en
      Operating instructionsArtis 170 / 210
    • Safety Instructions
      • General
      • Intended use
      • Environmental Conditions
      • Obligations of the Operating Company
      • Obligations of personnel
      • Grid Connection
      • Residual current circuit breaker
      • Personal Protection and Protection of Others
      • Data on noise emission values
      • Danger from toxic gases and vapors
      • Danger from Flying Sparks
      • Risks from mains current and welding current
      • Stray welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF Safety Instructions
      • Particular hazard areas
      • Requirement for the shielding gas
      • Danger from Shielding Gas Cylinders
      • Danger Posed by Shielding Gas Leak
      • Safety Measures at the Setup Location and during Transport
      • Safety measures in normal operation
      • Maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
    • General information
      • General
        • Device concept
        • Operating principle
        • Application areas
        • Remote control operating mode
        • Notes on the device
        • Description of the warnings on the device
    • Operating controls and connections
      • Control Panel
        • General
        • Danger due to incorrect operation
        • Control panel
      • Connections, Switches, and Mechanical Components
        • Operating Controls, Connections, and Mechanical Components
    • Installation and Startup
      • Minimum equipment for welding operations
        • General
        • TIG DC welding
        • MMA welding
      • Before installation and initial operation
        • Intended use
        • Setup Regulations
        • Mains connection
        • Generator-powered operation
      • Connecting the Mains Cable
        • General
        • Safety
        • Connecting the mains cable
      • Commissioning
        • Safety
        • General
        • Connecting the Gas Cylinder
        • Connecting the welding torch to the welding system
        • Establishing a Ground Earth Connection with the Workpiece
        • Measuring the welding circuit resistance "r"
    • Welding Mode
      • TIG Operating Modes
        • Safety
        • Symbols and explanations
        • 2-Step Mode
        • 4-Step Mode
        • Spot Welding
      • TIG welding
        • Danger due to incorrect operation and electric current
        • Preparation
        • TIG welding
        • Welding parameters
      • Igniting the arc
        • Igniting the arc using high frequency
          (HF ignition)
        • Contact ignition for welding torches with torch trigger
        • Contact ignition for welding torches without torch trigger
        • Igniting the arc using high-frequency contact
          (Touch-HF)
        • Overloading of the tungsten electrode
        • End of Welding
      • Special functions
        • Arc break monitoring function
        • Ignition Time-Out
        • TIG pulsing
        • Tacking function
      • Manual Metal Arc Welding
        • Preparation
        • MMA welding
        • Manual Metal Arc Welding with Cel Electrodes
        • Pulse welding
        • Starting current > 100% (HotStart)
        • Starting current < 100%
          (SoftStart)
        • Anti-stick function
    • Setup Settings
      • The Setup Menu
        • General
        • Accessing the Setup Menu
        • Adjusting Parameters
        • Overview
      • TIG Setup Menu
        • Parameters in the TIG Setup menu
        • Parameters in the TIG - 2nd level Setup menu
        • Parameters in the 2nd level Setup menu
      • Rod Electrode Setup Menu
        • Parameters in the stick electrode Setup menu
    • Troubleshooting and Maintenance
      • Troubleshooting
        • General
        • Safety
        • Displayed Faults
        • Service messages
        • No Function
        • Inadequate function
      • Service, maintenance and disposal
        • General
        • Safety
        • At every start-up
        • Maintenance every two months
        • Disposal
    • Appendix
      • Average consumption values
        • Average shielding gas consumption during TIG welding
      • Technical data
        • Special Voltage
        • Artis 170 EF,
          Artis 170 np
        • Artis 170 XT/B,
          Artis 170 XT/np
        • Artis 210 EF,
          Artis 210 np
        • Artis 210 XT/B,
          Artis 210 XT/np
        • Explanation of footnotes
        • China Energy Label
        • Overview with critical raw materials, year of production of the device
    • 005-03112026
    Artis 170 / 210
    download
    Control panel
    Commissioning
    TIG welding
    Setup menu
    Technical data
    Spare parts
    ContactLegal NoticeGeneral Terms & ConditionsData Privacy StatementCookie Policy
    Safety Instructions
    link_horizontalLink copied
    Warnings are intended to warn people of possible injuries and to avoid personal injury and damage to the product. They relate to individual actions with and on the product.
    DANGER!
    Indicates an immediately dangerous situation.
    Serious injury or death will result if the danger is not avoided.
    Action step to escape the situation.
    WARNING!
    Serious injury or death may result if the danger is not avoided.
    CAUTION!
    Minor or moderate injury may result if the danger is not avoided.
    NOTE!
    Indicates a situation that may result in property damage.
    If the situation is not avoided, impaired work results, material damage to the product or other property are the possible consequences.
    Action step to avoid the situation.
    Safety instructions are designed to ensure safe product use. They are preventive and help to inform users about the fundamental risks involved when dealing with the product. They do not refer specifically to individual actions with and on the product.
    1. Safety Instructions
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    General
    The device has been manufactured using state-of-the-art technology and according to recognized safety standards. If used incorrectly or misused, however, it can cause
    • Injury or death to the operator or a third party
    • Damage to the device and other material assets belonging to the operating company
    • Inefficient operation of the equipment
    All persons involved in the commissioning, operation, maintenance, and servicing of the device must
    • Be suitably qualified
    • Have knowledge of welding
    • Have completely read and followed these Operating Instructions
    The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
    All safety and danger notices on the device must
    • Be kept in a legible state
    • Not be damaged/marked
    • Not be removed
    • Not be covered, pasted, or painted over
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
    Before switching on the device, remove any faults that could compromise safety.
    Intended use
    The external high-frequency device is intended exclusively to support the ignition of a TIG arc in combination with Fronius system components.
    The environmental conditions, safety instructions, and regulations of the welding machine shall apply.
    Any other use or use above and beyond this shall be deemed to be not in accordance with the intended use.
    Intended use also means:
    • Reading these operating instructions in their entirety
    • Following all the instructions and safety rules in these operating instructions
    • Observing the welding machine operating instructions
    • Carrying out all the specified inspection and maintenance work
    The device is designed for commercial and industrial use.
    Temperature range of the ambient air:
    • During operation: -10°C to +40°C (14°F to 104°F)
    • During transport and storage: -20°C to +55°C (-4°F to 131°F)
    Relative humidity:
    • Up to 50% at 40°C (104°F)
    • Up to 90% at 20°C (68°F)
    Ambient air: free of dust, acids, corrosive gases or substances, etc.
    Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
    The operating company must only allow persons to work with the device if they
    • Are familiar with the basic occupational safety and accident prevention regulations and are trained in handling the device
    • Have read and understood these Operating Instructions, especially the section "Safety Rules," and have confirmed this with their signature
    • Are trained according to the requirements for the work results
    The safety-conscious work of the personnel must be checked regularly.
    All persons who are instructed to work with the device must do the following before beginning work:
    • Follow the basic regulations for occupational safety and accident prevention
    • Read these operating instructions, especially the section "Safety rules", and confirm with their signature that they have understood and will follow them
    Before leaving the workplace, ensure that no personal injury or property damage can occur in their absence.
    Grid Connection
    Devices with a high output can influence the energy quality of the grid due to their current consumption.
    This may affect a number of device types in terms of:
    • connection restrictions
    • criteria regarding maximum permissible grid impedance *)
    • criteria regarding the minimum required short-circuit power *)
    *) both at the interface with the public grid
    See technical data
    In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
    IMPORTANT! Ensure secure grounding of the grid connection!
    Local regulations and national guidelines may mean that a residual current circuit breaker is required when connecting a device to the public grid.
    The residual current circuit breaker recommended for the device by the manufacturer can be found in the technical data.
    You are exposed to numerous hazards while handling the device, for example:
    • Flying sparks and pieces of hot metal
    • Arc radiation that poses a risk of injury to the eyes and skin
    • Hazardous electromagnetic fields that pose a risk of death for individuals with pacemakers
    • Electrical risks from grid current and welding current
    • Increased noise exposure - the sound level may exceed 85 dB
    • Harmful welding fumes and gases
    Wear suitable protective clothing when dealing with the device. The protective clothing must have the following properties:
    • Flame resistant
    • Insulating and dry
    • Covering the entire body and in good condition with no damage
    • Safety helmet
    • Cuffless pants
    Protective clothing involves the following:
    • Protecting the face and eyes from UV radiation, heat and flying sparks with a face guard featuring a regulation-compliant filter
    • Wearing regulation-compliant protective goggles with side protection behind the face guard
    • Wearing rigid, wet-insulating footwear
    • Protecting hands with appropriate gloves (featuring electrical insulation and thermal protection)
    • Wearing ear protection to reduce noise exposure and protect against injury
    Keep persons, especially children, away during the operation of the devices and during the welding process. If persons are in the vicinity, however:
    • Instruct them about all hazards (blinding hazard due to arcs, risk of injury from flying sparks, welding fumes hazardous to health, noise exposure, possible hazard due to grid current or welding current, etc.)
    • Provide suitable protective equipment or
    • Construct suitable protective walls and curtains.
    When idling and in the cooling phase following operation, the machine produces a maximum sound power level of <80 dB(A) (ref. 1 pW) corresponding to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
    A workplace-related sound emission value depends on various parameters, such as:
    • The welding or work process (MIG/MAG, TIG, plasma, HAP),
    • The selected current type (AC, DC),
    • The power range,
    • The type of weld metal or workpiece,
    • The resonance properties of the workpiece,
    • The workplace environment.
    • and others.
    A workplace-related sound level measurement is recommended.
    The fumes produced during welding contain toxic gases and vapors.
    Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
    Use at-source extraction source and a room extraction system.
    If possible, use a welding torch with an integrated extraction device.
    Keep your head out of the welding fumes and gases.
    Take the following precautionary measures for fumes and harmful gases:
    • Do not breathe them in.
    • Extract them from the work area using appropriate equipment.
    Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
    Use a welding helmet with air supply if there is insufficient ventilation.
    If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
    The following components are factors that determine how toxic the welding fumes are:
    • The metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaning agents, degreasers, and the like
    • The welding process used
    Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
    Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
    When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
    Flying sparks can cause fires and explosions.
