Indicates an immediate danger.
Could result in major injury or death.
Avoid the described danger.
Indicates a dangerous situation.
Could result in serious injury or death.
Avoid the dangerous situation.
Indicates a harmful situation.
Could result in injury and damage to property.
Avoid the harmful situation.
Indicates the possibility of damage to property and adverse effects on work results, as well as necessary additional information, tips and tricks, recommendations, etc.
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
The full text of the EU Declaration of Conformity is available at
https://www.fronius.com .
Devices bearing the CSA label satisfy the requirements of the relevant standards for Canada and the USA.
The welding machine is only intended for MIG/MAG, MMA, and TIG welding in conjunction with Fronius components.
Any other use shall be deemed to be not in accordance with the intended use.
Intended use also meansThe device has been manufactured in line with the state of the art and according to recognized safety standards.
Intended use also meansIMPORTANT! Any use that does not comply with the intended use shall be deemed misuse.
Impermissible misuse includes the following:The Fortis MIG/MAG welding machine is a digitalized, microprocessor-controlled inverter welding machine.
Depending on the variant, the welding machine is available with integrated 4-roller wire drive or with a separate wirefeeder.
A modular and compact design and the ability to easily extend the system guarantee a high degree of flexibility.
The welding machine can be adapted to any specific situation.
Explanation of the abbreviations:
| C | Welding machine with integrated 4-roller wire drive |
| /G | Gas-cooled (small machine housing) |
| /GW | Gas-cooled or water-cooled (large machine housing) |
In addition to the standard version, all welding machines are also available in the following versions:
| /nc | without mains cable |
| /XT | Extended (larger voltage range, lower energy consumption, single-phase usage, CEL welding) |
| /600 | Input voltage of 600 V (only for welding machines with 400 A and 500 A) |
The central control and regulation unit of the welding machines is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Rule algorithms ensure that the desired target state is maintained.
The machines are used commercially for manual applications, mainly with steel and galvanized sheets.
However, aluminum, other metals, and alloys as well as flux core wires can also be welded.
Common areas of application include
A rating plate and various safety symbols are attached to the device, depending on the device version.
The safety symbols indicate dangers during welding operation that can result in serious personal injury and damage to property if not observed.
Rating plate and safety symbols
| * | For all Fortis /XT and Fortis /600V welding machines |
| ** | Only for Fortis C /XT and Fortis C /600V welding machines on the inside of the device |
Safety symbols on the rating plate:
Welding is dangerous. The following basic requirements must be met:
Warning notices are attached to the device for certain device versions.
The arrangement of the symbols may vary.
| ! | Warning! Caution! The symbols represent possible dangers. |
| A | Drive rollers can injure fingers. |
| B | The welding wire and drive parts are under welding voltage during operation. Keep hands and metal objects away! |
| 1. | An electric shock can be fatal. |
| 1.1 | Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves. |
| 1.2 | Use a base that is insulated from the floor and work area to protect against electric shock. |
| 1.3 | Before working on the device, switch off the device and remove the mains plug or disconnect the power supply. |
| 2. | Inhalation of welding fumes can be harmful to health. |
| 2.1 | Keep your face away from any welding fumes. |
| 2.2 | Use forced-air ventilation or local extraction to remove welding fumes. |
| 2.3 | Remove welding fumes with a fan. |
| 3. | Welding sparks can cause an explosion or fire. |
| 3.1 | Keep flammable materials away from the welding process. Do not perform welding near flammable materials. |
| 3.2 | Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher. |
| 3.3 | Do not weld on drums or closed containers. |
| 4. | Arc rays can burn the eyes and injure the skin. |
| 4.1 | Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body. |
| 5. | Before working on the machine or welding: undertake training on the device and read the instructions! |
| 6. | Do not remove or paint over the sticker with the warnings. |
| * | Manufacturer order number of the sticker |
| (A) | The cooling unit must only be operated using Cooling Liquid FCL10/20. Other coolants are not suitable due to their electrical conductivity and insufficient material compatibility. See also 'Filling the cooling unit' from page (→) onwards. |
| (B) | |
| (C) | Cleaning the fin element using compressed air |
| (D) | Cleaning the cooling unit filter See also 'Cleaning the cooling unit filter' from page (→) onwards. |
The welding machines can be operated with various system components and options. This makes it possible to optimize procedures and to simplify machine handling and operation, depending on the field of application for the welding machine.
| (1) | Fortis 270 - 320 C /G welding machine (with integrated wirefeeder) |
| (2) | Fortis 320 - 500 C /GW welding machine (with integrated wirefeeder) + optional cooling unit |
| (3) | Fortis 320 - 500 GW welding machine + optional toolbox |
| (4) | WF 25s wirefeeder |
Other system components (not shown):
OPT/s Duo
Hardware extension for a C /GW welding machine in order to be able to additionally operate an external WF 25s wirefeeder (= DUO operation)
OPT/s CU 1200
Optional water cooling for the welding machines Fortis 320 - 500 C /GW and Fortis 320 - 500 /GW
incl. start-up monitoring and temperature sensors
OPT/s CU 1200 MC
Optional water cooling for the welding machines Fortis 320 - 500 C /GW and Fortis 320 - 500 /GW, also for DUO operation
incl. temperature sensors, coolant connections at the rear and front, bracket, and flow sensor
The filter can also be mounted on the rear of the device.
DUO operation:
The Fortis 320 - 500 C /GW welding machines are also operated with a separate WF 25s wirefeeder.
OPT/s Water Connection DUO
Double water connections on the cooling unit (required for DUO operation)
OPT/s CU Flow Sensor
Flow sensor for the cooling unit
OPT/s VRD Class A
Safety option to reduce open circuit voltage
OPT/s Toolbox
Removable, lockable toolbox for the gas-cooled welding machines Fortis 320 - 500 C /GW and Fortis 320 - 500 /GW
OPT/s Ethernet
Optional RJ45 Ethernet port to connect the welding machines to a local network
OPT/s MP 400/500, OPT/s MP 400/500 XT /600 V
Multiprocess
incl. additional TIG socket, built-in gas solenoid valve, polarity reverser, and TIG Multi Connector port
OPT/s TMC 400/500
Optional TIG Multi Connector port for non-Multiprocess devices
OPT/s Current Socket Front
Additional current socket on the front for 400 / 500 A welding machines (e.g., for arc air gouging)
OPT/s Welding Torch Holder
OPT/s Organizer
Small parts storage on the top of the welding machine
AI IO TMC /s
Automatic Interface
OPT/s NFC Reader /TMC
External NFC card reader
OPT/s VRD Class A /IK
VRD Class A functionality
OPT/s MultiProcess
For enhanced TIG and MMA functionality
Standard for the Fortis 270 C /G and Fortis 320 C /G
Optional for the Fortis 400 C and Fortis 500 C
Software options
OPT/s Pulse/Std Mix Fortis
All MIG/MAG mix characteristics and the additional characteristic property "mix" are available on the welding machine.
OPT/s Retro TransSteel
All MIG/MAG standard and pulse characteristics of the TransSteel series and the additional characteristic property "Retro" are available on the welding machine.
OPT/i WeldCube Navigator
Software for creating digital instructions for manual welding processes, which are processed by welders.
The welder is guided through the welding instructions by WeldCube Navigator.
For the OPT/i WeldCube Navigator option to work properly, the OPT/s Job, OPT/s Documentation, and OPT/s NFC Reader options must be available on the welding machine.
For Fortis C devices without multiprocess, the OPT/s TMC 400/500 option must also be available on the welding machine.
For Fortis /GW devices, the OPT/s WF TIG Multi Connector port option must be available on the WF 25s wirefeeder or the OPT/s TMC 400/500 option must be available on the welding machine.
OPT/s Duo
Duo functionality (two welding lines)
For the OPT/s Duo option to work properly, the OPT/s Duo /IK option or the OPT/s Duo CK option must be available on the welding machine.
OPT/s Documentation
To document the welding data
Without OPT/s Documentation only a logbook with events is available.
OPT/s Jobs
With the OPT/s Jobs option, the job process is available, including Load More EasyJobs, Optimize job, Duplicate job, Job correction limits, and Delete job.
Without OPT/s Job, only a maximum of four EasyJobs can be saved and selected.
BLE-WIFI24 inside
WLAN and Bluetooth functionality on the welding machine control panel (for certified countries)
Depending on the country, the option is automatically released on the welding machine.
OPT/i Custom NFC - ISO 14443A
Option to use a custom frequency band for key cards
Option OPT/s NFC Reader /TMC is required for the option OPT/i Custom NFC - ISO 14443A.
The welding machines have a number of different Welding Packages, welding characteristics, and welding processes so that the broadest range of materials can be effectively processed.
The following Welding Packages (WP) are available for the welding machines:
WP Standard Fortis
4,066,023
(enables MIG/MAG standard welding)
WP Pulse Fortis
4,066,024
(enables MIG/MAG pulse welding)
WP Standard/Pulse Fortis
4,066,025
(enables MIG/MAG standard welding and MIG/MAG pulse welding)
IMPORTANT! On a welding machine without Welding Packages, only the following welding processes are available:
Depending on the welding process and shielding gas combination, various process-optimized welding characteristics are available when selecting the filler metal.
The welding characteristics have special properties that provide information about usage.
Special properties and use of the welding characteristics
(described according to the following pattern):
Property
Process
Description
dynamic
Puls, Standard
Characteristic for deep penetration and reliable root formation at high welding speeds
mix
Puls
Characteristic for the generation of a rippled weld seam.
The heat input into the component is specifically controlled by the cyclic process change between pulse and dip transfer arc.
PCS
Puls + Standard
The characteristic changes directly from the pulsed arc to a concentrated spray arc above a certain power. The advantages of pulsed and spray arcs are combined in one characteristic.
retro
Pulse, Standard
The characteristic has the same welding properties as the predecessor TransSteel (TSt) device series.
root
Standard
Characteristics for root passes with powerful arc
universal
Puls, Standard
The characteristic is very well suited for all common welding tasks.
Property
Process
Description
dynamic
Puls, Standard
mix
Puls
PCS
Puls + Standard
retro
Pulse, Standard
root
Standard
universal
Puls, Standard
MIG/MAG pulse welding is a pulsed arc process with a controlled material transfer.
In the base current phase, the energy input is reduced to such an extent that the arc barely burns steadily and the surface of the workpiece is preheated. In the pulsing current phase, an accurately timed current pulse guarantees a precise detachment of the weld material droplet.
This principle guarantees low-spatter welding and precise operation throughout the entire power range.
MIG/MAG pulse welding can be set on the control panel of the welding machine under "Pulse" in the welding processes.
MIG/MAG standard welding is a MIG/MAG welding process covering the entire power range of the welding machine with the following arc types:
Dip transfer arc
Droplet transfer occurs in the lower power range during the short circuit.
Intermediate arc
The intermediate arc alternates irregularly between short circuits and spray transfers. This results in increased spatter. It is not possible to use this arc effectively, so it is better to avoid it.
Spray arc.
A short circuit-free transfer of material in the high power range.
MIG/MAG standard welding can be set on the control panel of the welding machine under "Standard" in the welding processes.
MIG/MAG manual welding is a MIG/MAG welding process in which the wire speed, the welding voltage, and the arc-force dynamic (a correction parameter) are set separately.
MIG/MAG manual welding can be set on the control panel of the welding machine under "Manual" in the welding processes.
SynchroPulse is available for all process (Standard / Pulse).
The cyclic change of the welding power between two operating points with SynchroPulse achieves a finely rippled weld appearance and a non-continuous heat input.
With stitch welding, all welding processes can be interrupted cyclically. As such, the heat input is controlled in a targeted manner.
The welding time, pause time and the number of interval cycles can be set individually (e.g. for producing a rippled weld seam, for tacking thin sheets or, in the case of longer pause times, for simple, automatic spot welding operation).
Stitch welding is possible with every operating mode.
In special 2-step mode and special 4-step mode, no interval cycles are executed during the start and end phases. The interval cycles are only executed in the main process phase.
TIG welding is a welding process in which the arc is ignited between the workpiece and a non-consumable, heat-resistant tungsten electrode. The arc fuses the base material. Depending on the application, filler metal can be fed into the weld pool in the form of rods or welding wires.
The weld pool is surrounded by an inert shielding gas environment in order to protect the weld pool from reactions with the ambient air.
TIG welding can be set on the control panel of the welding machine under "TIG" in the welding processes.
Manual metal arc welding is a manual welding process in which a sheathed stick electrode is melted.
The sheath of the stick electrode melts during welding, releasing gas and slag that protect the weld pool from reactions with the ambient air.
Manual metal arc welding can be set on the control panel of the welding machine under "MMA" in the welding processes.
In arc air gouging, an arc is ignited between a carbon electrode and the workpiece; the base material is melted and blown out with compressed air.
The operating parameters for arc air gouging are defined in a special characteristic.
Applications:
IMPORTANT! Arc air gouging is only possible with steel materials!
The parameters necessary for welding can be easily selected and changed using dials.
The parameters are shown on the display during welding.
Because of firmware updates, certain functions may be available for your device but not described in these operating instructions or vice versa.
In addition, individual figures may also differ slightly from the operating controls of your device. These operating controls function in exactly the same way, however.
Danger due to incorrect operation and work not carried out correctly.
This may result in serious personal injury and damage to property.
All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
Read and understand all safety rules and user documentation for this equipment and all system components.
| No. | Function |
| (1) | Menu button To open the Setup menu |
| (2) | Information button For retrieving a variety of information on the operation of the welding machine |
| (3) | Display |
| (4) | Wire-threading button For threading the wire electrode into the torch hosepack without gas or current After pressing the button, an animated graphic with motor current, motor power, and conveyed wire length is displayed. The feeder inching speed can be changed immediately using the middle selection dial (8). |
| (5) | Gas-test button To set the required quantity of gas on the gas pressure regulator. After pressing the Gas-test button, gas flows for 30 s. Pressing it again ends the process prematurely. The display shows an animated graphic with the remaining gas flow duration. |
Pressing the Gas-test button also causes a cooling unit to start working.
