the following before beginning the work:
    • Follow the basic regulations for occupational safety and accident prevention
    • Read these Operating Instructions, especially the section "Safety Rules," and confirm that they have understood and will follow them by signing
    Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
    Grid Connection
    Devices with a high output can influence the energy quality of the grid due to their current consumption.
    This may affect a number of device types in terms of:
    • connection restrictions
    • criteria regarding maximum permissible grid impedance *)
    • criteria regarding the minimum required short-circuit power *)
    *) both at the interface with the public grid
    See technical data
    In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
    IMPORTANT! Ensure secure grounding of the grid connection!
    You are exposed to numerous hazards while handling the device, for example:
    • Flying sparks and pieces of hot metal
    • Arc radiation that poses a risk of injury to the eyes and skin
    • Hazardous electromagnetic fields that pose a risk of death for individuals with pacemakers
    • Electrical risks from grid current and welding current
    • Increased noise exposure
    • Harmful welding fumes and gases
    Wear suitable protective clothing when dealing with the device. The protective clothing must have the following properties:
    • Flame resistant
    • Insulating and dry
    • Covering the entire body and in good condition with no damage
    • Safety helmet
    • Cuffless pants
    Protective clothing involves the following:
    • Protecting the face and eyes from UV radiation, heat and flying sparks with a face guard featuring a regulation-compliant filter
    • Wearing regulation-compliant protective goggles with side protection behind the face guard
    • Wearing rigid, wet-insulating footwear
    • Protecting hands with appropriate gloves (featuring electrical insulation and thermal protection)
    • Wearing ear protection to reduce noise exposure and protect against injury
    Keep persons, especially children, away during the operation of the devices and during the welding process. If persons are in the vicinity, however:
    • Instruct them about all hazards (blinding hazard due to arcs, risk of injury from flying sparks, welding fumes hazardous to health, noise exposure, possible hazard due to grid current or welding current, etc.)
    • Provide suitable protective equipment or
    • Construct suitable protective walls and curtains.
    The fumes produced during welding contain toxic gases and vapors.
    Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
    Use at-source extraction source and a room extraction system.
    If possible, use a welding torch with an integrated extraction device.
    Keep your head out of the welding fumes and gases.
    Take the following precautionary measures for fumes and harmful gases:
    • Do not breathe them in.
    • Extract them from the work area using appropriate equipment.
    Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
    Use a welding helmet with air supply if there is insufficient ventilation.
    If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
    The following components are factors that determine how toxic the welding fumes are:
    • The metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaning agents, degreasers, and the like
    • The welding process used
    Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
    Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
    When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
    Flying sparks can cause fires and explosions.
    Never undertake welding near flammable materials.
    Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
    Keep suitable, tested fire extinguishers on hand.
    Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
    Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
    Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
    Do not touch voltage-carrying parts inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
    Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
    Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
    All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Before every use, check power connections for secure fit by hand.
    In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
    Do not wrap cables or leads around your body or parts of the body.
    Concerning the electrode (stick electrode, tungsten electrode, welding wire, etc.)
    • Never immerse it in liquids to cool it
    • Never touch it when the welding system is switched on
    The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
    Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
    Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
    Switch off unused devices.
    When working at elevated heights, wear a safety harness to prevent falls.
    Before working on the device, switch off the device and remove the mains plug.
    Secure the device to prevent the mains plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
    After opening the device:
    • Discharge all electrically charged components
    • Ensure that all components are disconnected from the power supply
    If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
    If the following instructions are not observed, stray welding currents may occur, which pose a risk of the following:
    • Fire
    • Overheating of parts connected to the workpiece
    • Irreparable damage to ground conductors
    • Damage to the device and other electrical equipment
    Ensure that the workpiece clamp is securely connected to the workpiece.
    Secure the workpiece clamp as close to the spot to be welded as possible.
    Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
    Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
    In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage grid.
    EMC measures
    In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
    Test and assess the immunity of equipment in the vicinity of the device in accordance with national and international provisions. Examples of interference-prone equipment that could be affected by the device:
    • Safety devices
    • Grid power lines, signal lines, and data transfer lines
    • IT and telecommunications equipment
    • Devices for measuring and calibrating
    Supporting measures to avoid EMC problems:
    1. Grid power supply
      • If electromagnetic interference occurs despite a grid connection that complies with regulations, take additional measures (e.g., use a suitable grid filter).
    2. Welding power-leads
      • Keep them as short as possible
      • Route them close together (also to avoid EMF problems)
      • Route them far from other lines
    3. Equipotential bonding
    4. Workpiece grounding
      • If necessary, establish grounding using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices in the vicinity
      • Shield the entire welding installation
    EMF measures
    Electromagnetic fields may cause health problems that are not yet known:
    • Effects on the health of persons close by, e.g., those with pacemakers and hearing aids
    • Persons with pacemakers must seek advice from their doctor before staying in the immediate vicinity of the device and the welding process
    • Keep distances between welding power-leads and the head/torso of the welder as great as possible for safety reasons
    • Do not carry welding power-leads and hosepacks over your shoulder or wrap them around your body or body parts
    Keep hands, hair, loose clothing, and tools away from moving parts, such as:
    • Fans
    • Gears
    • Rollers
    • Shafts
    • Wirespools and welding wires
    Do not reach into rotating gears of the wire drive or into rotating drive parts.
    Covers and side panels must only be opened/removed during maintenance and repair work.
    During operation
    • Ensure that all covers are closed, and all side parts have been mounted properly.
    • Keep all covers and side parts closed.
    The welding wire protruding from the welding torch poses a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
    Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
    Do not touch the workpiece during or after welding—risk of burns.
    Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
    Leave the welding torch and other parts with a high operating temperature to cool before working on them.
    Special regulations apply in areas at risk of fire or explosion
    – follow the appropriate national and international regulations.
    Welding machines for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the welding machine may not be located in such areas.
    Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
    When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
    Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
    • Attach chains or ropes to all designated attachments of the suitable load-carrying equipment.
    • Chains or ropes must be the smallest angle possible from vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device is equipped with a carrier strap or handle, then this is used exclusively for transport by hand. The carrier strap is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
    All lifting equipment (straps, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
    The test interval and scope must at least comply with the respective valid national standards and guidelines.
    There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
    Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
    Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
    Keep shielding gas cylinders away from welding or other electrical circuits.
    Risk of explosion: Never weld on a compressed shielding gas cylinder.
    Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
    If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
    When no welding is taking place, close the valve of the shielding gas cylinder.
    Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
    Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
    Risk of asphyxiation due to uncontrolled shielding gas leak
    Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
    • Ensure there is a sufficient supply of fresh air with a ventilation flow rate of at least 20 m³ per hour.
    • Please observe the safety and maintenance information for the shielding gas cylinder or the main gas supply.
    • When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
    • Always check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before each start-up.
    A toppling device can be deadly! Set up the device securely on an even, solid surface
    • The maximum permitted tilt angle is 10°.
    • Follow the appropriate national and international regulations.
    Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
    Only set up and operate the device in accordance with the protection class shown on the rating plate.
    When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
    Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
    Do not lift or transport any active devices. Switch off and disconnect devices from the grid before transport or lifting.
    Before transporting a welding system (e.g., with a trolley, cooling unit, welding machine, and wirefeeder), completely drain the coolant and dismantle the following components:
    • Wirefeeder
    • Wire spool
    • shielding gas cylinder
    It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a danger of:
    • Inefficient operation of the device
    Safety devices that are not fully functional must be repaired before the device is switched on.
    Before switching on the device, ensure that no one can be put in danger.
    The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
    Always secure the shielding gas cylinder well and remove before transporting by crane.
    Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
    Only use appropriate original coolant from the manufacturer.
    Do not mix original coolant from the manufacturer with other coolants.
    Only connect system components from the manufacturer to the cooling unit circuit.
    Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
    Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
    When the system is cool, always check the coolant level before starting welding.
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
    The manufacturer recommends calibrating welding machines within the same 12-month interval.
    A safety inspection by a qualified electrician is recommended
    • After alterations
    • After repair, service, and maintenance
    When performing the safety inspection, follow the appropriate national and international standards and guidelines.
    You can obtain more information about the safety inspection and calibration from your Fronius branch or your Fronius partner, who will provide the necessary documents upon request.
    Disposal
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Crush cardboard boxes
    Safety symbols
    Devices with the CE label meet the requirements of all valid EU Directives, such as:
    • Directive 2014/30/EU on electromagnetic compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • and others
    The full text of the EU Declaration of Conformity is available at
    https://www.fronius.com .
    Devices bearing the CSA label satisfy the requirements of the relevant standards for Canada and the USA.
    Data security
    • saving and storing personal settings.
    Copyright
    General
    Device concept
    The WF 25i Dual enables the joint use of two welding process lines with one power source. The welding process lines can be changed using the torch trigger, on the power source, via the operating controls on the wirefeeder, or on a remote control.
    Two spool holders and different options are available for the WF 25i Dual:
    WF 25i Dual with D300 spool holder and spool cover
    for D300 mm wirespools
    (with the Trabant, remote control, tool tray, crane transport, and hosepack holder options)
    for large D450 mm spools
    (with the Trabant, remote control, tool tray, and crane transport options)
    1. General
    Device concept
    1. General
    System requirements
    In order for the WF 25i Dual dual-head wirefeeder to work properly, the power source must have the following firmware version:
    official_TPSi_iWave_3.5.2-xxx.ffw or higher
    1. General
    The wirefeeder has safety symbols and a rating plate fitted. These safety symbols and the rating plate must not be removed or painted over. The safety symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage to property.
    • All system component Operating Instructions, especially the safety rules
    Welding is dangerous. To ensure that this device can be used correctly and safely, the following basic requirements must be met:
    • Adequate welding qualifications
    • Appropriate protective equipment
    • Keep unauthorized people away from the wirefeeder and the welding process
    Dispose of old devices in accordance with safety rules and not in normal domestic waste.
    • Gears
    • Feed rollers
    • Wirespools and wire electrodes
    During operation
    An electric shock can be fatal!
    Do not touch any exposed live parts!
    Also see page (→)!
    1. General
    Warning notices are attached to the device for certain device versions.
    The arrangement of the symbols may vary.
    Warning! Caution!
    The symbols represent possible dangers.
    A
    Drive rollers can injure fingers.
    B
    The welding wire and drive parts are under welding voltage during operation.
    Keep hands and metal objects away!
    1.
    1.1
    Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves.
    1.2
    Use a base that is insulated from the floor and work area to protect against electric shock.
    1.3
    Before working on the device, switch off the device and remove the mains plug or disconnect the power supply.
    2.
    Inhalation of welding fumes can be harmful to health.
    2.1
    Keep your face away from any welding fumes.
    2.2
    Use forced-air ventilation or local extraction to remove welding fumes.
    2.3
    Remove welding fumes with a fan.
    3.
    Welding sparks can cause an explosion or fire.
    3.1
    Keep flammable materials away from the welding process. Do not perform welding near flammable materials.
    3.2
    Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher.
    3.3
    Do not weld on drums or closed containers.
    4.
    Arc rays can burn the eyes and injure the skin.
    4.1
    Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body.
    5.
