Warnings are intended to warn people of possible injuries and to avoid personal injury and damage to the product. They relate to individual actions with and on the product.
Indicates an immediately dangerous situation.
Serious injury or death will result if the danger is not avoided.
Action step to escape the situation.
Serious injury or death may result if the danger is not avoided.
Minor or moderate injury may result if the danger is not avoided.
Indicates a situation that may result in property damage.
If the situation is not avoided, impaired work results, material damage to the product or other property are the possible consequences.
Action step to avoid the situation.
Safety instructions are designed to ensure safe product use. They are preventive and help to inform users about the fundamental risks involved when dealing with the product. They do not refer specifically to individual actions with and on the product.
Incorrect operation or misuse
IMPORTANT!
Tampered-with and non-functioning protection devices
The device may be damaged
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
Danger from electromagnetic fields for persons with pacemakers and defibrillators!
This can result in serious injury.
Persons with pacemakers must maintain a distance of at least 60 cm.
Persons with defibrillators must maintain a distance of at least 40 cm.
Danger due to open or damaged housing!
This can result in severe personal injury and damage to property due to high voltage and/or fire.
Do not use the device if the housing is damaged or open.
Send in the device for repair.
Danger from loose parts in the housing!
Do not use the device if there are loose parts in the housing.
Danger due to cables!
Damaged or exposed cables can result in severe personal injury and damage to property.
Do not use the device if the cables attached to or plugged into the device are damaged.
Adequately support the weight of the device and the charging cable.
Provide mechanical relief for the cables.
Lay the charging cable securely to avoid the risk of tripping over the charging cable.
Danger due to wet or dirty connectors!
Charring caused by prolonged usage can result in severe personal injury and damage to property.
Only mount the device vertically.
Dry wet connectors in a de-energized state.
Clean soiled connectors in a de-energized state.
Danger from gassing vehicle batteries!
Only use in well-ventilated areas.
Danger from driving away with the charging cable connected!
This can result in severe personal injury or damage to property.
Disconnect the charging cable from the electric vehicle before driving away.
Do not bypass the safety device of the electric vehicle.
Danger due to excessive load!
The load when operating the device with an earthed plug must not exceed 10 A.
The earthed socket outlet must be suitable for continuous operation at 10 A.
Check for heat generation after each use.
The device and the sockets must not overheat.
Danger due to excessive charging current!
Fires or damage to the in-house installation may result.
Observe the maximum permissible current at the connected socket.
If the maximum charging current is not known, charge with the lowest possible charging current.
Only use original adapters. An automatic reduction of the charging current to 16 A by plugging in the adapter is only possible in conjunction with the original adapters.
Danger due to heat generation on the device!
The build-up of heat can lead to lasting damage and even fire.
Never cover the device during charging.
Unwind the cable completely from a cable drum.
Observe the correct installation position.
Never pull the plug out of the plug connection by the cable!
Observe the specifications of the grid operator regarding 1‑phase charging and the asymmetrical network load that may result.
The device has a built-in residual current protection module with residual current detection (20 mA AC and 6 mA DC). Observe the national standards. A separate type A residual current circuit breaker and an automatic circuit breaker must be connected upstream for each Wattpilot.
The device may only be operated at the following connections:In case of defective adapters or defective CEE plugs, send the device in for repair.
Operation or storage of the machine outside the stipulated area will be deemed as not in accordance with the intended purpose.
For exact information on permitted environmental conditions, please refer to the technical data.
During operation, due to the high electrical voltages and currents, local electromagnetic fields (EMF) are generated. These occur in the immediate vicinity of the inverter and the Fronius system components. Electromagnetic fields are also present in the area of the PV modules and their supply lines.
As long as the intended use and a minimum distance of 20 cm are observed, all limit values for human exposure are observed.
If the limit values are complied with, according to current scientific knowledge, no negative health effects from EMF exposure are to be expected. For persons with prostheses1) or active physical aids2), there is a possible health risk in the vicinity of photovoltaic system components. To avoid possible health risks, consult with the responsible doctor.
1) e.g., implants or metal parts
2) e.g., pacemaker, insulin pump, hearing aid, etc.
The device has an integrated surge protection device (SPD). This can negatively affect the insulation measurement. According to normative specifications, carry out the insulation measurement with a reduced voltage of 250 V DC and a resistance of >=1 MΩ. During the measurement, the Wattpilot displays the status code Ground fault detected (see Status codes).
Alternatively, disconnect the Wattpilot from the power supply. Carry out the insulation measurement directly on the grid lead with a measurement voltage of 500 V DC.
The symbols on the Fronius Wattpilot must not be removed or painted over. The notices and symbols warn against incorrect operation that may result in serious injury and damage.
Symbols on the rating plate: | |
IC-CPD marking – in-cable control and protection device (IC-CPD) with unswitched ground conductor for supplying electric vehicles in charging mode 2. | |
Cold environment – the device is protected against cold and suitable for use in temperatures down to minus 25 °C. | |
CE label – confirms compliance with applicable EU directives and regulations. The product has been tested by a specific notified body. | |
WEEE marking – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law. | |
RoHS marking – the product complies with the requirements of the EU Directive on the restriction of the use of certain hazardous substances in electrical and electronic equipment. See RoHS statement. | |
UKCA marking – confirms compliance with applicable UK directives and regulations. | |
RCM marking – tested according to the requirements of Australia and New Zealand. | |
Application notes
Software
Example: Click Save.
Instructions for action
This document provides detailed information and instructions to ensure that people can use the machine safely and efficiently.
The information is intended for the following groups of people:Regardless of any qualifications, only perform the activities listed in this document.
The definition of professional qualifications and their applicability are subject to national law.
When you connect your device (and any associated devices) to the internet, the following device and operating data (device ID/identifier, device IP address, device time, configuration settings, hardware and software information, device status log files, serial number) is sent automatically to
Fronius International GmbH, Froniusstraße 1, 4643 Pettenbach, Austria, telephone +43(0) 7242241-0, email: contact@fronius.com (controller)
and stored.
The processing of this device and operating data is carried out for the purpose of ensuring the operational safety of the device (time synchronization, provision of updates). This processing is therefore necessary for the functionality of the device and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
If you do not wish to have such data processed, you must manually disable the device's internet connection.
In addition, the device and operating data is also processed for the purpose of providing services as part of a supplementary digital service for your device (such as solar.web or similar) as soon as you have registered your device with such a digital service (identification). This data is processed to provide the requested digital services and is therefore necessary for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
Furthermore, this data processing is also carried out for maintenance and support purposes and for handling customer concerns as well as in warranty and guarantee cases (only in individual cases and given connection between device and internet). In this context, the device and operating data may also be passed on to our cooperation partners (third-party providers and suppliers). The processing of this data is necessary for maintenance and support purposes or for processing warranty and guarantee cases and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
Device and operating data are also processed for analysis and diagnostic purposes in order to gain insights into the functionality of the devices and improve them accordingly. This data processing is based on our legitimate interest (Art. 6 (1) (f) GDPR).
