en
      Operating instructionsFronius Backup Switch 1P/3P-63A
    • General information
      • Safety information
        • Safety instructions and important information
        • Environmental conditions
      • General
        • Information on the device
        • How information is presented in the document
        • Target group
        • Data security
        • Copyright
      • Fronius Backup Switch
        • Intended use
        • Foreseeable misuse
        • Scope of supply
        • Compatible devices
        • Explanation of symbols
        • Positioning
      • Operating controls and connections
        • Switch positions of the Backup Switch
        • Connection area
    • Installation and Startup
      • Requirements for connecting the Backup Switch
        • Protective circuit
        • Various cable types
        • Permissible cables for Backup Switch 1P/3P-63A
        • Permitted connection screws
      • Preparing for the installation
        • Safety
        • General disconnection of the power supply
        • Installation
        • Disassembly of the switch and the housing cover
        • Stripping lengths
      • 1-pin installation
        • Connecting the Backup Switch 1-pin to the public grid
        • Connecting load 1-pin in the backup power circuit to the Backup Switch
      • 3-pin installation
        • Connecting the Backup Switch 3-pin to the public grid
        • Connecting load 3-pin in the backup power circuit to the Backup Switch
      • Connecting the data communication cables
        • Description of the data communication
        • Notes on data communication
        • Data communication – Modbus RTU option
          TCP/IP | MQTT option
      • Mounting the protective cover
        • Mounting the protective covers
      • Mounting housing cover and switch
        • Mounting the housing cover and the switch
      • Commissioning
        • Putting the PV system into operation
        • General
        • Backup power - Configuring Full Backup
        • Testing backup power mode
        • Manual system start in backup power mode
    • Technical data
      • Technical data
        • Technical data
    • Service, warranty terms and conditions, and disposal
        • Maintenance
        • Fronius manufacturer's warranty
        • Disposal
    • Circuit Diagrams
      • Manual switch to backup power 1-pin separation, e.g., Australia
      • Manual switch to backup power 3-pin separation, e.g., Austria
    • 008-22042026
    download
    Installation
    Commissioning
    Technical data
    ContactLegal NoticeGeneral Terms & ConditionsData Privacy StatementCookie Policy
    General information
    link_horizontalLink copied
    Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. General information
    Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    WARNING!
    Incorrect operation or misuse
    IMPORTANT!
    In addition to the operating instructions, observe the following general and local rules:
    • Accident prevention
    • Fire protection
    • Environmental protection
    IMPORTANT!
    IMPORTANT!
    All safety and danger notices on the device:
    • Must be kept in a legible state
    • Must not be damaged/marked
    • Must not be removed
    • Must not be covered, have anything stuck on them, or painted over
    WARNING!
    Tampered-with and non-functioning protection devices
    WARNING!
    NOTE!
    The device may be damaged
    Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended use.
    General
    Technical data and markings are present on the Fronius Backup Switch. They must not be removed or painted over.
     Rating plate on the right side of the Backup Switch.
     Rating plate on the left side of the Backup Switch.
    Markings
    CE label – confirms compliance with applicable EU directives and regulations.
    UKCA marking – confirms compliance with applicable UK directives and regulations.
    C UL US LISTED marking – confirms compliance with applicable standards for Canada and the USA.
    IMPORTANT!
    NO power categories of the US versions of the Fronius product series "Primo GEN24 X.X 208-240 (Plus) (SC)" are compatible with the Fronius Backup Switch.
    2. General
    Markings
    IMPORTANT!
    2. General
    Application notes
    Software
    Example: Click Save.
    Instructions for action
    1Action steps are displayed with consecutive numbering.
    ✓This symbol indicates the result of the action step or the entire instruction.
    2. General
    Target group
    This document provides detailed information and instructions to ensure that all users can use the device safely and efficiently.
    • The information is intended for the following groups of people:
      • Technical specialists: People with appropriate qualifications and fundamental electronic and mechanical knowledge, who are responsible for the installation, operation, and maintenance of the device.
      • End users: People that use the device in daily operation and want to understand its basic functions.
    • Regardless of any qualifications, only perform the activities listed in this document.
    • All persons involved in the commissioning, maintenance, and servicing of the device must be appropriately qualified and have knowledge of working with electrical installations.
    • The definition of professional qualifications and their applicability are subject to national law.
    2. General
    Data security
    • Backing up any changes made to the factory settings
    • Saving and storing personal settings
    NOTE!
    2. General
    Copyright
    Intended use
    The Fronius Backup Switch is a piece of stationary equipment that was developed for use in public power grids with TN/TT systems. In the event of a grid failure, all connected loads and producers can be manually disconnected from the public grid in accordance with the specifications of the grid operator. The Fronius Backup Switch enables manual switching to the backup power supply. As soon as the public grid is stable again, the Fronius Backup Switch can be used to switch manually back to the power supply from the public grid. The Fronius Backup Switch can only be used in systems containing a Fronius inverter and battery storage system.
    2. Fronius Backup Switch
    Intended use
    Foreseeable misuse
    The Fronius Backup Switch is not suitable for the backup power supply of life-sustaining medical devices.
    Scope of supply
    Backup Switch scope of supply.
    (1)
    1 pc Fronius Backup Switch
    (2)
    2 pcs protective cover incl. 4 pcs screws B2.2 x 6.5 mm (not shown)
    (3)
    1 pc Quick Start Guide
    (4)
    1 pc "backup power supply" sticker
    Compatible devices
    Compatible inverters
    • Fronius Primo GEN24 Plus
    • Fronius Symo GEN24 Plus
    • Fronius Verto Plus
    IMPORTANT!