After pressing the Gas-test button, the cooling unit will then operate for 3 minutes.
Press the Gas-test button only when the welding torch is connected.
| (6) | Status indicator Green animated ... Device starting up or restarting Lights up green ... Device is ready for welding Lights up white ... Notification Lights up orange ... Warning Lights up red ... Error Blue animated ... Active welding mode Yellow animated ... Gas test is active Mint animated ... Wire threading is active |
| (7) | Left-hand selection dial with rotary/push button function For selecting and setting correction parameters as well as filler metal and shielding gas during MIG/MAG welding If the left-hand selection dial is pressed for longer than 2 seconds with the correction parameter selected, an additional menu opens. The additional menu allows you to define which parameter is displayed on the welding screen. For details on setting the parameter displayed on the welding screen, see from page (→) onwards. |
| (8) | Middle selection dial with rotary/push button function For selecting and setting the main welding parameters If the middle selection dial is pressed for more than 2 seconds during MIG/MAG welding, the SynchroPulse and Interval process functions can be activated or deactivated. |
| (9) | Right-hand selection dial with rotary/push button function For selecting and setting welding processes, operating mode, jobs, the welding parameter wizard, and correction parameters If the right-hand selection dial is pressed for longer than 2 seconds with the correction parameter selected, an additional menu opens. The additional menu allows you to define which parameter is displayed on the welding screen. For details on setting the parameter displayed on the welding screen, see from page (→) onwards. |
| (10) | Multifunctional dial |
| (11) | Multifunctional dial |
| (12) | Multifunctional dial |
| (13) | Multifunctional dial The buttons (10) - (13) can be assigned with an EasyJob or with parameters from the Setup menu. More information about EasyJobs can be found from page (→) onwards More information about favorite parameters can be found from page (→) onwards |
Turning the selection dial
For some parameters, a value that has been changed by turning the selection dial is automatically applied without having to press the selection dial. |
A selected element is highlighted in white on the display between two blue lines:
The shielding gas | The main welding parameter | The correction parameter 'arc length correction' is selected. |
To change the values of selected elements, press the corresponding selection dial.
Pressing the selection dial
After pressing the left-hand selection dial, the shielding gas can be changed by turning the left or middle selection dial. | After pressing the middle selection dial, the main welding parameter of wire speed can be changed. | After pressing the right-hand selection dial, the 4-step operating mode can be changed by turning the right or middle selection dial. |
The following information or parameters are displayed in the individual sections of the display.
The displayed parameters vary according to the selected welding process.
| No. | Description |
| (1) | Bluetooth status indicator (only on certified devices)
WLAN status
Cloud status WeldCube Air The symbol lights up green when there is an active connection to WeldCube Air. Logged-on users / locked state of the welding machine |
| (2) | Welding data Welding current [A], wire speed [m/min or ipm], welding voltage [V] Different values are displayed depending on the situation:
| (3) | Errors, warnings, notes Single-phase power supply display (for /XT devices only) Time Date |
| (4) | Filler metal Wire diameter Shielding gas Characteristic property |
| (5) | Process functions and indicators The display is gray ... Function possible, but not activated The indicator lights up green ... Function is activated |
| Current welding process line INT = wire drive of the welding machine | |
| Wire threading indicator | |
| MIG/MAG: |
| Intermediate arc indicator during standard welding | |
| TIG: |
| On Multiprocess welding machines, the symbol for the overloaded electrode is displayed here. | |
| Gas-test indicator | |
| MIG/MAG: |
| SynchroPulse indicator | |
| TIG: |
| During TIG welding, the symbol for TIG pulsing (pulse frequency) is displayed here: | |
| Interval indicator |
| (6) | Welding process |
| (7) | Operating mode |
| (8) | Easy JOB / editing JOB For details see Job Mode from page (→) onwards |
| (9) | Welding parameter wizard For details on the welding parameter wizard, see from page (→) onwards |
| (10) | Correction parameters * |
| (11) | Currently set welding parameters (standard value) + unit Setting range and symbol of the currently set welding parameter (setting range depends on the current characteristic) Symbol and value of the other synergic parameters Wire speed – welding current – sheet thickness |
| (12) | Correction parameters * |
| * | Depending on the welding process, the last parameter displayed on the left or right display section can be defined. For details see from page (→) onwards. |
Depending on the selected welding process, an additional menu is available for displaying a parameter on the welding screen.
Alternative way to open the additional menu:
The parameter selection with the right-hand selection dial is performed in the same way.
For certain parameters, animated graphics are shown on the display.
These animated graphics change when the value of the parameter is changed.
EasyJobs or parameters from the setup menu can be assigned to the four multifunctional buttons on the control panel.
The EasyJobs or the setup parameters can then be easily retrieved with the press of a button.
The assignment of the multifunctional buttons is shown on the display as per the following example:
Button 1:
The button is assigned but not currently activated.
A thin line (1) is shown on the right edge of the display at the height of the button.
Button 2:
The button is assigned and currently activated.
At the right edge of the display, the left end of a button (2a) is shown at the height of the button.
In addition, the currently active function (2b) is shown in the central display section (e.g., EasyJob 2, as shown in the figure).
Button 3:
Same as button 1
Button 4:
The button is not assigned.
When the button is pressed, a symbolized empty button (4) is displayed along with info text.
A symbolized EasyJob button is shown on the right edge of the display at the height of the button, and the active EasyJob is shown in the central display section.
Instead of EasyJobs, the multifunctional buttons can also be assigned with setup parameters.
A combination of EasyJobs and setup parameters is also possible.
Saving a setup parameter overwrites an EasyJob or setup parameter already saved under the same multifunctional button!
After approx. 3 seconds, a symbolized button with a green frame, the parameter, and the Save symbol are shown on the display, e.g.:
The parameter has been saved under the selected multifunctional button and can be retrieved using this button.
A symbolized button with the saved parameter is shown on the right edge of the display at the height of the button, and the active storage location is shown in the central display section.
The parameter can now be changed.
After approx. 3 seconds, a symbolized button with a green frame and the Save symbol is shown on the display.
The EasyJob or setup parameter saved under the multifunctional button is overwritten with the current settings.
After a total of approx. 5 seconds, the symbolized button is displayed with a red frame and the Delete symbol.
The EasyJob or setup parameter has been deleted from the storage location.
Fortis 270 C /G, Fortis 320 C /G
Fortis 320 C /GW, Fortis 400 C /GW, Fortis 500 C /GW
| No. | Function |
| (1) | TIG Multi Connector port included in the option Multiprocess or as a separate option OPT/s TMC 400/500 optional for Fortis 400 C / 500 C for connecting TIG welding torches, remote controls, etc. |
| (2) | Welding torch connection for connecting the FSC welding torch |
| (3) | (-) Current socket with bayonet latch for connecting the return lead cable for MIG/MAG welding; in conjunction with the option Multiprocess with integrated shielding gas connection |
| (4) | Polarity reverser in conjunction with the option Multiprocess To set the welding potential for MIG/MAG welding. No function for TIG and manual metal arc welding. |
| (5) | (+) Current socket with bayonet latch in conjunction with the option Multiprocess or the option front current socket |
| (6) | MIG/MAG shielding gas connection socket |
| (7) | TIG shielding gas connection socket in conjunction with the option Multiprocess |
| (8) | RJ45 Ethernet connection Option |
| (9) | Power switch for switching the welding machine on and off |
| (10) | Mains cable with strain relief |
| (11) | Wire spool cover |
| (12) | Viewing window |
4-roller wire drive
| No. | Function |
| (13) | Wire spool holder with brake For holding standard wire spools with a max. outer diameter of 300 mm (11.81 in.) and a max. weight of 19 kg (41.89 lbs.) |
| (14) | Swivel levers for holding the feed rollers |
| (15) | Protective cover of the 4-roller drive |
| (16) | Welding torch clamping lever |
| (17) | Clamping lever for adjusting the contact pressure |
For the welding machines Fortis 320 C /GW, Fortis 400 C /GW, and Fortis 500 C /GW, a cooling unit or a toolbox is optionally available.
For details on the optional cooling unit, see from page (→) onwards.
For details on the optional toolbox, see from page (→) onwards.
| No. | Function |
4-roller wire drive
| No. | Function |
Fortis 320 /GW, Fortis 400 /GW, Fortis 500 /GW
| No. | Function |
| (1) | Dummy cover Optional TIG Multi Connector port |
| (2) | (-) Current socket with bayonet latch for connecting the return lead cable for MIG/MAG welding |
| (3) | Dummy cover |
| (4) | Front current connection Option |
| (5) | Cooling unit Option For details on the optional cooling unit, see from page (→) onwards. |
| (6) | Dummy cover Ethernet RJ45 connection option |
| (7) | Power switch for switching the welding machine on and off |
| (8) | Mains cable with strain relief |
| (9) | Side cover |
| (10) | Wirefeeder control cable connection for connecting the control cable from the interconnecting hosepack for MIG/MAG welding |
| (11) | (+) Current socket with bayonet latch for connecting the mains cable from the interconnecting hosepack for MIG/MAG welding |
| (12) | Dummy cover without optional cooling unit or Coolant return connection (red) with optional cooling unit |
| (13) | Dummy cover without optional cooling unit or Coolant supply connection (blue) with optional cooling unit |
| * | Coolant filter not shown |
Storage compartments with open side cover
For the welding machines Fortis 320 /GW, Fortis 400 /GW, and Fortis 500 /GW, a cooling unit or a toolbox is optionally available.
| No. | Function |
| (1) | Coolant return connection (red) |
| (2) | Coolant supply connection (blue) The coolant connections can optionally or additionally also be attached to the rear. For cooling units for welding machines with a separate wirefeeder, the coolant connections are fitted on the rear of the cooling unit as standard. |
| (3) | Coolant filter |
| (4) | Coolant return connection with a fitted coolant filter |
| (5) | Viewing window of the coolant tank |
| (6) | Filler pipe of the coolant tank |
The toolbox option can only be installed on gas-cooled welding machines.
A standard padlock with a shackle diameter of 6-8 mm is required to lock the toolbox.
Depending on the welding process, a minimum level of equipment is required to work with the welding system.
The following describes the welding processes and the corresponding minimum equipment for welding operations.
For welding machines with Integrated wire drive:
In addition, for welding machines with separate wirefeeder:
The welding machine is generator-compatible.
The maximum apparent power S1max of the welding machine must be known in order to select the correct generator output.
The maximum apparent power S1max of the welding machine is calculated for 3-phase devices as follows:
S1max = I1max x U1 x √3
I1max and U1 according to the device rating plate and technical data
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator can be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the welding machine!
The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
The mains voltage tolerance is specified in the "Technical data" section.
For more detailed information about installing and connecting the system components, please refer to the appropriate operating instructions.
The XT variants of the welding machines can also be operated with a single-phase power supply.
With a single-phase power supply, a corresponding message is shown on the display every time the welding machine is started up:
This message can be confirmed or disappears after a timer has expired.
Once the message has been confirmed/disappears, the symbol for single-phase mode remains on the display.
The symbol can change color, for example, if "warning" or "power limitation" has been set for the reaction.
For details on the mains fuse and reaction, see from page (→) onwards.
IMPORTANT! With a single-phase power supply, the output power of the welding machines is reduced as follows:
| Max. output power | ||
| MIG/MAG | TIG | MMA |
Fortis 270 XT | max. 240 A | max. 240 A | < 240 A |
Fortis 320 XT | max. 270 A | max. 270 A | < 270 A |
Fortis 400 XT | max. 320 A | max. 320 A | < 320 A |
Fortis 500 XT | max. 320 A | max. 320 A | < 320 A |
For a single-phase power supply of the welding machine, the mains cable must be correctly connected.
For details on connecting a single-phase mains cable, see from page (→) onwards.
In the case of /nc and /XT welding machines, no mains cable is connected when delivered.
Before commissioning, a mains cable corresponding to the connection voltage must be installed with a minimum cross-section according to the following table.
Welding machine | Mains cable |
Fortis 270 C /nc | 4G2,5 |
Fortis 270 C /XT/nc |
Fortis 320 C/nc | 4G2,5 |
Fortis 320 C/XT/nc |
Fortis 400 C/nc | 4G4 |
Fortis 400 C/XT/nc |
Fortis 400 C/600/nc | 4x AWG12 (4G2,5) |
Fortis 500 C/nc | 4G6 |
Fortis 500 C/XT/nc |
Fortis 500 C/600/nc | 4x AWG12 (4G2,5) |
Danger from work that is not carried out properly.
The work described below may only be performed by trained specialist personnel.
Follow national standards and guidelines.
Danger from improperly prepared grid cable.
Short circuits and damage to property may result.
Fit ferrules to all phase conductors and the ground conductor of the stripped grid cable.
IMPORTANT! The ground conductor should be approx. 20-25 mm (0.8-1 in.) longer than the phase conductors.
Serious personal injuries may result.
Do not lift or transport any active devices.
Switch off and disconnect devices from the grid before transport or lifting.
Close ground earth connections before transport.
Danger from falling objects.
Serious personal injury and damage to property may result.
Only use suitable transportation equipment from the manufacturer to transport devices by crane.
Attach chains or ropes to all designated attachment points on the transportation equipment.
The chains or ropes must form the smallest angle possible from vertical.
Observe and comply with valid national and regional guidelines for accident prevention and hazards during transport and shipment.
Danger from damaged devices.
This can result in personal injury and damage to property.
After transport and before commissioning, visually inspect the device for damage.
Have any damage repaired by trained service technicians before commissioning the device.
The carrying handle on the device is only to be used for transport by hand.
The carrying handle is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
Example of a welding system with the following components: | |
Danger from devices or components falling.
Before transporting the welding system, detach the wirefeeder and the shielding gas cylinder, and completely drain the coolant.
Ensure that the remaining system components are securely seated on the trolley.
