en
      Operating InstructionsIgnis 150/180 Standard
    • Safety rules
      • General
      • Intended use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Mains connection
      • Residual current protective device
      • Protecting yourself and others
      • Data on noise emission values
      • Danger from toxic gases and vapours
      • Danger from flying sparks
      • Risks from mains current and welding current
      • Meandering welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF Safety Instructions
      • Specific hazards
      • Requirement for the shielding gas
      • Danger from shielding gas cylinders
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
    • General
      • Device concept
      • Application areas
    • Before commissioning
      • Safety
      • Intended use
      • Setup regulations
      • Generator-powered operation
    • Controls, connections and mechanical components
      • Safety
      • Ignis 150 controls, connections and mechanical components
      • Ignis 180 controls, connections and mechanical components
      • Control panel
    • MMA welding
      • Preparation
      • MMA welding
      • SoftStart / HotStart function
      • Arc-force dynamic
      • Pulse welding
    • TIG welding
      • General
      • Connecting the gas cylinder
      • Preparation
      • Setting the gas pressure on the welding torch with gas cut-off valve
      • TIG welding
      • TIG Comfort Stop
    • Welding process Setup menu
      • Accessing the Setup menu
      • Changing welding parameters
      • Exiting the Setup menu
      • Parameters for MMA welding
      • Parameters for TIG welding
    • Setup menu - Level 2
      • Welding parameters in the level 2 Setup menu
    • Care, maintenance and disposal
      • Safety
      • General
      • Maintenance at every start-up
      • Maintenance every 2 months
      • Disposal
    • Troubleshooting
      • Safety
      • Indicated errors
      • Service messages
      • No function
      • Faulty operation
    • Average consumption values
      • Average wire electrode consumption during MIG/MAG welding
      • Average shielding gas consumption during MIG/MAG welding
      • Average shielding gas consumption during TIG welding
    • Technical data
      • Explanation of the term "duty cycle"
      • Ignis 150
      • Ignis 180
      • Ignis 180 XT
      • China Energy Label
      • Overview with critical raw materials, year of production of the device
    • 005-20102026
    download
    Control panel
    Setup parameters - MMA welding
    Setup parameters - TIG welding
    Spare parts
    ContactImprintTerms and ConditionsData privacy statementCookie Policy
    Safety rules
    link_horizontalLink copied
    Warnings are intended to warn people of possible injury and to prevent personal injury and damage to the product. They relate to individual actions performed with and on the product.
    DANGER!
    Indicates an immediately dangerous situation.
    Serious injury or death will result if the hazard is not avoided.
    Action step to escape the situation.
    WARNING!
    Serious injury or death will potentially result if the hazard is not avoided.
    CAUTION!
    Minor or moderate injury may result if the hazard is not avoided.
    NOTE!
    Indicates a situation which may result in damage to property.
    Failure to avoid the situation may result in impaired work results and material damage to the product or other property.
    Action step to avoid the situation.
    Safety instructions are intended to ensure safe use of the product. They are preventive and help to inform users about basic risks when using the product. They do not refer specifically to individual actions performed with and on the product.
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of welding and
    • read and follow these operating instructions carefully.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before switching on the device, rectify any faults that could compromise safety.
    1. Safety rules
    Intended use
    The external high-frequency device is intended exclusively to support the ignition of a TIG arc in combination with Fronius system components.
    The environmental conditions, safety instructions, and regulations of the welding machine shall apply.
    Any other use or use above and beyond this shall be deemed to be not in accordance with the intended use.
    Intended use also means:
    • Reading these operating instructions in their entirety
    • Following all the instructions and safety rules in these operating instructions
    • Observing the welding machine operating instructions
    • Carrying out all the specified inspection and maintenance work
    The device is designed for commercial and industrial use.
    1. Safety rules
    Ambient temperature range:
    • during operation: -10 °C to + 40 °C (14 °F to 104 °F)
    • during transport and storage: -20 °C to +55 °C (-4 °F to 131 °F)
    Relative humidity:
    • up to 50% at 40 °C (104 °F)
    • up to 90% at 20 °C (68 °F)
    The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
    Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so must:
    • observe the basic instructions regarding safety at work and accident prevention; and
    • read these operating instructions (especially the "Safety rules" section) and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Mains connection
    This may affect a number device types in terms of:
    • Connection restrictions
    • Criteria with regard to the maximum permissible mains impedance *)
    • Criteria with regard to the minimum short-circuit power requirement *)
    *) at the interface with the public grid
    see "Technical data"
    In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
    IMPORTANT! Ensure that the mains connection is earthed properly
    1. Safety rules
    Local regulations and national guidelines may require a residual current protective device when connecting equipment to the public grid.
    The type of residual current protective device recommended by the manufacturer for the equipment is indicated in the technical data.
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks, e.g.
    • flying sparks and hot pieces of metal
    • Arc radiation, which can damage eyes and skin
    • Hazardous electromagnetic fields, which can endanger the lives of those using cardiac pacemakers
    • Risk of electrocution from mains current and welding current
    • Greater noise pollution - the noise level may exceed 85 dB
    • Harmful welding fumes and gases
    Suitable protective clothing must be worn when working with the device. The protective clothing must have the following properties:
    • Flame-resistant
    • Insulating and dry
    • Covers the whole body, is undamaged and in good condition
    • Safety helmet
    • Trousers with no turn-ups
    Protective clothing refers to a variety of different items. Operators should:
    • Protect eyes and face from UV rays, heat and sparks using a protective visor and regulation filter
    • Wear regulation protective goggles with side protection behind the protective visor
    • Wear stout footwear that provides insulation even in wet conditions
    • Protect the hands with suitable gloves (electrically insulated and providing protection against heat)
    • Wear ear protection to reduce the harmful effects of noise and to prevent injury
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers (risk of dazzling by the arc, injury from flying sparks, harmful welding fumes, noise, possible risks from mains current and welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains.