We store this data for as long as it is necessary to fulfill the existing contract with you. Any storage beyond this is carried out for legal reasons or if we have a legitimate interest in doing so. For more information on data processing for the solar.web-digital service, as well as our general privacy policy and your rights as a data subject, please visit https://www.fronius.com.
The Fronius Wattpilot Go 11 J 2.0 / Go 22 J 2.0 / Go 22 J 2.0 AUS is a mobile charging station for charging electric vehicles for connection to an AC/three-phase network.
The Fronius Wattpilot Home 11 J 2.0 / Home 22 J 2.0 is a charging station for charging electric vehicles for fixed connection to an AC/three-phase network.
The Wattpilot may only be used for the purpose of charging battery-powered electric vehicles and plug-in hybrid vehicles in conjunction with the corresponding adapters and cables.
Intended use also includes complying with all the instructions in these operating instructions.
The following circumstances shall be deemed to be not in accordance with intended use:The Fronius Wattpilot Go 11 J 2.0 / Go 22 J 2.0 / Go 22 J 2.0 AUS is a mobile charging station for charging electric vehicles for connection to an AC/three-phase network.
The following circumstances shall be deemed to be not in accordance with intended use:Depending on the product variant, the scope of delivery differs as follows.
Fronius Wattpilot Go 11 J 2.0 / Go 22 J 2.0 / Go 22 J 2.0 AUS*
| (1) | Mounting bracket, incl. screws and dowels |
| (2) | Wattpilot Go 11 J 2.0 or Wattpilot Go 22 J 2.0 |
| (3) | Anti‑theft device |
| (4) | Reset card |
| (5) | ID chip |
| (6) | Quick Guide |
*The scope of delivery for the Fronius Wattpilot Go 22 J 2.0 AUS differs from the other product variants by the plug type.
| (2) | Wattpilot Home 11 J 2.0 or Wattpilot Home 22 J 2.0 |
| (4) | Reset card |
| (5) | ID chip |
| (6) | Quick Guide |
Only use original adapters for the operation of the Wattpilot!
The CEE plugs (see IEC 60309) of the adapter set differ from those of other suppliers due to their design with a reed contact.
Use original adapter sets.
Accessories, optional
Item designation | Item number |
Type 2 charging cable, 32 A, 22 kW, 2.5 m | 4,240,419 |
Type 2 charging cable, 32 A, 22 kW, 5.0 m | 4,240,180 |
Type 2 charging cable, 32 A, 22 kW, 7.5 m | 4,240,420 |
ID chips, 10 pieces | 4,240,181 |
Mounting plate Go 2.0 (mounting bracket) | 4,240,421 |
Type 2 wall bracket (cable wall bracket) | 4,240,422 |
Adapter set Go 11 2.0, CEE adapter 16 A to
| 4,240,405 |
Adapter Go 11 CEE32 red 2.0, (3-phase) | 4,240,406 |
Adapter Go 11 CEE16 blue 2.0, (1-phase) | 4,240,407 |
Adapter Go 11 type F plug 2.0 (household socket) | 4,240,408 |
Adapter set Go 22 2.0, CEE adapter 32 A to
| 4,240,410 |
Adapter Go 22 CEE16 red 2.0, (3-phase) | 4,240,411 |
Adapter Go 22 CEE16 blue 2.0, (1-phase) | 4,240,412 |
Adapter Go 22 type F plug 2.0 (household socket) | 4,240,413 |
Suitable generators can be PV inverters from third-party manufacturers, for example. A prerequisite for compatibility with external generators is that no other self-consumption controllers (e.g., battery, Power-to-Heat) are operated in parallel. This can negatively affect PV optimization. The proportion of energy consumed by other loads is not taken into account in the Fronius Solar.wattpilot app.
Requirement:
* For connection via Modbus RTU, the generator requires a Fronius Datamanager Box 2.0 (item number 4,240,125).
For more information, see Data communication with inverter.
Compatibility with the connected devices (see list below) and a Fronius Smart Meter at the feed-in point are prerequisites for using certain functions (e.g., PV surplus).
Suitable Fronius inverters
*Requirement:
**Requirement:
| (1) | CEE plug |
| (2) | Connection cable |
| (3) | Strain-relief device |
| (4) | Housing |
| (5) | Card reader |
| (6) | Pushbutton |
| (7) | Type 2 junction box |
| (8) | LED ring |
| (9) | Rating plate |
Symbols on front of the device: | |
Kartenleser | |
Eco Mode | |
Next Trip Mode | |
| (1) | CEE plug |
| (4) | Housing |
| (5) | Card reader |
| (6) | Pushbutton |
| (8) | LED ring |
Kartenleser | |
Eco Mode | |
Next Trip Mode | |
Behind the symbol is the card reader for reading ID chips and the reset card.
The card reader uses RFID (radio-frequency identification). RFID is the transmitter‑receiver technology for automatic and contactless identification with radio waves.
The level of the charging current can be set or the operating mode changed by pressing the pushbutton.
Pressing for less than 0.5 s
Briefly pressing the pushbutton changes the operating mode. The charging modes areThe selected charging mode (see Different charging modes on page (→)) is indicated by the LED status indicator (see LED status indicator on page(→)); in Standard Mode no operating mode LED lights up.
Pressing for over 2.0 s
Repeatedly pressing the pushbutton changes the preset charging current (in amperes). The level of the set charging current is indicated by the LED status indicator (see LED status indicator on page (→)).
Pressing for over 10 s
The WiFi hot spot password is reset. This function is available from software version 41.7.
The level of the preset charging current can be adjusted in the app (see Stromstufe on page (→)).
Standard settings
An ID chip enables personalized access to the Fronius Wattpilot. The ID chip is used for authentication and recording user-dependent charging amounts.
To set this up, activate authentication in the Access > Authentication menu in the app (see Authentifizierung). Charging with authentication activated is possible after scanning the supplied ID chip or by confirming in the app. To do this, hold the ID chip just in front of the card reader on the Wattpilot.
A name can be assigned to each ID chip. The stored charging amount per ID chip can be seen in this menu (see RFID chips).
No authentication is required to assign the charging amount to the ID chips.
The reset card resets all settings (e.g., access management, WiFi, and LED settings) to the factory settings. The device can also be reset using the Fronius Solar.wattpilot app. The paired ID chips, the associated charging amounts, and the settings in the Safety and grid menu are still stored.
The following information is printed on the reset card.
Resetting the Wattpilot
Keep the reset card safe!
The reset card contains all access data.
TIP: Place the reset card in the supplied self-adhesive transparent bag and keep it in a safe place.
The LED status indicator on the Wattpilot indicates whether the system is switched on and the current system status of the Wattpilot. One LED represents one ampere (1 A). A maximum of 32 A is displayed.
