The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device mustFor the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
The cleaning device is intended exclusively for the mechanical cleaning of Fronius robot welding torches in automatic operation. Any other use shall be deemed to be not in accordance with the intended use.
Intended use also means:The device is designed for operation in industry and business.
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6500 ft.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Do not linger in the operating area of the robot.
Always integrate the device into a higher-level safety system in a secured area.
If this area has to be accessed for preparatory or maintenance work, ensure thatIf untrained operating personnel have access to the device, the compressed air supply to the device must be disconnected for the duration of this access in accordance with "Performance Level d" of ISO 13849-1.
In addition to these Operating Instructions, the safety rules of the robot manufacturer must be followed.
The human body, and, in particular, hands, face and hair, plus items of clothing and all tools, must be kept away from moving components, such as:Do not touch the cleaning cutter immediately after operation - burning hazard. Follow the special safety regulations for handling the cleaning cutter in the Operating Instructions.
Protect hands, face and eyes from flying parts (chips, etc.) and compressed air/parting agent mixture discharged from the parting-agent injection nozzle.
Covers must only be opened/removed during maintenance, installation and repair work.
During operation:You are exposed to numerous hazards while handling the device. In addition to these Operating Instructions, the safety rules of the manufacturer of the entire welding system must be followed.
Keep persons, especially children, away during the operation of the devices and during the welding process. However, if persons are in the vicinity:EMC device classification as per the rating plate or technical data.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
A toppling device can be deadly! Install the device horizontally on a flat, stable surface free of vibration, anchor it securely on the surface, and secure against toppling.
Special regulations apply in areas at risk of fire or explosionUse instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before it is commissioned. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is started up.
Before starting up the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
A safety inspection by a certified electrician is recommended:For the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
Devices with CE marking satisfy the essential requirements of the relevant directives (e.g. the low-voltage, electromagnetic compatibility, and machinery directives).
Packaging materialsCopyright of these operating instructions remains with the manufacturer.
The cleaning device is intended to automatically clean MIG/MAG welding torches. The cleaning device can be used to reliably clean the inside of gas nozzles and the face of the gas nozzles in a range of welding torch geometries. This significantly increases the service life of wearing parts. At the same time, the even application of parting agent prevents the build-up of new dirt.
The cleaning device is exclusively suited for operation in automation and robot applications and can be used for a range of materials.
Main applications:The cleaning device has warning notices and a rating plate fitted. These warning notices and the rating plate must not be removed or painted over.
PLEASE NOTE! Risk of serious injury from mechanically moving parts. | |
For indoor use only. | |
CE label – confirms compliance with applicable EU directives and regulations. | |
WEEE marking – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law. | |
UKCA marking – confirms compliance with applicable UK directives and regulations. | |
Wear eye protection. | |
Warning before the device switches on automatically. | |
Warning of hand injuries. |
Transport the device using the following transport equipment:
Danger from devices and objects falling.
When transporting the device by counterbalanced lift truck or lift truck, secure the device to prevent it from falling.
Do not turn, brake, or accelerate in a sudden, jerking manner.
Danger due to improper transport.
Follow the transport instructions on the device packaging.
| (1) | Robacta Reamer Single/Twin cleaning device |
| (2) | 2x parting agent containers |
| (3) | Collection container with mounting bracket |
| (4) | Harting Han12P (X1) without cable |
| (5) | Compressed air relief valve |
| (6) | Operating Instructions |
| (7) | Wrench for cleaning motor |
| (8) | Mounting material to assemble the cleaning device:
The “Robacta Reamer” parting agent (item number 42.0411.8042) and the cleaning cutter are not included in the scope of supply. Find the right cleaning cutter in the Spare Parts List for the welding torch used: https://spareparts.fronius.com/
Please follow the safety rules below when using all the functions described in the "Operating controls, connections, and mechanical components" chapter.