    1. Safety rules
    When idling and in the cooling phase following operation, the machine produces a maximum sound power level of <80 dB(A) (ref. 1 pW) corresponding to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
    A workplace-related sound emission value depends on various parameters, such as:
    • The welding or work process (MIG/MAG, TIG, plasma, HAP),
    • The selected current type (AC, DC),
    • The power range,
    • The type of weld metal or workpiece,
    • The resonance properties of the workpiece,
    • The workplace environment.
    • and others.
    A workplace-related sound level measurement is recommended.
    1. Safety rules
    The fumes produced during welding contain harmful gases and vapours.
    Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
    Keep your face away from welding fumes and gases.
    Fumes and hazardous gases
    • must not be breathed in
    • must be extracted from the working area using appropriate methods.
    Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
    If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
    The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:
    • Metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaners, degreasers, etc.
    • Welding process used
    The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
    Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
    Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    1. Safety rules
    Flying sparks may cause fires or explosions.
    Never weld close to flammable materials.
    Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
    Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
    Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
    Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
    1. Safety rules
    An electric shock is potentially life threatening and can be fatal.
    Do not touch live parts either inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
    Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
    Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Use the handle to ensure the power connections are tight before every use.
    In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
    Do not wrap cables or leads around the body or parts of the body.
    The electrode (rod electrode, tungsten electrode, welding wire, etc.) must
    • never be immersed in liquid for cooling
    • never be touched when the welding system is switched on.
    Double the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
    Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
    Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    If necessary, provide adequate earthing for the workpiece.
    Switch off unused devices.
    Wear a safety harness if working at height.
    Before working on the device, switch it off and pull out the mains plug.
    Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
    After opening the device:
    • Discharge all live components
    • Ensure that all components in the device are de-energised.
    If work on live parts is required, have a second person switch off the main switch at the right moment.
    1. Safety rules
    If the following instructions are ignored, meandering welding currents can develop with the following consequences:
    • Fire hazard
    • Overheating of parts connected to the workpiece
    • Damage to ground conductors
    • Damage to device and other electrical equipment
    Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
    If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
    In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check and evaluate the immunity to interference of nearby devices according to national and international regulations. Examples of equipment that may be susceptible to interference from the device include:
    • Safety devices
    • Network, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite the correct mains connection, additional measures are necessary (e.g. use of a suitable line filter)
    2. Welding power-leads
      • must be kept as short as possible
      • must be laid close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Earthing of the workpiece
      • If necessary, establish an earth connection using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices nearby
      • Shield the entire welding installation
    1. Safety rules
    General information
    During operation, high electrical voltages and currents give rise to localized electromagnetic fields (EMFs). Electromagnetic fields occur:
    • Around the welding circuit
    • In the vicinity of the welding system
    The applicable limit values for human exposure are met when the product is used for its intended use and in compliance with the applicable occupational safety regulations. Based on current scientific knowledge, no adverse health effects are expected provided these limit values are observed.
    In the welding shop
    Due to potential health risks, be mindful of and instruct people in the vicinity—even if they are separated by walls—as well as visitors.
    Due to potential health risks, the following individuals should consult their doctor before staying near welding systems:
    • People who wear prosthetics and jewelry, e.g., implants and metal parts in and on the body
    • People who use active medical devices, such as pacemakers, insulin pumps, hearing aids, etc.
    Avoid large-area current loops caused by the welding power-lead and the hose pack:
    • Bundle the return lead cable and the welding power-lead or hose pack together and secure them with tape.
    • Both cables must run on the same side of the body.
    • Connect the grounding cable as close as possible to the area of the workpiece being welded.
    Keep as much distance as possible from the welding power-leads and hose packs:
    • Do not work or linger in the immediate vicinity of the welding machine.
    • Do not move the welding machine around while it is in operation.
    • Do not route the return lead cable, welding power-leads, or hose pack directly against your body.
    • Do not drape the return lead cable, welding power-leads, or hose pack over your shoulder or across your thighs.
    • Do not wrap the return lead cable, welding power-leads, or hose pack around your arm or body.
    Additional Information and Recommendations
    Further information and recommendations can be found, among others, in standard EN IEC 60974‑9:2018.
    The EMF data sheets for welding machines are available athttps://www.fronius.com/en/download-centerfor download.
    Further information on EMFs and information for people with implants can be found on our website athttps://www.fronius.com/en/welding/know-how/welding-protection
    For information on occupational safety during welding, click Download the Health & Safety brochure now. The relevant state-level authorities and agencies responsible for worker protection also provide the locally applicable regulations on their websites.
    1. Safety rules
    Specific hazards
    Keep hands, hair, clothing and tools away from moving parts. For example:
    • Fans
    • Cogs
    • Rollers
    • Shafts
    • Wire spools and welding wires
    Do not reach into the rotating cogs of the wire drive or into rotating drive components.
    Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
    During operation
    • Ensure that all covers are closed and all side panels are fitted properly.
    • Keep all covers and side panels closed.
    The welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
    Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
    Never touch the workpiece during or after welding - risk of burns.
    Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
    Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
    Special provisions apply in areas at risk of fire or explosion
    - observe relevant national and international regulations.
    Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
    Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
    Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
    • Hook chains or ropes onto all suspension points provided on the suitable load-carrying equipment.
    • Chains or ropes must be at the smallest angle possible to the vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
    All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
    The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
    Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
    1. Safety rules
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    1. Safety rules
    Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
    Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
    Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
    Keep the shielding gas cylinders well away from any welding or other electrical circuits.
    Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
    Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
    Turn your face to one side when opening the valve of a shielding gas cylinder.
    Close the shielding gas cylinder valve if no welding is taking place.
    If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
    The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
    1. Safety rules
    A device toppling over could easily kill someone. Place the device on a solid, level surface such that it remains stable
    • The maximum permissible tilt angle is 10°.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
    When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
    Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
    After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a danger of:
    • serious or fatal injury to the operator or third parties;
    • damage to the device and other material assets belonging to the operating company; and
    Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
    Only Fronius original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
    Only use suitable original coolant from Fronius.
    Do not mix Fronius original coolant with other coolants.
    Only connect Fronius system components to the cooling circuit.
    Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant can ignite under certain. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
    Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from the service centre or downloaded from the manufacturer's website.
    Check the coolant level before starting to weld while the system is still cool.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
    The manufacturer recommends that the welding machines be calibrated at the same 12-monthly interval.
    A safety inspection should be carried out by a qualified electrician:
    • after any modifications or installation of additional parts;
    • following repair, care and maintenance.
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on the safety inspection and calibration can be obtained from a Fronius branch or Fronius Service Partner.
    1. Safety rules
    Disposal
    According to the relevant EU Directive and national law, the following products must be disposed of separately and recycled:
    • Waste electrical and electronic equipment
    • Used batteries (portable batteries, industrial batteries)
    Used equipment and batteries must be returned to the distributor or an authorised local collection system. Do not dispose of batteries in domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
    Arrange for the safe collection and proper disposal of damaged, leaking or decommissioned batteries by a battery recycling company or the Fronius Service Partner.
    It should also be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances, such as heavy metals or electrolytes, which can contaminate the soil, water and air.
    This ensures environmental protection and the sustainable use of natural resources.
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark meet the requirements of all valid EU directives, such as:
    • Directive 2014/30/EU on Electromagnetic Compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • And so on
    The full text of the EU Declaration of Conformity can be found at
    https://www.fronius.com .
    Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Data security
    • saving and retaining personal settings
    1. Safety rules
    Copyright
    Copyright of this document remains with Fronius International GmbH.
    Text, illustrations and other media correspond to the technical state of the art at the time of publication. Fronius reserves the right to make changes. If you have any suggestions for improvement, or can point out any inconsistencies in this document, we will be most grateful for your comments.
    General
    Device concept
    The welding system has the following properties:
    • Compact dimensions
    • Robust plastic housing
    • Extremely reliable even under harsh operating conditions
    • Carrying strap for easy transport on construction sites, etc.
    • Protected controls
    • Current sockets with bayonet latch
    In conjunction with the digital resonance inverter, an electronic regulator adapts the welding system characteristic to suit the welding electrode during welding. The result is a lightweight and compact device with excellent ignition and weld properties.
    The welding system also features a ‘Power Factor Correction’, which adapts the current consumption of the welding system to the sinusoidal mains voltage. This results in numerous advantages for the user, such as:
    • Low primary current
    • Low conduction losses
    • Late tripping of the automatic circuit breaker
    • Improved stability in the event of voltage fluctuations
    • Long mains leads can be used
    • In the case of multivoltage devices, a continuous input voltage range.
    When using cellulose electrodes (CEL), a dedicated operating mode can be chosen for perfect welding results.
    1. General
    Device concept
    1. General
    The warning notices and safety symbols on the welding system must not be removed or painted over. They warn against incorrect operation which can lead to serious injury and damage.
    Meaning of safety symbols on the device:
    Welding is dangerous. The following basic requirements must be met to ensure the equipment is used properly:
    • Welders must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved must be kept at a safe distance from the welding process
    • All the Operating Instructions for the system components of the welding system, especially the safety rules
    Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules.
    1. General
    Application areas
    MMA welding
    TIG welding, welding torch with gas cut-off valve
    Safety
    WARNING!
    Fully read and understand this document.
    1. Before commissioning
    Safety
    WARNING!
    Intended use
    The device has been manufactured in accordance with the state of the art and the recognised safety rules.
    The welding machine is intended exclusively for MMA welding and TIG welding in conjunction with system components from Fronius.
    Any use above and beyond this purpose is deemed improper.
    Proper use also includes
    • Carefully reading and understanding all Operating Instructions
    • Observing and following all safety instructions carefully
    • Performing all stipulated inspection and maintenance work.
    Setup regulations
    WARNING!
    Danger from machines toppling over or falling.
    Set up the device securely on an even, solid surface.
    Check all screw connections are tightly fastened after installation.
    The device is tested to IP 23 protection, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12.5 mm (0.49 in.)
    • Protected against spraywater at any angle up to 60° to the vertical
    Cooling air
    The device must be set up in such a way that cooling air can flow freely through the slots in the front and rear panels.
    Dust
    Ensure that metallic dust is not sucked into the system by the fan, when carrying out grinding for example.
    Outdoor operation
    The device can be set up and operated outdoors in accordance with IP23 degree of protection. Avoid direct wetting (e.g. from rain).
    The welding system is generator-compatible.
    In order to dimension the required generator output, the maximum apparent power S1max of the welding system is required.
    The maximum apparent power S1max of the welding system can be calculated as follows:
    S1max = I1max x U1
    See device rating plate or technical data for I1max and U1 values
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator may be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the welding system.
    When using single-phase devices with a 3-phase generator, note that the specified generator apparent power is often only available as a whole across all three phases of the generator. If necessary, obtain further information on the single-phase power of the generator from the generator manufacturer.
    NOTE!
    The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
    Details of the mains voltage tolerance can be found in the ‘Technical data’ section.
    Safety
    WARNING!
