Incorrect operation or misuse
IMPORTANT!
Tampered-with and non-functioning protection devices
The device may be damaged
During operation, due to the high electrical voltages and currents, local electromagnetic fields (EMF) occur in the environment around the inverter and the Fronius system components as well as in the area of the PV modules including the supply lines.
In the case of exposure to humans, the required limit values are observed when the products are used in line with the intended use and the recommended distance of at least 20 cm is observed.
If these limit values are complied with, according to current scientific knowledge, no health-endangering effects from EMF exposure are to be expected. If wearers of prostheses (implants, metal parts in and on the body) as well as active physical aids (pacemakers, insulin pumps, hearing aids, etc.) are in the vicinity of components of the PV system, they must consult with the responsible doctor regarding possible health risks.
Technical data and markings are located on the Fronius Backup Controller. This information must be kept in a legible condition and must not be removed, covered, pasted or painted over.
Labelling | |
CE label – confirms compliance with applicable EU directives and regulations. | |
WEEE marking – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law. | |
RCM marking – tested according to the requirements of Australia and New Zealand. | |
Labelling | |
Application notes
Software
Example: Click Save.
Instructions for action
This document provides detailed information and instructions to ensure that all users can use the device safely and efficiently.
The Fronius Backup Controller is a fixed piece of equipment designed for use in public grids with TT-/TN-S-/TN-C-S systems. Its main function is to automatically and securely disconnect all connected loads and generators from the public grid in the event of a grid failure or grid malfunction in accordance with the specifications of the grid operator. As soon as grid stability has been restored, the loads and generators are automatically reconnected to the public grid.
Backup power switching is not suitable to supply loads that require an uninterruptible power supply or increased availability (e.g., IT networks, life-sustaining medical devices).
| (1) | Fronius Backup Controller |
| (2) | Quick Start Guide |
| (3) | Backup power warning notice |
| PV module | |
| Fronius Hybrid inverter | |
| Fronius Backup Controller | |
| Inverter in the system | |
| Primary meter | |
| Utility meter | |
| Grid | |
| Battery | |
| Loads in the system |
The Fronius Backup Controller must be installed in the backup power circuit of the photovoltaic system.
Other inverters/generators in the house
Only one hybrid inverter may be installed in the backup power circuit of the photovoltaic system. Failure to follow this specification may result in damage to the photovoltaic system.
Install other inverters/generators outside the backup power circuit.
Alternatively, install a dedicated backup power circuit for these devices.
All components in the backup power circuit of the photovoltaic system must be compatible and must not impair the function of the photovoltaic system.
Incompatible components in the backup power circuit of the photovoltaic system
Incompatible components can interfere with or restrict the operation and function of the photovoltaic system when in backup power mode.
Only use compatible components recommended by the manufacturer.
Device name | Item number |
Fronius Smart Meter IP 5kA-3 | 42,0411,0347 |
Fronius Smart Meter 63A-3 | 43,0001,1473 |
Fronius Smart Meter TS 65A-3 | 43,0001,0044 |
| (1) | 1-pin push-in terminal for the neutral conductor connection to the Fronius Smart Meter (max. 1 A). |
| (2) | 8-pin push-in terminal for loads/generators in the backup power circuit. |
| (3) | Push-in terminal for digital inputs/outputs (I/Os). |
| (4) | 6-pin push-in terminal for the supply from the public grid. |
I/O pin | Parameter | Description |
IO 0 | Enable backup power locking | Before the inverter switches to backup power mode, the pin IO 0 must be active (value = 1). |
IN 6 | Grid relay open feedback | If the mains voltage is too low or the pin IO 0 is active (value = 1), relay K1 is open and relay K2 is closed. The auxiliary contacts of the mains isolation relays are closed and the pin IN 6 is active (value = 1). |
IN 7 | Locking feedback | When IO 0 and IN 6 are active, the auxiliary contact closes and pin IN 7 is active (value = 1). The inverter receives a feedback signal and switches to backup power mode. |
The LED status indicator shows the operating status.
Symbol | LED status | Description |
Lights up green | The "Grid" LED indicates that all connected loads and inverters in the backup power circuit are being supplied by or are connected to the public grid. | |
Lights up blue | The "Full Backup" LED indicates that all connected loads and inverters in the backup power circuit are safely disconnected from the public grid and that the Full Backup power supply is active. |
Single-core | Multi-stranded | Fine-stranded | Fine-stranded with ferrule and collar | Fine-stranded with ferrule without collar |
Round copper conductors can be connected to the terminals as described below.
Push-in terminals for the supply from the public grid.* | ||||
2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 6 mm2 | 2.5 - 6 mm2 |
Push-in terminals for the loads/generators in the backup power circuit.* | ||||
Push-in terminal for the neutral conductor connection to the Fronius Smart Meter (max. 1 A) | ||||
1 - 4 mm2 | 1 - 4 mm2 | 1 - 4 mm2 | 1 - 2.5 mm2 | 1 - 2.5 mm2 |
Round copper conductors can be connected to the push-in terminals for digital inputs/outputs (I/Os) as described below.