    Before working on the machine or welding:
    undertake training on the device and read the instructions!
    6.
    Do not remove or paint over the sticker with the warnings.
    Manufacturer order number of the sticker
    (1)
    Crane transport option
    OPT/WF Lift Bail Dual
    (2)
    Tool tray option
    OPT/WF Tool Tray Dual
    (3)
    Hosepack holder option
    Two-part, only in conjunction with D300 spool holder with cover
    OPT/WF Hosepack Holder Dual
    (4)
    OPT/WF Spool Holder D300 Dual
    (5)
    Dual-head wirefeeder
    WF 25i Dual No Spool /4R/G/FSC
    (6)
    Remote control option
    RC Panel Standard, RC Panel Pro
    (7)
    Coolant connections option
    OPT/WF Water Connection Dual
    (8)
    OPT/WF Spool Holder D450 Dual
    (without wirespools)
    (9)
    Trabant trolley option
    OPT/TU Trabant
    (10)
    Boom mounting kit option
    OPT/WF Boom Mounting Kit Dual
    Not pictured:
    • Euro connection conversion kit
    • SpeedNet cable 5 m
    • SpeedNet cable 10 m
    1. Options and components
    (1)
    (2)
    Tool tray option
    (3)
    (4)
    (5)
    (6)
    (7)
    (8)
    (9)
    OPT/TU Trabant
    (10)
    Not pictured:
    Trolley options
    (1)
    TU Car 4 Pro trolley
    incl. gas cylinder holder
    (2)
    WF Dual mounting set option
    OPT/TU Mounting Set WF Dual
    incl.:
    1. Storage vessel
    2. Tubular frame
    3. 2 x insulated torch holder
    4. Second gas cylinder holder and cylinder strap
      Mounting material
    Required for setup on the trolley:
    • TU Car 4 Pro trolley
    • OPT/TU Mounting Set WF Dual H510 option (for gas-cooled systems)
      or
      OPT/TU Mounting Set WF Dual H740 option (for water-cooled systems)
    WF 25i Dual with D300 spool holder on the trolley
    An alternative setup on the trolley could include the WF 25i Dual with D450 spool holder.
    Details on setting up the dual-head wirefeeder on the trolley can be found in the "OPT/TU Mounting Set WF Dual" Installation Instructions (42,0410,2636).
    1. System configurations
      or
    The OPT/WF Boom Mounting Kit Dual option is required for setup on the welding boom.
    The use of welding wire drums is recommended.
    WF 25i Dual with boom mounting kit option, mounted on the welding boom (schematic presentation)
    Max. delivery head
    3 m / 9 ft. 10.11 in.
    Max. conveying length, horizontal
    5 m / 16 ft. 4.85 in.
    Max. conveying distance, welding wire drum to welding torch
    16 m / 52 ft. 5.92 in.
    NOTE!
    The dual-head wirefeeder must be installed on the welding boom in such a way that it is insulated.
    Use boom mounting kit option or equivalent insulation.
    Setup on the crane
    The OPT/WF Lift Bail Dual option is required for setup on the crane.
    WF 25i Dual with D300 spool holder for crane setup
    IMPORTANT! Setup and operation on the crane are only permitted for the WF 25i Dual with D300 spool holder.
    NOTE!
    For crane applications, select the suspension position of the dual-head wirefeeder so that it hangs as horizontally as possible on the crane.
    Observe details on crane transport (from page (→)).
    System limits
    Depending on the welding system, the following data must be observed for water-cooled system components.
    Welding system with WF 25i Dual and TPS 320i - 600i (MIG/MAG):
    Suitable cooling units
    CU 1100i, CU 1100i /MV RVP,
    CU 1400i Pro
    Interconnecting hosepack *
    Max. 25 m / 82 ft. 0.25 in.
    Torch hosepack
    2 x max. 6 m / 19 ft. 8.22 in.
    Welding system with WF 25i Dual and iWave 300i - 500i MP (MIG/MAG + TIG):
    CU 1400i Pro
    MIG/MAG torch hosepack
    TIG torch
    hosepack **
    Max. 8 m / 26 ft. 2.96 in.
    IMPORTANT! A water-cooled TIG extension hosepack cannot be used in conjunction with a WF 25i Dual.
    Connection from the power source to the wirefeeder
    For multiprocess welding systems, if a water-cooled TIG welding torch is connected in addition to the 2 water-cooled MIG/MAG welding torches.
    Crane transport
    The following safety sticker is attached to the crane transport option OPT/WF Lift Bail Dual:
    a) b) c)
    1. The WF 25i Dual may only be transported with the OPT/WF Lift Bail Dual option mounted on the crane.
      For details, see page (→).
    2. Crane transport of a welding system mounted on the trolley with WF 25i Dual is only permitted in conjunction with the OPT/TU Mounting Set WF Dual option.
    3. Crane transport of a welding system mounted on the trolley with WF 25i Dual on the crane transport option OPT/WF Lift Bail Dual is not permitted.
      For details, see page (→) or the Installation Instructions for the OPT/TU Mounting Set WF Dual option (42,0410,2636).
    The crane transport option OPT/WF Lift Bail Dual also has a rating plate indicating the maximum load capacity:
    1. Crane transport
    a) b) c)
    1. Crane transport
    The OPT/WF Lift Bail Dual crane transport option is required for crane transport of the WF 25i Dual with D300 spool holder.
    WARNING!
    Danger from falling objects.
    Ensure that the crane transport option has been mounted correctly according to the specifications in these Operating Instructions and taking into account all torque specifications.
    Ensure that the wirespools/basket-type spools, including basket-type spool adapters, are always firmly seated on the wirespool holders.