Only use suitable transportation equipment from the manufacturer to transport welding systems by crane.
Danger from devices and components falling as a result of damaged lifting equipment.
Regularly check all lifting equipment used for crane transport such as straps, buckles, chains, etc., for mechanical damage, corrosion, and changes due to other environmental influences.
The inspection interval and scope of the inspection must comply with the relevant valid national standards and guidelines.
Welding during crane transport is possible and permissible if this is stated in the intended use of the device (for intended use, see from page (→) onwards).
Danger from devices or welding systems toppling over.
Set up the device securely on an even, solid surface.
The maximum permitted tilt angle is 10°.
Check all screw connections are tightly fastened after installation.
Danger from areas at risk of fire and explosion as well as from areas with increased electrical hazard.
Follow national and international regulations for areas at risk of fire and explosion.
Follow national and international regulations for areas with increased electrical hazard.
Danger due to selecting an unsuitable installation location.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
The ambient air must be free of dust, acids, corrosive gases or substances, and other similar substances.
Do not set up and operate the device over 2000 m (6561 ft. 8.16 in.) above sea level.
The device can be set up and operated outdoors in accordance with protection class IP23. Direct moisture (e.g., from rain) must be avoided.
Danger of electric shock due to insufficient mains connection.
Only connect the device to a grid with a ground conductor.
Only connect the device to the grid via a plug-in system with a ground conductor contact.
If operating the device on a grid without a ground conductor and on a socket without a ground conductor contact, observe all national regulations for protection by electrical separation.
Due to local regulations and national guidelines, a residual-current circuit breaker may be required when connecting a device to the public grid. The residual-current circuit breaker recommended for the device can be found in the technical data.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
Before connecting the device to the mains, check with the grid operator whether or not the device is allowed to be connected.
The maximum permissible grid impedance that is decisive for a mains connection is stated in the technical data.
An inadequately dimensioned electrical installation can lead to serious damage to property.
The mains lead and its fuse protection should be designed to suit the existing power supply.
The technical data on the rating plate should be followed.
Danger from incorrect operation or misuse.
This can result in serious personal injury - including injury to third parties, damage to property, and impaired welding results.
All persons involved in the commissioning, operation, maintenance, and servicing of the device must be appropriately qualified and have knowledge of welding.
Observe generally applicable and regional regulations regarding accident prevention and environmental protection.
Danger of electric shock.
Do not touch live parts inside or outside the device.
During MIG/MAG welding, the welding wire, the wirespool, the feed rollers, as well as any pieces of metal in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder mount.
Use a dry backing bar or cover with sufficient insulation against the ground potential.
The backing bar or cover must completely cover the entire area between the body and the ground potential.
Only use undamaged, insulated, and adequately dimensioned cables and leads.
Do not wrap cables or leads around your body or parts of the body.
Never touch the welding wire, tungsten electrode, or the stick electrode when the welding machine is switched on.
Ground the workpiece.
Switch off unused devices.
Before working on the device, switch it off, remove the grid plug, and attach a clearly legible and understandable warning sign to prevent the grid plug from being connected and the device switched on again.
After opening the device, ensure that all components are disconnected from the power supply – especially all electrically charged components.
Danger due to electromagnetic fields.
These can damage your health and the health of persons in the vicinity, e.g., anyone fitted with a pacemaker or wearing a hearing aid.
Keep distances between welding power-leads and the head/torso of the welder as great as possible.
Do not carry welding power-leads and hosepacks over your shoulder or wrap them around your body or body parts.
Anyone wearing a pacemaker must seek advice from their doctor before spending any time in the immediate vicinity of the device and the welding process.
Danger due to stray welding currents.
Overheating of components, fire, destruction of ground conductors, and damage to the device and other electrical equipment may result.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device so that it is sufficiently insulated against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Ensure that the unused welding torch / electrode holder is adequately insulated when using power distribution boards, twin-head mounts, etc.
In automated MIG/MAG applications, the wire electrode must be insulated when feeding it from the welding wire drum, large spool, or wirespool to the wirefeeder.
Electromagnetic compatibility (EMC) describes the unwanted mutual influence of electrical/electronic devices.
The EMC device classification is shown on the rating plate of the device or in the technical data.
Despite compliance with the standardized emission limit values, electrical devices can, in certain cases, influence each other in the intended application area.
Interference-prone equipment that could be affected by the device includes:Danger due to electromagnetic emissions.
Operational disruptions and malfunctions as well as resulting damage may result.
Use suitable grid filters.
Keep welding power-leads as short as possible, route them close together and far from other lines.
Perform equipotential bonding.
Ground the workpiece, e.g., using suitable capacitors.
Shield the entire welding system.
Shield other devices in the vicinity.
Danger from flying sparks.
Could result in fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected using a certified cover.
Keep suitable, certified fire extinguishers on hand.
Take appropriate measures to ensure that sparks and hot metal particles do not get into surrounding areas through small cracks and openings.
Only undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes, if these have been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, etc. are/were stored.
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
Danger from flying sparks and flying hot metal particles.
Could result in injury.
Wear suitable protective clothing when working with the device.
The protective clothing must be flame retardant, insulating, dry, and undamaged, must cover the whole body, and the pants must be cuffless.
Wear rigid, wet-insulating footwear.
Wear appropriate, electrically insulating, and heat protective gloves.
Wear a safety helmet.
Danger from arc radiation, UV radiation, heat, and flying sparks that pose a risk of injury to the eyes and skin
Use a face guard with a regulation-compliant filter insert.
Wear regulation-compliant protective goggles with side protection behind the face guard.
Danger due to increased noise exposure.
Could result in hearing damage.
Use hearing protection during welding.
The device produces a maximum noise level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation in relation to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
A workplace-specific emission value for welding (and cutting) cannot be specified because this value depends on the welding process and the environmental conditions. It is influenced by a wide range of parameters, such as the welding process itself (MIG/MAG, TIG welding), the selected current type (direct current, alternating current), the power range, the type of weld metal, the resonance properties of the workpiece, the workplace environment, and many other factors.
Danger from welding operation (blinding hazard, flying sparks, harmful welding fume, noise, etc.)
Personal injury may result.
Keep unauthorized people away during the operation of the devices and during the welding process.
Inform people in the vicinity about all the dangers of the welding operation.
Provide suitable protective equipment.
Construct suitable protective walls and curtains.
Danger from toxic gases and vapors.
Fumes produced during welding contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
If possible, use a welding torch with an integrated extraction device.
Keep your face out of the welding fume and gases produced.
Do not breathe in fume or harmful gases.
Ensure that there is a sufficient supply of fresh air.
A ventilation flow rate of at least 20 m³/h (11.77 cfm) must be provided at all times.
Use a welding helmet with air supply if there is insufficient ventilation.
Danger due to missing, defective or circumvented safety equipment.
This can result in serious personal injury - including injury to third parties, damage to property, and undesired welding results.
Only operate the device when all safety equipment is fully functional.
Any safety equipment that is not fully functional must be repaired by an authorized specialist before the device is switched on.
Never bypass or disable safety equipment.
Before switching on the device, ensure that no one can be put in danger.
Danger due to rotating parts such as fans, gears, rollers, shafts or wirespools.
Keep hands, hair, loose clothing, and tools away from moving parts.
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Danger due to missing or opened covers.
Before operation, ensure that all covers and side panels are present and have been correctly fitted.
Ensure that all covers and side panels are closed during operation.
Only open covers and side panels for the duration of assembly and maintenance activities.
Danger from pressurized shielding gas cylinders.
Serious personal injury and damage to property can result from explosions.
Protect pressurized shielding gas cylinders from high heat, mechanical impact, slag, open flames, sparks, and arcs.
Do not weld pressurized shielding gas cylinders.
Keep shielding gas cylinders away from welding or other circuits.
Do not hang the welding torch on a shielding gas cylinder.
Leave the protective cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Mount shielding gas cylinders vertically and secure them from falling in accordance with the instructions.
Observe and follow the manufacturer's instructions and national and international provisions for shielding gas cylinders and accessories.
Remove the shielding gas cylinder before transporting a welding system with trolley by crane.
Observe the safety and maintenance information on the shielding gas cylinder or a central gas supply.
Danger from shielding gas escaping without notice.
Shielding gas is colorless and odorless and, in the event of leaks, may replace the oxygen in the ambient air.
Could result in serious injury or death due to suffocation.
There must be a ventilation flow rate of at least 20 m³ per hour.
Close the valve of the shielding gas cylinder or a central gas supply when no welding is taking place.
Turn your face away from the outlet when a valve on a shielding gas cylinder is being opened.
Check the shielding gas cylinder or central gas supply for uncontrolled gas leakage before each start-up.
If an adapter is being used, use suitable Teflon tape to seal the thread of the shielding gas connection on the device side before installation.
Danger due to contaminated shielding gas.
This can result in damage to property and undesired weld results.
The quality of the shielding gas must meet the following specifications:
Solid particle size < 40 μm
Pressure condensation point < -20 °C
Max. oil content < 25mg/m³
Danger due to hot components, parts, and liquids.
Could result in burns and injury.
Do not touch the workpiece during and after welding.
Allow hot components, hot parts, and hot liquids to cool before touching (e.g., the welding torch).
If a cooling unit is being used, switch it off before disconnecting coolant hoses.
Danger due to slag flying off cooling workpieces.
Also wear protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Secure all these devices and components so they cannot be switched back on.
Danger of electrical current due to electrically conductive dust in the device.
Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
Only use feed rollers which match the wire electrode.
An overview of the available feed rollers and their possible uses can be found in the online spare parts catalog (O-ETK).
![]() | Online spare parts catalog (O-ETK): |
Danger due to feed roller holders shooting upwards.
This can result in personal injury.
When unlocking the lever, keep fingers away from the area to the left and right of the lever.
Danger from falling gas cylinders.
Place gas cylinders on a solid, level surface so that they remain stable. Secure gas cylinders to prevent them from falling over.
Observe the safety rules of the gas cylinder manufacturer.
When establishing a ground earth connection, observe the following points:
Failure to do so may impair welding results and pulse welding.
Use a separate return lead cable for each welding machine
Keep positive cables and return lead cables together as long and as close as possible
Physically separate the welding circuits of individual welding machines
Do not route several return lead cables in parallel;
if parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
Keep the return lead cables as short as possible and use cables with a large cross-section
Do not cross over return lead cables
Avoid ferromagnetic materials between the return lead cables and the interconnecting hosepack
Do not reel up long return lead cables—coil effect!
Route long return lead cables in loops
Do not route return lead cables in iron pipes, metal cable trays, or along steel beams, avoid cable ducts;
(routing positive cables and return lead cables together in an iron pipe does not cause any problems)
If several return lead cables are being used, separate the grounding points on the component as far as possible and do not allow crossed current paths between the individual arcs.
Impaired welding results due to a ground earth connection being shared by several welding machines!
If several welding machines are all welding one component, a common ground earth connection can have a significant effect on the welding results.
Disconnect welding circuits!
Provide a separate ground earth connection for each welding circuit!
Do not use a common return lead cable!
Danger from springiness of spooled wire electrode.
When inserting the wire spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Danger from falling wire spool.
Ensure that the wire spool is fitted securely to the wire spool holder.
Danger due to falling wire spool as a result of the locking ring being fitted the wrong way round.
Could result in personal injury and functional impairments.
Always position the locking ring as shown in the image below.
When working with basket-type spools, only use the basket-type spool adapter supplied with the device.
Wear safety goggles.
When inserting the wirespool/basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Danger from falling basket-type spool.
Make sure that the basket-type spool with basket-type spool adapter is fitted securely to the wire spool holder.
Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
Danger due to falling basket-type spool as a result of the locking ring being fitted the wrong way round.
If the polarity reverser is incorrectly connected, it can result in poor-quality weld properties or damage to the device.
Connect the polarity reverser according to the wire electrode used.
Check the wire electrode packaging to determine whether the wire electrode is for (+) or (-) welding.
Danger due to sharp end of the wire electrode.
This can damage the welding torch.
Deburr the end of the wire electrode well before threading in.
Lay out the torch hosepack as straight as possible.
Danger due to emerging wire electrode.
Hold the welding torch so that the tip of the welding torch points away from the face and body.
Wear suitable protective goggles.
Do not point the welding torch at people.
Ensure that the wire electrode can only intentionally make contact with electrically conductive objects.
The wire electrode can be threaded by pressing a wire threading button provided in the welding system or by pressing the torch trigger.
The "Wire threading" dialog window is shown on the displays of the welding machine and wirefeeder.
Instructions for wire threading
If contact is made with the ground during wire threading, the wire electrode is automatically stopped.
When the torch trigger is pressed once, the wire electrode moves forwards 1 mm.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
The standard values for the contact pressure can be found on the sticker on the 4-roller drive.
After releasing the torch trigger, the wire spool must stop unreeling.
Adjust the brake if necessary.
Danger from incorrect installation.
Personal injury and damage to property may result.
Do not dismantle the brake.
Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
The brake is only available as a complete unit.
The illustration of the brake is for information purposes only.
IMPORTANT! For optimum welding results, the manufacturer recommends carrying out an R/L alignment whenever the device is commissioned and whenever changes are made to the welding system.
Further information on the R/L alignment can be found in the setup menu / MIG/MAG / R/L alignment as of page (→).
| * | only if the coolant connections are installed in the wirefeeder and only if the interconnecting hosepack is water-cooled |
Risk of overheating caused by an incorrectly routed interconnecting hosepack.
The welding system components may be damaged.
Do not form any loops when routing the interconnecting hosepack
Do not cover the interconnecting hosepack
Do not wind the interconnecting hosepack as you get near the gas cylinder and do not wrap it around the gas cylinder
IMPORTANT!
Do not reel up long return lead cables - coil effect!
IMPORTANT! For optimum weld properties, route the return lead cable as close as possible to the interconnecting hosepack.