    Never undertake welding near flammable materials.
    Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
    Keep suitable, tested fire extinguishers on hand.
    Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
    Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
    Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
    Do not touch voltage-carrying parts inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
    Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
    Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
    All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Before every use, check power connections for secure fit by hand.
    In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
    Do not wrap cables or leads around your body or parts of the body.
    Concerning the electrode (stick electrode, tungsten electrode, welding wire, etc.)
    • Never immerse it in liquids to cool it
    • Never touch it when the welding system is switched on
    The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
    Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
    Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
    Switch off unused devices.
    When working at elevated heights, wear a safety harness to prevent falls.
    Before working on the device, switch off the device and remove the mains plug.
    Secure the device to prevent the mains plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
    After opening the device:
    • Discharge all electrically charged components
    • Ensure that all components are disconnected from the power supply
    If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
    If the following instructions are not observed, stray welding currents may occur, which pose a risk of the following:
    • Fire
    • Overheating of parts connected to the workpiece
    • Irreparable damage to ground conductors
    • Damage to the device and other electrical equipment
    Ensure that the workpiece clamp is securely connected to the workpiece.
    Secure the workpiece clamp as close to the spot to be welded as possible.
    Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
    Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
    In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage grid.
    EMC measures
    In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
    Test and assess the immunity of equipment in the vicinity of the device in accordance with national and international provisions. Examples of interference-prone equipment that could be affected by the device:
    • Safety devices
    • Grid power lines, signal lines, and data transfer lines
    • IT and telecommunications equipment
    • Devices for measuring and calibrating
    Supporting measures to avoid EMC problems:
    1. Grid power supply
      • If electromagnetic interference occurs despite a grid connection that complies with regulations, take additional measures (e.g., use a suitable grid filter).
    2. Welding power-leads
      • Keep them as short as possible
      • Route them close together (also to avoid EMF problems)
      • Route them far from other lines
    3. Equipotential bonding
    4. Workpiece grounding
      • If necessary, establish grounding using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices in the vicinity
      • Shield the entire welding installation
    General information
    During operation, high electrical voltages and currents give rise to localized electromagnetic fields (EMFs). Electromagnetic fields occur:
    • Around the welding circuit
    • In the vicinity of the welding system
    The applicable limit values for human exposure are met when the product is used for its intended use and in compliance with the applicable occupational safety regulations. Based on current scientific knowledge, no adverse health effects are expected provided these limit values are observed.
    In the welding shop
    Due to potential health risks, be mindful of and instruct people in the vicinity—even if they are separated by walls—as well as visitors.
    Due to potential health risks, the following individuals should consult their doctor before staying near welding systems:
    • People who wear prosthetics and jewelry, e.g., implants and metal parts in and on the body
    • People who use active medical devices, such as pacemakers, insulin pumps, hearing aids, etc.
    Avoid large-area current loops caused by the welding power-lead and the hose pack:
    • Bundle the return lead cable and the welding power-lead or hose pack together and secure them with tape.
    • Both cables must run on the same side of the body.
    • Connect the grounding cable as close as possible to the area of the workpiece being welded.
    Keep as much distance as possible from the welding power-leads and hose packs:
    • Do not work or linger in the immediate vicinity of the welding machine.
    • Do not move the welding machine around while it is in operation.
    • Do not route the return lead cable, welding power-leads, or hose pack directly against your body.
    • Do not drape the return lead cable, welding power-leads, or hose pack over your shoulder or across your thighs.
    • Do not wrap the return lead cable, welding power-leads, or hose pack around your arm or body.
    Additional Information and Recommendations
    Further information and recommendations can be found, among others, in standard EN IEC 60974‑9:2018.
    The EMF data sheets for welding machines are available athttps://www.fronius.com/en/download-centerfor download.
    Further information on EMFs and information for people with implants can be found on our website athttps://www.fronius.com/en/welding/know-how/welding-protection
    For information on occupational safety during welding, click Download the Health & Safety brochure now. The relevant state-level authorities and agencies responsible for worker protection also provide the locally applicable regulations on their websites.
    Keep hands, hair, loose clothing, and tools away from moving parts, such as:
    • Fans
    • Gears
    • Rollers
    • Shafts
    • Wire spools and welding wires
    Do not reach into rotating gears of the wire drive or into rotating drive parts.
    Covers and side panels must only be opened/removed during maintenance and repair work.
    During operation
    • Ensure that all covers are closed, and all side parts have been mounted properly.
    • Keep all covers and side parts closed.
    The protrusion of welding wire from the welding torch represents a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
    Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
    Do not touch the workpiece during or after welding – risk of burns.
    Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
    Leave the welding torch and other parts with a high operating temperature to cool before working on them.
    Special regulations apply in areas at risk of fire or explosion
    – follow the appropriate national and international regulations.
    Welding systems for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the welding system may not be located in such areas.
    Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
    When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
    In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    If the device is equipped with a carrier belt or handle, then this is used exclusively for transport by hand. The carrier belt is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
    All lifting equipment (belts, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
    The test interval and scope must at least comply with the respective valid national standards and guidelines.
    There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
    Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
    Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
    Keep shielding gas cylinders away from welding or other electrical circuits.
    Risk of explosion: Never weld on a compressed shielding gas cylinder.
    Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
    If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
    When no welding is taking place, close the valve of the shielding gas cylinder.
    Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
    Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
    Risk of asphyxiation due to uncontrolled shielding gas leak
    Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
    • Ensure there is a sufficient supply of fresh air with a ventilation flow rate of at least 20 m³ per hour.
    • Please observe the safety and maintenance information for the shielding gas cylinder or the main gas supply.
    • When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
    • Always check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before each start-up.
    A toppling device can be deadly! Set up the device securely on an even, solid surface
    • The maximum permitted tilt angle is 10°.
    • Follow the appropriate national and international regulations.
    Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
    Only set up and operate the device in accordance with the protection class shown on the rating plate.
    When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
    Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
    Do not lift or transport any active devices. Switch off and disconnect devices from the grid before transport or lifting.
    It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a danger of:
    • Serious or fatal injury to the operator or third parties
    • Inefficient operation of the device
    Safety devices that are not fully functional must be repaired before the device is switched on.
    Before switching on the device, ensure that no one can be put in danger.
    The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
    Always secure the shielding gas cylinder well and remove before transporting by crane.
    Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.).
    Only use appropriate original coolant from the manufacturer.
    Do not mix original coolant from the manufacturer with other coolants.
    Only connect system components from the manufacturer to the cooling circuit.
    Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
    Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from the service center or via the manufacturer's website.
    When the system is cool, always check the coolant level before starting welding.
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
    The manufacturer recommends calibrating welding machines within the same 12-month interval.
    A safety inspection by a qualified electrician is recommended
    • After alterations
    • After repair, service, and maintenance
    When performing the safety inspection, follow the appropriate national and international standards and guidelines.
    You can obtain more information about the safety inspection and calibration from the Fronius branch or the Fronius Service Partner.
    Disposal
    In accordance with the EU Directive and national law, the following products must be disposed of separately and recycled:
    • Waste electrical and electronic equipment
    • Used batteries (portable batteries, industrial batteries)
    Used equipment and batteries must be returned to the distributor or an authorized local collection system. Do not dispose of batteries with domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
    Arrange for the safe collection and proper disposal of damaged, leaking or used batteries by a battery recycling company or the Fronius Service Partner.
    In addition, it should be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances such as heavy metals or electrolytes, which can contaminate soil, water and air.
    This ensures environmental protection and the sustainable use of natural resources.
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Compress the cardboard box to reduce volume
    Safety symbols
    Devices with the CE label meet the requirements of all valid EU Directives, such as:
    • Directive 2014/30/EU on electromagnetic compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • and others
    The full text of the EU Declaration of Conformity is available at
    https://www.fronius.com .
    Devices bearing the CSA label satisfy the requirements of the relevant standards for Canada and the USA.
    Data security
    • saving and storing personal settings.
    Copyright
    General information
    General
    Device concept
    The Artis 170 and Artis 210 TIG welding systems are microprocessor-controlled inverter welding machines.
    A modular design and easy ability to extend the system guarantee a high degree of flexibility.
    The welding systems are generator-compatible and are equipped with protected operating elements and a robust plastic housing.
    As a result of the simple operating concept, key functions can be quickly viewed and adjusted.
    The welding systems can also be operated via the standard TIG Multi Connector with various remote controls or an Up/Down torch.
    The TIG pulsed arc function means that the welding systems offer a wide frequency range.
    Additionally, the welding systems offer "Power Factor Correction", meaning the current consumption of the welding system adapts to the sinusoidal mains voltage. This results in advantages such as:
    • Low primary current
    • Low conductivity losses
    • Late tripping of the automatic circuit breaker
    • Improved stability during voltage fluctuations
    • Compatibility with long mains leads
    • Consistent input voltage range with multivoltage devices
    1. General information
    General
    Device concept
    2. General
    Device concept
    2. General
    Operating principle
    The central control unit of the welding system controls the entire welding process.
    During the welding process, actual values are continually measured and the device immediately responds to any changes. Rule algorithms ensure that the desired target state is maintained.
    This results in:
    • A precise welding process
    • A high degree of reproducibility of all results
    • Excellent weld properties
    2. General
    Application areas
    The welding systems can be used in repair and maintenance for production and manufacturing tasks.
    2. General
    The Artis 170 and Artis 210 welding systems can be operated using the following remote controls:
    • RC Bar 1P
    • RC Panel MMA
    • RC Pedal TIG
    • RC Panel Basic TIG
    2. General
    Notes on the device
    A rating plate and different safety symbols for the specific model are attached to the device.
    The safety symbols indicate hazards during welding, which, if not observed, can lead to serious injury and damage to property.
    Rating plate and safety symbols:
    • Must be kept in a legible state
    • Must not be damaged
    • Must not be removed
    • Must not be covered, have anything stuck on them, or painted over
    Safety symbols on the rating plate:
    Welding is dangerous. The following basic requirements must be met:
    • Adequate welding qualifications
    • Appropriate protective equipment
    • Exclusion of unauthorized persons
    • These operating instructions
    • All system component operating instructions, especially the safety rules
    2. General
    Warning notices are attached to the device for certain device versions.