Read and understand all safety rules and user documentation for this equipment and all system components.
| (1) | Knife / wire cutter (available option) 2x knives for cutting the welding wire (max. 2 welding wires à 1.6 mm diameter). |
| (2) | Clamping device gas nozzle (available option) fixes the gas nozzle during the cleaning process. The clamping device must be selected depending on the gas nozzle used. |
| (3) | Cleaning cutter (available option) |
| (4) | Parting agent injection device includes the parting-agent injection nozzle. The parting-agent injection nozzle ensures that the parting agent only reaches the inside/face of the gas nozzle. |
| (5) | Cleaning motor drives the cleaning cutter. |
| (6) | Lifting device Lifts the cleaning motor with the cleaning cutter into the gas nozzle during the cleaning process. |
| (7) | Touch sense (available option) Gauge for the wear of the contact tip and the exit angle of the wire electrode. |
| (8) | TCP (ToolCenterPoint) with protective cover |
| (9) | Manually check the “Clamp gas nozzle / Cut wire” function. |
| (10) | Manually check the “Spray in release agent” function. |
| (11) | Manually check the “Cleaning motor on / Lifting device up” function. |
| (12) | Actuator/sensor connection |
| (13) | Compressed air connection socket For supplying dry compressed air at 6 bar (86.99 psi). For more information on compressed air quality, see chapter Specifications for the compressed air supply on page (→). Thread identification for compressed air connection: G ¼” |
| (14) | Harting Han12P (X1) connection socket + 24 V DC power supply |
| (15) | Protective cover |
| (16) | Parting agent container |
| (17) | Capacity of the parting agent container (storage capacity: 1l) |
| (18) | Connection elbow |
| (19) | Closure cap |
| (20) | Suction hose |
| (21) | Intake filter |
Danger from overcurrent.
Damage to the Harting Han12P (X1) connection power supply may result.
Provide the power supply with 500 mA fuse protection against overcurrent.
Danger due to long control line.
Malfunctions in the signal transmission may result.
Keep the control line between the robot control and the cleaning device as short as possible.
The Harting Han12P (X1) connecting plug for connecting the cleaning device to the robot control is included in the scope of supply. The cable harness has to be adjusted for the robot control connection technology.
All the work and functions described in this document must only be carried out by trained and qualified personnel.
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
Danger due to machines starting automatically.
In addition to these Operating Instructions, observe the safety rules of the robot manufacturer and welding system manufacturer. Before entering the robot work area, ensure that all protective measures in the robot work area are in place and remain in place for the duration of the access.
Danger due to moving mechanical parts, flying debris (chips, etc.), and compressed air/parting agent mixture discharged from the parting-agent injection nozzle.
Before carrying out any work, disconnect the compressed air and power supply from the cleaning device and the associated system components and make sure that the compressed air and power supply remain disconnected until all work has been completed.
Before carrying out any work, ensure that the cleaning device is depressurized - the necessary steps for this can be found in the following chapter Ensuring that the cleaning device is depressurized from page (→).
If the cleaning device is supplied with voltage and/or compressed air, there is a risk of serious injury from: rotating cleaning cutter, cleaning motor moving up/down, gas nozzle clamping device moving out/in, activated wire cutter, flying parts (chips, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
If work is required on the cleaning device while the cleaning device is being supplied with voltage and/or compressed air, take the following safety measures.
Keep your body, especially hands, face and hair, as well as objects and all items of clothing away from the cleaning cutter, cleaning motor, lifting device, gas nozzle clamping device, wire cutter, and parting-agent injection nozzle.
Wear hearing protection.
Wear protective goggles with side protection.
Could result in serious personal injury and damage to property.
The device must only ever be operated by one person.
During device operation, it is prohibited for any persons to be inside the working area of the device.
The device must only ever be maintained by one person.
When work is taking place on the device, it is prohibited for any other persons to be in the vicinity of the device.
The device must not be set up and operated outdoors. The installed electrical components must be protected against direct exposure to moisture.
Danger from devices falling or toppling over.
Always screw the cleaning device to the base.
If untrained operating personnel have access to the device, the compressed air supply to the device must be disconnected for the duration of this access in accordance with “Performance Level d” of ISO 13849-1.
We recommend FESTO’s MS6-SV soft-start and quick exhaust valve for interrupting the compressed air supply as required.
The supplied mounting material only for bases up to max. 5 mm (0.197 in.) Use material thickness.
For bases with a material thickness greater than 5 mm (0.197 in.), suitable and appropriately dimensioned fastening material must be used.