IMPORTANT! For optimum welding results, the manufacturer recommends carrying out an R/L alignment whenever the device is commissioned and whenever changes are made to the welding system. Further information on the R/L alignment can be found in the setup menu / MIG/MAG / R/L alignment as of page(→).
The filter and mounting plate are included in the scope of supply of the optional cooling unit.
The filter must be installed before commissioning the cooling unit!
The cooling unit must not be operated without a filter.
When the optional cooling unit is installed in the factory, a 5 l canister containing coolant is included in the scope of supply.
Danger from using prohibited coolant.
Do not mix different coolants.
When changing the coolant, make sure all the coolant is replaced.
Danger due to coolant escaping.
If coolant ends up on the outside of the device, this should be removed immediately.
Make sure that no coolant ends up on the inside of the cooling unit.
IMPORTANT! The filter insert in the filler pipe must be checked before each filling or refilling of the coolant tank to ensure that:
Before commissioning the cooling unit, make sure that:
There is sufficient coolant in the cooling unit
The coolant is free of contamination
The welding torch is connected
In the component menu of the welding machine, the following operating modes can be set for the cooling unit:
For details on the cooling unit settings, see from page (→) onwards.
After the end of welding, the pump continues to operate for 2 minutes, after which the pump switches off.
Draining the coolant
Danger due to hot coolant.
This can result in burns or scalding.
Allow the coolant to cool down to +25 °C / +77 °F before starting work.
Switch off the cooling unit before disconnecting coolant hoses.
As soon as the hose for draining the coolant is plugged in at the coolant drainage point, the coolant will run out.
Lifting the welding machine on the front side facilitates complete emptying of the cooling unit.
Do not dispose of coolant in the sewage system.
Coolants should be disposed of according to applicable national and local regulations.
In Duo operation, a welding machine with integrated wire drive is operated with an additional external wirefeeder.
Duo operation enables the joint use of two welding process lines with one welding machine. The welding process lines can be changed using the torch trigger, on the welding machine, via the operating controls on the wirefeeder, or on a remote control.
With Multiprocess devices, it is also possible to switch to a TIG welding process line in addition to the two MIG/MAG welding process lines.
The TIG welding torch is connected to the welding machine; the welding process lines can also be switched over via the TIG welding torch.
For the TIG welding process line, the polarity reverser on the welding machine must be reconnected manually.
Danger due to unused welding torches or electrodes.
In Duo operation, the welding potential is applied to electrodes of unused welding torches or electrode holders.
Personal injury and damage to property as a result of unexpected voltages or arcs may result.
Only put aside unused welding torches when they are insulated against ground.
Do not place unused welding torches on the workpiece.
Duo operation is possible with gas and water-cooled welding systems.
The welding machine can be locked by pressing a key combination or by means of an external NFC key reader, e.g., to prevent unauthorized access or the modification of welding parameters.
To lock and unlock the welding machine, the welding machine must be turned on.
NFC key = NFC card or NFC key fob
User Management on the welding machine or SmartManager offers further locking and unlocking functions as well as functions for different people logging in and out.
For details, see
For details, see
Unlocking the welding machine
For details on the predefined role "locked", see User Management from page (→) onwards.
To lock and unlock the welding machine using an NFC key, the OPT/s NFC Reader /TMC option must be connected to the welding machine.
Locking the welding machine
If the OPT/s NFC Reader /TMC option is connected, User Management is also available in the welding machine Setup menu.
For details on User Management, see from page (→) onwards.
With the OPT/s NFC Reader /TMC option connected, the following status indicators can be displayed on the NFC key reader:
"4-step mode" is suitable for longer weld seams.
"Special 2-step mode" is ideal for welding in higher power ranges. In special 2-step mode, the arc starts at a lower power, which makes it easier to stabilize.
To activate special 2-step mode:
Special 4-step mode allows the starting and final current to be configured in addition to the advantages of 4-step mode.
The "Spot welding" mode is suitable for welded joints on overlapped sheets.
Start by pressing and releasing the torch trigger – GPr gas pre-flow – welding current phase over the SPt spot welding time duration – GPo gas post-flow.
If the torch trigger is pressed again before the end of the spot welding time (< SPt), the process is canceled immediately.
The 2-step stitch welding operating mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the base material.
The 4-step stitch welding operating mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the base material.
GPr
Gas pre-flow time
IS
Starting-current phase: rapid heating of the base material despite high heat dissipation at the start of welding
tS
Starting current duration
SL1
Slope 1: continuous reduction of the starting current to the welding current
I
Welding current phase: even heat input into the base material whose temperature is raised by the advancing heat
IE
Final current phase:
tE
Final current duration
SL2
Slope 2: continuous reduction of the welding current to the final current
GPo
Gas post-flow
SPt
Spot welding time
Iwt
Stitch welding time
Ibt
Stitch pause time
A cooling unit in the welding system starts to work.
Left-hand selection dial | Middle selection dial | Right-hand selection dial |
Filler metal | Wire speed 1) 4) Welding current 1) Sheet thickness 1) | Welding process
Wire electrode diameter | Operating mode 5) | |
Shielding gas | Easy JOB | |
Characteristic property | Wizard | |
Pulse correction 2) 6) |
| Arc length correction 2) 3) 6) |
| 1) | If one of these parameters is changed for the Pulse and Standard welding processes, the remaining parameters are also adjusted. |
| 2) | For Pulse welding process |
| 3) | For Standard welding process |
| 4) | For Manual welding process |
| 5) | Depends on the welding process |
| 6) | The parameters displayed on the welding screen can be set depending on the selected welding process. For details, see from page (→) onwards. |
| 7) | Only for /XT devices |
If one of the welding parameters is changed in the pulsed and standard welding processes, the remaining parameters are also adjusted.
Welding parameters for Pulse and Standard |
Wire speed *
1.0-25 m/min / 39.4-984.3 ipm (depending on characteristic)
Current [A] *
Setting range: depends on the selected welding process and welding program
Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding.
Sheet thickness [mm/inch] *
Pulse correction
For correcting the pulse energy in pulsed welding
Pulse correction is set using the left-hand dial.
-10-+10
Factory setting: 0
- ... lower droplet detachment force
0 ... neutral droplet detachment force
+ ... increased droplet detachment force
Dynamic correction
For setting the short circuit current and the current to short circuit breakup during standard welding
The dynamic correction is set using the left-hand dial.
-10-+10
Factory setting: 0
| -10 | harder arc (higher current in case of short circuit breakup, increased welding spatter) |
| +10 | softer arc (lower current in case of short circuit breakup, reduced welding spatter formation) |
For correcting the arc length
The arc length correction is set using the right-hand dial.
-10-+10
Factory setting: 0
- ... shorter arc length
0 ... neutral arc length
+ ... longer arc length
| * | If one of these three parameters is changed, the remaining parameters are also adjusted. |
The following parameters can be set for Pulse and Standard for display on the welding screen:
Welding parameters for Manual |
Wire speed
For setting a harder and more stable arc
Arc-force dynamic
For influencing the short-circuiting dynamic at the instant of droplet transfer
The arc-force dynamic is set using the left-hand dial.
0-10
Factory setting: 1.5
0 ... harder and more stable arc
10 ... softer and low-spatter arc
Voltage [V]
The voltage is set using the right-hand dial.
The following parameters can be set for Manual for display on the welding screen:
For details on the setup parameters, see from page (→) onwards.
At the end of each welding operation, the welding data is stored as an average value and shown on the display.
Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component – such as wirefeeder or remote control – on the control panel of the welding machine.
The welding parameter wizard supports the welder in selecting the welding parameters. The parameter recommendation can be accepted or saved as a job.
The welding parameters can now be welded or saved as an EasyJob.
Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
Stitch welding must be switched off for spot welding.
Setup menu - MIG/MAG - Mode Setup - Interval = off
Once spot welding mode has been selected, the spot welding time parameter is available in the left-hand additional menu.
The spot welding time can also be set in the additional menu.
For details on the additional menu, see from page (→) onwards.
Procedure for creating a welding spot:
The selected weld start and weld end parameters are also active when spot welding.
The start/end of welding treatment for spot welding can thus be stored in the Setup menu under MIG/MAG / Start/End.
If final current time is active, the end of welding is not after the set spot welding time, but only after the set slope and final current times have elapsed.
Alternative way to activate stitch welding:
Press the middle selection dial for more than two seconds
The function menu opens.
Select and activate stitch welding
Once stitch welding has been activated, the stitch welding time parameter is available in the left-hand additional menu and the stitch pause time and stitch cycles parameters are available in the right-hand additional menu.
Procedure for stitch welding:
EasyJob = saving current welding settings
The saved EasyJob can be accessed at any time by pressing a button.
Up to four EasyJobs can be saved using the existing multifunctional buttons.
The EasyJobs are saved under job numbers 1 - 4.
Saving an EasyJob overwrites an EasyJob saved under the same number!
The settings have been saved. The last saved settings are activated.
If the OPT/s Job option is available, up to 1000 jobs can be stored and reproduced on the welding machine.
Jobs can only be saved when you are not welding. In addition to the current welding settings, the process parameters and certain machine defaults are also taken into account when saving jobs.
| * | Explanation of text input on page (→), step 2 |
Before retrieving a job, ensure that the welding system is set up and installed according to the job in question.
IMPORTANT! In Job Mode, only the "JOB" welding parameter can be changed; the remaining welding parameters can only be viewed or changed as part of the job correction limits.
Use the Load EasyJob function to load the data for a stored job or EasyJob onto the welding screen. The corresponding welding parameters are displayed and can be welded, modified, or saved as a new job or EasyJob.
For each job, individual correction limits can be set for welding power and arc length.
If correction limits are set for a job, the welding power and arc length of the job can be corrected within the specified limits.
The following devices offer TIG welding without multiprocess:
Fortis 400 C /GW*
Fortis 500 C /GW*
Fortis 320 /GW
Fortis 400 /GW
Fortis 500 /GW
| * | The Fortis 400 C /GW and Fortis 500 C /GW devices are delivered as standard without the multiprocess function. |
Fortis 400 C /GW*
Fortis 500 C /GW*
Fortis 320 /GW
Fortis 400 /GW
Fortis 500 /GW
Fortis 400 C /GW*
Fortis 500 C /GW*
Fortis 320 /GW
Fortis 400 /GW
Fortis 500 /GW
Danger of injury and damage from electric shock.
When the power switch is switched to position - I -, the tungsten electrode of the welding torch is live.
Ensure that the tungsten electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
Under certain circumstances, it may not be possible to change welding parameters that have been set on a control panel of a system component—such as a wirefeeder or remote control—on the control panel of the welding machine.
Break voltage
For setting a voltage value at which the welding process may be ended by a slight raise of the TIG welding torch. 10.0-30.0 V
Factory setting: 14 V
Main current (I1)
3-270 A ... Fortis 270 C
3-320 A ... Fortis 320 C / Fortis 320
3-400 A ... Fortis 400 C / Fortis 400
3-500 A ... Fortis 500 C / Fortis 500
Factory setting: 50 A
Comfort Stop sensitivity
For activating/deactivating the TIG Comfort Stop function
off / 0.1-1.0 V
Factory setting: 0.8 V
At the end of the welding process, an automatic shutdown of the welding current follows a significant increase of the arc length. This prevents the arc from having to be unnecessarily lengthened when lifting the TIG gas-valve welding torch.
Process:
The arc ignites when the workpiece makes contact with the tungsten electrode.
*) Intermediate lowering
With intermediate lowering, the welding current is lowered to the set lowering current I2 during the main current phase.
| GPr | Gas pre-flow |
| SPt | Spot welding time |
| IS | Starting current: the temperature is raised gently at low welding current, so that the filler metal can be positioned correctly |
| IE | Final current: to avoid local overheating of the parent material caused by heat accumulation at the end of welding. This prevents possible sagging of the weld seam. |
| tUP | UpSlope: steady rise of the starting current to the main current (welding current) I1 |
| tDOWN | DownSlope: steady lowering of the welding current until it reaches the final current |
| I1 | Main current (welding current): uniform thermal input into the parent material, whose temperature is raised by the advancing heat |
| I2 | Lowering current: intermediate lowering of the welding current to avoid local overheating of the parent material |
| GPO | Gas post-flow |
If the OPT/s MP 400/500 or OPT/s MP 400/500 XT /600V Multiprocessoption is available on the welding machine, the following connections are also available on the welding machine:
If a Multiprocess option is available, more TIG welding parameters are also available.
Preparation for TIG welding if there is a Multiprocess option for the welding machine:
Danger of injury and damage to property from electric shock.
Ensure that the tungsten electrode is not touching anyone or any electrically conductive or grounded parts (housing, etc.).
For the welding machines Fortis 270 C and Fortis 320 C or if the OPT/s MP 400/500 or OPT/s MP 400/500 XT /600V Multiprocess option is available on the welding machine, the following TIG welding parameters are available:
Starting current IS
0 – 200% (of the main current)
Factory setting: 50%
UpSlope
off; 0.1 – 30.0 s
Factory setting: 0.5 s
IMPORTANT! The stored UpSlope value applies to the 2-step and 4-step modes.
Main current I1
3 – 270 A ... Fortis 270 C
3 – 320 A ... Fortis 320 C
3 – 400 A ... Fortis 400 C
3 – 500 A ... Fortis 500 C
Factory setting: -
IMPORTANT! For welding torches with Up/Down function, the full setting range can be selected while the device is on standby.
Lowering current I2
only in 4-step mode
0 – 200% (of the main current I1)
I2 < 100%
Brief, adapted reduction of the welding current
(e.g., when changing the welding wire during the welding process)
I2 > 100%
Brief, adapted increase in the welding current
(e.g., for welding over tacking points with a higher power level)
The values for Slope1 and Slope2 can be set for the TIG welding parameters.
DownSlope
off; 0.1 – 30.0 s
Factory setting: 1.0 s
IMPORTANT! The stored DownSlope value applies to the 2-step and 4-step operating modes.
Final current IE
0 – 100% (of the main current)
Factory setting: 30%
The following parameters can be set for TIG for display on the welding screen:
For details on the setup parameters, see as of page (→).