    The arrangement of the symbols may vary.
    1.
    1.1
    Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves.
    1.2
    Use a base that is insulated from the floor and work area to protect against electric shock.
    1.3
    Before working on the device, switch off the device and remove the mains plug or disconnect the power supply.
    2.
    Inhalation of welding fumes can be harmful to health.
    2.1
    Keep your face away from any welding fumes.
    2.2
    Use forced-air ventilation or local extraction to remove welding fumes.
    2.3
    Remove welding fumes with a fan.
    3.
    Welding sparks can cause an explosion or fire.
    3.1
    Keep flammable materials away from the welding process. Do not perform welding near flammable materials.
    3.2
    Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher.
    3.3
    Do not weld on drums or closed containers.
    4.
    Arc rays can burn the eyes and injure the skin.
    4.1
    Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body.
    5.
    Before working on the machine or welding:
    undertake training on the device and read the instructions!
    6.
    Do not remove or paint over the sticker with the warnings.
    Manufacturer order number of the sticker
    Control Panel
    General
    NOTE!
    Because of software updates, certain functions may be available for your device but not described in these Operating Instructions or vice versa.
    In addition, individual figures may also differ slightly from the operating elements of your device. These operating elements function in exactly the same way, however.
    1. Operating controls and connections
    Control Panel
    General
    NOTE!
    2. Control Panel
    General
    NOTE!
    2. Control Panel
    WARNING!
    Danger due to incorrect operation and work not carried out correctly.
    This may result in serious personal injury and damage to property.
    All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
    Read and understand all safety rules and user documentation for this equipment and all system components.
    2. Control Panel
    Control panel
    ItemName
    (1)
    Special indicators
    HF ignition indicator (high frequency ignition)
    Illuminates when the "IGn" setup parameter has been set to "on"
    Tacking indicator
    Illuminates when the "tAC" setup parameter has been set to a period of time
    Pulsing indicator
    Illuminates when the "F-P" setup parameter has been set to a pulse frequency
    Spot welding indicator
    Illuminates when the "SPt" setup parameter has been set to a spot welding time
    (2)
    Special indicators
    Remote control indicator
    Illuminates when a foot-operated remote control is connected
    Electrode overloaded indicator
    Illuminates when the tungsten electrode is overloaded
    Further information related to the "electrode overloaded" indicator can be found in the "TIG welding" section of the "Welding mode" chapter
    CEL indicator
    Illuminates when the "CEL" setup parameter has been set to "on"
    Trigger indicator
    Illuminates when the "tri" setup parameter has been set to "off"
    (3)
    Welding current display
    To display the welding current for the parameters:
    • Starting current IS
    • Welding current I1
    • Lowering current I2
    • Final current IE
    Before the start of welding, the left digital display shows the set value. For IS, I2, and IE, the right digital display also indicates the % amount of the welding current I1.
    After the start of welding, the left digital display shows the current actual value of the welding current.
    The relevant parameters in the welding process are shown by the illuminated segment in the welding parameter overview (10)
    (4)
    Left digital display
    (5)
    HOLD indicator
    At the end of welding, the current actual values for the welding current and welding voltage are saved - the "hold" indicator illuminates.
    The "hold" indicator relates to the last main current I1 to be reached. Any further interaction with the welding system will cause the "hold" indicator to go out.
    IMPORTANT! No hold values are output if the main current phase has never been reached.
    (6)
    Right digital display
    (7)
    Welding voltage indicator
    Illuminates when parameter "I1" is selected.
    During welding, the current actual value of the welding voltage is shown on the right digital display.
    Before welding, the right digital display shows:
    • 0.0 for selected TIG welding operating modes
    • Current value of the open circuit voltage if the setup parameter "tri" is set to "off" or if the manual metal arc welding mode is selected (after a delay of 3 seconds; 93 V is approximately the average value of the pulsed open circuit voltage)
    (8)
    Unit indicators
    s indicator
    Illuminates if the parameters "tup" and "tdown" have been selected, as well as the following setup parameters:
    GPr | GPo | SPt | tAC | t-S | t-E | Hti | Ito | ArC | St1 | St2 | SPb
    Hz indicator
    Illuminates:
    When a value for the pulse frequency has been set for the "F-P" setup parameter
    If the "F-P" setup parameter is selected.
    % indicator
    Illuminates when parameters "IS", "I2", and "IE" have been selected, as well as the setup parameters "dcY", "I‑G", and "HCU"
    mm indicator
    Illuminates when the "ELd" setup parameter is set
    (9)
    "Mode" button
    For selecting the operating mode
    2-step mode
    4-step mode
    MMA welding
    When an operating mode is selected, the corresponding LED lights up.
    If the "Trigger" parameter is set to "oFF" in the Setup menu or a foot-operated remote control is connected, the 2T and 4T LEDs light up at the same time.
    (10)
    Welding parameter overview
    The welding parameter overview contains the most important welding parameters for the welding operation. The welding parameter sequence is depicted by a "washing line" structure. Navigation within the welding parameter overview is carried out by turning the dial.
    The welding parameter overview contains the following welding parameters:
    Starting current IS
    For TIG welding
    UpSlope tup
    Period of time it takes to rise from the starting current IS to the specified main current I1 during TIG welding
    t-u for the UpSlope is displayed on the left digital display.
    IMPORTANT! The UpSlope tup is saved separately for the following operating modes:
    • 2-step mode
    • 4-step mode
    • When the "Trigger" setup parameter is set to "oFF"
    • When a foot-operated remote control has been connected
    Main current (welding current) I1
    • For TIG welding
    • For manual metal arc welding
    Lowering current I2
    For TIG 4-step mode
    DownSlope tdown
    Period of time it takes to fall from the specified main current I1 to the final current IE during TIG welding
    t-d for the DownSlope is displayed on the left digital display.
    IMPORTANT! The DownSlope tdown is saved separately for the following operating modes:
    • 2-step mode
    • 4-step mode
    Final current IE
    For TIG welding
    Pulses *)
    Pulse frequency for TIG welding
    Tacking *)
    Duration of the pulsed welding current
    The pulsing and tacking parameters are only displayed if the setup parameter "Ptd - pulse TAC display" is set to "on".
    (11)
    Dial with rotary/push button function
    For selecting elements, setting values, and scrolling through lists
    (12)
    Gas-test button
    For setting the required shielding gas volume on the gas pressure regulator
    When the gas-test button is pressed, shielding gas will flow for 30 s. Press the button again or start welding to stop the gas flow prematurely.
    (1)
    Control panel
    (2)
    (-) Current socket with integrated gas connection
    For connecting:
    the TIG welding torch
    the electrode cable during manual metal arc welding
    (3)
    TMC connection (TIG Multi Connector)
    For connecting the control plug of the TIG welding torch
    For connecting foot remote controls
    For connecting remote controls for manual metal arc welding
    (4)
    (+) Current socket with bayonet latch
    Connect the grounding cable here
    (5)
    Carry strap
    (6)
    Cable strap
    To hold the mains cable and the welding power-leads
    IMPORTANT! Do not use the cable strap to transport the device!
    (7)
    Mains switch
    (8)
    Mains cable with strain relief
    For MV devices: mains cable to plug in
    (see "Connecting the Mains Cable" on page (→))
    (9)
    Air filter
    (10)
    Shielding gas connection socket
    2. Connections, Switches, and Mechanical Components
    (1)
    Control panel
    (2)
    For connecting:
    (3)
    (4)
    (5)
    Carry strap
    (6)
    Cable strap
    (7)
    Mains switch
    (8)
    (9)
    Air filter
    (10)
    General
    Depending on the welding process, a minimum level of equipment is required to work with the welding system.
    The following describes the welding processes and the corresponding minimum equipment for welding operations.
    1. Installation and Startup
    General
    2. Minimum equipment for welding operations
    General
    TIG DC welding
    • Welding system
    • Return lead cable
    • TIG welding torch with or without rocker switch
    • Gas connection (shielding gas supply)
    • Filler metal depending on application
    MMA welding
    • Welding system
    • Return lead cable
    • Electrode holder
    • Stick electrodes, depending on application
    WARNING!
    2. Before installation and initial operation
    WARNING!
    Intended use
    The welding system is intended exclusively for TIG welding and manual metal arc welding.
    Any other use does not constitute proper use.
    • Following all the instructions in these Operating Instructions
    Setup Regulations
    WARNING!
    Danger due to devices or welding systems toppling over.
    Set up the device securely on an even, solid surface.
    The maximum permissible tilt angle is 10°.
    Check all screw connections are tightly fastened after installation.
    WARNING!
    Danger from areas at risk of fire and explosion as well as from areas with increased electrical risk.
    Observe national and international regulations for areas at risk of fire and explosion.
    Observe national and international regulations for areas with increased electrical risk.
    CAUTION!
    Danger due to inappropriate selection of the installation location.
    The ambient air must be free from dust, acids, corrosive gases or substances and similar.
    Do not install and operate the device over 2000 m (6561 ft.) 8.16 in.) above sea level.
    The device is tested to IP23 protection, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12.5 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° to the vertical
    The device can be set up and operated outdoors in accordance with protection class IP23.
    Avoid direct wetting (e.g. from rain).
    The venting duct is a very important safety device. When choosing the installation location, ensure that the cooling air can enter and exit unhindered through the air ducts on the front and back of the machine. Electroconductive metallic dust must not be allowed to get sucked directly into the device (e.g. from grinding work).
    Mains connection
    • The devices are designed for the mains voltage specified on the rating plate.
    • If your version of the appliance does not come with mains cables and mains plugs ready-fitted, these must be fitted by a qualified person in accordance with national standards.
    • The fuse protection for the mains lead is indicated in the technical data.
    WARNING!
    Risk of electric shock due to inadequate mains connection.
    This can result in serious injury and death.
    Only connect the device to a grid with a ground conductor.
    Only connect the device to the grid via a connector system with a ground conductor contact.
    If operating the device on a grid without ground conductor and on a socket without ground conductor contact, observe all national regulations for protective separation.