The first two LEDs indicate the currently active operating mode. If these do not light up white, the Wattpilot is in standard mode—charging takes place with the maximum set current without taking surplus PV electricity and flexible electricity tariffs into account.
| Eco Mode
| Next Trip Mode
| Starting
| Ready
| Enable
| Waiting
| Wait for car
| 1-phase charging
| 2-phase charging
| 3-phase charging
| Charging finished
| ID chip detected
| Invalid value
| Grounding test deactivated
| Internal communication fault
| Residual current detected
| Grounding fault detected
| At least one phase of the power supply is missing
| Temperature too high
| Unlocking or locking error
| Charge controller error
| Update
| Update successful
| Update failed
| Reset card detected
The Wattpilot can be used like any other charging station. For start-up, the charging cable must be plugged in and the Wattpilot starts charging. By pressing the pushbutton (see Pushbutton functions on page (→)) it is possible to switch between the charging modes (see Different charging modes on page (→)) and change the level of charging current (see Stromstufe on page (→)).
The Fronius Wattpilot automatically or manually switches between 1‑phase and 3‑phase charging (see PV surplus).
The automatic phase changeover enables charging with a low start-up power (1‑phase with 1.4 kW) in the case of PV surplus.
1‑phase charging has the advantage that the charging power can be regulated in smaller increments (0.23 kW) and a small PV surplus is used more efficiently.
For higher PV surplus, 3‑phase charging is preferred. Higher maximum charging power levels are achieved in this way.
To further optimize the charging process, define time intervals for falling below the phase changeover limit value as well as for the pause between the phase changeover.
Unbalanced load management limits the total charging current. The unbalanced load remains below the desired value, which is specified, for example, by the utility. The maximum phase unbalanced load can be set by a qualified technician in accordance with the applicable regulations (see Grid settings).
Exceeding the phase unbalanced load
Select the three-phase power level in such a way that the maximum permissible phase unbalanced load is not exceeded. To do this, amend the settings in the Fronius Solar.wattpilot app under Settings > Grid requirements.
Charging with PV surplus can be activated and adjusted in the Fronius Solar.wattpilot app (see Tariff).
Minimum charging time
Permanent switching of the relays can have a negative effect on the service life of the device.
A minimum charging time of 5 minutes per charging process is stored.
The PV surplus function uses excess energy from a photovoltaic system and, if available, a battery. Details on compatibility with the PV system can be found under Tariff and Suitable generators from third-party manufacturers.
Setting limit values ensures the distribution of the PV surplus power to the loads. A battery is charged to the desired state of charge, hot water is heated to the target temperature with the Fronius Ohmpilot, and a vehicle is charged.
PV surplus regulation
The PV surplus regulation works with only one Wattpilot per photovoltaic system at a time.
If several devices are installed in the system, activate Use PV surplus for all devices.
Configure the devices so that 1 Wattpilot is charging with Eco Mode while the other devices are charging in Standard Mode.
Set a Start value in kW for the charging of the vehicle. If the PV surplus is above this value, the Wattpilot starts charging the vehicle with minimum current.
Enter a Phase switch level (specified in kW), at which the Wattpilot switches from 1‑phase to 3‑phase charging.
Configure the Start value and Phase switch level in the Tariff menu.
The power level is regulated in 1-ampere increments. At nominal voltages of 230 and 400 V, this corresponds to 0.23 kW for 1-phase and 0.69 kW for 3-phase charging. The table shows an overview of charging current and charging power.
Charging current [A] | 6 | 8 | 10 | 12 | 14 | 16 | 20 | 24 | 32 |
1-phase [kW] | 1.4 | 1.8 | 2.3 | 2.8 | 3.2 | 3.7 | 4.6 | 5.5 | 7.4 |
3-phase [kW] | 4.2 | 5.5 | 6.9 | 8.3 | 9.7 | 11 | 13.8 | 16.6 | 22 |
Minimum charging power of electric vehicles
Many electric vehicles require a minimum charging power of 1.4 kW. In smaller photovoltaic systems the electricity that is not covered by the photovoltaic system is drawn from the grid. This results in a power mix of self-consumption and grid consumption.
For smaller PV systems, set the start-up power level below 1.4 kW so that sufficient power is available for charging.
Example
Photovoltaic generation | |
Electric vehicle |
The figure illustrates the behavior with a set start-up power level of 1.4 kW and a 3‑phase power level of 4.14 kW. If the PV surplus is less than 1.4 kW, the vehicle does not charge.
If the PV surplus is between 1.4 and 4.2 kW, the Wattpilot regulates the charging power in 0.23 kW increments.
If the PV surplus is above 4.14 kW, the Wattpilot switches from 1‑phase charging to 3‑phase charging and regulates the charging power in 0.69 kW increments.
The Ohmpilot and PV battery SOC menu tiles in the Fronius Solar.wattpilot app (see chapter Start page and navigation elements) influence the priority of the Wattpilot. The level of the selected limit values defines under which conditions the charging of the electric vehicle starts. The load management settings on the user interface of the inverter must also be taken into account.
IMPORTANT!
The I/O power management of the inverter is not suitable for load management of the Wattpilot. The priorities of the loads are not clearly assigned.
Ohmpilot
Set a temperature limit value on the start page of the Fronius Solar.wattpilot app. When the hot water has reached this temperature, the charging process starts with PV surplus.
Fronius Ohmpilot temperature sensor
If no temperature sensor is connected to the Fronius Ohmpilot, a temperature of 0 °C is assumed. In the event of a defect in the temperature sensor, the Ohmpilot is automatically prioritized over the Wattpilot.
Use a temperature sensor.
Set a target temperature to prioritize the use of PV surplus for the Ohmpilot.
Set a temperature of 0 °C if the Wattpilot has a higher priority than the Ohmpilot.
PV battery SOC
The SOC or State of Charge is the state of charge of the stationary battery. Set the following limit values for the use of the energy from the battery for charging on the start page of the Fronius Solar.wattpilot app:
Example
Charging the electric vehicle takes priority over the battery and the Ohmpilot. The Charge above parameter is set to 0%. The limit value of the Ohmpilot is set to 0 °C. The electric vehicle is charged with PV surplus. The state of charge of the battery and the temperature of the Ohmpilot are not relevant.
Priority in the inverter | Wattpilot | Battery** | Ohmpilot |
Battery* > Ohmpilot | Priority 3 until SOC and temperature limit value reached, then priority 1 | Priority 1 until SOC, then priority 2 | Priority 2 until temperature limit value reached, then priority 3 |
Ohmpilot > Battery* | Priority 3 until SOC and temperature limit value reached, then priority 1 | Priority 2 until SOC, then priority 3 | Priority 1 until temperature limit value reached, then priority 2 |
Priority in the inverter | Wattpilot | Ohmpilot |
Ohmpilot | Priority 2 until temperature limit value reached, then priority 1 | Priority 1 until temperature limit value reached, then priority 2 |
Battery* | Priority 2 until SOC, then priority 1 | Priority 1 until SOC, then priority 2 |
*Please see the operating instructions for the inverter for a list of compatible batteries.