    Ensure that the side parts of the spool holder are closed and secured during crane transport.
    Only transport the wirefeeder using the crane transport option.
    For crane transport, use only tested lifting equipment that complies with national guidelines.
    Select the suspension position of the dual-head wirefeeder so that it hangs as horizontally as possible on the crane.
    1. Crane transport
    The OPT/WF Lift Bail Dual crane transport option is required for crane transport of the WF 25i Dual with D450 spool holder without spool cover.
    WARNING!
    Before transporting by crane, remove the wirespools/basket-type spools, including the basket-type spool adapters, from the wirespool holders.
    1. Crane transport
    The WF Dual mounting set trolley option is required for crane transport of the welding system mounted on the trolley.
    WARNING!
    Ensure that the welding system and the WF Dual mounting set option are correctly mounted on the trolley.
    Before transporting by crane, remove the gas cylinders from the trolley.
    For the WF 25i Dual with D300 spool holder, ensure that
    a) the wirespools/basket-type spools, including basket-type spool adapters, are firmly seated on the wirespool holders;
    b) the side parts of the spool holder are closed and secured during crane transport.
    For the WF 25i Dual with D450 spool holder without spool cover, remove the wirespools before transporting by crane.
    Transport the welding system on the trolley only at the marked positions.
    Always attach the lifting equipment to all four suspension points.
    Details on crane transport can be found in the Installation Instructions for the OPT/TU Mounting Set WF Dual (42,0410,2636) option.
    Safety
    WARNING!
    Danger due to incorrect operation and work not carried out correctly.
    This may result in serious personal injury and damage to property.
    All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
    Read and understand all safety rules and user documentation for this equipment and all system components.
    1. Operating controls, connections and mechanical components
    Safety
    WARNING!
    (1)
    For transport by crane
    The wirespools can remain in the wirefeeder if the side parts of the spool holder are closed and secured.
    For use on the crane
    The wirefeeder hangs on the crane during welding work, the wirespools are in the wirefeeder, the side parts of the spool holder are closed and secured.
    (Also see System configurations/Setup on the crane from page (→))
    (2)
    Tool tray option
    (3)
    Remote control holder
    (4)
    Welding line 1 button/LED
    To activate welding line 1
    The LED lights up when the welding line is active.
    (5)
    (6)
    Welding torch connection
    Welding process line 1
    (7)
    Coolant supply connection (blue) *
    Option
    (8)
    Coolant return connection (red) *
    Option
    (9)
    SpeedNet connection
    For connecting the remote control
    (10)
    Option
    Welding process line 2
    (11)
    Option
    (12)
    OPT/TU Trabant
    (13)
    (14)
    Welding line 2 button/LED
    To activate welding line 2
    (15)
    Wirespool cover
    both sides
    (16)
    Hosepack holder
    If the coolant hoses of one welding torch are terminated, the other welding torch is also no longer supplied with coolant.
    In this case, use the enclosed, short cooling hose piece for bridging.
    (1)
    The wirespools must be removed for transport by crane.
    (2)
    Tool tray option
    (3)
    (4)
    (5)
    (6)
    (7)
    Option
    (8)
    Option
    (9)
    SpeedNet connection
    (10)
    Option
    (11)
    Option
    (12)
    OPT/TU Trabant
    (13)
    (14)
    The wirespools are not included in the scope of supply.
    Wirefeeder rear
    (1)
    Strain-relief device for the interconnecting hosepack
    (2)
    Wire infeed tube
    (3)
    Option
    For connecting the coolant return hose from the interconnecting hosepack
    (4)
    Power connection
    For connecting the power cable from the interconnecting hosepack
    (5)
    Option
    For connecting the coolant supply hose from the interconnecting hosepack
    (6)
    Wire infeed tube
    (7)
    Shielding gas connection
    (8)
    SpeedNet connection
    For connecting the SpeedNet cable from the interconnecting hosepack
    (9)
    Wirefeeder side
    Illustration without covers and side parts shown
    (1)
    Basket-type spool adapter
    (2)
    Wirespool holder with brake
    (3)
    Operating status LED
    Lights up green when the device is ready for operation
    (4)
    Gas-test button
    (5)
    Wire-return button
    (6)
    Wire-threading button
    (7)
    Clamping lever
    For adjusting the contact pressure of the feed rollers
    (8)
    4-roller drive
    (9)
    Clamping lever
    The described elements are located on both sides of the wirefeeder.
    Gas-test button
    After pressing the gas-test button, gas is released for 30 s. Pressing the button again will end the process prematurely.
    Wire-return button
    There are two options available for retracting the wire electrode:
    Option 1
    Withdraw wire electrode at the preset wire return speed:
    • Press and hold the wire-return button
    • After pressing the wire-return button, the wire electrode is retracted by 1 mm (0.039 in.)
    • After a brief pause, the wirefeeder continues retracting the wire electrode – if the wire-return button is kept pressed down, then the speed increases with each further second by 10 m/min (393.70 ipm) until the preset wire-return speed is reached
    Option 2
    Withdraw wire electrode in 1 mm steps (0.039 in. steps)
    • Always press (touch) the wire-return button for less than 1 second
    NOTE!
    Only retract the wire electrode a small amount at a time, to avoid the wire electrode becoming entangled on the wirespool during retraction.
    NOTE!
    If there is a ground earth connection with the contact tip, before the wire-return button is pressed, the wire electrode is retracted by pressing the wire-return button until the wire electrode is short-circuit-free—however, this must not exceed 10 mm (0.39 in.) each time the button is pressed.
    If the wire electrode needs to be retracted further, press the wire-return button again.