    As a result of software updates, you may find that there are functions available on your device that are not described in these Operating Instructions, or vice versa.
    Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    1. Controls, connections and mechanical components
    Safety
    WARNING!
    (1)
    Control panel
    (2)
    (-) current socket
    with bayonet latch
    (3)
    TIG Multi Connector
    Ignis 150 RC only - for connecting a remote control
    After connecting a remote control to the welding system
    • ‘rc’ appears on the welding system display
    • the welding current can only be adjusted using the remote control
    (4)
    (+) current socket
    with bayonet latch
    (5)
    Carrying strap
    (6)
    Cable strap
    for holding the mains cable and the welding power-leads
    Do not use to move the device!
    (7)
    Mains switch
    (8)
    Air filter
    Use of the current connections during manual metal arc welding (depending on electrode type):
    • (+) current socket for electrode holder or grounding cable
    • (-) current socket for electrode holder or grounding cable
    Use of the current connections during TIG welding:
    • (+) current socket for grounding cable
    • (-) current socket for welding torch
    (1)
    Control panel
    (2)
    (-) current socket
    with bayonet latch
    (3)
    TIG Multi Connector
    Ignis 180 RC only - for connecting a remote control
    (4)
    (+) current socket
    with bayonet latch
    (5)
    Carrying strap
    (6)
    Cable strap
    (7)
    Mains switch
    (8)
    Air filter
    Control panel
    (1)
    Setting value indicator
    shows which setting value is selected:
    • Arc-force dynamic
    • Welding current
    • Pulse welding (only available for manual metal arc welding)
    (2)
    Unit indicator
    shows the unit of the value that is currently being changed with the adjusting dial (7):
    • Time (seconds)
    • Percent
    • Frequency (Hertz)
    (3)
    Setting value button
    for selecting the desired setting value (1)
    (4)
    Display
    shows the current figure of the selected setting value
    (5)
    Welding process indicator
    shows which welding process is selected:
    • MMA welding
    • MMA welding with Cel electrode
    • TIG welding
    (6)
    Welding process button
    for selecting the welding process
    (7)
    Adjusting dial
    for continuous adjustment of the selected setting value (1)
    (8)
    Status indicators
    display various operating modes of the welding system:
    • VRD
      lights up when the safety device for voltage reduction is activated (VRD devices only)
    • Setup
      lights up in Setup mode
    • Temperature
      lights up when the device is outside the permissible temperature range
    • Fault
      lights up in the event of a fault, also see section ‘Troubleshooting’
    • TAC
      lights up when the tacking function is activated
      (only possible on TIG devices with the TIG welding process)
    MMA welding
    Preparation
    CAUTION!
    Danger from electric shocks. As soon as the welding system is switched on, the electrode in the electrode holder is live.
    This can result in injury and damage to property.
    Ensure the electrode does not touch any persons or electrically conductive or earthed parts (the housing, etc.)
    5
    1. MMA welding
    Preparation
    CAUTION!
    5
    1. MMA welding
    MMA welding
    1Use the welding process button to select one of the following processes:
    • MMA welding - the MMA welding indicator lights up after selection
    • MMA welding with Cel electrode - the MMA welding with Cel electrode indicator lights up after selection
    2Press the setting value button until
    • the welding current indicator lights up
    3Adjust the welding current using the adjusting dial
    • Welding system is ready for welding
    1. MMA welding
    This function is used to set the starting current.
    Setting range: 1 - 200 %
    Operating principle:
    At the start of the welding process, the welding current is reduced (SoftStart) or increased (HotStart) for 0.5 seconds, depending on the setting.
    The change is shown as a percentage from the set welding current.
    The duration of the starting current can be changed in the Setup menu using the starting current duration (Hti) parameter.
    Setting the starting current:
    1Press the setting value button until
    • the SoftStart / HotStart indicator lights up
    2Turn the adjusting dial until the desired value is reached
    • power source is ready for welding
    The maximum HotStart current is limited as follows:
    • Ignis 150 to 160 A
    • Ignis 180 to 200 A
    Examples (set welding current = 100 A):
    100 %
    = 100 A starting current = function deactivated
    80 %
    = 80 A starting current = SoftStart
    135 %
    = 135 A starting current = HotStart
    200 %
    = 160 A starting current on Ignis 150 = HotStart, maximum current limit is reached!
    200 %
    = 200 A starting current on Ignis 180 = HotStart
    Example of HotStart function
    Features of SoftStart function:
    • Reduced pore formation with certain electrode types
    Features of HotStart function:
    • Improved ignition properties, even when using electrodes with poor ignition properties
    • Better fusion of the base material during the start-up phase, meaning fewer cold-shut defects
    • Largely prevents slag inclusions
    1. MMA welding
    Arc-force dynamic
    To obtain optimum welding results, it will sometimes be necessary to adjust the arc-force dynamic.
    Setting range: 0 - 100 (corresponds to 0 - 200 A current increase)
    At the moment of droplet transfer or in the event of a short circuit, the amperage is briefly increased in order to obtain a stable arc.
    If the rod electrode is at risk of sinking into the weld pool, this measure prevents the weld pool from solidifying, as well as preventing a prolonged short-circuit of the arc. This largely prevents the rod electrode from sticking.
    Setting the arc-force dynamic:
    • the arc-force dynamic indicator lights up
    2Turn the adjusting dial until the desired correction value is reached
    The maximum arc-force dynamic current is limited as follows:
    • Ignis 150 to 180 A
    • Ignis 180 to 220 A
    Examples:
    • Arc-force dynamic = 0
      • arc-force dynamic deactivated
      • soft, low-spatter arc
    • Arc-force dynamic = 20
      • arc-force dynamic with 40 A current increase
      • harder, more stable arc
    • Arc-force dynamic = 60, set welding current = 100 A
      • for the Ignis 150: actual increase is just 80 A as the maximum current limit is reached!