Install the cleaning device and the mounting bracket on a flat, stable solid surface (base) free of vibration.
IMPORTANT!
Position the cleaning device so that the robot’s approach route to the cleaning position is as short as possible.
IMPORTANT!
Always secure the assembly stand to the base.
Only use screws suitable for the base (not included in the scope of delivery) to fasten the assembly stand.
Always screw the cleaning device to the work stand.
Set up the work stand (available as an option) on a level, solid, and vibration-free base (foundation).
IMPORTANT!
Position the work stand so that the robot’s approach route to the cleaning device on the work stand is as short as possible.
Danger due to incorrectly adjusted cleaning position of the welding torch.
The welding torch may be damaged.
Only position the contact tips centrally and vertically over the cleaning motor.
The gas nozzle locking screws are only used for the rough positioning of the contact tip. The gas nozzle locking screw is more or less visible in the bore of the gas nozzle clamping device, depending on the angle of the contact tip.
Before start-up, make sure that the cleaning position is set correctly.
The respective contact tip of the twin welding torch must be positioned centrally and vertically above the cleaning cutter.
Position the contact tip only centrally and vertically above the cleaning motor.
Danger due to hot cleaning cutter.
Serious burns may result.
Before handling the cleaning cutter, allow it to cool to room temperature (+25°C, +77°F).
Danger due to incompatible wearing parts.
Property damage and malfunctions may result.
Only use original Fronius spare parts (contact tips, gas nozzles and cleaning cutters).
IMPORTANT!
No liability is accepted for damage caused by the use of contact tips, gas nozzles, or cleaning cutters from other manufacturers.
To disassemble the cleaning cutter, follow the steps in reverse order.
IMPORTANT!
IMPORTANT!
For twin welding torches, the function test (steps 10 - 12) must be performed individually for each contact tip.
IMPORTANT!
Danger due to mechanically moving parts.
The torch neck changeover station must not be supplied with compressed air until the installation has been completed.
| * | Attach the compressed air supply line to the compressed air relief valve. Thread identification Compressed air connection: G ¼” |
You can interrupt and restore the compressed air supply to the cleaning device by moving the compressed air relief valve back and forth.
| (1) | Cleaning device is supplied with compressed air. |
| (2) | Compressed air supply to the cleaning device is interrupted. The cleaning device is free of compressed air. |
IMPORTANT!
Only use the water-based “Robacta Reamer” parting agent (item number 42.0411.8042) provided by the manufacturer. Its composition is specifically tailored for use with the cleaning device. Correct operation is not ensured when other products are used.
IMPORTANT!
Remove the parting agent container (1 liter) from the cleaning device and terminate the parting agent hose.
IMPORTANT!
The parting agent hose must not be extended. For proper operation, use only original parting agent hoses.
IMPORTANT!
Connect the release agent hose to the cleaning device and fasten the cap of the parting agent container.
IMPORTANT!
For proper functioning of the injection device, observe the following information on positioning the parting agent container.
Ensure proper routing and connection of the ground cable. Damage to the ground cable of the OPT/i TSS TCP Touch Sense option can impair its function.
Lay the ground cable in the cable guide on the underside of the OPT/i TSS TCP Touch Sense option.
Do not crush the ground cable or damage the insulation.
IMPORTANT!
For the function of the OPT/i TSS TCP Touch Sense option, a ground earth connection to the workpiece is required.
IMPORTANT!
For the following tasks, the cleaning device must be supplied with compressed air. This results in danger from the rotating cleaning cutter, cleaning motor moving up/down, gas nozzle clamping device moving out/in, flying parts (chips, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
IMPORTANT!
The quantity of parting agent is controlled by the injection time (see chapter Program sequence from page (→)).
An active signal from the robot control starts up the cleaning device.
Danger due to improper installation and commissioning.
The cleaning device’s functions must be manually checked before starting automatic operation.
Only start automatic mode once the cleaning device has been installed and commissioned properly.
If wetting agent has not been applied to the inside of the welding torch, this may lead to the permanent contamination of the welding torch when welding begins.
Always wet the inside of the welding torch with the manufacturer’s parting agent before starting automatic mode.