    CAUTION!
    Danger due to insufficiently dimensioned electrical installations.
    Dimension the mains lead and its fuse to suit the local power supply.
    The technical data shown on the rating plate applies.
    NOTE!
    Before connecting the device to the mains, check with the grid operator whether the device may be connected.
    The maximum permissible mains impedance that is decisive for a mains connection is stated in the technical data.
    IMPORTANT! Ensure that the mains connection is earthed properly!
    Due to local regulations and national guidelines, a residual current circuit breaker may be required when connecting a device to the public grid. The type of residual current circuit breaker recommended for the device is specified in the technical data.
    The welding system is generator-compatible.
    The maximum apparent power S1max of the welding system is required for dimensioning the necessary generator output.
    The maximum apparent power S1max of the welding system is calculated as follows:
    S1max = I1max x U1
    I1max and U1 according to the device rating plate and technical data
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator can be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the welding system!
    When single-phase devices are being operated with a three-phase generator, note that the stated apparent power of the generator is often just the total that can be present across all three phases of the generator. If necessary, obtain further information about the single-phase power of the generator from the generator manufacturer.
    NOTE!
    The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
    The mains voltage tolerance is specified in the "Technical data" section.
    General
    If a welding system is delivered without a mains cable installed, a mains cable corresponding to the welding system's connection voltage must be connected before commissioning.
    The mains cable is included in the scope of supply for the welding system.
    2. Connecting the Mains Cable
    General
    Safety
    WARNING!
    1To connect the mains cable:
    • Plug in the mains cable
    • Turn the mains cable 45° to the right until it audibly locks into place
    IMPORTANT! If the welding system is equipped with a mains cable but no mains plug, connection to the public grid must only be carried out in accordance with national guidelines and only by trained and qualified personnel.
    Commissioning
    Safety
    WARNING!
    Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
    Secure all these devices and components so they cannot be switched back on.
    WARNING!
    Danger of electrical current due to electrically conductive dust in the device.
    Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
    2. Commissioning
    Safety
    WARNING!
    WARNING!
    2. Commissioning
    General
    Commissioning of the welding system is described in relation to a standard configuration for the main usage scenario of TIG welding.
    The standard configuration consists of the following system components:
    • Welding system
    • TIG manual welding torch
    • Gas pressure regulator
    • Gas cylinder
    2. Commissioning
    WARNING!
    Danger of falling gas cylinders.
    Securely set up the gas cylinders on a level and stable surface. Secure gas cylinders to prevent them from falling over.
    Please observe the gas cylinder manufacturer's safety rules.
    2. Commissioning
    NOTE!
    Do not use pure tungsten electrodes for Artis welding systems (color code: green).
    1Fit parts to the welding torch according to the Operating Instructions for the welding torch
    2. Commissioning
    2. Commissioning
    IMPORTANT! For optimum welding results, determine the welding circuit resistance “r" before starting welding.
    The welding circuit resistance "r" must also be determined if one of the following components of the welding system is changed:
    • Torch hosepack
    • Welding torch
    • Grounding cable
    For more information on determining the welding circuit resistance, refer to the 2nd TIG menu (see page(→)).
    Welding Mode
    TIG Operating Modes
    Safety
    WARNING!
    1. Welding Mode
    TIG Operating Modes
    Safety
    WARNING!
    1. Welding Mode
    2. TIG Operating Modes
    Safety
    WARNING!
    1. Welding Mode
    Pull back and hold the torch trigger | Release the torch trigger | Briefly pull back the torch trigger (< 0.5 s)
    Push the torch trigger forward and hold | Release the torch trigger
    IS
    Starting-current phase: the temperature is raised gently at low welding current, so that the filler metal can be positioned correctly
    tS
    Starting current duration
    tup
    UpSlope phase: steady rise of the starting current to the main current (welding current) I1
    I1
    Main current phase (welding current phase): uniform thermal input into the parent material, whose temperature is raised by the advancing heat
    I2
    Lowering current phase: intermediate lowering of the welding current to avoid local overheating of the parent material
    tdown
    DownSlope phase: steady lowering of the welding current until it reaches the final current
    IE
    Final current phase: to avoid local overheating of the parent material caused by heat accumulation at the end of welding. This prevents possible sagging of the weld seam.
    tE
    Final current duration
    SPt
    Spot welding time
    GPr
    Gas pre-flow time
    GPo
    Gas post-flow time
    1. Welding Mode
    2-Step Mode
    • Welding: Pull back the torch trigger and hold it in this position
    • End of welding: Release the torch trigger
    2-step mode
    The Setup menu can be used to set a starting current time (t-S) and a final current time (t-E) for 2-step mode.
    1. Welding Mode
    4-Step Mode
    • Start of welding with starting current IS: pull back the torch trigger and hold it in this position
    • Welding with main current I1: release the torch trigger
    • Lowering to final current IE: pull back the torch trigger and hold it in this position
    • End of welding: release the torch trigger
    4-step mode
    *) Intermediate lowering
    With intermediate lowering, the welding current is lowered to the set lowering current I-2  during the main current phase.
    • To activate intermediate lowering, push the torch trigger forward and hold it in this position
    • Release the torch trigger to resume the main current
    1. Welding Mode
    Spot Welding
    If a value has been set for the setup parameter SPt, then 2-step mode operating mode is the same as spot welding operating mode. The spot welding special display illuminates on the control panel.
    • Welding: Briefly pull back the torch trigger
      The duration of welding corresponds to the value that was entered for the setup parameter SPt.
    • Premature ending of the welding process: Pull back the torch trigger again
    When using a foot remote control, the spot welding time begins when the foot remote control is pressed. Foot remote controls cannot be used to adjust the power.
    1. Welding Mode
    TIG welding
    WARNING!
    WARNING!
    1. Welding Mode
    2. TIG welding
    WARNING!
    WARNING!
    1. Welding Mode
    2. TIG welding
    Preparation
    WARNING!
    When the power switch is switched to position - I -, the tungsten electrode of the welding torch is live.
    Ensure that the tungsten electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
    1. Welding Mode
    2. TIG welding
    TIG welding
    1Select the desired TIG operating mode by pressing the operating mode button:
    2Press the dial
    In the welding parameter overview, the assigned welding parameters illuminate to around 50%. The segment of the currently selected welding parameter illuminates fully.
    3Turn the dial and select the welding parameter to be set (so that the segment assigned to the welding parameter in the welding parameter overview illuminates)
    4Press the dial
    5Turn the dial and adjust the value of the selected welding parameter
    6Press the dial to confirm the value of the welding parameter
    7Adjust other parameters in the Setup menu if necessary
    (Details in the "Setup settings" chapter from page (→))
    8Open the gas cylinder valve
    9Adjust quantity of shielding gas:
    Press the gas-test button
    The gas pre-flow test lasts for 30 seconds at the most. Press the button again to stop the gas flow prematurely.
    Turn the adjusting screw on the bottom of the gas pressure regulator until the manometer displays the desired quantity of gas
    NOTE!
    All parameter set values that are set using the dial are saved until their next alteration.
    This applies even if the welding system is switched off and on again.
    10Commence the welding process (ignite arc)
    1. Welding Mode
    2. TIG welding
    Welding parameters
    IS
    Starting current
    1 - 200% of the main current I1
    Factory setting 35%
    tup
    UpSlope
    off / 0.01 - 9.9 s
    Factory setting: 0.5 s
    • 2-step mode
    • 4-step mode
    I1
    Main current
    10 – 170 A ... Artis 170
    10 – 210 A ... Artis 210
    Factory setting: 100 A
    I2
    Lowering current (only in 4-step mode)
    1 - 200% (of the main current I1)
    Factory setting: 50%
    tdown
    DownSlope
    off / 0.01 - 9.9 s
    Factory setting: 1.0 s
    • 2-step mode
    • 4-step mode
    IE
    Final current
    1 - 100% (of the main current I1)
    Factory setting: 30%
      Pulses *
    F-P (pulse frequency)
    off / 0.2 - 990 Hz
    Factory setting: off
      Tacking *
    off / 0.1 - 9.9 s / on
    1. Welding Mode
    Igniting the arc
    (HF ignition)
    CAUTION!
    Risk of injury due to an electric shock
    Although Fronius devices comply with all the relevant standards, high frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
    Use prescribed protective clothing, especially gloves!
    Only use suitable, completely intact, and undamaged TIG hosepacks!
    Do not work in damp or wet environments!
    Take special care when working on scaffolding, work platforms, in tight, difficult to access or exposed places, or when welding out-of-position!
    HF ignition is activated when the setup parameter "IGn" is set to "on".
    The HF ignition special indicator illuminates on the control panel.
    Unlike contact ignition, there is no risk of contaminating the tungsten electrode and workpiece during HF ignition.
    Procedure for HF ignition:
    1Position the gas nozzle at the ignition point so that there is a gap of approximately 2 to 3 mm (5/64 - 1/8 in.) between the tungsten electrode and the workpiece. A gap exists.
    2Increase the tilt angle of the welding torch and press the torch trigger according to the selected operating mode.
    The arc ignites without coming into contact with the workpiece.
    3Tilt the welding torch to the normal position.
    4Carry out welding.
    1. Welding Mode
    2. Igniting the arc
    (HF ignition)
    CAUTION!
    4Carry out welding.
    1. Welding Mode
    2. Igniting the arc
    When the "IGn" setup parameter is set to "OFF", the HF ignition is deactivated. The arc ignites when the workpiece makes contact with the tungsten electrode.
    Procedure for igniting the arc using contact ignition for welding torches with torch trigger:
    1Position the gas nozzle at the ignition point so that there is a gap of approximately 2 to 3 mm (5/64 to 1/8 in.) between the tungsten electrode and the workpiece.
    2Press the torch trigger.
    Shielding gas flows
    3Gradually tilt the welding torch up until the tungsten electrode touches the workpiece
    4Raise the welding torch and rotate it into its normal position.
    The arc ignites.
    5Carry out welding.