    There are two options available for the wire threading:
    Option 1
    Thread the wire electrode at the preset feeder inching speed:
    • Press and hold the wire-threading button
    • After pressing the wire-threading button, the wire electrode will be threaded in by 1 mm (0.039 in.)
    • After a brief pause, the wirefeeder continues threading in the wire electrode – if the wire-threading button is kept pressed down, then the speed increases with each further second by 10 m/min (393.70 ipm) until the preset feeder inching speed is reached
    • If the wire electrode meets a ground earth connection, then the wirefeeding is stopped and the wire electrode is retracted again by 1 mm (0.039 in.)
    Option 2
    Thread the wire electrode in 1 mm steps (0.039 in. steps)
    • Always press (touch) the wire-threading button for less than 1 second
    NOTE!
    If there is a ground earth connection with the contact tip, before the wire-threading button is pressed, the wire electrode is retracted by pressing the wire-threading button until the wire electrode is short-circuit-free—however, this must not exceed 10 mm (0.39 in.) each time the button is pressed.
    If after the 10 mm (0.39 in.) wire retraction there is still a ground earth connection with the contact tip, then when the wire-threading button is pressed again, the wire electrode is retracted again by a maximum of 10 mm (0.39 in.). The process is repeated until there is no longer any ground earth connection with the contact tip.
    Safety
    WARNING!
    1. Before installation and initial operation
    Safety
    WARNING!
    Intended use
    The device is intended exclusively for end of wirefeeding with MIG/MAG welding in combination with Fronius system components.
    The wirefeeder is designed for welding operation during crane transport (e.g., on the crane boom, on the balancer, on movable mountings, etc.).
    Any other use does not constitute proper use.
    Intended use also means
    • Reading these Operating Instructions in their entirety
    • Following all instructions and safety rules in these Operating Instructions
    • Carrying out all the specified inspection and maintenance work
    Setup regulations
    WARNING!
    Danger from devices falling or toppling over.
    Set up all system components, upright brackets, and trolleys so that they are stable on a flat and solid surface.
    Depending on the system configuration, ensure that all screw connections are tightened to the correct torque.
    For crane applications, use only tested lifting equipment that complies with national guidelines.
    The dual-head wirefeeder and the dual-head wirefeeder with the D300 spool holder with cover have been tested according to protection class IP 23. This means:
    • Protection against the penetration of solid foreign bodies with a diameter of more than 12.5 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° from the vertical
    The wirefeeder and wirefeeder with D300 spool holder can be set up and operated outdoors in accordance with protection class IP 23. Avoid the effects of direct moisture (from rain, for example).
    The dual-head wirefeeder with the D450 spool holder without cover has been tested according to protection class IP 20. This means:
    • No protection against water
    The wirefeeder with the D450 spool holder must only be set up and operated in closed rooms.
    Safety
    WARNING!
    Before starting work, switch off all devices and components involved, and disconnect them from the grid.
    1. Installing optional equipment
    Safety
    WARNING!
    Use screws from the scope of supply of the spool holder
    2 x M5 x 12 mm, tightening torque = 3 Nm / 2.21 lb-ft
    4Repeat work steps 2 and 3 on the other side of the wirefeeder
    4 x M5 x 12 mm, tightening torque = 3 Nm / 2.21 lb-ft
    6 x M8 x 20 mm, tightening torque = 21 Nm / 15.49 lb-ft;
    Crane transport option mounted on D300 spool holder
    Screws and mounting material from the scope of supply of the crane transport option.
    The option is mounted on the D450 spool holder without spool cover in the same way.
    8 x M5 x 12 mm, tightening torque = 3 Nm / 2.21 lb-ft
    4 x brass spacer M5x12 mm, tightening torque = 2.1 Nm / 1.55 lb-ft
    4 x M8 x 25 mm + M8 washer + NL8
    Tightening torque = 21 Nm / 15.49 lb-ft
    4 x M8 x 30 mm + M8 washer + NL8
    Safety
    WARNING!
    1. Connecting the wirefeeder to the welding machine
    Safety
    WARNING!
    General
    The wirefeeder is connected to the power source by means of the interconnecting hosepack.
    Connecting the wirefeeder to the power source is described with reference to the WF 25i Dual with D300 spool holder.
    The WF 25i Dual with D450 spool holder is connected to the power source in the same way.
    2 x M5 x 12 mm
    3Repeat work steps 1 and 2 on the other side of the wirefeeder
    Push wirefeeder to the front;
    Guide interconnecting hosepack and gas 2 through the spool holder
    5
    Connect the interconnecting hosepack and gas 2 to the wirefeeder
    6
    Push the wirefeeder back into the original position
    7
    2 x M5 x 12 mm, tightening torque = 3 Nm / 2.21lb-ft
    8Repeat work step 7 on the other side of the wirefeeder
    9
    10Fix the strain-relief device of the interconnecting hosepack to the wirespool holder with 2 M5 x 12 mm screws
    Tightening torque = 3 Nm / 2.21 lb-ft
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, leads, and hosepacks must always be securely connected, undamaged, and correctly insulated.
    Only use adequately dimensioned cables, leads, and hosepacks.
    Check that they are tightly fastened at least every three months.
    For water-cooled hosepack only
    CON
    = interconnecting hosepack
    EXT
    = extension hosepack
    Connect all connections so they are hand-tight.
    Check for tightness.
    Tightening the power connection hand-tight corresponds to 7-8 Nm.
    If the components are not bundled in the protective bag, all interfaces must be fixed so they are immovable.
    NOTE!
    Reduced service life at a bending radius of r < 200 mm.
    Note the bending radius!
    Do not use a bending radius smaller than r = 200 mm!
    NOTE!
    Note the current load!