      • for Ignis 180: arc-force dynamic with 120 A current increase
    1. MMA welding
    Pulse welding
    Pulse welding is welding with a pulsing welding current. It is used for out-of-position welding of steel pipes or when welding thin sheets.
    In these applications, the welding current set at the start of welding is not always ideal for the whole welding process:
    • if the amperage is too low, the base material will not melt sufficiently
    • if overheating occurs, the liquid weld pool may drip.
    Setting range: 0.2 - 990 Hz
    • A low base current I-G rises steeply to the significantly higher pulse current I-P and drops back to the base current I-G after the Duty cycle dcY time. The pulse current I-P can be set on the welding system.
    • This results in an average current that is lower than the set pulse current I-P.
    • During pulse welding, small sections of the welding location melt quickly and then rapidly re-solidify.
    The welding system controls the Duty cycle dcY parameter and base current I-G according to the set pulse current and pulse frequency.
    Pulse welding - welding current curve
    Adjustable parameters:
    • F-P: Pulse frequency (1/F-P = time interval between two pulses)
    • I-P:  Pulse current
    • SoftStart/HotStart
    Fixed parameters:
    • I-G: Base current
    • dcY: Duty cycle
    To use pulse welding:
    • the pulse welding indicator lights up
    2Turn the adjusting dial until the desired frequency value (Hz) is reached
    TIG welding
    General
    NOTE!
    Do not use pure tungsten electrodes (colour-coded green) if the TIG welding process has been selected.
    1. TIG welding
    General
    NOTE!
    1. TIG welding
    WARNING!
    Danger from falling gas cylinders.
    Place gas cylinders on a solid, level surface so that they remain stable. Secure gas cylinders to prevent them from falling over.
    Observe the safety rules of the gas cylinder manufacturer.
    1. TIG welding
    Preparation
    CAUTION!
    Danger from electric shocks. As soon as the welding system is switched on, the electrode in the welding torch is live.
    1. TIG welding
    Welding torch with gas cut-off valve
    1Open the gas cut-off valve
    - shielding gas flows
    2Set the desired gas flow rate on the pressure regulator
    3Close the gas cut-off valve
    1. TIG welding
    TIG welding
    1Select TIG welding with the welding process button
    • the TIG welding indicator lights up
    4Place the gas nozzle down on the ignition location, ensuring there is a gap of approx. 2 to 3 mm (5/64 to 1/8 in.) between the tungsten electrode and the workpiece
    5Actuate the gas cut-off valve
    • shielding gas flows
    6Gradually tilt the welding torch up until the tungsten electrode touches the workpiece
    7Raise the welding torch and rotate it into its normal position
    • the arc ignites
    8Carry out welding
    1. TIG welding
    TIG Comfort Stop
    To activate and set the TIG Comfort Stop function, see the description External Parameters for TIG welding starting on page (→).
    Operating principle and use of the TIG Comfort Stop:
    1Welding
    2During welding, raise the welding torch
    • the arc length is increased significantly
    3Lower the welding torch
    • the arc length is decreased significantly
    • the TIG Comfort Stop function is activated
    4Keep the welding torch at the same height
    • the welding current continually decreases (DownSlope) until the arc goes out
    5Wait for the gas post-flow time to finish and lift the welding torch away from the workpiece
    Welding current and gas flow curve with TIG Comfort Stop function activated
    (1)
    Gas pre-flow
    (2)
    Gas post-flow
    DownSlope:
    The DownSlope time tdown is 0.5 seconds and cannot be adjusted.
    Gas post-flow:
    The gas post-flow must be carried out manually.
    1Use the Welding Process button to select the process whose Setup parameters are to be changed:
    • MMA welding
    • TIG welding
    2Press the Setting Value and Welding Process buttons at the same time
    • The code for the first parameter in the Setup menu is displayed on the control panel
    1. Welding process Setup menu
    • MMA welding
    • TIG welding
    1Turn the adjusting dial to select the desired parameter
    2Press the adjusting dial to display the set value of the parameter
    3Press the adjusting dial to change the value
    The set value is immediately active.Exception:
    When resetting to the factory settings, the adjusting dial needs to be pressed after changing the value in order to activate the change.
    4Press the adjusting dial to go back to the list of parameters
    1Press the Setting Value or Welding Process button to exit the Setup menu
    Parameter
    Description
    Range
    Unit
    Starting current duration
    For the SoftStart / HotStart function
    Factory setting: 0.5 seconds
    0.1 - 2.0
    Seconds
    Anti-stick
    When the anti-stick function is active, the arc is extinguished after 1.5 seconds in the event of a short circuit (sticking of the electrode)
    Factory setting: ON (activated)
    On
    OFF
    Start ramp
    To activate/deactivate grinding mode
    On
    OFF
    Break voltage (Voltage cut off)
    Used to specify at which arc length the welding process is to be completed.
    The welding voltage increases as the length of the arc increases. The arc is extinguished when it reaches the voltage specified here
    Factory setting: 45 volts
    25 - 90
    Volts
    Factory setting (FACtory)
    This can be used to reset the device to its factory settings
    • cancel reset
    no
    • reset the parameters for the selected welding process to their factory settings
    YES
    • reset the parameters for all welding processes to their factory settings
    ALL
    Resetting of the selected value to its factory setting must be confirmed by pressing the adjusting dial.