    1. Welding Mode
    2. Igniting the arc
    When the "IGn" setup parameter is set to "oFF", the HF ignition is deactivated. The arc ignites when the workpiece makes contact with the tungsten electrode.
    The "Tri" setup parameter must be set to "oFF".
    Procedure for igniting the arc using contact ignition for welding torches without torch trigger:
    2Actuate gas cut-off valve.
    Shielding gas flows
    3Gradually tilt the welding torch up until the tungsten electrode touches the workpiece.
    The arc ignites.
    5Carry out welding.
    1. Welding Mode
    2. Igniting the arc
    (Touch-HF)
    CAUTION!
    Although Fronius devices comply with all relevant standards, the high-frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
    Only use suitable, completely intact and undamaged TIG hosepacks!
    Take special care when working on scaffolds, work platforms, in forced positions, in tight, difficult to access or exposed places!
    The welding process is initiated by briefly touching the workpiece with the tungsten electrode. The high-frequency ignition is performed after the set HF ignition delay time has elapsed.
    1. Welding Mode
    2. Igniting the arc
    If the tungsten electrode is overloaded, the "electrode overloaded" indicator illuminates on the control panel.
    Possible causes of an overloaded tungsten electrode:
    • Diameter of the tungsten electrode is too small
    • Main current I1 value is set too high
    Remedy:
    • Use tungsten electrode with larger diameter
      (in this case, the "ELd" setup parameter value must also be adjusted to the new electrode diameter)
    • Reduce the main current
    IMPORTANT! The "electrode overloaded" display is tailored for use with ceriated tungsten electrodes. For all other electrodes, the "electrode overloaded" indicator can be used as a guide.
    1. Welding Mode
    2. Igniting the arc
    End of Welding
    1Depending on the set operating mode, end welding by releasing the torch trigger
    2Wait for the set gas post-flow and hold the welding torch in position over the end of the weld seam.
    It is also possible to end welding with the TIG Comfort Stop (CSS) function on welding torches with or without a torch trigger.
    This function can be adjusted in the TIG - 2nd level Setup menu (see page (→)).
    1. Welding Mode
    Special functions
    If the arc breaks and no current flow takes place during the time set in the Setup menu, the welding system automatically switches off. The control panel displays the service code "no | Arc".
    Press any button on the control panel or the torch trigger to restart the welding process.
    The "2nd level Setup menu" section describes how to set the arc break monitoring (Arc) setup parameters.
    1. Welding Mode
    2. Special functions
    1. Welding Mode
    Ignition Time-Out
    The welding system has an Ignition Time-Out.
    If the torch trigger is pressed, gas pre-flow begins immediately and the ignition procedure is then initiated. If no arc emerges during the period of time set in the Setup menu, the welding system automatically switches off. The control panel displays the service code "no | IGn".
    Press any button on the control panel or the torch trigger to launch a further attempt.
    The "2nd level Setup menu" section describes how to set the "Ignition Time-Out" (Ito) parameter.
    1. Welding Mode
    TIG pulsing
    The welding current set at the start of welding may not always be optimum for the entire welding process:
    • If the amperage is too low, the base material will not be sufficiently melted
    • If overheating occurs, there is a risk that the liquid weld pool may drip
    The TIG pulsing function is able to help with this (TIG welding with a pulsing welding current):
    A low base current I-G rises steeply to a significantly higher pulse current I1 and falls again, after the set time dcY (duty cycle), to the base current I-G.
    During TIG pulsing, small sections of the welding location melt quickly and then rapidly re-solidify.
    During manual applications, the welding wire is applied in the maximum current phase during TIG pulsing (only possible in the low frequency range from 0.25-5 Hz). Higher pulse frequencies are mostly used in automated applications and mainly serve to stabilize the arc.
    TIG pulsing is used to weld steel pipes when welding out-of-position or to weld thin sheet metal.
    TIG pulsing in operation:
    TIG pulsing—welding current progression curve
    Key:
    IS
    Starting current
    IE
    Final current
    tup
    UpSlope
    tdown
    DownSlope
    F-P
    Pulse frequency *)
    dcY
    Duty cycle
    I-G
    Base current
    I1
    Main current
    *) (1/F-P = Time between two pulses)
    1. Welding Mode
    Tacking function
    There is a tacking function on the welding machine.
    When a period of time is set for the "tAC" (tacking) setup parameter, the tacking function is assigned to the 2-step and 4-step modes. The process of the operating modes remains unchanged.
    During this time, a pulsed welding current is available, which optimizes the merging of the weld pool when tacking two components.
    Tacking function in operation:
    Tacking function—welding current curve
    Key:
    tAC
    Duration of pulsed welding current for tacking process
    IS
    Starting current
    IE
    Final current
    tup
    UpSlope
    tdown
    DownSlope
    I1
    Main current
    IMPORTANT! When using a pulsed welding current:
    • The welding machine automatically regulates the pulse parameters in relation to the set main current I1.
    • No pulse parameters have to be set.
    The pulsed welding current starts
    • After the starting-current phase IS has finished
    • With the UpSlope phase tup
    Depending on the set tAC time, the pulsed welding current can be stopped up to and including the final-current phase IE ("tAC" setup parameter to "On").
    After the tAC time has elapsed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
    IMPORTANT! To set a defined tacking time, the "tAC" setup parameter can be combined with the "SPt" setup parameter (spot welding time).
    1. Welding Mode
    Manual Metal Arc Welding
    link_horizontalLink copied
    Danger due to incorrect operation and electric current
    WARNING!
    WARNING!
    1. Welding Mode
    2. Manual Metal Arc Welding
    WARNING!
    WARNING!
    1. Welding Mode
    Preparation
    1Set the power switch to - O -
    2Unplug mains plug
    3Remove TIG welding torch
    4Insert grounding cable and lock:
    • For manual metal arc DC- welding in the (+) current socket
    • For manual metal arc DC+ welding in the (-) current socket
    5Connect the other end of the grounding cable to the workpiece
    6Insert electrode cable and lock by turning to the right:
    • For manual metal arc DC- welding in the (-) current socket
    • For manual metal arc DC+ welding in the (+) current socket
    7Insert mains plug
    WARNING!
    When the power switch is switched to position - I -, the rod electrode in the electrode holder is live.
    Ensure that the rod electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
    8Set the power switch to - I -
    All displays on the control panel briefly illuminate.
    1. Welding Mode
    MMA welding
    1Select the manual metal arc welding operating mode by pressing the operating mode button:
    IMPORTANT! If the manual metal arc welding operating mode is selected, the welding voltage is only available after a delay of 3 seconds.
    2Turn the dial to set the welding current
    The set value is immediately applied.
    3Adjust other parameters in the Setup menu if necessary
    NOTE!
    4Initiate welding process
    1. Welding Mode
    Manual Metal Arc Welding with Cel Electrodes
    IMPORTANT! To weld with Cel electrodes, the setup parameter CEL must be set to "on" (also see page (→))!
    1. Welding Mode
    Pulse welding
    Pulse welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
    In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:
    • If overheating occurs, there is a danger that the liquid weld pool may drip
    Adjustment range: off, 0.2 - 990 Hz
    Operating principle:
    • A low base current I-G rises steeply to the significantly higher pulse current I-P and drops back to the base current I-G after the Duty cycle dcY time.
    • During pulse welding, small sections of the welding location melt quickly and then rapidly re-solidify.
    NOTE!
    The welding system regulates the duty cycle parameter "dcY" and the base current "I-G" according to the set pulse frequency.
    Pulse welding - welding current curve
    Adjustable parameters:
    F-P
    Pulse frequency (1/F-P = Time between two pulses)
    SoftStart / HotStart
    Fixed parameters:
    I-G
    Base current
    dcY
    Duty cycle
    Using pulse welding:
    1Select manual metal arc welding operating mode
    2Set the parameter "F-P" in the Setup menu to a value between 0.2 and 990 Hz
    The pulsing special indicator illuminates on the control panel of the welding system.
    1. Welding Mode
    Starting current > 100% (HotStart)
    Advantages
    • Improved ignition properties, even when using electrodes with poor ignition properties
    • Better fusion of base material in the start phase, therefore less neutralization
    • Slag inclusions largely avoided
    Example of a starting current > 100% (HotStart)
    Key:
    Hti
    Hot current time,
    0-2 s,
    Factory setting 0.5 s
    HCU
    HotStart current,
    0-200%,
    Factory setting 150%
    I1
    Main current = set welding current
    Operation
    During the set hot current time (Hti) the welding current I1 rises to the HotStart current HCU.
    The setting of the available parameters is described in the "Setup menu" section from page (→).
    1. Welding Mode
    Starting current < 100%
    (SoftStart)
    A starting current of < 100% (SoftStart) is suitable for basic electrodes. Ignition is carried out with a low welding current. As soon as the arc is stable, the welding current continues to increase until it reaches the welding current command value that was set.
    Example of a starting current < 100% (SoftStart)
    Advantages:
    • Improvement of ignition properties with electrodes that ignite at a low welding current
    • Reduction of welding spatter
    (1)
    HCU starting current
    (2)
    Hti starting current time
    (3)
    Main current I1
    The starting current and starting current time are set in the Setup menu from page (→).
    1. Welding Mode
    Anti-stick function
    As the arc becomes shorter, the welding voltage may also fall so that the stick electrode is more likely to stick to the workpiece. This may also cause the stick electrode to burn out.
    Electrode burn-out is prevented by activating the anti-stick function. If the stick electrode begins to stick, the welding system immediately switches the welding current off. The welding process can be resumed without problems once the stick electrode has been detached from the workpiece.
    The anti-stick function can be activated or deactivated in the Setup menu, see page (→).
    Setup Settings
    The Setup Menu
    General
    The welding system Setup menu provides easy access to expert knowledge and additional functions. The Setup menu makes it possible to easily adjust the parameters for various tasks.
    Located in the Setup menu are:
    • Setup parameters with a direct effect on the welding process
    • Setup parameters for pre-setting the welding system
    1. Setup Settings
    The Setup Menu
    General
    1. Setup Settings
    2. The Setup Menu
    General
    1. Setup Settings
    2. The Setup Menu
    Accessing the Setup Menu
    1Press and hold the operating mode button
    2Press the gas-test button
    The corresponding Setup menu will be displayed for the set operating mode.