    Dimensioning of the correct hosepack according to the following table:
    Welding current
    40% d.c. / 40° C
    Cross-section up to 10 m
    Cross-section up to 50 m
    150 A
    16mm²
    25mm²
    200 A
    25mm²
    35mm²
    250 A
    35mm²
    50mm²
    300 A
    50mm²
    70mm²
    400 A
    70mm²
    95 mm²
    500 A
    95 mm²
    120 mm²
    600 A
    120 mm²
    120 mm²
    Safety
    WARNING!
    1. Connecting the welding torch
    Safety
    WARNING!
    WARNING!
    Danger from electrical current due to inadequate connections.
    All cables, leads, and hosepacks must be securely connected, undamaged, correctly insulated, and adequately sized.
    only if the coolant connections are installed in the wirefeeder and for water-cooled welding torches;
    Observe the color coding of the coolant connections!
    CAUTION!
    Danger due to lack of coolant.
    Overheating and damage to property may result
    If coolant connections are present, always connect the coolant hoses of both welding torches.
    5
    6Repeat the work steps on the other side of the wirefeeder
    Safety
    WARNING!
    1. Inserting/changing feed rollers
    Safety
    WARNING!
    General
    The feed rollers are not inserted in the system when first delivered.
    In order to guarantee optimum feeding of the wire electrode, the feed rollers must be adjusted to the wire diameter and the wire alloy to be welded.
    NOTE!
    Danger due to deficient feed rollers.
    This can result in poor-quality weld properties.
    Only use feed rollers which match the wire electrode.
    An overview of the available feed rollers and their possible uses can be found in the Spare Parts Lists.
    CAUTION!
    Danger due to feed roller holders shooting upwards.
    This could result in injury.
    When unlocking the clamping lever, keep fingers away from the area to the left and right of the clamping lever.
    CAUTION!
    Danger due to open feed rollers.
    After inserting/changing the feed rollers, always install the protective cover of the 4-roller drive.
    If the D450 spool holder without spool cover is to be operated with a D300 wirespool, the brake must be remounted:
    (1)
    Mounting position of the brake when using wirespools with a diameter of 450 mm
    (2)
    Mounting position of the brake when using wirespools with a diameter of 300 mm
    1Remove M16 screw at the rear of the brake
    3Re-fix the brake in the new position using the M16 screw
    NOTE!
    When using a D300 wirespool on the D450 spool holder, the braking force of the D450 brake must also be adjusted.
    1. Remounting the D450 brake for operation with a D300 wirespool
    (1)
    (2)
    NOTE!
    Safety
    WARNING!
    Danger from electric current.
    Before carrying out maintenance or service work, switch off all devices and components involved and disconnect them from the power supply.
    Secure all devices and components involved against being switched on again.
    After opening the appliance, use a suitable measuring device to ensure that electrically charged components (e.g. capacitors) are discharged.
    CAUTION!
    Danger from springiness of spooled wire electrode.
    Personal injury may result.
    Wear safety goggles.
    When inserting the wirespool/basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
    CAUTION!
    Danger from falling wire spool/basket-type spool.
    Could result in injury.
    Ensure that the wire spool is fitted securely to the wire spool holder.
    Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
    Make sure that the basket-type spool with basket-type spool adapter is fitted securely to the wire spool holder.
    1. Inserting the wirespool/basket-type spool
    Safety
    WARNING!
    CAUTION!
    CAUTION!
    WARNING!
    Danger due to falling wirespool as a result of the locking ring being fitted the wrong way round.
    Always position the locking ring as shown below.
    WARNING!
    Danger from falling basket-type spool due to missing basket-type spool adapter.
    When working with basket-type spools, only use the basket-type spool adapter supplied with the device.
    WARNING!
    Danger from falling basket-type spool.
    WARNING!
    Danger due to falling basket-type spool as a result of the locking ring being fitted the wrong way round.
    WARNING!
    NOTE!
    Use appropriate spool adapters for applications with 60 lb flux core wire spools.
    Spool adapters for 60 lb flux core wire spools are not available from Fronius.
    General
    NOTE!
    The wire electrode can be threaded using any wire-threading button of another system component – for example, the wire-threading button of the power source.
    The function of the wire-threading button is the same for all system components of the manufacturer.
    More information on the function of the wire-threading button can be found from page (→).
    1. Threading the Wire Electrode
    General
    NOTE!
    Preparation
    WARNING!
    Serious personal injuries may result.
    CAUTION!
    Danger due to unintentional ignition of an arc.
    Personal injury and damage to property may result.
    Before starting work, disconnect the ground earth connection between the welding system and workpiece.
    CAUTION!
    Danger due to sharp end of the wire electrode.
    Thoroughly deburr the end of the wire electrode before inserting.
    WARNING!
    Danger due to emerging wire electrode.
    Hold the welding torch so that the tip of the welding torch points away from the face and body.
    Wear suitable protective goggles.
    Do not point the welding torch at people.
    Ensure that the wire electrode does not touch any electrically conductive objects.
    CAUTION!
    1Lay the torch hosepack straight
    CAUTION!
    Danger from excessive contact pressure.
    This can result in damage to property and poor weld properties.
    Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
    Contact pressure standard values for U-groove rollers:
    • Steel: 4 - 5
    • CrNi: 4 - 5
    • Aluminum: 0.5 - 1.5
    • Tubular covered electrodes: 2 - 3
    Contact pressure standard values for knurled rollers:
    • Tubular covered electrodes: 1 - 2
    Observe the sticker on the wire drive!
    Adjusting the brake
    General
    NOTE!
    Overrunning of the brake can result in damage to property.