    Level 2 Setup menu
    To set general welding parameters
    For details, see the "Level 2 Setup menu" section
    Parameter
    Description
    Range
    Unit
    Comfort Stop Sensitivity
    Factory setting on Ignis: 1.5 volts
    Factory setting on Ignis 180: 1.5 volts
    Factory setting: 35 V (for 2-step mode, 4-step mode and pedal remote control)
    For details, see the TIG Comfort Stop section starting at page (→)
    OFF
    0.6 - 3.5
    Volts
    Factory setting: 25 V (for the trigger = oFF mode)
    10 - 45
    Volts
    • cancel reset
    no
    YES
    ALL
    Level 2 Setup menu
    Parameter
    Description
    Range
    Unit
    Software version
    The full version number of the currently installed software is spread across a number of displays and can be retrieved by turning the adjusting dial.
    Automatic switch-off (time Shut down)
    If the device is not used or operated for a specified period of time, it automatically switches itself into Standby mode
    Pressing any button on the control panel will cancel Standby mode and the device will be ready to resume welding
    Factory setting: OFF
    5 - 60
    OFF
    Minutes
    Fuse
    For displaying/setting the fuse used
    Factory setting:
    • for mains voltage 230 V = 16 A
    • for mains voltage 120 V = 20 A
    If a fuse is set on the welding system, the welding system limits the power drawn from the mains. This prevents the automatic circuit breaker from tripping immediately
    At
    230 V:
    10 / 13 / 16 / OFF (Ignis 180 XT only)
    At
    120 V:
    15 / 16 / 20 / OFF (Ignis 180 XT only)
    Ampere
    Ignis 150 - Ratio between set fuse and welding current:
    Mains voltage
    Set
    fuse
    Welding current electrode
    TIG
    welding current
    Duty cycle
    230 V
    10 A
    110 A
    150 A
    35%
    13 A
    130 A
    150 A
    35%
    16 A
    150 A
    150 A
    35%
    Ignis 180 - Ratio between set fuse and welding current:
    Mains voltage
    Set fuse
    TIG
    welding current
    Duty cycle
    230 V
    10 A
    125 A
    180 A
    40%
    13 A
    150 A
    200 A
    40%
    16 A
    180 A
    220 A
    40%
    180 A
    220 A
    40%
    120 V*
    15 A
    85 A
    130 A
    40%
    16 A
    95 A
    140 A
    40%
    20 A (Ignis 180 XT only)
    120 A
    170 A
    40%
    120 A
    170 A
    40%
    * Depending on the triggering characteristic of the automatic circuit breaker, the full duty cycle of 40% cannot be achieved on 120 V grids (e.g. USA circuit breaker type CH ̴15% D.C.)
    Parameter
    Description
    Range
    Unit
    Operating time (System on time)
    For displaying the operating time (begins to count as soon as the device is switched on)
    The full operating time is spread across a number of displays and can be retrieved by turning the adjusting dial
    Hours, minutes, seconds
    Welding time (System Active time)
    For displaying how long the system has been active for (only shows the time during which welding was in progress)
    The full system active time is spread across a number of displays and can be retrieved by turning the adjusting dial
    1. Setup menu - Level 2
    Parameter
    Description
    Range
    Unit
    Software version
    5 - 60
    OFF
    Minutes
    Fuse
    Factory setting:
    At
    230 V:
    At
    120 V:
    Ampere
    Mains voltage
    Set
    fuse
    TIG
    welding current
    Duty cycle
    230 V
    10 A
    110 A
    150 A
    35%
    13 A
    130 A
    150 A
    35%
    16 A
    150 A
    150 A
    35%
    Mains voltage
    Set fuse
    TIG
    welding current
    Duty cycle
    230 V
    10 A
    125 A
    180 A
    40%
    13 A
    150 A
    200 A
    40%
    16 A
    180 A
    220 A
    40%
    180 A
    220 A
    40%
    120 V*
    15 A
    85 A
    130 A
    40%
    16 A
    95 A
    140 A
    40%
    120 A
    170 A
    40%
    120 A
    170 A
    40%
    Parameter
    Description
    Range
    Unit
    Safety
    WARNING!
    WARNING!
    Danger from electric current.
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    CAUTION!
    Danger from inadequate ground conductor connections.
    The housing screws provide a suitable ground conductor connection for earthing the housing.
    The housing screws must never be replaced with different screws unless a reliable ground conductor connection is established.
    1. Care, maintenance and disposal
    Safety
    WARNING!
    WARNING!
    CAUTION!
    General
    Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the device remains in a usable condition for many years.
    • Ensure that the mains plug and mains cable as well as the welding torch / electrode holder are undamaged. Replace any damaged components.
    • Make sure that the welding torch / electrode holder and the grounding cable are properly connected to the welding system and screwed / locked as described in this document
    • Ensure that a proper ground earth connection has been established to the workpiece.
    • Check that there is an all-round clearance of 0.5 m (1 ft 8 in.) around the device to ensure that cooling air can flow in and out freely. Air inlets and outlets must never be covered, not even partially.
    Clean air filter:
    Disposal
    Troubleshooting
    Safety
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    Safety
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    Indicated errors
    Overtemperature
    "hot" appears on the display, the temperature indicator lights up
    Cause:Operating temperature too high
    Remedy:Allow device to cool (do not switch off the device - the fan will cool it down)
    1. Troubleshooting
    Service messages
    When E and a 2-digit error number appear on the display (e.g. E02) and the ‘Error’ indicator lights up, this is an internal welding system source service code.
    Example:
    It is also possible that several error numbers are present. These appear when turning the adjusting dial.
    Make a note of the error numbers shown on the display, and of the serial number and configuration of the welding system, and contact our after-sales service team with a detailed description of the error.