    3To exit the Setup menu, press the operating mode button
    1. Setup Settings
    2. The Setup Menu
    Adjusting Parameters
    The parameters in the Setup menu are adjusted as follows:
    1Turn the selection dial and select the desired setup parameter
    2Press selection dial to adjust the value for the setup parameter
    The parameter is displayed on the left digital display. The currently set value for the parameter is displayed on the right digital display.
    3Turn selection dial and adjust the value of the setup parameter
    4Press selection dial to confirm the value of the setup parameter
    1. Setup Settings
    2. The Setup Menu
    Overview
    The following sections describe the Setup menu:
    • TIG Setup menu
    • Rod electrode Setup menu
    1. Setup Settings
    TIG Setup Menu
    Parameters in the TIG Setup menu
    The following parameters are available through the TIG Setup menu:
    Electrode diameter
    0.0 - 3.2 mm
    Factory setting: 2.4 mm
    Spot welding time/stitch welding time
    off / 0.05 - 25 s
    If a value has been set for the setup parameter SPt, this means that 2-step mode corresponds to the spot welding mode.
    The spot welding special indicator illuminates on the control panel if a value for the spot welding time has been entered.
    Interval pause time
    This parameter is only available in 2-step mode and when the "SPt" parameter is activated.
    off / 0.5 - 25 s
    Tacking
    Tacking function - duration of the pulsed welding current at the start of the tacking process
    on
    The pulsed welding current remains present until the end of the tacking process
    0.1 - 9.9 s
    The selected time begins with the UpSlope phase. After the set time has passed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
    off
    Tacking function is switched off
    The tacking special indicator illuminates on the control panel if a value has been set.
    Pulse frequency
    off / 0.2 - 990 Hz
    The set pulse frequency is also applied for the lowering current.
    The pulsing special indicator illuminates on the control panel if a value for the pulse frequency has been entered.
    Duty cycle
    Relationship between pulse duration and base current duration at the set pulse frequency
    10 - 90%
    Base current
    0 - 100% (of the main current I1)
    Starting current time
    The starting current time indicates the duration of the starting-current phase .
    off / 0.01 - 9.9 s
    IMPORTANT! The starting current time is only valid for 2-step mode, spot welding, and operation using a foot-operated remote control.
    In 4-step mode, the duration of the starting-current phase is determined  by the torch trigger.
    Final current time
    The final current time indicates the duration of the final-current phase.
    off / 0.01 - 9.9 s
    IMPORTANT! The final current time is only valid for 2-step mode and spot welding. In 4-step mode, the duration of the final-current phase is determined by the torch trigger (section "TIG operating modes").
    Gas pre-flow time
    Duration of the gas pre-flow
    0 - 9.9 s
    Factory setting: 0.4 s
    Gas post-flow time
    Duration of the gas post-flow
    0.2 - 25 s / Aut
    Factory setting: Aut
    Gas purging
    off / 0.1 - 9.9 minutes
    Shielding gas pre-purging starts once a value has been set for GPU.
    For safety reasons, it is necessary to re-enter a value for GPU in order to re-start shielding gas pre-purging.
    IMPORTANT! Shielding gas pre-purging is mainly required if condensate has built up after longer periods of downtime in the cold. Long hosepacks in particular may be affected by this.
    Reset welding system
    No / YES / ALL
    Factory setting: No
    YES:
    Only the currently active welding mode is reset (2T / 4T / trigger = oFF / STICK / STICK CEL / foot-operated remote control)
    ALL:
    All operating modes are reset.
    Left display Right display
    For setting the following parameters:
    • r (welding circuit resistance)
    • Slope Time 1 (only in 4-step mode)
    • Slope Time 2 (only in 4-step mode)
    • Trigger
    • HF ignition
    • Pulse TAC display
    • Ignition Time-Out
    • Arc break monitoring
    • TIG Comfort Stop - Comfort Stop sensitivity
    • Break voltage
    • Main current changeover
    For viewing "system active time", "system on time", "fuse" and "software version" parameters
    For setting the "time shut down" parameter
    1. Setup Settings
    2. TIG Setup Menu
    Electrode diameter
    0.0 - 3.2 mm
    off / 0.05 - 25 s
    Interval pause time
    off / 0.5 - 25 s
    Tacking
    on
    0.1 - 9.9 s
    off
    Pulse frequency
    off / 0.2 - 990 Hz
    Duty cycle
    10 - 90%
    Base current
    off / 0.01 - 9.9 s
    Final current time
    off / 0.01 - 9.9 s
    Gas pre-flow time
    0 - 9.9 s
    Gas post-flow time
    0.2 - 25 s / Aut
    Gas purging
    No / YES / ALL
    Factory setting: No
    YES:
    ALL:
    • Trigger
    • HF ignition
    • Pulse TAC display
    • Ignition Time-Out
    • Break voltage
    1. Setup Settings
    2. TIG Setup Menu
    Parameters in the TIG - 2nd level Setup menu
    The following parameters are available through the second level of the TIG Setup menu:
    Welding circuit resistance
    For displaying the total resistance of the torch hosepack, welding torch, workpiece, and return lead cable
    IMPORTANT! The ground earth connection and contact of the tungsten electrode must be made on a cleaned workpiece surface.
    1Establishing a ground earth connection
    2Select "r" and press the dial
    The last measured value is displayed on the right display.
    3Place the tungsten electrode flush against the workpiece surface
    4Press the torch trigger or gas-test button
    The value for "r" is determined, the right display shows "run".
    The current value for "r" is then displayed in MOhm on the right display.
    If an error occurs while determining the welding circuit resistance, "r" is displayed on the left display and "Err" is displayed on the right display.
    Pressing the torch trigger or the gas-test button restarts the determination of the welding circuit resistance.
    In the event of an error:
    • Inspect torch hosepack, welding torch, and return lead cable for damage
    • Check connections and contacts
    • Check the cleanliness of the workpiece surface
    Slope Time 1 (only available in 4-step mode)
    Ramping time from the main current I1 to the lowering current I2
    off / 0.01 - 9.9 s
    Slope Time 2 (only available in 4-step mode)
    Ramping time from the lowering current I2 back up to the main current I1
    off / 0.01 - 9.9 s
    Trigger
    Torch trigger operating mode
    off / on
    Factory setting: on
    off
    Operating welding torch without torch trigger
    High frequency ignition is deactivated.
    on
    TIG 2-step or 4-step mode
    HF ignition
    off / tHF / EHF / on
    Factory setting: on
    off
    No HF ignition at the start of welding - welding started by contact ignition
    tHF
    The welding process is initiated by briefly touching the workpiece with the tungsten electrode. The high frequency ignition is performed after the set HF ignition delay time has elapsed.
    EHF
    Start with an external ignition device, e.g., plasma welding
    on
    The HF ignition special indicator illuminates on the control panel when the "HF ignition" parameter is set to "on".
    CAUTION!
    Time after touching the workpiece with the tungsten electrode after which the high frequency ignition takes place.
    0.1 - 5.0 s
    Pulse TAC display
    off / on
    Factory setting: on
    This menu item can be used to hide the pulsing and tacking parameters on the control panel in the welding parameter overview.
    Ignition time out
    Period of time until the safety cut-out following failed ignition
    0.1 - 9.9 s
    Factory setting: 5 s
    Period of time until the safety cut-out following an arc break
    0.1 - 9.9 s
    IMPORTANT! Arc break monitoring is a safety function and cannot be deactivated.
    A description of the arc break monitoring function can be found in the "TIG welding" section on page (→).
    TIG Comfort Stop Sensibility - Comfort Stop sensitivity
    The parameter is only available if the "Trigger" parameter is set to "off".
    oFF / 0.6 - 3.5 V
    Factory setting: 1.5 V
    At the end of the welding process, an automatic shutdown of the welding current follows a significant increase of the arc length. This prevents the arc from having to be unnecessarily lengthened when lifting the TIG welding torch.
    Process:
    1Welding
    2Briefly lift the welding torch at the end of welding
    The arc lengthens significantly.
    3Lower the welding torch
    • The arc shortens significantly
    • The TIG Comfort Stop function has triggered
    4Maintain height of the welding torch
    • The welding current ramps down continuously (DownSlope).
    • The arc goes out.
    IMPORTANT! The DownSlope is fixed and cannot be adjusted.
    5 Lift the welding torch from the workpiece
    Break voltage
    For setting a voltage value at which the welding process may be ended by slightly raising the TIG welding torch.
    The higher the break voltage value, the higher the arc can be raised.
    The break voltage values for 2-step mode, 4-step mode, and operation with a foot-operated remote control are all stored together.
    If the "tri" parameter (trigger - torch trigger operating mode) is set to "oFF", the values are stored separately.
    10 - 45 V
    Factory setting: 35 V (for 2-step and 4-step mode and operation with a foot-operated remote control)
    Factory setting: 25 V (for trigger = oFF operation)
    on / off
    Factory setting: on
    on
    After welding has started, an automatic selection of the main current I1 takes place.
    The main current I1 can be adjusted immediately.
    off
    During welding, the last selected parameter remains selected.
    The last selected parameter can be adjusted immediately.
    No automatic selection of the main current I1 takes place.
    1. Setup Settings
    2. TIG Setup Menu
    Parameters in the 2nd level Setup menu
    The following parameters are available through the second level of the Setup menu:
    System active time
    To display the welding duration (the time during which welding has taken place)
    The complete welding duration is divided across several displays and can be viewed by turning the dial.
    Displayed in h / min. / sec.
    System on time
    For displaying the operating duration (count begins as soon as the device is switched on)
    The complete operating duration is divided across several displays and can be accessed by turning the dial.
    Fuse
    To display/set the fuse being used
    At 230 V: 10, 13, 16 A / off *
    At 120 V: 15, 16, 20 A * / off *
    * Only on Artis 170 MV / Artis 210 MV
    Factory setting:
    16 A at a mains voltage of 230 V
    16 A at a mains voltage of 120 V
    If a fuse is set on the welding system, the welding system will limit the current drawn from the grid, which prevents an immediate tripping of the automatic circuit breaker.