Tariff zones
If the energy supplier offers a flexible electricity tariff, this function can be used. This is taken into account when using Eco Mode and Next Trip Mode.
Provider
A prerequisite is an electricity retailer that bills flexible electricity tariffs hourly via the electricity exchange, e.g.:
The Wattpilot obtains the tariffs of the electricity exchange directly from the Internet. It is possible to specify a price limit. As soon as the price is below this limit, charging starts in Eco Mode. In Next Trip Mode the Wattpilot charges with the cheapest electricity tariff that is available in the defined charging period.
All displayed prices correspond to the current tariffs of the electricity exchange. Additional costs may apply depending on the provider.
Example
The figure shows the development of the electricity price (cents per kWh) of an electricity retailer within 24 hours. The hourly tariffs are retrieved from the electricity exchange at a specific time for the next day.
When the Wattpilot is connected to the Internet, the device supports the Dynamic Load Balancing function (dynamic load management). The function is available with the following system components:
Activation
Activation
Dynamic Load Balancing manages the charging current at the grid connection point and limits the charging current if there is a risk of overloading the grid connection. The function takes into account the electricity generated by the photovoltaic system and other generators in the system as well as the consumption. Prioritization can be set up for several Wattpilots. The dynamic control uses the maximum possible charging current.
Dynamic Load Balancing monitors the available current per phase (including PV surplus) at the grid connection point and dynamically distributes this to one or more Wattpilots. The Wattpilots are supplied with the maximum available current. The delivery current is not exceeded and can be limited for the Wattpilots.
Charging 1-phase electric vehicles evenly with multiple Wattpilots
If there are multiple 1-phase electric vehicles, an excessive unbalanced load can occur.
If there are multiple Wattpilots, change the phase assignment at the terminals cyclically.
Set the maximum delivery current to match the post-meter fuse.
Control system example
| (1) | Photovoltaic system |
| (2) | Inverter |
| (3) | Loads |
| (4) | Fronius Smart Meter |
| (5) | Fronius Wattpilot |
| (6) | Electric vehicle |
| (7) | Grid connection point |
In the control system example, the energy drawn from the public grid is limited to 32 A. 8 A are generated by the PV system. Of a total of 40 A, 20 A are accounted for by the loads in the household. The Dynamic Load Balancing distributes 20 A to the connected Wattpilots. This enables charging of, for example, two electric vehicles with 10 A each.
Charging is interrupted or does not start.
If Dynamic Load Balancing is activated, charging interruptions may occur. Some electric vehicles encounter problems when starting charging again.
In the case of systems with multiple Wattpilots, charging priorities can be set. The charging stations (electric vehicles) with a higher priority are supplied with current first; charging stations with a lower priority have to wait. If there is current left over, it is shared among the lower-priority Wattpilots.
The vehicles that are to be charged first and with the maximum available current must be assigned a high priority. A low priority can be assigned to vehicles that should wait to charge until sufficient current is available.
In the case of Wattpilots with the same priority, the available current is shared equally.
Example 1
Distribution of the charging current with three Wattpilots with different priorities (one with high priority, two with medium priority). |
Example 2
Distribution of the charging current with three Wattpilots (X, Y, Z) with the same priority. Each Wattpilot is assigned the minimum charging current (unless the minimum charging current is no longer available). If there is charging current left over, it is distributed wherever possible, starting with the first Wattpilot in the loop.
Wattpilot X has a minimum charging current of 6 A, Wattpilot Y 10 A and Wattpilot Z 6 A. There is 15 A of charging current to be distributed. The charging current is distributed as follows.
The 15 A charging current was distributed among the equally prioritized Wattpilots and charged. As soon as charging current is available again, the electric vehicle is charged at Wattpilot Y.
The following link provides current webinars and how-to videos for the Fronius Wattpilot.
The following criteria must be taken into account when choosing a location.
The Wattpilot is suitable for outdoor operation without direct sunlight. | ||
| The Wattpilot is suitable for operation in a well-ventilated indoor area. | |
| Do not operate the Wattpilot in areas where there is an increased risk from ammonia gases. |
The Wattpilot is suitable for operation indoors and outdoors.
For environmental conditions, see WattpilotHome11J2.0 on page (→).
Beware of warping of the mounting bracket on uneven surfaces.
An uneven surface can cause the mounting bracket to warp, making it impossible to attach the Wattpilot.
Select a suitable location on an even surface.
The Wattpilot is designed to be installed vertically on a vertical, level wall. | ||
The type 2 plug is not waterproof.
Water can penetrate when the Wattpilot is mounted horizontally.
Mount the Wattpilot vertically.
Installation and commissioning may only be carried out by a qualified electrician!
Requirements for the qualification of qualified electricians – knowledge of and compliance with the five safety rules for working on electrical systems.
Disconnect.
Secure against anyone inadvertently turning on the power again.
Ensure the system is no longer live.
Ground and short circuit.
Cover or shield neighboring parts that are energized.
Failure to comply with the reporting obligation may result in legal consequences.
Failure to comply with the reporting obligation may result in fines or sanctions.
Check with the utility to confirm whether there is a reporting obligation for charging stations in the target country.
If necessary, report the charging station to the responsible utility in order to avoid legal consequences.
Disconnect.
When mounting the mounting bracket, ensure that it is not warped or deformed. The following illustrations may differ slightly from the actual product; the Wattpilot Home 11 J 2.0 / Home 22 J 2.0 does not have a mains plug.
Mark the drill holes 4 times.
Drill 4 holes.
Place dowels in the holes and fasten the mounting bracket with screws.
Hang the Wattpilot in the mounting bracket.
To protect the Wattpilot from contact, it must be mounted at least 140 cm above the ground.
The minimum height of 140 cm must be observed in Sweden.
The fastening materials and the padlock are not included. Use appropriate fastening materials depending on the substrate. The installer is responsible for selecting the right type of fixing.
Mount the anti-theft protection at least 5 cm above the mounting bracket.
Drill a hole with a suitable drill bit.
Mount the anti-theft protection using suitable fastening materials.
Secure the Wattpilot with a padlock.
When installing the Wattpilot Home 11 J 2.0 or Home 22 J 2.0, the mains cable must be installed by a qualified person in accordance with national standards. The fuse protection for the mains lead must be dimensioned in accordance with the device technical data.
Danger from mains voltage!
Always make sure the circuit is disconnected and de-energized before carrying out any connection work.
Have the connection work performed by an authorized electrician.
Have the 5‑pin mains cable connected by an authorized electrician in accordance with national standards and safety rules. Depending on the available mains supply type, opt for a 1- or 3-phase connection.
*Digital input: optional connection to a ripple control receiver with floating contact
For 1-phase operation, use phase L1.
To supply power to the Wattpilot, phase L1 must be connected. The unused phases L2 and L3 must be isolated (contact protection)!