    Err | 001 -003, Err | 011, Err | 015, Err | 021, Err | 033 - 035, Err | 037 - 040,
    Err| 042 -044, Err | 046 - 052
    Cause:Fault in power module
    Remedy:Contact After-Sales Service
    Err | 004
    Cause:Open circuit voltage is not being reached:
    electrode in contact with workpiece / hardware fault
    Remedy:Remove electrode holder from workpiece. If the service code continues to be displayed, contact after-sales service
    Err | 005, Err | 006, Err | 012
    Cause:System start-up failed
    Remedy:Switch device off and on again. Contact after-sales service if a repeated occurrence
    Err | 010
    Cause:Overvoltage at the current socket (> 113 VDC)
    Remedy:Contact after-sales service
    Err | 016, Err | 017
    Cause:Memory fault
    Remedy:Contact After-Sales Service / Press adjusting dial to acknowledge the service message
    NOTE!
    On standard variants of the device, acknowledging the service message has no effect on the availability of welding system functions.
    On all other variants (TIG, etc.), only a restricted range of functions is available after acknowledging the message. Contact After-Sales Service to have the full functionality restored.
    Err | 019
    Cause:Overtemperature or undertemperature
    Remedy:Operate the device in permitted ambient temperatures. For more details on environmental conditions, see "Environmental conditions" in the "Safety rules" section
    Err | 020
    Cause:Improper use of the device
    Remedy:Only use the device for its intended purpose
    Err | 022
    Cause:Welding current set too high
    Remedy:Ensure that the welding system is being operated on the correct mains voltage; ensure that the correct fuse is set; set a lower welding current
    Err | 037
    Cause:Mains voltage too high
    Remedy:Pull out the mains plug immediately; ensure that the welding system is being operated on the correct mains voltage
    Err | 036, Err | 041, Err | 045
    Cause:Mains voltage outside tolerance or maximum load of grid is too low
    Err | 065 - 075
    Cause:Communication error with the display
    Remedy:Switch device off and on again / contact after-sales service if a repeated occurrence
    1. Troubleshooting
    No function
    The device cannot be switched on
    Cause:Mains switch is faulty
    No welding current
    Welding system is switched on, indicator for the selected welding process is lit
    Cause:Welding power-lead connections have been disconnected
    Remedy:Establish proper welding power-lead connections
    Cause:Poor or no earth
    Remedy:Establish a connection to the workpiece
    Cause:There is a break in the power cable in the welding torch or electrode holder
    Remedy:Replace welding torch or electrode holder
    No welding current
    Device switched on, indicator for the selected welding process is lit, overtemperature indicator lit
    Cause:Duty cycle exceeded - device overloaded - fan running
    Remedy:Keep within duty cycle
    Cause:Thermostatic automatic circuit breaker has switched off the device
    Remedy:Wait until the welding system comes back on automatically at the end of the cooling phase (do not switch off the device - the fan will cool it down)
    Cause:Faulty fan in welding system
    Cause:Insufficient cooling air intake
    Remedy:Ensure adequate air supply
    Cause:Air filter is dirty
    Remedy:clean air filter
    Cause:Power module error
    Remedy:Turn off the device, then turn it on again.
    If the error occurs frequently, contact After-Sales Service.
    1. Troubleshooting
    Faulty operation
    Poor ignition properties during manual metal arc welding
    Cause:Incorrect welding process selected
    Remedy:Select "manual metal arc welding" or "manual metal arc welding with Cel electrode" process
    Cause:Starting current too low; electrode sticking during ignition
    Remedy:Increase starting current
    Cause:Starting current too high; electrode consumed too quickly during ignition or is generating a lot of spatter
    Remedy:Reduce starting current
    In some cases, arc breaks during welding
    Cause:Break voltage (Uco) set too low
    Remedy:Increase break voltage (Uco) in Setup menu
    Cause:Electrode (e.g. grooved electrode) voltage too high
    Remedy:If possible, use an alternative electrode or a power source with more welding power
    Rod electrode tends to stick
    Cause:Value of arc-force dynamic parameter (MMA welding) set too low
    Remedy:Increase value of arc-force dynamic parameter
    Poor weld properties
    (severe spattering)
    Cause:Incorrect electrode polarity
    Remedy:Reverse electrode polarity (refer to manufacturer's instructions)
    Cause:Poor grounding (earthing) connection
    Remedy:Fasten earthing clamps directly to workpiece
    Cause:Setup parameters not ideal for selected welding process
    Remedy:Select the optimal settings in the Setup menu for the selected welding process
    Tungsten electrode melting
    Tungsten inclusions in base metal during the ignition phase
    Cause:Incorrect tungsten electrode polarity
    Remedy:Connect the TIG welding torch to the (-) current socket
    Cause:Incorrect (or no) shielding gas
    Remedy:Use inert shielding gas (argon)
    Average wire electrode consumption at a wire speed of 5 m/min
    Wire electrode diameter
    1.0 mm
    1.2 mm
    1.6 mm
    Steel wire electrode
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    Aluminium wire electrode
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    Average wire electrode consumption at a wire speed of 10 m/min
    1.0 mm
    1.2 mm
    1.6 mm
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Average consumption values
    1.0 mm
    1.2 mm
    1.6 mm
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    1.0 mm
    1.2 mm
    1.6 mm
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1.0 mm
    1.2 mm
    1.6 mm
    2.0 mm
    2 x 1.2 mm (TWIN)
    Average consumption
    10 l/min
    12 l/min
    16 l/min
    20 l/min
    24 l/min
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    Technical data
    Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
    The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
    If the ambient temperature is higher, either the ED or output must be reduced accordingly.