    Max. welding current depending on the selected fuse
    Duty cycle = 40%
    Device
    Mains voltage
    Fuse
    Max. TIG welding current
    Max. electrode welding current
    Artis 170
    Artis 170 MV
    230 V
    10 A
    170 A
    125 A
    13 A
    170 A
    150 A
    16 A
    170 A
    150 A
    oFF *
    170 A
    150 A
    120 V **
    15 A
    130 A
    85 A
    16 A
    140 A
    95 A
    20 A *
    140 A
    100 A
    oFF *
    140 A
    100 A
    Artis 210
    Artis 210 MV
    230 V
    10 A
    180 A
    125 A
    13 A
    200 A
    150 A
    16 A
    210 A
    150 A
    oFF *
    210 A
    150 A
    120 V **
    15 A
    130 A
    85 A
    16 A
    140 A
    95 A
    20 A *
    170 A
    120 A
    oFF *
    170 A
    120 A
    Depending on the trigger characteristics of the automatic circuit breaker used, the full duty cycle of 40% may not be reached with a 120 V grid (for example, USA circuit breaker type CH 15% D.C.).
    Software version
    The complete version number of the current software is divided across several displays and can be viewed by turning the dial.
    Automatic shutdown
    off / 5 - 60 minutes
    If the device is not used or operated within a set period of time, it automatically switches into Standby mode.
    Pressing a button on the control panel switches off Standby mode - the device is now ready for welding.
    1. Setup Settings
    Rod Electrode Setup Menu
    Parameters in the stick electrode Setup menu
    The following parameters are available through the stick electrode Setup menu:
    HotStart current
    1 - 200%
    Factory setting: 130%
    0.1 - 2.0 s
    Start ramp
    To activate/deactivate the start ramp for the manual metal arc welding ignition process
    on / off
    Factory setting: on (activated)
    Pulse frequency
    for pulse welding with stick electrodes
    off / 0.2 - 990 Hz
    Anti-stick
    on / off
    Factory setting: on
    CEL mode
    on / off
    To weld with Cel electrodes, the parameter must be set to "on".
    Dynamic correction
    To optimize the welding result
    0 - 100
    Factory setting: 20
    0
    Softer and low-spatter arc
    100
    Harder and more stable arc
    At the moment of droplet transfer or in event of a short circuit, a short-term increase in the amperage will occur. To maintain a stable arc, the welding current temporarily rises. If the stick electrode is at risk of sinking into the weld pool, this action prevents the weld pool from solidifying, as well as reducing the duration of the arc's short circuit. The risk of the stick electrode sticking is therefore largely ruled out.
    Break voltage
    Limitation of the welding voltage
    25 - 90 V
    Factory setting: 45 V
    In principle, the arc length depends on the welding voltage. To end the welding process, a significant lifting of the stick electrode is usually required. The "Uco" parameter allows the welding voltage to be limited to a value, which permits the welding process to be ended by only slightly lifting the stick electrode.
    IMPORTANT! If the welding process regularly comes to an unintentional end, set the break voltage parameter to a higher value.
    No / YES / ALL
    Factory setting: No
    YES:
    ALL:
    For more details about the 2nd level Setup menu, see page (→).
    1. Setup Settings
    2. Rod Electrode Setup Menu
    HotStart current
    1 - 200%
    0.1 - 2.0 s
    Start ramp
    on / off
    Pulse frequency
    off / 0.2 - 990 Hz
    Anti-stick
    on / off
    Factory setting: on
    CEL mode
    on / off
    Dynamic correction
    0 - 100
    Factory setting: 20
    0
    100
    Break voltage
    25 - 90 V
    No / YES / ALL
    Factory setting: No
    YES:
    ALL:
    Troubleshooting and Maintenance
    Troubleshooting
    General
    The welding system is equipped with an intelligent safety system, which completely negates the need for fuses. After correcting a possible error, the welding system can be properly operated again without having to change any fuses.
    1. Troubleshooting and Maintenance
    Troubleshooting
    General
    2. Troubleshooting
    General
    2. Troubleshooting
    Safety
    WARNING!
    WARNING!
    CAUTION!
    Danger due to insufficient ground conductor connection.
    This can result in personal injury and damage to property.
    The housing screws provide a suitable ground conductor connection for grounding the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    2. Troubleshooting
    Displayed Faults
    Overtemperature
    "Err | hot" is shown on the display
    Cause:Operating temperature is too high
    Remedy:Leave the device to cool (Do not switch off the device—the fan will cool the device)
    2. Troubleshooting
    Service messages
    If "Err" is displayed on the left display and an error code is displayed on the right display, this is an internal service code for the welding system.
    Example:
    There can be multiple error codes. These appear by turning the dial.
    Take note of all displayed error codes as well as the serial number and configuration of the welding system, and then contact the service center with a detailed error description.
    Err | 1-3 / 11 / 15 / 21 / 33-35 / 37-40 / 42-44 / 46-52
    Cause:Power module error
    Remedy:Contact the service team
    Err | 4
    Cause:Open circuit voltage has not been reached:
    Electrode is in contact with the component/hardware defect
    Remedy:Remove the electrode support from the component. If the service code continues to be displayed, contact service team
    Err | 5 / 6 / 12 / 14
    Cause:System start failure
    Remedy:Turn device off and on again. If this happens multiple times, inform service team
    Err | 10
    Cause:Overvoltage at the current socket (> 113 VDC)
    Err | 16 / 17 / 18
    Cause:Memory error
    Remedy:Contact service team;
    Err 16: press dial to acknowledge service message
    NOTE!
    For standard device variants, acknowledging the service message does not have an effect on the welding system's range of functions.
    For all other device variants (TIG, etc.), the welding system only offers a restricted range of functions after acknowledgment. Inform the service team to re-establish the full range of functions.
    Err | 19
    Cause:Overtemperature or undertemperature
    Remedy:Operate device at permitted ambient temperature. For more information about environmental conditions see "Environmental Conditions" in the "Safety Rules" section
    Err | 20
    Cause:Improper use of the device
    Remedy:Only use the device in accordance with the intended purpose
    Err | 22
    Cause:Welding current set too high
    Remedy:Ensure that the welding system is being operated at the correct mains voltage; ensure the correct fuse is set; set a lower welding current
    Err | 37
    Cause:Mains voltage exceeds admissible limits
    Remedy:Immediately pull out the mains plug and ensure that the welding system is being operated at the correct mains voltage
    Err | 36 / 41 / 45
    Cause:Mains voltage is outside of the tolerance or mains output is insufficient for the connected device(s)
    Err | 65-75
    Cause:Error in communicating with the display
    Remedy:Turn device off and on again / inform service team if this happens multiple times
    r | Err
    Cause:Error while determining the welding circuit resistance
    Remedy:Inspect torch hosepack, welding torch, and grounding cable for damage;
    check connections and contacts;
    check the cleanliness of the workpiece surface.
    For more information on determining the welding circuit resistance, refer to the 2nd TIG menu (see page (→)).
    2. Troubleshooting
    No Function
    Device cannot be switched on
    Cause:Defective power switch
    Remedy:Inform service team
    No welding current
    The welding system is switched on, display for selected process illuminates
    Cause:Welding power-lead connections interrupted
    Remedy:Correctly establish welding power-lead connections
    Cause:Poor grounding or no grounding at all
    Remedy:Establish a connection with the workpiece
    Cause:Power cable in the welding torch or electrode holder interrupted
    Remedy:Replace welding torch or electrode holder
    No welding current
    Switch on device, display illuminates for selected process, overtemperature display illuminates
    Cause:Duty cycle exceeded - device overloaded - fan running
    Remedy:Observe duty cycle
    Cause:Thermal automatic circuit breaker has shut down the device
    Remedy:Wait for device to cool down (do not switch off the device - the fan will cool the device); the welding system will switch on again automatically after a short time
    Cause:Fan in the welding system defective
    Remedy:Contact After-Sales Service
    Cause:Cooling air supply is insufficient
    Remedy:Ensure there is a sufficient air supply
    Cause:Air filter is dirty
    Remedy:Clean air filter
    Remedy:Switch the device off and then on again
    If this error persists, inform service team
    2. Troubleshooting
    Inadequate function
    Poor ignition properties during manual metal arc welding
    Cause:The wrong process has been selected
    Remedy:Select "manual metal arc welding" or "manual metal arc welding with Cel electrodes" process
    Cause:Starting current too low; electrode remains stuck during ignition process
    Remedy:Increase starting current
    Cause:Starting current too high; electrode burns too quickly during ignition process or spatters strongly
    Remedy:Decrease starting current
    Arc occasionally breaks during the welding process
    Cause:Break voltage (Uco) is set too low
    Remedy:Raise the break voltage (Uco) in the Setup menu
    Cause:Voltage of the electrode too high (e.g. grooved electrode)
    Remedy:Use alternative electrode if possible or use power source with higher welding power
    Rod electrode tends to stick to the workpiece
    Cause:Value for dynamic parameter (manual metal arc welding) set too low
    Remedy:Set a higher value for dynamic parameter
    Poor-quality weld property
    (strong spattering)
    Cause:Incorrect polarity of the electrode
    Remedy:Reverse the polarity of the electrode (observe manufacturer guidelines)
    Cause:Poor ground earth connection
    Remedy:Attach earthing clamps directly to the workpiece
    Cause:Non-viable setup setting for the selected process
    Remedy:Optimize the setting for the selected process in the Setup menu
    Tungsten electrode melts
    Tungsten inclusions in the base material during the ignition phase
    Cause:Incorrect polarity of the tungsten electrode
    Remedy:Connect TIG welding torch to the (-) current socket
    Cause:Incorrect shielding gas, no shielding gas
    Remedy:Use inert shielding gas (argon)
    Service, maintenance and disposal
    General
    The device only requires a minimum of service and maintenance under normal operating conditions. However, several points must be observed in order for the device to remain operational for years to come.
    2. Service, maintenance and disposal
    General
    Safety
    WARNING!
    WARNING!