    After releasing the torch trigger/wire-threading button, the wirespool must stop unreeling.
    If it continues unreeling, readjust the brake.
    1. Adjusting the brake
    General
    NOTE!
    WARNING!
    CAUTION!
    Design of the brake
    CAUTION!
    Danger from incorrect installation.
    Do not dismantle the brake.
    Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
    The brake is only available as a complete unit.
    The illustration of the brake is for information purposes only.
    WARNING!
    CAUTION!
    Preliminary design of the D450 brake
    WARNING!
    Commissioning
    Safety
    WARNING!
    1. Commissioning
    Safety
    WARNING!
    1. Commissioning
    Only for WF 25i Dual with spool holder D450 without spool cover:
    When the dual head wirefeeder is connected to the power source and the power source is on, certain electrical live (hot) parts are exposed!
    WARNING!
    Electric shock can kill!
    Danger of electric shock due to electrically live (hot), exposed parts.
    Touching electrically live (hot) parts can cause serious personal injury.
    Do not touch the following electrically live (hot) parts:
    Wirespool,
    Wire electrode,
    Current sockets,
    Welding torch connection,
    Feed rollers (with feed roller cover open).
    Use a dry underlayer to insulate the floor and work area.
    1. Commissioning
    The following requirements must be fulfilled for commissioning of the wirefeeder:
    • Wirefeeder connected to power source by means of interconnecting hosepack
    • Welding torch connected to wirefeeder
    • Feed rollers inserted into wirefeeder
    • Wirespools/basket-type spools and their adapters inserted into wirefeeder
    • Wire electrodes threaded in
    • Contact pressure of the feed rollers set
    • Brakes adjusted
    • All covers closed, all side parts mounted, and all protection devices in good order and installed in the location intended
    • Welding process line selected
    1. Commissioning
    Commissioning
    The wirefeeder is started up in manual applications by pressing the torch trigger and in automated applications by an active signal to start welding.
    The following processes and parameters are available on the welding machine for operating the wirefeeder:
    • TIG DynamicWire
    • Wirefeeder setup
      (Process parameters / Common/TIG/MMA/CEL / Wirefeeder setup)
    1. Commissioning
    NOTE!
    If the dual-head wirefeeder is integrated into a multiprocess welding system, the wirefeeder must be disconnected from the power source before activating a TIG AC welding process!
    Terminate the interconnecting hosepack!
    process line
    The welding process line can be selected in the following ways:
    • Using the torch trigger on the welding torch
    • Using the button/LED on the wirefeeder
    • Using the gas-test, wire-return, and wire-threading buttons on the wirefeeder
    • On the power source
    • Using the RC Panel Standard or RC Panel Pro remote control
    NOTE!
    It is not possible to switch to the other welding process line during the welding process.
    1. Selecting the welding process line
    process line
    NOTE!
    Selecting the
    Press the corresponding torch trigger to switch to the other welding process line.
    Selecting the
    Press the corresponding button on the wirefeeder to switch to the other welding process line.
    If the LED on the button lights up, this welding process line is activated.
    Button/LED on the wirefeeder
    1, 2 = welding process lines
    Selecting the
    If one of the gas-test, wire-return, or wire-threading buttons is pressed on one side of the wirefeeder, this welding process line is activated.
    The LED of the corresponding button on the wirefeeder lights up.
    The power source or the RC Panel Pro remote control detects when a dual-head wirefeeder is in the welding system. The status line of the power source display shows the active welding process line.
    To change the welding process line, touch the welding process line displayed in the status line and confirm the subsequent confirmation prompt to change the welding process line.
    For details on selecting the welding process line, refer to the power source Operating Instructions.
    Selecting the
    To change the welding process line, press the corresponding selection dial on the remote control twice:
    • Left-hand selection dial = welding process line 1
    • Right-hand selection dial = welding process line 2
    The display of the remote control shows the change of the welding process line.
    After the display goes out, the LED on the corresponding selection dial lights up to indicate the active welding process line.
    Troubleshooting
    Safety
    WARNING!
    WARNING!
    Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
    Secure all these devices and components so they cannot be switched back on.
    CAUTION!
    Danger due to hot system components and/or equipment.
    This can result in burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
    Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
    1. Troubleshooting
    Safety
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    Troubleshooting
    Make a note of the serial number and configuration of the device, and provide the service team with a detailed error description if:
    • Errors occur that are not covered in this document
    • The troubleshooting measures provided in this document are unsuccessful
    Welding machine not working
    Power switch is switched on; displays and indicators do not illuminate
    Cause:Mains lead damaged or broken, mains plug not inserted
    Remedy:Check mains lead, if necessary insert mains plug
    Cause:Mains socket or mains plug faulty
    Remedy:Replace faulty parts
    Cause:Mains fuse
    Remedy:Replace mains fuse
    Cause:Short circuit on the 24 V power supply of the SpeedNet connection or external sensor
    Remedy:Disconnect connected components
    Nothing happens after pressing torch trigger
    Power source power switch is ON and indicators are lit up
    Cause:Welding torch or welding torch control line faulty
    Remedy:Replace the welding torch
    No welding current
    Power switch of the welding machine switched on, indicators light up
    Cause:Incorrect ground connection
    Remedy:Check ground connection for polarity
    Cause:Power cable in welding torch damaged or broken
    no shielding gas
    all other functions present
    Cause:Gas cylinder empty
    Remedy:Change gas cylinder
    Cause:Gas pressure regulator faulty
    Remedy:Replace gas pressure reducer
    Cause:Gas hose not attached, or damaged
    Remedy:Attach or replace gas hose
    Cause:Welding torch faulty
    Remedy:Change welding torch
    Cause:Gas solenoid valve faulty
    Remedy:Inform the service team
    Irregular wire speed
    Cause:Braking force has been set too high
    Remedy:Loosen the brake
    Cause:Contact tip hole too narrow
    Remedy:Use suitable contact tip
    Cause:Inner liner in the welding torch faulty
    Remedy:Check the inner liner for kinks, dirt, etc. and replace if necessary
    Cause:Feed rollers not suitable for wire electrode used
    Remedy:Use suitable feed rollers
    Cause:Feed rollers have the wrong contact pressure
    Remedy:Optimize contact pressure
    Wirefeed issues
    For applications with long hosepacks
    Cause:Improper laying of the hosepack
    Remedy:Lay hosepack as straight as possible while avoiding tight bending radii
    Welding torch gets very hot
    Cause:Welding torch is inadequately sized
    Remedy:Observe duty cycle and load limits
    Cause:For water-cooled systems only: Coolant flow too low
    Remedy:Check coolant level, coolant flow rate, coolant contamination, etc. For more detailed information, refer to the operating instructions for the cooling unit
    Cause:Distance from workpiece is too small
    Remedy:Increase the distance (stick out)
    Poor-quality weld properties
    Cause:Incorrect welding parameters
    Remedy:Check settings
    Cause:Poor ground earth connection
    Remedy:Establish good contact with workpiece
    Cause:Too little or no shielding gas
    Remedy:Check pressure regulator, gas hose, gas solenoid valve, welding torch gas connection, etc.