In backup power mode, select the maximum charging current so that the maximum output power of the inverter is not exceeded.
IMPORTANT!
Check whether the electric vehicle allows charging at 53 Hz. If necessary, adjust the Backup power frequency offset parameter on the user interface of the inverter.
Start up the permanently installed Wattpilot Home 11 J 2.0 / Home 22 J 2.0 from step 2.
Connect the CEE plug to a suitable socket directly or with a suitable adapter.
The LEDs light up in rainbow colors during an initial self-test. Afterwards, the number of LEDs corresponding to the set charging current light up blue.
Connect a Type 2 to Type 2/Type 1 charging cable to the Wattpilot and the car.
During a test, all LEDs light up yellow.
The start of the charging process is indicated by the switching of the LEDs and started with a clicking sound from the Wattpilot.
For more information on LED status indicators, see chapter LED status indicator on page (→).
The car is charged.
The car is charged.
When the vehicle battery is fully charged, the vehicle stops charging.
The charging cable remains locked to the Wattpilot by default (anti-theft protection). This can be changed in the app (see chapter Cable release on page (→)).
The way in which the cable is released can be configured in the app.
If the power supply is interrupted, the charging cable remains locked in the Wattpilot for reasons of theft protection. The cable release can be activated in the app under "Unlock in case of power failure".
Restore the power supply to the Wattpilot to unlock the charging cable.
Configure the cable release in the app.
Charging with PV surplus (see PV surplus) is possible in combination with a compatible Fronius inverter (see Suitable inverters). This function can be used with external inverters (see Suitable generators from third-party manufacturers) if a Fronius Smart Meter IP 5kA-3 is installed. As soon as an inverter is in the network, the Wattpilot automatically pairs with the first inverter found.
Open the Fronius Solar.wattpilot app to pair another inverter.
RequirementsThe Fronius Solar.wattpilot app can be used to commission, configure, operate, and update the Wattpilot. The app visualizes charging processes and saves the records (e.g., for billing purposes). The app is available for Android™ and iOS®.
Software updates
Outdated versions of the app and device firmware can negatively affect the functionality and safety of the device.
Activate the notification for available updates of the app and the device firmware in the Services > Software version menu.
When notified, update to the new version of the device firmware or app.
The Fronius Solar.wattpilot app is available on the following platforms.
On end devices with an iOS operating system, enable access for the Fronius Solar.wattpilot app:
The Wattpilot opens a WiFi hot spot that is always on.
For devices with an Android operating system, the selected Wattpilot WiFi must remain connected even when there is no Internet connection.
In Germany, to comply with the documentation obligation set out in Section 14a of the EnWG (law on the fuel and electricity industries) the Wattpilot must be permanently connected to the Internet in order to be able to verify implementation of the external control commands.
To add new or already connected devices in the Fronius Solar.wattpilot app:
The images show the start page of the Fronius Solar.wattpilot app.
Tap on the device name to manage and add devices. | |
Charging process view:
Charging mode: Select a charging mode (see Different charging modes). | |
In Next Trip Mode, under Departure, specify the desired amount of energy in a kilometer range and the time. | |
Set the charging speed (see Stromstufe). | |
Navigate from the Home start page to the following menu areas: |
Swipe left in the charging process view. | |
The records of charging processes and charged energy can be found in the History menu.
Value | Description |
Session Number | Unique identification number |
Session Identifier | Unique charging process number |
ID chip | Information on the logged-in ID chip. If charging is carried out without an ID chip, this line is empty. |
Operating mode Eco[%] | Proportion of charged energy from Eco Mode as a percentage. |
Operating mode Next Trip [%] | Proportion of charged energy from Next Trip Mode as a percentage. |
Start | Date and time the charging cable was plugged in. |
End | Date and time when the charging cable was disconnected. |
Total duration | Charging period |
Duration of active current flow | Period of time the vehicle was charged with energy. |
Maximum output [kW] | Maximum power achieved in kilowatts |
Maximum current [A] | Maximum current in amperes |
Energy [kWh] | Charged energy in kilowatt-hours |
Meter reading at the start [kWh] | Meter reading in kilowatt-hours at the start of charging. |
Meter reading at the end [kWh] | Meter reading in kilowatt-hours at the charge end. |
All configuration options for charging the electric vehicle, data communication, permissions, and handling of the Fronius Solar.wattpilot app can be found in the Settings menu.
In Standard Mode, the Wattpilot charges at the preset amperage (e.g., 16 A). A PV surplus and the electricity tariff are not taken into account. Current levels with associated charging current can be defined in the Stromstufe menu. Charging takes place with grid current if necessary.
In Eco Mode a vehicle is only charged if there is surplus energy available from the photovoltaic system and/or the electricity price is below a defined limit value.
Change mode for guaranteed charging
If there is no PV surplus or cheap electricity available, charging is not carried out in Eco Mode.
For guaranteed charging, change to Standard or Next Trip Mode.
Battery discharge
If the system contains a battery, the battery is discharged to charge the electric vehicle before grid current is drawn.
Define the limit values for the battery in the prioritization (see Prioritization of Fronius Ohmpilot and battery storage).
Use the Energy cost assistant (=ECA) function in Solar.web to further optimize battery management in combination with flexible electricity tariffs.
Next Trip Mode regulates the charging of the electric vehicle until the next planned trip, taking into account PV surplus and a flexible electricity tariff. The following parameters are relevant for charging:
The Wattpilot calculates the set average consumption. The time charging starts is selected in such a way that the desired charging amount is charged at least one hour before the charge end. The actual state of charge of the electric vehicle battery is not read out. The set charging amount is charged in addition to the charging amount available in the electric vehicle.
After activating the mode, charging starts briefly to calculate the charging schedule taking into account the possible charging power. If no flexible electricity tariff is activated in the Tariff menu, charging is started at the latest possible time. Any PV surplus is used and the electric vehicle battery is protected. If no time is provided for the calculation of the charging schedule, charging starts immediately.
If the charging cable is disconnected and reconnected while Next Trip Mode is activated, the calculation is repeated. The set charging amount is charged in addition to the charging amount already available. Recalculation also takes place in the event of changes to the settings of the Fronius Solar.wattpilot app.
Internet connection
If the Tariff function is activated (in Next Trip Mode) and there is no connection to the Internet, the data of the electricity provider is not retrieved. The Next Trip Mode LED on the Wattpilot flashes white.
Charging starts at the latest possible time in order to reach the set charging amount.
Next Trip Mode LED flashing white
If the set charging amount cannot be charged in the specified time or if the vehicle cannot store the set charging amount, the LEDs flash white.
Reduce the charging amount or extend the charging time.
Prerequisite
The function is available when a battery is present in the photovoltaic system and Eco Mode is selected.
If the Energy Cost Assistant function is active on the inverter, the inverter can temporarily block the battery discharge, for example, to charge the battery from the public grid at a low electricity price.