    At every start-up
    • Check mains plug and mains cable, as well as the welding torch, interconnecting hosepack, and ground earth connection for damage
    • Check if the all-round clearance of the device is 0.5 m (1 ft. 8 in.) so that cooling air can circulate unimpeded
    NOTE!
    Air inlet and outlet openings must not be blocked or even partially covered.
    Maintenance every two months
    Clean air filter:
    Disposal
    Disposal must only be carried out in accordance with the section of the same name in the "Safety rules" chapter.
    Appendix
    Average consumption values
    Average shielding gas consumption during TIG welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    2. Average consumption values
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    Technical data
    Special Voltage
    For devices designed for special voltages, the technical data on the rating plate applies.
    1. Appendix
    2. Technical data
    Special Voltage
    1. Appendix
    2. Technical data
    Artis 170 EF,
    Artis 170 np
    Mains voltage U1
    1 x 230 V
    Max. effective primary current (I1eff)
    11.3 A
    Max. primary current (I1max)
    15.0 A
    Mains voltage tolerance
    -30% / +15%
    Mains frequency
    50/60 Hz
    Mains fuse
    16 A slow-blow
    Mains connection 1)
    Zmax at PCC3) = 356 MOhm
    Primary continuous power (100% D.C. 2) )
    2.7 kVA
    Max. apparent power S1max
    3.5 kVA
    Cos phi
    0.99
    Welding current range
    TIG
    3 - 170 A
    MMA
    10 - 150 A
    Welding current at 10 min / 40 °C (104 °F), U1 = 230 V
    TIG
    40% D.C. 2) / 170 A
    60% D.C. 2) / 155 A
    100% D.C.2) / 140 A
    MMA
    40% D.C. 2) / 150 A
    60% D.C. 2) / 120 A
    100% D.C. 2) / 110 A
    Open circuit voltage (pulsed)
    TIG
    35 V
    MMA
    101 V
    Working voltage
    TIG
    10.1 - 16.8 V
    MMA
    20.4 - 26.0 V
    Striking voltage Up
    9.0 kV
    The arc ignition device is suitable for manual operation
    Protection class
    Protection class 23
    Type of cooling
    AF
    Insulation class
    A
    EMC emission class (according to EN/IEC 60974-10)
    A
    Overvoltage category
    III
    Pollution degree according to IEC60664
    Ambient temperature
    -10 °C - +40 °C / +14 °F - +104 °F
    Storage temperature
    -25 °C - +55 °C / -13 °F - +131 °F
    Dimensions l x w x h
    435 x 160 x 310 mm / 17.1 x 6.3 x 12.2 in.
    Weight
    9.8 kg / 21.61 lb.
    Mark of conformity
    CE
    Safety symbols
    S
    Max. shielding gas pressure
    5 bar/73 psi
    Noise emissions (LWA)
    68.0 dB(A)
    Idle state power consumption at 230 V
    15 W
    Energy efficiency of the welding system
    at 150 A / 26 V
    88%
    1. Appendix
    2. Technical data
    Artis 170 XT/B,
    Artis 170 XT/np
    Mains voltage
    1 x 120 V / 1 x 230 V
    1 x 120 V
    14.5 A
    1 x 230 V
    11.3 A
    1 x 120 V
    22.7 A
    1 x 230 V
    15.0 A
    1 x 120 V
    -20% / +15%
    1 x 230 V
    -30% / +15%
    Mains frequency
    50/60 Hz
    Mains fuse
    1 x 120 V
    20 A slow-blow
    1 x 230 V
    16 A slow-blow
    Mains connection 1)
    Zmax at PCC 3) = 356 MOhm
    1 x 120 V
    1.8 kVA
    1 x 230 V
    2.7 kVA
    1 x 120 V
    2.8 kVA
    1 x 230 V
    3.5 kVA
    Cos phi
    0.99
    TIG / 1 x 120 V
    3 - 140 A
    TIG / 1 x 230 V
    3 - 170 A
    Stick electrode / 1 x 120 V
    10 - 100 A
    Stick electrode / 1 x 230 V
    10 - 150 A
    TIG / 1 x 120 V
    40% D.C. 2) / 140 A
    60% D.C. 2) / 120 A
    100% D.C. 2) / 100 A
    TIG / 1 x 230 V
    40% D.C. 2) / 170 A
    60% D.C. 2) / 155 A
    100% D.C.2) / 140 A
    40% D.C. 2) / 100 A
    60% D.C. 2) / 90 A
    100% D.C. 2) / 80 A
    40% D.C. 2) / 150 A
    60% D.C. 2) / 120 A
    100% D.C.2) / 110 A
    TIG
    35 V
    MMA
    101 V
    Working voltage
    TIG / 1 x 120 V
    10.1 - 15.6 V
    TIG / 1 x 230 V
    10.5 - 16.8 V
    20.4 - 24.0 V
    20.4 - 26.0 V
    Striking voltage Up
    9 kV
    Protection class
    Protection class 23
    Type of cooling
    AF
    Insulation class
    A
    A
    III
    Ambient temperature
    Storage temperature
    Weight
    9.8 kg / 21.61 lb.
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    5 bar/73 psi
    68.0 dB(A)
    15 W
    at 150 A / 26 V
    88%
    1. Appendix
    2. Technical data
    Artis 210 EF,
    Artis 210 np
    Mains voltage U1
    1 x 230 V
    13.5 A
    20.0 A
    -30% / +15%
    Mains frequency
    50/60 Hz
    Mains fuse
    16 A slow-blow
    Mains connection 1)
    Zmax at PCC3)= 261 MOhm
    3.2 kVA
    4.6 kVA
    Cos phi
    0.99
    TIG
    3 - 210 A
    MMA
    10 - 180 A
    U1 = 230 V
    TIG
    40% D.C. 2) / 210 A
    60% D.C. 2) / 185 A
    100% D.C. 2) / 160 A
    MMA
    40% D.C. 2) / 180 A
    60% D.C. 2) / 150 A
    100% D.C. 2) / 120 A
    TIG
    35 V
    MMA
    101 V
    Working voltage
    TIG
    10.1 - 18.4 V
    MMA
    20.4 - 27.2 V
    Striking voltage Up
    9.0 kV
    Protection class
    Protection class 23
    Type of cooling
    AF
    Insulation class
    A
    A
    III
    Ambient temperature
    Storage temperature
    Weight
    9.8 kg / 21.61 lb.
    Mark of conformity
    CE
    Safety symbols
    S
    5 bar/73 psi
    68.0 dB(A)
    15 W
    at 180 A / 27.2 V
    88%
    1. Appendix
    2. Technical data
    Artis 210 XT/B,
    Artis 210 XT/np
    Mains voltage
    1 x 120 V
    18.0 A
    1 x 230 V
    13.5 A
    1 x 120 V
    29.0 A
    1 x 230 V
    20.0 A
    1 x 120 V
    -20% / +15%
    1 x 230 V
    -30% / +15%
    Mains frequency
    50/60 Hz
    Mains fuse
    1 x 120 V
    20 A slow-blow
    1 x 230 V
    16 A slow-blow
    Mains connection 1)
    1 x 120 V
    2.2 kVA
    1 x 230 V
    3.2 kVA
    1 x 120 V
    3.5 kVA
    1 x 230 V
    4.6 kVA
    Cos phi
    0.99
    TIG / 1 x 120 V
    3 - 170 A
    TIG / 1 x 230 V
    3 - 210 A
    10 - 120 A
    10 - 180 A
    TIG / 1 x 120 V
    40% D.C. 2) / 170 A
    60% D.C. 2) / 150 A
    TIG / 1 x 230 V
    40% D.C. 2) / 210 A
    60% D.C. 2) / 185 A
    100% D.C.2) / 160 A
    40% D.C. 2) / 120 A
    60% D.C. 2) / 100 A
    100% D.C. 2) / 90 A
    40% D.C. 2) / 180 A
    60% D.C. 2) / 150 A
    100% D.C.2) / 120 A
    TIG
    35 V
    MMA
    101 V
    Working voltage
    TIG / 1 x 120 V
    10.1 - 16.8 V
    TIG / 1 x 230 V
    10.1 - 18.4 V
    20.4 - 24.8 V
    20.4 - 27.2 V
    Striking voltage Up
    9 kV
    Protection class
    Protection class 23
    Type of cooling
    AF
    Insulation class
    A
    A
    III
    Ambient temperature
    Storage temperature
    Weight
    9.9 kg / 21.8 lb.
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    5 bar/73 psi
    68.0 dB(A)
    15 W
    at 180 A / 27.2 V
    88%
    1. Appendix
    2. Technical data
    Explanation of footnotes
    /EF
    Welding system with mains cable fitted
    /np
    Welding system with mains cable fitted and without plug for the public grid
    /B
    Welding system with mains cable to plug in
    1)
    On a public grid with 230 V and 50 Hz
    2)
    D.C. = duty cycle
    3)
    PCC = interface to the public grid
    1. Appendix
    2. Technical data
    China Energy Label
    Artis 170 /nc
    Artis 210 /nc
    1. Appendix
    2. Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address:
    Find downloads: critical
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    Part Name
    Hazardous Substances
    Lead
    (Pb)
    Mercury
    (Hg)
    Cadmium
    (Cd)
    hexavalent
    chromium
    (Cr (VI))
    polybrominated
    biphenyls
    (PBB)
    polybrominated
    diphenyl ethers
    (PBDE)
    diethylhexyl phthalate
    (DEHP)
    benzyl butyl phthalate
    (BBP)
    dibutyl phthalate
    (DBP)
    di-isobutyl phthalate
    (DOBP)
    Packaging
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Housing
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Metal Parts
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    PCB
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Cables and Cable Assemblies
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    This table is prepared in accordance with the provisions of SJ/T 11364.
    O
    Indicates that the hazardous substance contained in all of the homogeneous materials for this part is below the limit requirement of GB/T 26572.
    X
    Indicates that the hazardous substance contained in at least one of the homogeneous materials used for this part is above the limit requirement of GB/T 26572.
    All parts in this table marked with an "X" comply with the European Union's RoHS legislation.