If the diameter of the gas nozzle is too small, the gas nozzle may not be clamped properly in the clamping device. No signal is output that the clamping device is closed.
Cleaning motor on / lifting device up signal:
= Pin 1 at the Harting Han12P connecting plug (X1)
Spray in parting agent signal:
= Pin 2 on the Harting Han12P connecting plug (X1)
Clamp gas nozzle / cut wire signal:
= Pin 9 on Harting Han12P connector (X1)
Actuator/sensor signal (Pin 7):
= Pin 7 on the Harting Han12P connecting plug (X1)
Actuator/sensor signal (Pin 8):
= Pin 8 on the Harting Han12P connecting plug (X1)
Upper cleaning motor signal:
= Pin 5 at the Harting Han12P connecting plug (X1)
Lower cleaning motor signal:
= Pin 6 at the Harting Han12P connecting plug (X1)
Gas nozzle free signal:
= Pin 11 on the Harting Han12P connecting plug (X1)
Gas nozzle clamped / wire cutter closed signal:
= Pin 10 at Harting Han12P connecting plug (X1)
Danger due to cleaning agents containing solvents.
Only clean the cleaning device with cleaning products that are free of solvents.
Only clean the parting agent container with cleaning products that are free of solvents.
Disposal must only be carried out in accordance with the section of the same name in the "Safety rules" chapter.
| Cause: | Injection quantity too low. |
| Remedy: | Extend the injection time. |
| Cause: | The intake filter of the parting agent hose in the parting agent container is contaminated. |
| Remedy: | Clean the suction filter of the parting agent hose with compressed air (for more information, see chapter Starting Up the Parting Agent Atomizer from page (→)). |
| Cause: | No signal from robot. |
| Remedy: | Check robot program. |
| Cause: | Parting-agent injection nozzle blocked. |
| Remedy: | Clean the parting-agent injection nozzle. Notify the service team (have parting-agent injection nozzle replaced). |
| Cause: | Vacuum pump defective. |
| Remedy: | Contact service team (have vacuum pump replaced). |
| Cause: | Solenoid valve has mechanical fault. |
| Remedy: | Contact service team (have solenoid valve replaced). |
| Cause: | Position of the cleaning motor incorrectly set. |
| Remedy: | Set the position of the cleaning motor correctly (see chapterAdjusting the Position of the Cleaning Motor from page (→)). |
| Cause: | Cleaning position of the welding torch incorrectly set. |
| Remedy: | Set the cleaning position of the welding torch again (see chapter Welding Torch Cleaning Position from page (→)). |
| Cause: | Cleaning cutter does not fit the welding torch geometry. |
| Remedy: | Fit a correct cleaning cutter. |
| Cause: | Cleaning cutter worn. |
| Remedy: | Replace cleaning cutter. |
| Cause: | Compressed air supply missing. |
| Remedy: | Set up the compressed air supply. |
| Cause: | Throttle valve cannot be adjusted or is faulty. |
| Remedy: | Contact service team (have throttle valve replaced). |
| Cause: | Seal on lifting cylinder is faulty. |
| Remedy: | Contact service team (have lifting cylinder replaced). |
| Cause: | Cleaning motor has mechanical fault. |
| Remedy: | Contact service team (have cleaning motor replaced). |
Supply voltage | + 24 V DC |
Nominal output | 2.4 W |
Nominal pressure | 6 bar |
Air consumption | 420 l/min |
Thread identification for compressed air connection | G ¼” |
Standard I/O (X1) | Input: + 24 V DC/max. 100 mA |
Cleaning time | 4.5 - 6.5 s |
Overall cycle time | 5.0 - 9.0 s |
Capacity of the parting agent container | 1 l |
Protection class | Protection class 21 |
Mark of conformity | CE, UKCA |
Safety symbols | S |
“Performance Level” | c |
Maximum noise emission (LWA) | 82 dB (A) |
EMC emission class | A1) |
Dimensions l x w x h | 345 x 245 x 400 mm |
Weight | 14.5 kg |
1) A device in emissions class A is not intended for use in residential areas in which the electrical power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies.
Weight | 14.5 kg |
Weight | 14.5 kg |