IO connections with push-in terminal | ||||||
Max. | Stripping length | Cable recommendation | ||||
30 m * | 10 mm | 0.14 - 1.5 mm2 | 0.14 - 1.5 mm2 | 0.14 - 1 mm2 | 0.14 - 1.5 mm2 | Single conductors possible |
| * | The maximum cable length between the inverter and the Backup Controller must not exceed 30 m (32 yd). Fronius recommends using at least CAT 5 STP (shielded twisted pair) cables. |
Danger from short circuits due to foreign bodies in the housing.
An electric shock can lead to serious injury or death.
Cover vents during installation.
Only trained service technicians who have received training from the respective inverter or battery manufacturer are authorized to perform commissioning, maintenance, and service activities for inverters and batteries, and only within the scope of the technical regulations.
Read the installation instructions and operating instructions from the respective manufacturer before installing and commissioning the equipment.
Danger from mains voltage and DC voltage from PV modules that are exposed to light, as well as batteries.
All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and battery, and are de-energized.
Only an authorized electrical engineer is permitted to connect this equipment to the public grid.
Danger from damaged and/or contaminated terminals.
Prior to connection work, check the terminals for damage and contamination.
Remove any contamination while the equipment is de-energized.
Have defective terminals repaired by an authorized specialist.
Switch off the house connection fuse and the automatic circuit breaker. Set the DC disconnector to the "off" switch position.
Switch off the battery connected to the inverter.
Wait for the capacitors of the inverter to discharge (2 minutes).
The Fronius Backup Controller can be mounted on a 35 mm DIN rail. The housing comprises 11 modules according to DIN 43880 and conforms to unit size 2.
Danger from loose and/or incorrectly clamped single conductors in the terminal.
Only connect one single conductor in the slot provided for each terminal.
Check that the single conductors are secure in the terminal.
Make sure that the single conductor has been fully inserted into the terminal and that no single wires are protruding out of the terminal.
Strip the insulation of the single conductors by 12 mm.
Select the cable cross-section in accordance with the instructions in Permitted cables for the electrical connection from page (→).
Lift the operating levers of the terminals to open. Insert the stripped single conductors into the slot provided in the terminal, in each case as far as it will go.
IMPORTANT!
The neutral conductor must be connected to the public grid.
Close the terminal operating levers until they engage.
IMPORTANT!
Strip the insulation of the single conductors by 10 mm.
Lift the operating levers of the terminals to open. Insert the stripped single conductor into the slot provided in the terminal as far as it will go.
Close the operating lever of the terminal until it engages.
Danger due to a short circuit between the single conductor of the shielding and live components.
Insulate unused single conductors of the shielding with a shrink sleeve.
Danger from external power supply
If the data communication area of the inverter is connected to a powerful external power supply, the Backup Controller may be damaged.
The external supply must not exceed a voltage of 12 V (+/- 10%).
Power requirements of the Backup Controller and battery
If additional loads are connected to the data communication area of the inverter, e.g., to the digital I/Os, the power requirements of the Backup Controller and battery may no longer be met. The function of the automatic backup power switching may be impaired.
Switch on the battery connected to the inverter.
Set the DC disconnector to the "on" switch position. Turn on the automatic circuit breaker.
IMPORTANT!
Settings in the Device configuration > Functions and I/Os menu item may only be implemented by a trained technician! The service password must be entered for the Device configuration menu item.
A battery charge of min. 30% is recommended for test mode.
A description of how to run the test mode can be found in the checklist – Backup power (https://www.fronius.com/en/search-page, item number: 42,0426,0365).
Clean the Backup Controller as required with a damp cloth.
Do not use cleaning agents, abrasives, solvents or similar to clean the Backup Controller.
Maintenance and service work may only be carried out by a trained technician.
Packaging materialsDetailed warranty conditions specific to your country can be found at www.fronius.com/solar/garantie .
To secure the full warranty period for the newly installed Fronius product, it is necessary to register at www.solarweb.com .
General data | |
Grid configuration | TT/TN-S/TN-C-S |
Housing | 11 modules according to DIN 43880 |
Mounting | 35 mm DIN rail |
Weight | 856 g |
Protection class | IP20 |
Fault Ride Through (FRT) | According to EN 50549-10 |
Short-circuit breaking capacity | Class PC |
Short-circuit current resistance | 2600 A |
Self-consumption | <5 W |
Environmental conditions | |
Permitted ambient temperature | -20 to +50 °C |
Permissible humidity | 50% relative humidity at 40 °C |
Max. altitude | 2000 m |
Vibrations | Not permitted |
Rated values | |
Nominal voltage | 230/400 V 3-pole or 3-pole + N |
Nominal current | 35 A |
Max. permissible fuses | 35 A gG fuse |
Duty cycle | 100% at AC-32 |
Rated power | 24 kVA |
Grid frequency | 50 Hz |
Power loss (at nominal current) | 15 W |
Overvoltage category | III |
Electromagnetic compatibility | |
Interference immunity | According to EN 61000-6-2 2019-12-01 |
Emissions | According to EN 61000-6-3 2020-07 |
Compatible inverters | |
Fronius Primo GEN24 3.0 - 6.0 kW Plus | |
Fronius Symo GEN24 6.0 - 10.0 kW Plus | |
Fronius Symo GEN24 6.0 - 12.0 kW Plus SC | |
Fronius Verto 15.0 - 20.0 kW Plus |
General data | |
Weight | 856 g |
Rated values | |