Procedure for igniting the arc using contact ignition:
If the tungsten electrode is overloaded, this can result in material detachment on the electrode, which can cause contamination to enter the weld pool.
If the tungsten electrode is overloaded, the "electrode overloaded" indicator lights up in the central display section (for details, see from page (→) onwards).
The "electrode overloaded" indicator depends on the set electrode diameter and the set welding current.
The welding current set at the start of welding may not always be ideal for the entire welding process:
The TIG pulsing function is able to help with this (TIG welding with a pulsing welding current):
A low base current (2) rises steeply to a significantly higher pulse current and falls again in line with a duty cycle (5) to the base current (2).
During TIG pulsing, small sections of the welding area are quickly melted and then allowed to quickly solidify again.
During manual applications, the welding wire is applied in the maximum current phase during TIG pulsing (only possible in the low-frequency range from 0.25 – 5 Hz).
TIG pulsing is used to weld steel pipes when welding out-of-position or to weld thin sheet metal.
TIG pulsing in operation:
Key:
(1) Main current, (2) Base current, (3) Starting current, (4) UpSlope, (5) Pulse frequency *
(6) Duty cycle, (7) DownSlope, (8) Final current
* (1/F-P = Time between two pulses)
Base current and duty cycle are specified by the welding machine.
Key:
The tacking function is available for TIG welding.
When a period of time is set for the setup parameter Tacking (4), the tacking function is assigned to the 2-step and 4-step modes. The sequence of operating modes remains unchanged.
The Tacking (TAC) indicator lights up in the central display section.
During this time, a pulsed welding current is available, which optimizes the merging of the weld pool when tacking two components.
How the tacking function works during TIG welding:
Key:
(1) Main current, (2) Starting current, (3) UpSlope, (4) Duration of pulsed welding current for tacking process, (5) DownSlope, (6) Final current
When using a pulsed welding current:
The welding machine automatically controls the pulse parameters according to the set main current (1).
No pulse parameters need to be set.
Depending on the set tacking duration, the pulsed welding current can be stopped up to and including the final current phase (6).
After the tacking time has passed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
Check the packaging or labeling on the stick electrode to determine whether the stick electrodes are to be welded on the positive pole (+) or the negative pole (-).
When the power switch is in position - I -, the stick electrode in the electrode holder is live.
Ensure that the stick electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
CEL welding is only possible with /XT welding machines.
For manual metal arc welding, the following welding parameters can be set and displayed:
Starting current
For setting a starting current value in the range 0 - 200% of the set welding current in order to avoid slag inclusions or incomplete fusion.
The starting current depends on the electrode type.
0 - 200%
Factory setting: 150%
The starting current is active for the starting current time set in the Setup menu.
Main current [A]
Setting range: depends on the welding machine used
Arc-force dynamic
0 - 100
Factory setting: 20
0 ... soft and low-spatter arc
100 ... harder and more stable arc
For manual metal arc welding, the following setup parameters can be defined as the last welding parameter:
For CEL welding, the following welding parameters can be set and displayed under "Welding":
Starting current
For setting a starting current value in the range 0-200% of the set welding current in order to avoid slag inclusions or incomplete fusion.
0-200%
The starting current is active for the starting current time set under the process parameters.
Main current [A]
Arc-force dynamic
0-100
Factory setting: 20
As the arc becomes shorter, the welding voltage may also fall so that the stick electrode is more likely to stick to the workpiece. This may also cause the stick electrode to burn out.
Electrode burn-out is prevented by activating the anti-stick function. If the stick electrode begins to stick, the welding machine immediately switches the welding current off. The welding process can be resumed without problems once the stick electrode has been detached from the workpiece.
The anti-stick function is activated and deactivated in the stick electrode menu.
Electrode pulsing is a stick electrode welding process with a pulsing welding current, e.g., for welding steel pipes when welding out of position or for welding thin sheet metal.
The welding current set at the start of welding may not always be ideal for the entire welding process:During electrode pulsing, a low base current IG rises steeply to the significantly higher pulse current IP and then drops back to the base current IG after a certain time tdcy.
The base current, pulse current, and time are specified by the welding machine according to the set pulse frequency FP.
During electrode pulsing, small sections of the welding location melt quickly and then rapidly re-solidify.
Welding current curve during electrode pulsing:
For electrode pulsing, the electrode characteristic must be set to "I-constant".
Danger due to incorrect operation and work not carried out correctly.
This may result in serious personal injury and damage to property.
All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
Read and understand all safety rules and user documentation for this equipment and all system components.
Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
IMPORTANT! A return lead cable with a cable cross-section of 120 mm² is required for arc air gouging.
When the power switch is switched to position - I -, the electrode in the arc air gouging torch is live.
Ensure that the electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
Danger due to loud operating noise.
This may result in personal injury.
Use suitable hearing protection during arc air gouging!
The settings for break voltage and starting current time are ignored.
At higher amperages, use both hands to guide the arc air gouging torch!
Use a suitable welding helmet.
The contact angle of the carbon electrode and gouging speed determine the depth of an air gap.
The parameters for arc air gouging correspond to the welding parameters for MMA welding, see page (→).
The available menus are displayed:
| * | The CEL menu is also displayed on /XT welding machines. |
A selected menu is highlighted, enlarged, and shown between two blue lines on the display.
The first parameter or the first parameter group of the menu is selected and can be edited.
A selected parameter or group of parameters are also shown brightly on the display between two blue lines.
Opening the parameter group
The parameters in the group are displayed and can be modified.
Setting parameters
The value of the parameter is highlighted and can now be changed.
The menu symbol is highlighted in white.
No matter where you are in the setup menu, the welding screen is displayed upon pressing the menu button.
If you press the menu button again, the last menu accessed is displayed.
In the setup menu, certain parameters are grayed out because they have no function with the currently selected settings.
Grayed-out parameters can be selected but not amended.
Grayed-out welding parameters have no influence on the current welding process or the welding result.
The current system data are displayed.
Welding current in A | |||||||
Welding voltage in V | |||||||
Wire speed in m/min or ipm | |||||||
Real-time arc power in kW If the welding speed is known, the electrical energy per unit length can be calculated: E = IP / vs
Duration of current weld in s | |||||||
Arc energy in kJ E = IE / L
Arc energy is generally used in manual welding to calculate the energy per unit length. | |||||||
Total operating hours of the welding machine in h | |||||||
Arc time in h | |||||||
Current weld | |||||||
Wire drive in the welding machine | |||||||
External wirefeeder |
The following process parameters can be set and displayed for the start and end of welding:
Starting current
To set the starting current for MIG/MAG welding (e.g., start of welding for aluminum)
0-400 % (of the welding current)
Factory setting: 135%
Starting current time
For specifying how long the starting current is to be active
off / 0.1-10.0 s
Factory setting: off
Slope 1
For setting the time during which the starting current is reduced or increased to the welding current
0.0-9.9 s
Slope 2
For setting the time during which the welding current is reduced or increased to the final current.
0.0-9.9 s
Final current
For setting the final current in order to
0-400% (of the welding current)
Final current time
For specifying how long the final current is to be active
off / 0.1-10.0 s
Wire retraction
For setting the wire retraction value (= combined value from wire retraction and a time) during MIG/MAG manual welding
The wire retraction depends on the equipment on the welding torch.
0.0-10.0
Factory setting: 0.0
Starting current
off / 0.1-10.0 s
Slope 1
0.0-9.9 s
Slope 2
0.0-9.9 s
Final current
Final current time
off / 0.1-10.0 s
Wire retraction
0.0-10.0
Spot welding
2-step /4-step
Factory setting: 4-step
Spot welding time
0.1 – 10.0 s
Stitch
To activate/deactivate stitch welding
off/on
Stitch cycles
constant / 1 – 99
Factory setting: constant
Stitch welding time
0.01 – 9.9 s
Factory setting: 0.3 s
Stitch pause time
off / 0.01 – 9.9 s
For mixing processes, the following process parameters can be set under Process Mix:
Upper power time correction
To set the duration of the hot process phase in a mixed process
-10.0 – +10.0
Factory setting: 0
Upper and lower power time correction is used to define the relationship between the hot and cold process phases.
If the lower power time correction is increased, the process frequency reduces and the pulse process phase becomes longer.
If the lower power time correction is reduced, the process frequency increases and the pulse process phase becomes shorter.
Lower power time correction
To set the duration of the cold process phase in a mixed process
-10.0 – +10.0
Factory setting: 0
Lower power correction
To set the energy input in the cold process phase in a mixed process
-10.0 – +10.0
Factory setting: 0
If the lower power correction is increased, this results in a higher wire speed and therefore a higher energy yield in the cold standard process phase.
| (1) | Lower power correction |
| (2) | Lower power time correction |
| (3) | Upper power time correction |
| vD | Wire speed |
The following process parameters can be set and displayed for the gas default settings:
Gas pre-flow
To set the gas flow time before ignition of the arc
0 – 9.9 s
Factory setting: 0.1 s
Gas post-flow
To set the gas flow time after the end of the arc
0 – 60 s
The following process parameters can be set for SynchroPulse welding:
(1) SynchroPulse
To activate/deactivate SynchroPulse
off / on
Factory setting: on
(2) Wire speed
To set the average wire speed and therefore the welding power for SynchroPulse
For example: 2 - 25 m/min (ipm)
(Depending on wire speed and welding characteristic)
Factory setting: 5.0 m/min
(3) Delta wire feed
To set the delta wire feed:
With SynchroPulse, the set wire speed is alternately increased/decreased by the delta wire feed. The parameters concerned are modified accordingly to match the acceleration/deceleration of the wire speed.
0.1 - 3.0 m/min / 5 - 115 ipm
Factory setting: 2.0 m/min
(4) Frequency
To set the SynchroPulse frequency
off / 0.5 - 5.0 Hz
(5) Duty Cycle (high)
For weighting the duration of the higher operating point in a SynchroPulse period
10 - 90%
(6) Arc correction high
For correcting the arc length with SynchroPulse at the higher operating point (= average wire speed plus delta wire feed)
-10.0 - +10.0
- ... short arc
0 ... uncorrected arc length
+ ... longer arc
If SynchroPulse is activated, the normal arc length correction has no effect on the welding process.
The arc length correction is then no longer displayed in the welding parameters.
(7) Arc correction low
For correcting the arc length with SynchroPulse at the lower operating point (= average wire speed less delta wire feed)
-10.0 - +10.0
- ... short arc
+ ... longer arc
Ignition current (manual)
For setting the ignition current for MIG/MAG manual welding
100-500 A (Fortis 270 C)
100-550 A (Fortis 320 C, Fortis 320)
100-600 A (Fortis 400 C, Fortis 400)
100-600 A (Fortis 500 C, Fortis 500)
Factory setting: 500 A
Wire retraction (manual)
0.0-10.0
Slope characteristics
auto / U constant / 1,000-8 A/V
Factory setting: auto
auto:
A fixed characteristic slope is stored.
U constant:
The welding machine immediately regulates a change in the arc length.
8 A/V:
The welding device does not regulate a change in the arc length or only does this to a minimal extent.
Align the welding circuit resistance (R) and inductance (L) if one of the following welding system components is changed:
Prerequisites for R/L alignment:
The welding system must be complete: closed welding circuit with welding torch and torch hosepack, wirefeeders, return lead cables, interconnecting hosepacks.
Performing R/L alignment:
The current values for welding circuit inductance and welding circuit resistance are displayed.
The second step of the R/L alignment wizard is displayed.
The third step of the R/L alignment wizard is displayed.
The fourth step of the R/L alignment wizard is displayed.
The current values are displayed when the measurement is complete.
Welding circuit inductance limit values | |
Fortis 270 | 15 µH |
Fortis 400 / 500 | 25 µH |
Larger inductance values may impair welding results. This can be remedied by optimizing the routing of hosepacks and return lead cables (see also from page (→) or (→) onwards).
The following process parameters can be set and displayed for the start and end of TIG welding:
The starting current time indicates the duration of the starting-current phase.
off / 0.01 - 30.0 s
IMPORTANT! The starting current time is only valid for 2-step mode and spot welding. In 4-step mode, the duration of the starting-current phase is determined by the torch trigger.
Final current time
The final current time indicates the duration of the final-current phase.
off / 0.01 - 30 s
IMPORTANT! The final current time is only valid for 2-step mode and spot welding. In 4-step mode, the duration of the final-current phase is determined by the torch trigger.
Spot welding time
(only if the mode is set to spot welding)
0.02 - 120 s
Factory setting: 5.0 s
Break voltage
10.0 - 30.0 V
Torch trigger
on / off
Factory setting: on
on
Welding is started using the torch trigger
on
Welding is started by touching the workpiece with the tungsten electrode;
especially suitable for welding torches without torch triggers, ignition sequence depends on ignition parameters
off / 0.1 - 10.0 V
Process:
off / 0.01 - 30.0 s
Final current time
off / 0.01 - 30 s
Spot welding time
0.02 - 120 s
Break voltage
10.0 - 30.0 V
Torch trigger
on / off
Factory setting: on
on
on
off / 0.1 - 10.0 V
Process:
Electrode diameter
Setting range: off; 1.0 – 6.4 mm
Factory setting: 2.4 mm
Tacking
Tacking function – duration of the pulsed welding current at the start of the tacking process
off / 0.1 – 9.9 s / on
off
Tacking function is switched off
0.1 – 9.9 s
The selected time begins with the UpSlope phase. After the set time has passed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
on
The pulsed welding current remains present until the end of the tacking process
The Tacking (TAC) indicator lights up in the central display section if a value has been set.
Pulse frequency
off / 0.20 – 990 Hz
The set pulse frequency is also applied for the lowering current I2.
The Pulsing indicator lights up in the central display section if a value for the pulse frequency has been entered.
Gas pre-flow
0.0 – 9.9 s
Factory setting: 0.4 s
Gas post-flow
auto / 0 – 60 s
auto
Depending on the electrode diameter and welding current, the welding machine calculates and automatically adjusts the optimal gas post-flow time.