Function
The energy for charging is used directly from the battery. As a result, low-cost energy can be obtained, even if no PV surplus is available. The settings can be used to define how much residual energy remains in the battery. In addition, you can set whether the charge from the battery should be used once, or whether it should continue until the vehicle is unplugged.
It can take up to 10 minutes for the battery to discharge at maximum power. The state of charge of the battery at the inverter must be greater than the Discharge until limit value.
Für die Einstellung der Ladegeschwindigkeit (siehe Start page and navigation elements) 5 Stufen mit dazugehörigem Ladestrom in Ampere definieren. Je nach Gerätevariante für jede Stufe einen Wert zwischen 6 A und 32 A angeben. Alternativ den Druckknopf am Gerät für mindestens 2 Sekunden drücken, um die Stromstufen durchzuschalten (siehe Kapitel Pushbutton functions auf Seite (→)).
Ladeinfrastruktur
Die Ladung mit hoher Lade-Geschwindigkeit in unbekannter Ladeinfrastruktur kann zu Unterbrechungen des Ladevorgangs führen.
Die niedrigste Lade-Geschwindigkeit (6 A) wählen, wenn die Ladeinfrastruktur nicht bekannt ist.
Lebensdauer der Fahrzeug-Batterie
Eine langsame Ladung mit niedrigem Ladestrom schont die Batterie des Fahrzeugs.
Eine niedrige Lade-Geschwindigkeit einstellen, um die Batterie-Lebensdauer zu verlängern.
Ladeinfrastruktur
The Scheduler limits charging to certain times for the following application examples:
Activated Eco Mode or Next Trip Mode
If charging is restricted by the charging timer, Eco Mode and Next Trip Mode are blocked outside this period.
Adjust the time intervals for the scheduler to the users' travel habits and the availability of PV surplus.
For optimum charging behavior, please note the information in the operating instructions for the vehicle.
In this menu, select Standard and set the following parameters under Advanced settings. For optimum charging behavior, please note the information in the operating instructions for the vehicle.
Vehicle – Advanced settings
The Wattpilot can also individually adapt the charging process to the requirements of the vehicle. Under Charging behavior, select a vehicle from the list. The Wattpilot takes over all vehicle-specific parameters.
Activate the Use PV surplus slider to use the excess energy of the PV system for charging.
Inverter/Smart Meter IP
Select an available inverter or Smart Meter IP for connection to the Wattpilot. A connected device is displayed.
PV surplus start value
Define a limit value from which the available energy of the PV system is used for charging. In addition, specify a phase switch level for the switch from single-phase to three-phase charging. If "0" is set, the Wattpilot starts charging even if no PV surplus is available.
PV battery threshold
If a battery is integrated into the PV system, the following limit values can be set:
The set limit values are only active in Eco Mode and Next Trip Mode.
Ohmpilot threshold
If a Fronius Ohmpilot with a temperature sensor is installed in the PV system, set a limit value for the temperature here. When the set temperature is reached, the excess energy of the PV system is used for charging.
PV surplus – Advanced settings
The power is regulated in 1 ampere increments. Despite the control behavior, there is grid consumption or feed-in of the PV surplus between the increments.
If zero feed-in is activated, the Prefer from grid option is automatically activated to meet the regulatory requirements. PV optimization control may be restricted.
In the charging modes Flexible electricity price and Next Trip Mode vehicles can be charged from the grid at favorable rates with the Tariff function. A contract with a provider of a flexible electricity tariff is required.
Next Trip Mode only takes into account the cheapest charging times in the available time span.
Next Trip Mode
Electric vehicle | |
Household consumption |
There is a PV system, but no flexible electricity tariff. The daily journey to work starts at 08:00 hrs. The distance is 50 km round trip. The kilometers and the departure time have been entered in the Fronius Solar.wattpilot app. Charging starts at 15:00 hrs with PV surplus. The remaining charging amount is charged using grid current at the latest possible time in the early hours of the morning. The charge is completed one hour before departure.
State of charge
If the electric vehicle is sufficiently charged, the use of Eco Mode is recommended.
Select Eco Mode on the start page of the Fronius Solar.wattpilot app.
Eco Mode
A PV system and a flexible electricity tariff are available. In Eco Mode, the electric vehicle is connected to the Wattpilot at around 15:00 hrs, as although a fixed additional range for the electric vehicle is not necessary, cheaper electricity is to be used for charging. In the Fronius Solar.wattpilot app, the PV surplus and/or flexible electricity tariff must be activated and set in the Charging menu. Household consumption is covered by photovoltaic generation and the electric vehicle is charged with the PV surplus. Charging takes place using the PV surplus until around 20:00 hrs. Between 02:00 and 05:00 hrs, the electricity price falls below the defined price limit. The electric vehicle is charged with cheap electricity during this period.
Charging in Eco Mode
PV surplus | Price limit | Wattpilot |
No | No | No charging |
No | Yes | Max. charging |
Yes | No | Charging with PV surplus |
Yes | Yes | Max. charging |
PV surplus with phase switching
Electric vehicle |
The figure illustrates the behavior of the Wattpilot with a set start-up power level of 1.4 kW and a 3‑phase power level of 4.2 kW. If the PV surplus is less than 1.4 kW, the vehicle does not charge.
If the PV surplus is between 1.4 kW and 4.2 kW, the Wattpilot regulates the charging power in 0.23 kW increments.
If the PV surplus is above 4.2 kW, the Wattpilot switches from 1‑phase charging to 3‑phase charging and regulates the charging power in 0.69 kW increments.
Charging from the battery
The function is available when a battery is present in the photovoltaic system and Eco Mode or Next Trip Mode is selected.
In this example, the battery is 80% charged. Due to the current weather conditions, no additional energy is stored. The vehicle is charged up to the discharging limit (e.g., 20%). In addition, the settings stipulate that the discharge is continued until the vehicle is unplugged (see Charging from the battery). If the weather conditions change and PV surplus is fed into the battery again, the vehicle charges until it is unplugged.
Change the name of the Wattpilot.
Set the LED brightness values. Activate Switch off LEDs after 10 s in standby (optional).
An individual color scheme can be set for the different operating states of the Wattpilot. The color code of the selected color is displayed.
Set the time zone. Activate Automatically switch to daylight saving time to automatically set summer and winter time.
The password protects against unauthorized access.
Password policy
Password policy
Die Modusauswahl und die Auswahl der Stromstufe können auch über den Druckknopf am Gerät eingestellt werden.
Modusauswahl sperrenIt is possible for up to 10 commercially available RFID chips to be used. The RFID chip is used for authentication and to record each user's charging processes. The chip can be paired with several devices. The chips and the charging amount remain stored when the device is reset to factory settings. The supplied chips have already been paired.
Folgende Verbindungs-Möglichkeiten konfigurieren:
The charging point communication standard OCPP (Open Charge Point Protocol) enables communication between the Fronius Wattpilot and a management system. Setup is carried out via a remote server provider or locally.
Activate OCPP
Activation or deactivation of OCPP.