    Cause:Welding torch leaks
    Cause:Incorrect or heavily worn contact tip
    Remedy:Change contact tip
    Cause:Incorrect wire alloy or incorrect wire diameter
    Remedy:Check wire electrode in use
    Remedy:Check the weldability of the parent material
    Cause:Shielding gas not suitable for wire alloy
    Remedy:Use correct shielding gas
    Cause:Wear of the wirefeeding roller groove
    Remedy:Replace wirefeeding rollers
    Service, maintenance and disposal
    link_horizontalLink copied
    General
    The device only requires minimal of service and maintenance under normal operating conditions. However, several points must be observed for the welding system to remain operational for years to come.
    1. Service, maintenance and disposal
    General
    Safety
    WARNING!
    WARNING!
    CAUTION!
    At every start-up
    • Check all hosepacks and the ground earth connection for damage. Replace any damaged components.
    • Check feed rollers and inner liners for damage. Replace any damaged components.
    • Check contact pressure of the feed rollers and adjust if necessary.
    Every 6 months
    CAUTION!
    Danger from compressed air at close range.
    Electronic parts may be damaged.
    Do not bring the air nozzle too close to electronic parts.
    • Open covers, dismantle device side panels, and blow the inside of the device clean with dry, reduced compressed air. After cleaning, restore the system to its original condition.
    Disposal
    Disposal must only be carried out in accordance with the section of the same name in the "Safety rules" chapter.
    Technical data
    WF 25i Dual
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.2 A
    Welding current
    at 10 min/40 °C (104 °F)
    40% ED* / 500 A
    60% ED* / 450 A
    100% ED* / 360 A
    Maximum pressure of shielding gas
    7 bar
    101.53 psi
    Coolant
    Original Fronius
    Maximum pressure of coolant
    5 bar
    72.53 psi
    Wire speed
    1 - 25 m/min
    39.37 - 984.25 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8 - 1.6 mm
    0.03 - 0.06 in.
    Wirespool diameter
    Max. 300 mm
    Max. 11.81 in.
    Wirespool weight
    Max. 19 kg
    Max. 41.89 Ib.
    Protection class
    IP 23
    Mark of conformity
    S, CE, CSA
    Dimensions I x w x h
    (without options)
    550 x 256 x 354.5 mm
    21.65 x 10.08 x 13.96 in.
    Weight
    (without options)
    18.8 kg
    41.45 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 25i Dual
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.2 A
    Welding current
    40% ED* / 500 A
    60% ED* / 450 A
    100% ED* / 360 A
    7 bar
    101.53 psi
    Coolant
    Original Fronius
    5 bar
    72.53 psi
    Wire speed
    1 - 25 m/min
    39.37 - 984.25 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8 - 1.6 mm
    0.03 - 0.06 in.
    Wirespool diameter
    Max. 300 mm
    Max. 11.81 in.
    Wirespool weight
    Max. 19 kg
    Max. 41.89 Ib.
    Protection class
    IP 23
    Mark of conformity
    S, CE, CSA
    (without options)
    Weight
    (without options)
    18.8 kg
    41.45 Ib.
    * ED = Duty cycle
    1. Technical data
    Wirespool diameter
    Max. 300 mm
    Max. 11.81 in.
    Wirespool weight
    Max. 19 kg
    Max. 41.89 Ib.
    Protection class
    IP 23
    Dimensions l × w × h
    620 x 557 x 444 mm
    24.37 x 21.93 x 17.48 in.
    Weight
    - kg
    - Ib.
    1. Technical data
    Wirespool diameter
    Max. 450 mm
    Max. 17.72 in.
    Wirespool weight
    Max. 27.2 kg
    Max. 60 Ib.
    Protection class
    IP 20
    616 x 506 x 424 mm
    24.25 x 19.92 x 16.69 in.
    Weight
    - kg
    - Ib.
    1. Technical data
    HP 70i
    Welding current at 10 min/40°C (104°F)
    40% ED* / 400 A
    60% ED* / 365 A
    100% ED* / 320 A
    ED = Duty cycle
    1. Technical data
    HP 95i
    40% ED* / 500 A
    60% ED* / 450 A
    100% ED* / 360 A
    ED = Duty cycle