The welding system must be complete: closed welding circuit with welding torch and torch hosepack, wirefeeders, return lead cable, interconnecting hosepacks.
Perform R/L alignment:
The actual values for welding circuit inductance and welding circuit resistance are displayed.
The actual values are displayed when the measurement is complete.
The following process parameters can be set and displayed for the start and end of manual metal arc welding:
0.0 – 2.0 s
Break voltage
For setting a voltage value at which the welding process may be ended by a slight raise of the stick electrode.
20 – 90 V
Factory setting: 90 V
The arc length depends on the welding voltage. To end the welding process, a significant lifting of the stick electrode is usually required. The break voltage parameter allows the welding voltage to be limited to a value, which permits the welding process to be ended by only slightly lifting the stick electrode.
IMPORTANT! If the welding process regularly comes to an unintentional end, set the break voltage to a higher value.
0.0 – 2.0 s
Break voltage
20 – 90 V
Characteristic
For selecting the electrode characteristic
I-constant / 0.1 - 20.0 A/V / P-constant / Gouging
Factory setting: I-constant
| (1) | Working line for stick electrode |
| (2) | Working line for stick electrode with increased arc length |
| (3) | Working line for stick electrode with reduced arc length |
| (4) | Characteristic for selected parameter "I-constant" (constant welding current) |
| (5) | Characteristic for selected parameter "0.1 - 20" (drooping characteristic with adjustable slope) |
| (6) | Characteristic for selected parameter "P-constant" (constant welding power) |
| (7) | Example of set arc-force dynamic with selected characteristic (4) |
| (8) | Example of set arc-force dynamic with selected characteristic (5) or (6) |
I-constant (constant welding current)
0.1 - 20.0 A/V (drooping characteristic with adjustable slope)
P-constant (constant welding power)
Arc air gouging
| (7) | Example of set arc-force dynamic with selected characteristic (5) or (6) |
| (8) | Possible current change with selected characteristic (5) or (6) depending on the welding voltage (arc length) |
| (a) | Operating point with high arc length |
| (b) | Operating point with set welding current IH |
| (c) | Operating point with low arc length |
The characteristics (4), (5), and (6) shown apply when using a stick electrode whose characteristic at a certain arc length corresponds to the working line (1).
Depending on the set welding current (I), the intersection (operating point) of the characteristics (4), (5), and (6) is shifted along the working line (1). The operating point provides information about the current welding voltage and current welding current.
With a fixed welding current (IH), the operating point can travel along the characteristics (4), (5), and (6) depending on the current welding voltage. The welding voltage U depends on the arc length.
If the arc length changes, e.g., according to the working line (2), the operating point is the point where the corresponding characteristic (4), (5), or (6) intersects the working line (2).
Applies to characteristics (5) and (6): Depending on the welding voltage (arc length), the welding current (I) is also lower or higher, with a constant value for IH.
Anti-stick
To activate/deactivate the anti-stick function
off / on
Factory setting: on
Electrode burn-out is prevented by the anti-stick function. If the stick electrode begins to stick, the welding machine switches the welding current off after 1.5 seconds. The welding process can be resumed without problems once the stick electrode has been lifted from the workpiece.
Electrode pulsing
For activating or deactivating the pulse frequency
off / 0.20 - 100 Hz
For details on electrode pulsing, see from page (→) onwards.
This CEL menu is only available for /XT devices.
The following process parameters can be set and displayed for the start and end of CEL welding:
0.0 – 2.0 s
Break voltage
20 – 90 V
Anti-stick
off / on
Factory setting: on
Interior lighting
For activating/deactivating the interior lighting
off / 1 - 60 s / on
Factory setting: 5 s
off
The interior lighting is switched off.
1 - 60 s
The interior lighting lights up for the set period of time.
on
The interior lighting lights up permanently.
Interior lighting
off / 1 - 60 s / on
off
1 - 60 s
on
The following process parameters can be set and displayed for an optional cooling unit:
Cooling unit operating mode
For setting whether the cooling unit is to be switched off or operated automatically
auto / off
auto:
The cooling unit starts to operate when welding starts. The fan starts to operate from a coolant return temperature of 40 °C (104 °F). The coolant flow starts at approx. 1 l/min (0.26 gal./min [US]) and increases as the coolant return temperature increases to up to 1.5 l/min (0.40 gal./min [US]).
In the event of faults in the cooling circuit, a corresponding error message is displayed.
After the end of welding, the cooling unit continues to operate for the set cooling unit run-on time. When the cooling unit run-on time has elapsed, the cooling unit switches off.
off:
The cooling unit is deactivated.
No operation, even when welding starts
IMPORTANT! If a gas-cooled welding torch is operated on a welding machine with a cooling unit, set the cooling unit operating mode parameter to "off".
Cooling unit shut-off delay
Run-on time of the cooling unit after the end of welding
2-20 minutes
Factory setting: 2 minutes
Delay time flow sensor
Only in conjunction with the OPT/s CU Flow Sensor cooling unit option.
The flow sensor option is integrated into the OPT/s CU1200 MC cooling unit model.
For setting the time between the flow sensor tripping and the output of a warning message
5-25 s
Cooler flow warning limit
Only in conjunction with the OPT/s CU flow sensor cooling unit option.
If the parameter is activated, a warning is generated if the actual value falls below the entered value.
off / 0.75-0.95 l/min
The following process parameters can be set and displayed for the integrated wire drive and for a separate wirefeeder of a welding system:
Feeder inching speed
To set the wire speed at which the wire electrode or welding wire is fed into the torch hosepack
2 - 25 m/min / 78 - 984 ipm
Factory setting: 10 m/min
The feeder inching speed can also be set in the window that opens when the wire threading button is pressed:
Press the wire threading button
Turn the middle selection dial to adjust the value of the feeder inching speed
The following process parameters can be set and displayed for the welding machine:
Ignition timeout
Length of wire that is fed before the safety cut-out trips
off / 5 – 100 mm (0.2 – 3.94 in.)
The Ignition timeout process parameter is a safety function.
At high wire speeds in particular, the length of wire fed until the safety cut-out trips can deviate from the set wire length.
How it works:
If the torch trigger is pressed, the gas pre-flow begins immediately. Wirefeeding and the ignition process then begin. If there is no current flow within the specified fed wire length, the system switches off automatically.
Press the torch trigger again for a further attempt.
TIG Ignition timeout
Period of time until the safety cut-out following failed ignition.
0.1 – 9.9 s
Torch trigger job selection
Switch to the next job using the torch trigger
Switching can take place when idle or during welding.
on / off
The following data are displayed in the logbook:
| (1) | Filter |
| (2) | Logged in user |
| (3) | Number of the weld |
| (4) | Date (ddmmyy) |
| (5) | Time (hhmmss) |
| (6) | Duration of welding in s |
| (7) | Welding current in A (average) |
| (8) | Welding voltage in V (average) |
| (9) | Wire speed in m/min |
| (10) | Arc energy in kJ (for details see page (→)) |
| (11) | Job No. |
The following data can be displayed with the filter function (1):
Turn a selection dial to scroll through the list.
Press the selection dial to display details of a logbook entry.
| (1) | Filter |
| (11) | Job No. |
Job slope
Defines the time between the currently selected job and the next job
0.0 - 10.0 s
Factory setting: 0 s
Job slope
0.0 - 10.0 s
Upper power correction limit
For setting the upper power correction limit for a job
0 - 20%
Factory setting: 0%
Lower power correction limit
For setting the lower power correction limit for a job
-20 - 0%
Factory setting: 0%
Upper arc length correction limit
For setting the upper arc length correction limit for a job
0.0 - 10.0
Factory setting: 0
Lower arc length correction limit
For setting the lower arc length correction limit for a job
-10.0 - 0.0
Factory setting: 0
For more information on the job correction limits, see the chapter Job Mode on page (→).
Upper main current limit
For setting the upper main current limit for a job
0 - 20%
Factory setting: 0%
Lower main current limit
For setting the lower main current limit for a job
-20 - 0%
Factory setting: 0%
Arc break monitoring
Ignore/Error
Factory setting = ignorieren
Ignore:
Arc break monitoring is deactivated.
The welding machine remains active and no error message appears on the display.
Error:
Arc break monitoring is activated.
If the arc breaks off and there is no current flow within a set arc break time period, the system switches off automatically and an error message appears on the display.
Arc break filter time
An error is output if the set time period is exceeded.
0.1 – 9.9 s
Factory setting = 0.2 s
Ignore/Error
Ignore:
Error:
0.1 – 9.9 s
Wirefeeding force monitoring
ignore / warning / error
Factory setting: Ignore
Ignore ... no reaction
Warning ... a warning is displayed
Error ... Welding process is interrupted, an error message is displayed
Maximum force
0 – 999 N
Factory setting: 100 N
Maximum force deviation time
0.1 – 10.0 s
Factory setting: 3 s
The parameters can be set when the device is in single-phase mode.
Fuse current value
Fortis 270 /XT: off / 10 - 35 A
Fortis 320 /XT: off / 10 - 63 A
Fortis 400 /XT: off / 10 - 63 A
Fortis 500 /XT: off / 10 - 63 A
Reaction
off / power limitation / warning
off:
No reaction
Power limitation:
The output welding power is limited depending on the welding characteristic and the fuse current value.
Warning:
Is automatically set when a fuse current value > off has been set.
If a limit is exceeded, the symbol for single-phase mode changes to red, but there is no restriction of the output welding power.
Sampling rate
For activating/deactivating the sampling rate for the logbook
off / 0.1 - 100.0 s
off
Sampling rate is deactivated, only mean values are saved.
0.1 - 100 s
Documentation is saved at the set sampling rate.
User management is useful if multiple users are working with the same welding machine.
User management is carried out using different roles and with the help of NFC keys.
Users are assigned different roles depending on their level of training or qualification.
User Management
User Management includes all users registered on the welding machine. Users are assigned different roles depending on their level of training or qualification.
NFC key
An NFC card or and NFC key fob is assigned to a specific user who is registered on the welding machine.
NFC cards and NFC key fobs are commonly referred to as an NFC key in these operating instructions.
IMPORTANT! Each user should be assigned their own NFC key.
Role
Roles are used to manage registered users (= user management). The roles define access rights and the work activities that users can perform.
Two roles are predefined in the factory in User Management:
Administrator
with all rights and options
The "Administrator" role cannot be deleted, renamed, or edited.
The "Administrator" role contains the predefined "Admin" user, which cannot be deleted. The "Admin" user can be assigned a name, language, unit, web password, and NFC key.
Once "Admin" has been assigned an NFC key, user management is activated.
locked
preset in the factory with access rights to the welding processes, without process parameters and defaults
The role "locked"
The role "locked" cannot be assigned NFC keys.
If no NFC key is assigned to the predefined "Admin" user, each NFC key functions to lock and unlock the welding machine (no user management, see also section "Locking and unlocking the welding machine using an NFC key", page (→)).
A systematic procedure is required when creating roles and NFC keys.
Fronius recommends that you create one or two administrator keys. In the worst case scenario, a welding machine can no longer be operated without administrator rights.
Procedure
The loss of an administrator NFC key may affect welding machine usability, depending on your settings. Store one of the two administrator NFC keys in a safe place.
If an NFC key is assigned to the predefined "Admin" user in User Management, then User Management is activated.
Create a second administrator key:
| ... not possible | |
| ... possible | |
| ... hidden | |
| ... read only | |
| ... read and write |
For data privacy reasons, only personal ID numbers and no full names should be entered when creating users.
Procedure if
For setting the background lighting
0-10
Factory setting: 10 (brightest)
0-10
For activating / deactivating setting of the status indicator
off/on
Factory setting: on
For activating / deactivating the Mean display (large display of the average values after the end of welding over the entire display area)
Mean = average value
off / on
The date and time can be assigned automatically or set manually.
Setting the date and time manually
To set the date and time manually, Set date & time automatically must not be selected.
Units
Metric / Imperial
Factory setting: Metric
Standards
EN / AWS
Factory setting: EN
EN
Name of filler metal according to European standards
(e.g., AlMg 5, CuSi3, steel, etc.)
AWS
Name of filler metal according to the American Welding Standard
(e.g., ER 5356, ER CuSi-A, ER 70 S-6, etc.)
The following data are displayed:
The confirmation prompt for resetting the website password appears.
The website password is reset to the factory setting.
Factory settings
Bluetooth
on / off
Factory setting: on
The wordmark Bluetooth® and the Bluetooth® logos are registered trademarks and property of Bluetooth SIG, Inc. and are used by the manufacturer under license.
WLAN
on / off
Activating WLAN:
WLAN is deactivated (no tick in the checkbox):
Ethernet IP
For manually setting the network parameters
If DHCP is activated, the network parameters IP address, network mask, default gateway, DNS server 1 and DNS server 2 are grayed out and cannot be set.
The confirmation prompt for the factory settings appears.
With the SmartManager, the welding machines have their own website.
Once the OPT/s Ethernet option is installed on the welding machine, the welding machine can be connected to a computer via WLAN or a network cable, or integrated into a network.
The SmartManager of the welding machine can be accessed via the IP address of the welding machine.
IE 10 or higher or another modern browser is required in order to access the SmartManager.
The entries displayed on the SmartManager may vary depending on the system configuration, software extensions, and options available.
Examples of displayed entries:
Factory settings for username and password
The SmartManager for the welding machine is displayed.
There are two help functions when logging into the SmartManager:
Start unlock function?
This feature allows you to unlock an unintentionally locked welding machine and enable it for all functions.
A .txt file with the following file name is saved in the computer's download folder:
unlock_SN[serial number]_YYYY_MM_DD_hhmmss.txt
Fronius will reply by e-mail with a one-time unlock file with the following file name:
response_SN[serial number]_YYYY_MM_DD_hhmmss.txt
The welding machine is temporarily unlocked.
Forgot your password?