    Example: Welding at 150 A at 60% ED
    • Welding phase = 60% of 10 minutes = 6 minutes
    • Cooling phase = remaining time = 4 minutes
    • After the cooling phase, the cycle begins again.
    If the device is to be continuously operated without stopping:
    1Look in the technical data for a ED value of 100% for the current ambient temperature.
    2Reduce the output or amperage in line with this value so that the device can remain in use without observing a cooling phase.
    1. Technical data
    1. Technical data
    Ignis 150
    Mains voltage (U1)
    1 x 230 V
    Max. effective primary current (I1eff)
    15 A
    Max. primary current (I1max)
    24 A
    Max. apparent power (S1max)
    5.52 kVA
    Mains fuse
    16 A slow-blow
    Mains voltage tolerance
    -20% / +15%
    Grid frequency
    50/60 Hz
    Cos phi
    0.99
    Max. permitted mains impedance Zmax at PCC1)
    32 mOhm
    Recommended residual current circuit breaker
    Type B
    Welding current range (I2) rod electrode
    10-150 A
    Welding current range (I2) TIG
    10-150 A
    Welding current for MMA welding 10 min / 40 °C (104 °F)
    35 %
    150 A
    60 %
    110 A
    100 %
    90 A
    Welding current for TIG welding 10 min / 40°C (104°F)
    35 %
    150 A
    60 %
    110 A
    100 %
    90 A
    Output voltage range according to standard characteristic (U2) rod electrode
    20.4-26.0 V
    Output voltage range according to standard characteristic (U2) TIG
    10.4-16.0 V
    Open circuit voltage (U0 peak)
    96 V
    Protection class
    IP 23
    Type of cooling
    AF
    Overvoltage category
    III
    Pollution degree according to IEC60664
    EMC emission class
    A
    Safety symbols
    S, CE
    Dimensions (length x width x height)
    365 x 130 x 285 mm
    14.4 x 5.1 x 11.2 in.
    Weight
    6.3 kg
    13.9 lb.
    Idle state power consumption
    at 230 V
    15 W
    Energy efficiency of the welding system at
    150 A / 26 V
    87%
    1)
    Interface to a 230/400 V and 50 Hz public grid
    1. Technical data
    Ignis 180
    link_horizontalLink copied
    Mains voltage (U1)
    1 x 230 V
    16 A
    25 A
    5.75 kVA
    Mains fuse
    16 A slow-blow
    -20% / +15%
    Grid frequency
    50/60 Hz
    Cos phi
    0.99
    285 mOhm
    Type B
    10-180 A
    10-220 A
    40 %
    180 A
    60 %
    150 A
    100 %
    120 A
    40 %
    220 A
    60 %
    150 A
    100 %
    120 A
    20.4-27.2 V
    10.4-18.8 V
    101 V
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC emission class
    A
    Safety symbols
    S, CE
    435 x 160 x 310 mm
    17.1 x 6.3 x 12.2 in.
    Weight
    8.7 kg
    19.3 lb.
    at 230 V
    15 W
    Welding system energy efficiency at
    180 A/27.2 V
    88%
    1)
    1. Technical data
    Ignis 180 XT
    Mains voltage (U1)
    1 x 230 V
    1 x 120 V
    1 x 120 V
    16 A
    20 A
    15 A
    25 A
    28 A
    19 A
    5.75 kVA
    3.48 kVA
    2.28 kVA
    Mains fuse
    16 A slow-blow
    20 A slow-blow
    15 A slow-blow
    -20% /+15%
    Grid frequency
    50/60 Hz
    Cos phi
    0.99
    285 mOhm
    Type B
    Rod electrode
    TIG
    10 - 180 A
    10 - 220 A
    10 - 120 A
    10 - 170 A
    10 - 85 A
    10 - 140 A
    Welding current for MMA welding,
    40%/180 A
    60%/150 A
    100%/120 A
    40%/120 A
    60%/100 A
    100%/90 A
    40%/85 A
    60%/70 A
    100%/65 A
    Welding current for TIG welding,
    40%/220 A
    60%/160 A
    100%/130 A
    40%/170 A
    60%/130 A
    100%/100 A
    40%/140 A
    60%/110 A
    100%/100 A
    Rod electrode
    TIG
    20.4 - 27.2 V
    10.4 - 18.8 V
    101 V
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC emission class
    A
    Safety symbols
    S, CE
    435 x 160 x 310 mm
    Weight excluding mains cable
    8.3 kg
    18.4 lb.
    Weight including mains cable
    8.9 kg
    19.6 lb.
    Idle state power consumption at 230 V
    15 W
    Welding system energy efficiency at 180 A/27.2 V
    88%
    1)
    1. Technical data
    China Energy Label
    1. Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address.
    Find downloads: critical
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    Part Name
    Hazardous Substances
    Lead
    (Pb)
    Mercury
    (Hg)
    Cadmium
    (Cd)
    hexavalent
    chromium
    (Cr (VI))
    polybrominated
    biphenyls
    (PBB)
    polybrominated
    diphenyl ethers
    (PBDE)
    diethylhexyl phthalate
    (DEHP)
    benzyl butyl phthalate
    (BBP)
    dibutyl phthalate
    (DBP)
    di-isobutyl phthalate
    (DOBP)
    Packaging
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Housing
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Metal Parts
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    PCB
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Cables and Cable Assemblies
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    This table is prepared in accordance with the provisions of SJ/T 11364.
    O
    Indicates that the hazardous substance contained in all of the homogeneous materials for this part is below the limit requirement of GB/T 26572.
    X
    Indicates that the hazardous substance contained in at least one of the homogeneous materials used for this part is above the limit requirement of GB/T 26572.
    All parts in this table marked with an "X" comply with the European Union's RoHS legislation.