Address
Enter the address of the OCPP server made available by the provider in the OCPP menu of the app.
Alternative ID
An alternative ID can be stored in the History menu in case a charging process is started without authentication with an ID chip.
Phase assignment
Settings for the phase assignment of the Wattpilot in alignment with a Fronius Smart Meter. This is, for example, necessary for the load balancing to function correctly.
The Wattpilot's current firmware is loaded via the Internet. The Firmware version menu displays which firmware version is installed and whether an update is available.
Update the Fronius Solar.wattpilot app via the respective platform (Google Play Store, App Store).
Beta
New beta versions of the firmware can be pre-installed and tested. Test feedback on the beta versions is expressly welcomed.
Changing firmware
The old firmware remains stored on the Wattpilot after an update. In the event of an error, it is possible to switch between the old and the new firmware version even without an Internet connection.
Beta
Changing firmware
After pressing the button, the Wattpilot restarts.
Select this button to reset the Wattpilot to its factory settings. The following settings are not reset:
The technician password protects the network and security-related settings against unauthorized access.
For general information on Dynamic Load Balancing, see Dynamic load balancing. The Dynamic Load Balancing monitors the current at the reference point.
Choose country
Different charging conditions are allowed depending on the country. In this selection, all known default settings for the respective country are stored and can be selected directly.
Max. charging current
This setting is used to adjust the maximum charging current of the Wattpilot. For optimal use of the PV surplus, set the charging current to the maximum value approved by the utility.
Random maximum delay
Random charging start delay means that the grid is not overloaded when several Wattpilots start charging at the same time. This is relevant when using flexible electricity tariffs or after a power outage.
Initial Connection and Reconnection
Set the parameters for voltage, frequency, and time.
Undervoltage Shutdown
Define a threshold value for voltage and time for shutdown of the Wattpilot.
Phase unbalanced load
Activate and set the maximum phase unbalanced load. Set the maximum asymmetry in accordance with the applicable regulations (see Phase unbalanced load).
Standard mode
The charging cable at the charging station remains locked after completion of the charging process until the charging cable is disconnected from the vehicle (anti-theft protection).
Auto-unlock
The charging cable is only locked during charging.
Always locked
The charging cable on the Wattpilot is always locked. Switch to standard mode to unlock.
The charging cable is unlocked in the event of a power failure. By default, the charging cable remains locked in the event of a power failure for reasons of theft protection. To unlock the charging cable, the Wattpilot must be supplied with power again.
Activation or deactivation of the grounding test. It is necessary to deactivate the grounding test in insulated grids in some countries (e.g., Norway).
The digital input can be used with the Fronius Wattpilot Home 2.0.
The digital input in the mains lead can be used to limit the charging current, e.g., for charge release via a keylock switch or for the grid operator to connect to a ripple control receiver. The digital input settings can be protected with the technician password (Settings > Password > Protect digital input).
NO = Normally open
The red and white cables must be connected together to limit the charging power or charging current.
NC = Normally closed
The red and white cables must not be connected to limit the charging power or charging current.
The device has a built-in residual current protection module with residual current detection (IΔn = 20 mA AC and 6 mA DC).
The residual current detection tripping characteristic is as follows.
Residual currents
Residual currents can damage the device. For this reason, the Wattpilot Flex has a built-in residual current protection module with residual current detection.
Connect a separate residual current circuit breaker (type A, IΔn = 30 mA AC or type B if required) upstream of the installation.
Comply with all national regulations and standards.
Residual currents
Residual currents
The Wattpilot works with the following standard settings during start-up, without making any further settings in the Fronius Solar.wattpilot app. The standard settings can be restored with the reset card.
Charging mode | Go 11 J 2.0 / | Go 22 J 2.0 / |
Eco Mode | Off | |
Next Trip Mode | Off | |
Current level | Go 11 J 2.0 / | Go 22 J 2.0 / |
Level 1 (gentle) | 6 A | 10 A |
Level 2 | 10 A | 16 A |
Level 3 | 12 A | 20 A |
Level 4 | 14 A | 24 A |
Level 5 (rapid) | 16 A | 32 A |
Next Trip Mode | Go 11 J 2.0 / | Go 22 J 2.0 / |
Minimum range [km] or [kWh] | 100 [km] [18.00 kWh] | |
Until [time] | 06:00 | |
Eco Mode after Next Trip Mode | On | |
Consumption over 100 km | 18 [kWh] | |
Cost optimization | Go 11 J 2.0 / | Go 22 J 2.0 / |
Use Lumina Strom / aWattar | Off | |
Country | Germany | |
Eco Mode price limit | 3 cents | |
Use PV surplus | On | |
Inverter | First found, otherwise empty | |
PV battery threshold | 20% | |
Ohmpilot threshold | 20 °C | |
PV surplus | For advanced settings, see the following table | |
Car | For advanced settings, see the following table | |
PV surplus | Go 11 J 2.0 / | Go 22 J 2.0 / |
Start-up power level | 1.40 kW | |
Zero feed-in | Off | |
Control response | Standard | |
Car | Go 11 J 2.0 / | Go 22 J 2.0 / |
Choose car | Standard charging behavior | |
Minimum current | 6 A | |
Forced charging interval | 0 min | |
Allow charging pause | On | |
Simulate unplugging | Off | |
Charging pause | 0 min | |
Minimum charging time | 5 min | |
Choose phase switch | Automatic | |
3‑phase power level | 4.20 kW | |
Phase switch delay | 2 min | |
Phase switch interval | 10 min | |
Brightness | Go 11 J 2.0 / | Go 22 J 2.0 / |
Brightness | Max. | |
Switch off LEDs after 10 s in standby | Off | |
LED colors | Go 11 J 2.0 / | Go 22 J 2.0 / |
Ready | R = 0, G = 0, B = 255 | |
Charging | R = 0, G = 255, B = 255 | |
Done | R = 0, G = 255, B = 0 | |
Time zone | Go 11 J 2.0 / | Go 22 J 2.0 / |
Time zone | GMT+1:00 ECT European Central Time | |
Automatic summer time changeover | On | |
Local time | Automatic | |
Access management | Go 11 J 2.0 / | Go 22 J 2.0 / |
Authentication | Open | |
Lock mode selection | Never locked | |
Current level selection locked | Never locked | |
Cable release | Go 11 J 2.0 / | Go 22 J 2.0 / |
Cable release | Standard mode | |
Unlock in case of power failure | Off | |