After clicking on "Forgot your password?", a note appears indicating that the password can be reset on the welding machine (see also "Restoring the website password", page (→)).
Click on this symbol to
Changing the SmartManager password:
| * | A password must satisfy the following criteria:
Click on this symbol to expand the display of characteristics, material specifications and certain welding parameters on the SmartManager for the welding machine.
The settings depend on the user who is logged in.
Click on the language abbreviation to display the languages available for the SmartManager.
To change the language, click on the desired language.
The current status of the welding machine is displayed between the Fronius logo and the selected welding machine.
Caution/warning |
Error on the welding machine * |
Welding machine is welding |
Welding machine is ready for use (online) |
Welding machine is not ready for use (offline) |
| * | In the event of an error, a red error line with the error number appears above the line with the Fronius logo. After clicking on the error line, an error description is displayed. |
Click on the Fronius logo to open the Fronius homepage: www.fronius.com
Current welding system data is displayed.
Depending on the welding process, equipment, and existing WeldingPackages, the system data displayed will vary.
e.g. system data for MIG/MAG:
The documentation entry in the logbook shows the last 100 entries. These logbook entries can be welds, errors, warnings, notifications, and events.
The "Time filter" button can be used to filter the displayed data by a specific time period. This is entered with date (yyyy MM dd) and time (hh mm), each from – to.
An empty filter reloads the most recent welding operations.
The display of welding operations, errors, warnings, notifications, and events can be deactivated.
The following data is displayed:
| (1) | Number of the weld |
| (2) | Start time (date and time) |
| (3) | Duration of welding in s |
| (4) | Welding current in A (average) |
| (5) | Welding voltage in V (average) |
| (6) | Wire speed in m/min |
| (7) | Protection class – arc power in W (based on real-time values according to ISO/TR 18491) |
| (8) | IE – arc energy in kJ (as the total throughout the entire welding process according to ISO/TR 18491) |
Clicking on a logbook entry will display the details for that entry.
Details for welds:
Section No.
| (9) | Duration of the welding section in s |
| (10) | Welding current in A (average) |
| (11) | Welding voltage in V (average) |
| (12) | Wire speed in m/min |
| (13) | Welding speed (cm/min) |
| (14) | Arc power from real-time values in W |
| (15) | Arc energy in kJ |
| (16) | Job No. |
| (17) | Process |
Additional values can be also displayed by clicking on the "Paste column" button:
If the OPT/s documentation option is present on the welding machine, individual sections of welds can also be displayed.
The documentation can be exported in the desired format using the "PDF" and "CSV" buttons.
For CSV exports, the OPT/s documentation option must be present on the welding machine.
Details for welds:
Section No.
| (16) | Job No. |
| (17) | Process |
The sampling rate for documentation can be activated and set in the basic settings.
In addition, the motor force M1 – M3, gas flow actual value and welding speed can be activated for documentation.
If the OPT/s Jobs option is available on the welding machine, the following can be carried out under the Job data entry:
| * | Viewing and exporting as a PDF also works if the OPT/s Jobs option is not available on the welding machine. |
The job overview lists all jobs stored in the welding system.
After clicking on a job, the data and parameters stored for this job are displayed.
Job data and parameters can only be viewed in the job overview. The column width for parameters and values can be easily adjusted by dragging with the mouse pointer.
Further jobs can be easily added to the list with the displayed data by clicking on the "Add column" button.
All added jobs are compared with the selected job.
Existing jobs in the welding machine can be optimized, provided the OPT/s Jobs option is available on the welding machine.
To help when editing the job, further jobs can be easily added to the list with the displayed data by clicking on "Add job".
Creating a new job
This function allows externally stored jobs to be transferred into the welding system, provided the OPT/s Jobs option is available on the welding machine.
This function allows the welding machine to store jobs externally, provided the OPT/s Jobs option is available on the welding machine.
The jobs are exported as an XML file to the computer's download folder.
Under Job overview and Edit job, existing jobs in the welding machine can be exported as PDF or CSV files.
For CSV export, the OPT/s Jobs option must be available on the welding machine.
The PDF settings or CSV settings are displayed.
A PDF or CSV file of the selected jobs is created and saved depending on the settings for the browser used.
Under Process parameters, you can view and modify general process parameters and process parameters for components & monitoring of a welding machine.
Changing process parameters
The welding machine configuration can be viewed and modified under Designation & location.
Welding parameters and special functions for the welding machine can be set under Parameter display.
The selected parameters/functions are displayed in the welding parameters on the welding machine display.
The date & time can be set automatically or manually.
The following parameters can be set under Network settings:
Management
WLAN
WeldCube Air
Connect welding machine to WeldCubeAir
(alternatively click on the cloud icon at the top right)
Under the Save and restore entry
Starting a backup
Finding a recovery file
If you have any questions about configuration, contact your network administrator.
Under the User administration entry
User management is created on one welding machine and can then be saved with the export/import function and transferred to other welding machines.
Existing users can be viewed, changed and deleted, new users can be created.
Viewing/changing a user:
Deleting a user:
Creating a user:
Existing user roles can be viewed, changed and deleted, new user roles can be created.
Viewing/changing a user role:
The "Administrator" role cannot be changed.
Deleting a user role:
The "Administrator" and "locked" roles cannot be deleted.
Creating a user role:
Exporting users and user roles from a welding machine
User management for the welding machine is stored in the computer's download folder.
File format: userbackup_SNxxxxxxxx_YYYY_MM_DD_hhmmss.user
SN = serial number, YYYY = year, MM = month, DD = day
hh = hour, mm = minute, ss = second
Importing users and user roles into a welding machine
User management is stored on the welding machine.
To activate a CENTRUM server
(CENTRUM = Central User Management)
The Overview entry displays the components and options in the welding system with all the available information, e.g. firmware version, item number, serial number, production date, etc.
Click on the "Expand all groups" button to see further details about the individual system components.
Example welding machine:
Click on the "Collapse all groups" button to hide the details of the system components.
Click on the "Export component overview as" button to create an XML file from the details of the system components. This XML file can either be opened or saved.
Under the Update entry, the firmware of the welding machine can be updated.
The welding machine’s current firmware version is displayed.
After the update has been completed, the welding machine may need to be restarted.
After the update has been successfully completed, a confirmation message is displayed.
The SmartManager is not available during the restart.
After the restart, the SmartManager may no longer be available.
If you select No, the new software functions will be activated the next time the power is turned on/off.
Click on the link to view information on open source licensing.
Under the Update entry, the Fronius WeldConnect mobile application can also be called up. |
WeldConnect can be used to perform the following functions:
Fronius WeldConnect is available as follows:
For more information on Fronius WeldConnect, visit:
The following data can be displayed under function packages:
In the Characteristics overview entry
You can search for, sort and filter the displayed characteristics at any time.
The following information is displayed for the characteristics:
To sort the characteristics in ascending or descending order, click on the arrow next to the corresponding information.
The column widths can be easily adjusted by dragging with the mouse cursor.
Click on the "Show filter" symbol to display the possible filter criteria. With the exception of "ID" and "Replaced by", the characteristics can be filtered by all information.
First selection box = select all
To hide the filter criteria, click on the "Hide filter" symbol.
Under the Screenshot entry, a digital image of the welding machine display can be created at any time, regardless of navigation or set values.
Depending on the browser you are using, different functions are available for saving the screenshot, and the display may vary.
The welding machines are equipped with an intelligent safety system, making it possible to dispense with nearly all fuses. After correcting any errors, the welding machine can be operated properly again.
Possible malfunctions, warning notices or status codes are shown on the display as plain text dialogs.
Secure all these devices and components so they cannot be switched back on.
Danger due to insufficient ground conductor connection.
This can result in personal injury and damage to property.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
"Current limit" is a safety function for MIG/MAG welding, whereby
If the welding power is too high, the arc gets continuously smaller and may be extinguished. To stop the arc from being extinguished, the welding machine reduces the wire speed and therefore the welding power.
A corresponding warning is shown on the welding machine display.
| Cause: | Mains lead damaged or broken, mains plug not inserted |
| Remedy: | Check mains lead, if necessary insert mains plug |
| Cause: | Mains socket or mains plug faulty |
| Remedy: | Replace faulty parts |
| Cause: | Mains fuse |
| Remedy: | Replace mains fuse |
| Cause: | Short circuit on the 24 V power supply of the SpeedNet connection or external sensor |
| Remedy: | Disconnect connected components |
| Cause: | Overload, duty cycle exceeded |
| Remedy: | Observe the duty cycle |
| Cause: | Thermal automatic circuit breaker has tripped |
| Remedy: | Wait until the welding machine automatically comes back on after the end of the cooling phase |
| Cause: | Limited supply of cooling air |
| Remedy: | Ensure accessibility to cooling air ducts |
| Cause: | Fan in the welding machine defective |
| Remedy: | Contact After-Sales Service |
| Cause: | Incorrect ground connection |
| Remedy: | Check ground connection for polarity |
| Cause: | Power cable in welding torch damaged or broken |
| Remedy: | Replace the welding torch |
| Cause: | Control plug not plugged in |
| Remedy: | Plug in control plug |
| Cause: | Welding torch or welding torch control line faulty |
| Cause: | Interconnecting hosepack defective or not correctly connected (not in the case of welding machines with integrated wire drive) |
| Remedy: | Check interconnecting hosepack |
| Cause: | Gas cylinder empty |
| Remedy: | Change gas cylinder |
| Cause: | Gas pressure regulator faulty |
| Remedy: | Replace gas pressure reducer |
| Cause: | Gas hose not attached, or damaged |
| Remedy: | Attach or replace gas hose |
| Cause: | Welding torch faulty |
| Remedy: | Change welding torch |
| Cause: | Gas solenoid valve faulty |
| Remedy: | Inform the service team |
| Cause: | Wrong welding parameters, wrong correction parameters |
| Remedy: | Check settings |
| Cause: | Poor ground earth connection |
| Remedy: | Establish good contact with workpiece |
| Cause: | Several welding machines welding one part |
| Remedy: | Increase distance between hosepacks and return lead cables; Do not use a common ground. |
| Cause: | Too little or no shielding gas |
| Remedy: | Check pressure regulator, gas hose, gas solenoid valve, welding torch gas connection, etc. |
| Cause: | Welding torch leaks |
| Cause: | Incorrect or heavily worn contact tip |
| Remedy: | Change contact tip |
| Cause: | Incorrect wire alloy or incorrect wire diameter |
| Remedy: | Check wire electrode in use |
| Remedy: | Check the weldability of the base material |
| Cause: | Shielding gas not suitable for wire alloy |
| Remedy: | Use correct shielding gas |
| Cause: | Shielding gas, wirefeeder, welding torch or workpiece contaminated or magnetically charged |
| Remedy: | Perform R/L alignment; Adjust arc length; Check shielding gas, wirefeeder, welding torch position or workpiece for contamination or magnetic charge |
| Cause: | Braking force has been set too high |
| Remedy: | Loosen the brake |
| Cause: | Contact tip hole too narrow |
| Remedy: | Use suitable contact tip |
| Cause: | Faulty inner liner in welding torch |
| Remedy: | Check the inner liner for kinks, dirt, etc. and replace if necessary |
| Cause: | Feed rollers not suitable for wire electrode used |
| Remedy: | Use suitable feed rollers |
| Cause: | Incorrect contact pressure of feed rollers |
| Remedy: | Optimize contact pressure |
| Cause: | Incorrect arrangement of welding torch hosepack |
| Remedy: | Arrange the welding torch hosepack in as straight a line as possible, avoiding tight bends |
| Cause: | Welding torch is inadequately sized |
| Remedy: | Observe duty cycle and load limits |
| Cause: | For water-cooled systems only: Coolant flow too low |
| Remedy: | Check coolant level, coolant flow rate, coolant contamination, etc. Further information can be found in the "Troubleshooting the cooling unit" section below as of page (→). |
| Cause: | Coolant level too low |
| Remedy: | Top up coolant |
| Cause: | Constriction or foreign body in the cooling circuit |
| Remedy: | Remove constriction or foreign body |
| Cause: | Coolant contaminated |
| Remedy: | Change the coolant and then vent the cooling unit |
| Cause: | Coolant return filter and/or coolant pre-filter installed incorrectly |
| Remedy: | Clean coolant filter using clean tap water or change filter insert |
| Cause: | Coolant pump defective |
| Cause: | Coolant pump jammed |
| Cause: | Cooler or air filter dirty |
| Remedy: | Purge cooler with dry compressed air (see from page (→) onwards) Clean air filter (see from page (→) onwards) |
| Cause: | Fan faulty |
| Cause: | Coolant flow too low |
| Remedy: | Check coolant level. If necessary, top up coolant. Check coolant for pollution. Replace coolant if necessary |
| Cause: | Coolant pump jammed – coolant flow too low |
The welding machine only requires minimal service and maintenance under normal operating conditions. However, some important points must be noted to ensure that the welding system remains in a usable condition for many years.
Danger due to hot components and parts.
These can cause burns.
Leave hot components and parts such as welding torches to cool before working with them.
It is impossible to guarantee that third-party parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements.
Air inlet and outlet openings must not be blocked or even partially covered.
Only use the coolant Cooling Liquid FCL10/20 when filling the cooling unit.
Other coolants are not suitable due to their electrical conductivity and insufficient material compatibility.
Danger due to the effect of compressed air.
Do not clean electronic components with compressed air from a short distance.
For details on the coolant, see from page (→) onwards.
In the event of heavy soiling, the display protector can be changed as follows:
Cleaning the air filter is described using the example of the cooling unit air filter.
The welding machine air filter is cleaned in the same way.
IMPORTANT! If there is a cooling unit in the welding system, always clean both air filters!
Danger from coolant escaping.
Personal injury and damage to property may result.
If coolant ends up on the outside of the device, this should be removed immediately.
Make sure that no coolant ends up inside the cooling unit.
Danger due to hot coolant.
This can result in burns or scalding.