Grounding control | Go 11 J 2.0 / | Go 22 J 2.0 / |
Additional settings | Go 11 J 2.0 / | Go 22 J 2.0 / |
Grounding control | Activated | |
Allow Internet connection | On | |
Fronius Wattpilot - Technische Daten | Go 11 J 2.0 |
Maximale Ladeleistung | 11 kW |
Netzformen | TT/TN/IT |
Netzanschluss | CEE-Stecker rot 16 A, 5‑polig |
Nennspannung | 230 und 240 V (1‑phasig)/400 und 415 V (3‑phasig) |
Nennstrom (konfigurierbar) | 6 ‑ 16 A |
Netzfrequenz | 50 Hz |
Leistungsaufnahme im Standby | 1,9 W (LED dunkel), 4,2 W (LED hell) |
Ladesteckdose | Typ 2‑Dose mit |
Fehlerstrom Schutzeinrichtung | 20 mAAC, 6 mADC |
Leiterquerschnitt Zuleitung | Min. 2,5 mm2 |
RFID (radio frequency identification) | 13,56 MHz |
WLAN | IEEE 802.11b/g/n | 2,4 GHz |
Unterstützte Sicherheitsstandards | WEP, WPA, WPA2/WPA3 |
Schutzart | IP 65 |
Stoßfestigkeit | IK08 |
Abmessungen (Breite x Höhe x Tiefe) | 155 x 287 x 109 mm |
Gewicht | 2 kg |
Verwendung | Innen- und Außenbereich |
Installationsart | Hängend |
Umgebungstemperatur | -25 bis +40 °C |
Durchschnittliche Umgebungstemperatur über 24 Stunden | Max. 35 °C |
Luftfeuchtigkeit | 5 – 95 % |
Seehöhe | 0 – 2 000 m |
Schutzart | IP 65 |
Gewicht | 2 kg |
Fronius Wattpilot - Technische Daten | Go 22 J 2.0 |
Maximale Ladeleistung | 22 kW |
Netzanschluss | CEE-Stecker rot 32 A, 5‑polig |
Nennstrom (konfigurierbar) | 6 ‑ 32 A |
Leiterquerschnitt Zuleitung | Min. 6 mm2 |
Schutzart | IP 65 |
Gewicht | 2 kg |
Fronius Wattpilot - Technische Daten | Go 22 J 2.0 AUS |
Netzanschluss | 3-phasiger Stecker 32 A (AU), |
Schutzart | IP 65 |
Gewicht | 2 kg |
Fronius Wattpilot - Technische Daten | Home 11 J 2.0 |
Netzanschluss | 5‑poliges Kabel |
Netzstrom (konfigurierbar) | 6 ‑ 16 A |
Schutzart | IP 65 |
Gewicht | 2 kg |
Fronius Wattpilot - Technische Daten | Home 22 J 2.0 |
Netzstrom (konfigurierbar) | 6 ‑ 32 A |
Ladesteckdose | Infrastrukturseitige Typ 2‑Dose mit |
Schutzart | IP 65 |
Gewicht | 2 kg |
Due to the Fronius Wattpilot's phase, voltage, and switching function tests, a charge may be refused.
The status codes are displayed via the LED status indicator (see LED status indicator) directly on the Wattpilot and in the app under "Status".
| Cause: | The residual current device has detected an error. |
| Remedy: | The charging device in the vehicle may be defective. Have the charging device checked by a qualified technician. |
| Remedy: | Disconnect and reconnect the charging cable. |
| Cause: | The device is only supplied with 2 phases. |
| Remedy: | Ensure that phase 2 and phase 3 are correctly connected. Supply via only phase 1 is possible as an option. |
| Cause: | Ground fault detected. |
| Remedy: | Check that the connection is properly grounded. |
| Cause: | The relay has not switched. |
| Remedy: | The device must be disconnected from the power supply for 5 s. |
| Cause: | 53 Hz mains current detected. |
| Remedy: | Observe the instructions in the Operating Instructions. |
| Cause: | The plug locking system does not work. |
| Remedy: | Remove possible foreign parts in the plug housing. |
| Cause: | Type 2 plug not fully inserted. |
| Remedy: | Insert the type 2 plug into the device as far as it will go until you hear a click. |
| Cause: | The electric vehicle is plugged in. |
| Remedy: | Unplug the electric vehicle. |
| Cause: | "Always locked" under "Cable release" in the Solar.wattpilot app is activated. |
| Remedy: | Deactivate "Always locked" under "Cable release" in the Solar.wattpilot app. |
| Cause: | Release jammed. |
| Remedy: | Insert the type 2 plug into the device as far as it will go until you hear a click. If the problem has still not been fixed: Press the pushbutton on the device. If the problem has still not been fixed: Activate and save "Always locked" in the Solar.wattpilot app, then activate and save "Standard mode" under "Cable release". |
| Cause: | Device is not sending data. |
| Remedy: | Disconnect and reconnect the device. |
| Remedy: | Perform firmware update. |
| Remedy: | Have the device repaired. |
| Cause: | Continuous load, ambient temperature too high. |
| Remedy: | Unplug the device and allow it to cool down. |
| Cause: | Wrongly routed cables, direct sunlight, or high ambient temperature. |
| Remedy: | Switch off the device and allow it to cool down. |
| Cause: | Unable to retrieve flexible electricity tariff. |
| Remedy: | Check WiFi and Internet connection. |
| Remedy: | Wait until the server is available again. |
| Cause: | It was not possible to establish a connection with the inverter. |
| Remedy: | Check the network settings. |
| Remedy: | Check the settings of the inverter. |
| Remedy: | Make sure that the Fronius Solar API is activated on the inverter. |
| Cause: | Eco Mode is selected, and the Use PV surplus and Use flexible electricity tariff settings are deactivated. |
| Remedy: | Activate the Use PV surplus and/or Use flexible electricity tariff setting(s). |
| Remedy: | Switch the mode. |
| Cause: | Use flexible electricity tariff is activated and there is no data connection to the Internet. Cached price data are still available. |
| Cause: | The specified time is not sufficient for the desired amount of energy. |
| Remedy: | Extend the specified time for charging. |
| Remedy: | Reduce the desired amount of energy. |
| Cause: | It was not possible to establish a connection. |
| Cause: | The vehicle is not detected. |
| Remedy: | Check the vehicle cable and the fit of the charging plugs. |
| Cause: | No power on the junction box. |
| Remedy: | Check the overload fuse of the connection. |
| Cause: | The brightness of the LEDs has been set to 0. |
| Remedy: | Increase the brightness of the LEDs in the Fronius Solar.wattpilot app. |
| Cause: | "Switch off LEDs after 10 s in standby" has been enabled. |
| Remedy: | Deactivate "Switch off LEDs after 10 s in standby" or press the push button on the Wattpilot. |
Detailed warranty conditions specific to your country can be found at https://www.fronius.com/en/download-center?searchword=Warranty+conditions .
If there is a warranty for the relevant product, register the product at https://warranty.fronius.com/ and activate or extend the warranty.
Used equipment and batteries must be returned to the distributor or an authorized local collection system. Do not dispose of batteries with domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
Arrange for the safe collection and proper disposal of damaged, leaking or used batteries by a battery recycling company or the Fronius Service Partner.
In addition, it should be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances such as heavy metals or electrolytes, which can contaminate soil, water and air.
This ensures environmental protection and the sustainable use of natural resources.Packaging materials