Allow the coolant to cool down to +25 °C / +77 °F before commencing.
Switch off the cooling unit before disconnecting coolant hoses.
IMPORTANT! If the filter insert can no longer be cleaned without tools, replace the filter insert.
Danger from compressed air.
This may result in damage to electronic components.
Do not bring the air nozzle too close to electronic components.
When gas purging the cooling unit, hold the fan impeller firmly to prevent damage to the fan.
IMPORTANT! To update the firmware, you need a PC or laptop that is connected to the welding machine via an Ethernet network.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating welding machines within the same 12-month interval.
A safety inspection by a qualified electrician is recommendedWhen performing the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your Fronius branch or your Fronius partner, who will provide the necessary documents upon request.
Packaging materialsAverage wire electrode consumption at a wire speed of 5 m/min | |||
| 1.0 mm wire electrode diameter | 1.2 mm wire electrode diameter | 1.6 mm wire electrode diameter |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminum wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminum wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
The duty cycle (ED) is the period of a ten minute cycle in which the device may be operated at the stated power without overheating.
The ED values cited on the rating plate relate to an ambient temperature of 40 °C.
If the ambient temperature is higher, the ED or power must be lowered accordingly.
Example: Welding with 150 A at 60% ED
To use the device without interruptions:
For devices designed for special voltages, the technical data on the rating plate applies.
The following applies for all devices with a permitted grid voltage of up to 460 V: The standard mains plug allows the user to operate with a grid voltage of up to 400 V. For grid voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address:
Find downloads: critical
Temperature range of ambient air: | |
during operation | -10 °C to + 40 °C / 14 °F to 104 °F |
Relative humidity of ambient air: | |
at 40 °C / 104 °F | max. 50% |
Mains voltage (U1) | 3 x 400 V |
Max. effective primary current (I1eff) | 10.8 A |
Max. primary current (I1max) | 17.3 A |
Mains fuse | 16 A slow-blow |
Mains voltage tolerance | -10 / +10% |
Mains frequency | 50/60 Hz |
Cos phi (1) | 0.99 |
Max. permitted grid impedance Zmax on PCC1) | 75 mOhm |
Recommended residual-current circuit breaker | Type B |
Welding current range (I2) |
MIG/MAG | 3 - 270 A |
TIG | 3 - 270 A |
MMA | 10 - 270 A |
Welding current at | 40% / 270 A |
Output voltage range according to standard characteristic (U2) | |
MIG/MAG | 14.2 - 27.5 V |
TIG | 10.1 - 20.8 V |
MMA | 20.4 - 30.8 V |
Open circuit voltage | 104.1 V |
Protection class | IP 23 |
EMC emission class | A 2) |
Dimensions l x w x h | 681 / 368 / 555 mm |
Weight | 37.0 kg / 81.57 lb. |
Max. noise emission (LWA) | < 80 dB (A) |
Max. shielding gas pressure | 7 bar/101 psi |
Wire speed | 1 - 25 m/min / 40 - 980 ipm |
Wire drive | 4-roller drive |
Wire diameter | 0.6 - 1.6 mm/0.02 - 0.06 in. |
Wire spool diameter | max. 300 mm / max. 11.8 in. |
Wire spool weight | max. 20.0 kg / max. 44.1 lb. |
Idle state power consumption at 400 V | 23.5 W |
Welding machine efficiency at 270 A / 30.8 V | 88 % |
The wire drive of the Fortis 270 C is integrated in the welding machine.
| 1) | Interface to a 230/400-V and 50-Hz public grid |
| 2) | A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Mains voltage (U1) | 3 x 380 / 400 V |
Max. effective primary current (I1eff) | 10.6/10.8 A |
Max. primary current (I1max) | 16.8/17.3 A |
TIG | 3 - 270 A |
MMA | 10 - 270 A |
Weight | 35.7 kg / 78.71 lb. |
The wire drive of the Fortis 270 C /nc is integrated in the welding machine.
Mains voltage (U1) | 3 x 200/230/380/400/460/600 V |
3 x 200 V | 18.0 A |
3 x 230 V | 15.6 A |
3 x 380 V | 9.4 A |
3 x 400 V | 8.9 A |
3 x 460 V | 7.8 A |
3 x 600 V | 8.0 A |
1 x 230 V | 36.1 A |
3 x 200 V | 28.5 A |
3 x 230 V | 24.6 A |
3 x 380 V | 14.8 A |
3 x 400 V | 8.9 A |
3 x 460 V | 7.8 A |
3 x 600 V | 8.0 A |
1 x 230 V | 30.1 A |
Mains fuse | |
3 x 200 / 230 / 380 V | 35 A slow-blow |
3 x 400 / 460 / 600 V | 16 A slow-blow |
1 x 230 V | 35 A slow-blow |
Mains voltage tolerance | -10 / +6% |
TIG | 3 - 270 A |
MMA | 10 - 270 A |
U1 = 3 x 200 - 600 V | 40% / 270 A |
U1 = 1 x 230 V | 40% / 240 A |
Open circuit voltage | 70.5 V |
Weight | 37.4 kg / 82.45 lb. |
Idle state power consumption at 400 V | 25.2 W |
Welding machine efficiency | 87 % |
The wire drive of the Fortis 270 C /XT/nc is integrated in the welding machine.
Max. effective primary current (I1eff) | 12.7 A |
Max. primary current (I1max) | 20.0 A |
MIG/MAG | 3 - 320 A |
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Welding current at | 40% / 320 A |
MIG/MAG | 14.2 - 30.0 V |
TIG | 10.1 - 22.8 V |
MMA | 20.4 - 32.8 V |
Open circuit voltage | 64.4 V |
Weight | 38.0 kg / 83.78 lb. |
Idle state power consumption at 400 V | 27.3 W |
Welding machine efficiency | 89 % |
The wire drive of the Fortis 320 C is integrated in the welding machine.
Max. effective primary current (I1eff) | 13.1/12.7 A |
Max. primary current (I1max) | 20.7/20.0 A |
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Weight | 36.7 kg / 80.91 lb. |
The wire drive of the Fortis 320 C /nc is integrated in the welding machine.
3 x 200 V | 22.7 A |
3 x 230 V | 19.6 A |
3 x 380 V | 11.0 A |
3 x 400 V | 11.2 A |
3 x 460 V | 9.8 A |
3 x 600 V | 9.7 A |
1 x 230 V | 32.6 A |
3 x 200 V | 35.9 A |
3 x 230 V | 31.0 A |
3 x 380 V | 18.5 A |
3 x 460 V | 9.8 A |
3 x 600 V | 9.7 A |
1 x 230 V | 43.1 A |
Mains fuse | |
TIG | 3 - 320 A |
MMA | 10 - 320 A |
U1 = 3 x 200 - 600 V | 40% / 320 A |
U1 = 1 x 230 V | 40% / 270 A |
TIG | 10.4 - 22.8 V |
MMA | 20.1 - 32.8 V |
Open circuit voltage | 79.8 V |
Weight | 38.5 kg / 84.88 lb. |
Idle state power consumption at 400 V | 29.4 W |
Welding machine efficiency at | 89 % |
The wire drive of the Fortis 320 C /XT/nc is integrated in the welding machine.
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Dimensions l x w x h | 681 / 368 / 763 mm |
Weight | 42.3 kg / 93.26 lb. |
The wire drive of the Fortis 320 C /GW is integrated in the welding machine.
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Weight | 41.0 kg / 9.39 lb. |
The wire drive of the Fortis 320 C /GW/nc is integrated in the welding machine.
3 x 460 V | 9.8 A |
3 x 600 V | 9.7 A |
3 x 400 V | 17.7 A |
3 x 460 V | 15.4 A |
3 x 600 V | 15.3 A |
Mains fuse | |
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Weight | 42.7 kg / 94.14 lb. |
The wire drive of the Fortis 320 C GW/XT/nc is integrated in the welding machine.
Max. effective primary current (I1eff) | 21.8 A |
Max. primary current (I1max) | 28.1 A |
Mains fuse | 35 A slow-blow |
MIG/MAG | 3 - 400 A |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Welding current at | 40% / 400 A |
MIG/MAG | 14.2 - 34.0 V |
TIG | 10.1 - 26.0 V |
MMA | 20.4 - 36.0 V |
Weight | 42.0 kg / 92.59 lb. |
Idle state power consumption at 400 V | 26.9 W |
Welding machine efficiency | 89% |
The wire drive of the Fortis 400 C /GW is integrated in the welding machine.
Max. effective primary current (I1eff) | 22.7/21.8 A |
Max. primary current (I1max) | 28.9/28.1 A |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Weight | 40.1 kg / 88.41 lb. |
The wire drive of the Fortis 400 C /GW/nc is integrated in the welding machine.
3 x 200 V | 35.8 A |
3 x 380 V | 18.6 A |
3 x 460 V | 15.5 A |
3 x 600 V | 15.2 A |
1 x 230 V | 36.3 A |
3 x 200 V | 49.0 A |
3 x 230 V | 42.4 A |
3 x 380 V | 25.5 A |
3 x 400 V | 24.2 A |
3 x 460 V | 21.1 A |
3 x 600 V | 19.5 A |
1 x 230 V | 53.7 A |
Mains fuse | |
3 x 200 / 230 / 380 V | 63 A slow-blow |
3 x 400 / 460 / 600 V | 35 A slow-blow |
1 x 208 / 240 V | 50 A slow-blow |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
U1 = 1 x 230 V | 40% / 320 A |
U1 = 3 x 200 - 600 V | 40% / 400 A |
Weight | 43.6 kg / 96.12 lb. |
Idle state power consumption at 400 V | 30,5 W |
The wire drive of the Fortis 400 C /GW/XT/nc is integrated in the welding machine.
Mains voltage (U1) | 3 x 600 V |
Max. effective primary current (I1eff) | 16.7 A |
Max. primary current (I1max) | 22.0 A |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Open circuit voltage | 77.6 V |
EMC emission class | A 1) |
Weight | 41.3 kg / 91.05 lb. |
The wire drive of the Fortis 400 C /GW/600/nc is integrated in the welding machine.
| 1) | A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Max. effective primary current (I1eff) | 25.0 A |
Max. primary current (I1max) | 36.7 A |
MIG/MAG | 3 - 500 A |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
Welding current at | 40% / 500 A |
MIG/MAG | 14.2 - 39.0 V |
TIG | 10.1 - 30.0 V |
MMA | 20.4 - 40.0 V |
Wire spool weight | max. 200 kg / max. 44.1 lb. |
Idle state power consumption at 400 V | 27.8 W |
The wire drive of the Fortis 500 C /GW is integrated in the welding machine.
Max. effective primary current (I1eff) | 25.6/25.0 A |
Max. primary current (I1max) | 38.1/36.7 A |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
Weight | 40.2 kg / 88.63 lb. |
The wire drive of the Fortis 500 C /GW/nc is integrated in the welding machine.
3 x 200 V | 43.2 A |
3 x 230 V | 37.4 A |
3 x 380 V | 22.3 A |
3 x 400 V | 21.2 A |
3 x 460 V | 18.5 A |
3 x 600 V | 17.8 A |
1 x 230 V | 36.5 A |
3 x 200 V | 68.3 A |
3 x 230 V | 59.2 A |
3 x 380 V | 35.3 A |
3 x 400 V | 33.5 A |
3 x 460 V | 29.2 A |
3 x 600 V | 23.7 A |
1 x 230 V | 53.6 A |
Mains fuse | |
1 x 230 V | 50 A slow-blow |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
U1 = 3 x 200 - 600 V | 40% / 500 A |
Weight | 43.7 kg / 96.34 lb. |
Idle state power consumption at 400 V | 30.2 W |
The wire drive of the Fortis 500 C /GW/XT/nc is integrated in the welding machine.
Max. effective primary current (I1eff) | 19.2 A |
Max. primary current (I1max) | 29.1 A |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
The wire drive of the Fortis 500 C /GW/600/nc is integrated in the welding machine.
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Weight | 39.7 kg / 87.52 lb. |
TIG | 3 - 320 A |
MMA | 10 - 320 A |
Weight | 38.4 kg / 84.66 lb. |
3 x 460 V | 9.8 A |
3 x 600 V | 9.7 A |
Mains fuse | |
1 x 208 / 240 V | 35 A slow-blow |
TIG | 3 - 320 A |
MMA | 10 - 320 A |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Weight | 39.4 kg / 86.86 lb. |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Weight | 37.5 kg / 88.4 lb. |
Mains fuse | |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Weight | 41.0 kg / 90.39 lb. |
Idle state power consumption at 400 V | 30.5 W |
TIG | 3 - 400 A |
MMA | 10 - 400 A |
Weight | 38.7 kg / 85.32 lb. |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
Weight | 40.1 kg / 88.4 lb. |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
Weight | 37.6 kg / 82.89 lb. |
Mains fuse | |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
Weight | 41.1 kg / 90.6 lb. |
TIG | 3 - 500 A |
MMA | 10 - 500 A |
Supply voltage |
Current consumption | 2.1 A |
Cooling capacity at |
Max. delivery head | 50 m |
Max. delivery rate | 1.5 l/min |
Max. pump pressure | 5 bar |
Pump service life | up to 15,000 hrs |
Coolant content | 5 l |
Dimensions l/w/h | 740/340/230 mm |
Weight (without coolant) | 6 kg |
Coolant temperature monitoring | Warning above 68 °C (154.4 °F) Error message above 70 °C (158 °F) |
Flow monitoring | Warning at 1-0.7 l/min Error message below 0.7 l/min |
Compliance with directive 2014/53/EU - Radio Equipment Directive (RED)
The following table provides information on the frequency bands used and the maximum HF transmission power of Fronius wireless radio products sold in the EU, in accordance with Articles 10.8 (a) and 10.8 (b) of the RED.
Frequency range | Modulation |
2412 - 2462 MHz | 802.11b: DSSS 802.11 g: OFDM 802.11n: OFDM |
2402 - 2482 MHz | GFSK |