    Compatible Smart Meters
    • Fronius Smart Meter IP
    • Fronius Smart Meter 50kA-3
    • Fronius Smart Meter 63A-1
    • Fronius Smart Meter 63A-3
    • Fronius Smart Meter TS 5kA-3
    • Fronius Smart Meter TS 65A-3
    • Fronius Smart Meter TS 100A-1
    Details on how to connect a Fronius Smart Meter can be found in the respective operating instructions.
    To download the Smart Meter operating instructions, either click on the link Smart Meter operating instructions or visit the page fronius.com/en/solar-energy/installers-partners/downloads on an end device and enter the search term "Smart Meter".
    PV module icon
    PV module
    generates direct current
    Fronius Hybrid inverter
    Converts direct current into alternating current and charges the battery.
    • Fronius Symo / Primo GEN24 Plus
    Backup Switch icon
    In the event of a power failure or grid malfunction, this enables all connected loads and producers to be disconnected from the public grid manually and safely in accordance with the specifications of the grid operator. Once grid stability has been restored, manual reconnection to the public grid is possible.
    Inverter icon
    Inverter in the system
    e.g. Fronius Primo, Fronius Symo, etc.
    Fronius Smart Meter icon
    Primary meter (Fronius Smart Meter)
    records the load curve of the system and makes the measured data available for energy profiling in Fronius Solar.web. The primary meter also regulates the dynamic feed-in control.
    Utility meter Icon
    Utility meter
    measures the metering data relevant for the billing of electricity quantities (primarily the kilowatt hours of grid purchases and grid power feed). On the basis of the data relevant for billing, the electricity retailer invoices a grid purchase and the purchaser of the surplus pays for the grid power feed.
    Grid icon
    Grid
    supplies the loads in the system if insufficient power is being generated by the PV modules or supplied by the battery.
    Battery icon
    Battery
    is coupled to the inverter on the direct current side, and stores electrical energy.
    Load icon
    Loads in the system
    e.g. washing machine, lights, television, etc.
    Positioning
    The Fronius Backup Switch must be installed at the following position in the system.
    Symbolic system installation showing the positioning of each component.
    The three switch positions of the backup switch.
    The backup switch has three switch positions:
    (1)
    Grid operation
    The power is supplied by the public grid.
    (2)
    0-position (de-energized)
    The power supply is safely disconnected from the public grid or from the backup power supply.
    (3)
    Backup power mode
    The power is supplied as backup power via the inverter or the battery.
    IMPORTANT!
    In the switch position (2) the Backup Switch can be secured to prevent it from being switched on/off using a standard padlock. The national guidelines must be complied with in this respect.
    2. Operating controls and connections
    (1)
    Grid operation
    (2)
    (3)
    Backup power mode
    IMPORTANT!
    Connection area
    View of the terminals of the Backup Switch with 1/3-pin connection from above and below.
    (1)
    Auxiliary contact switch terminals: Data communication
    (2)
    Load disconnector 63 A terminals: Grid
    (3)
    Load disconnector 20 A terminals: Data communication
    (4)
    (5)
    Load disconnector 63 A terminals: Load
    (6)
    For information about installing data communication, see chapter Connecting the data communication cables on page (→).
    Protective circuit
    For safe operation of the Fronius Backup Switch, the following components must be installed in the switch cabinet:
    • Upstream overcurrent protection according to the information in the chapter Technical data on page (→).
    • A surge protection device (SPD) as specified in chapter Technical data on page (→).
    1. Installation and Startup
    Protective circuit
    2. Requirements for connecting the Backup Switch
    Protective circuit
    Various cable types
    Solid
    Fine-stranded
    Fine-stranded with ferrule and collar
    Fine-stranded with ferrule without collar
    Single-core cable type
    Fine-stranded cable type
    Fine-stranded cable type with ferrule and collar
    Fine-stranded cable type with ferrule without collar
    Connect only round copper wires to the terminals. See tables below:
    Permissible cables for terminals on load disconnector 63 A 1)
    1 conductor per terminal
    1 - 25 mm2
    4 - 16 mm2
    2.5 - 16 mm2
    2.5 - 16 mm2
    2 conductor per terminal
    ≤ 10 mm2
    ≤ 10 mm2
    ≤ 10 mm2
    ≤ 10 mm2
    Permissible cables for terminals on load disconnector 20 A 1)
    0.13 - 10 mm2
    0.5 - 6 mm2
    0.5 - 6 mm2
    0.5 - 6 mm2
    0.13 - 2.5 mm2
    0.13 - 2.5 mm2
    0.13 - 2.5 mm2
    0.13 - 2.5 mm2
    Permissible cables for terminals on auxiliary contact switch
    0.13 - 2.5 mm2
    0.75 - 2.5 mm2
    0.5 - 1.5 mm2
    0.5 - 1.5 mm2
    0.13 - 2.5 mm2
    0.75 - 2.5 mm2
    0.5 - 1.5 mm2
    0.5 - 1.5 mm2
    1) Select a cable cross-section that is sufficiently large. The cable cross-section depends on the power actually connected.
    Connection screw
    M5
    M3.5
    M3.5
    Tightening torque
    2 - 4 Nm
    0.8 - 1.7 Nm
    0.8 - 1.4 Nm
    Conductors per terminal
    Safety
    WARNING!
    Danger due to short circuits resulting from foreign bodies in the connection area.
    An electric shock can lead to serious injury or death.
    Keep foreign objects away from the connection area or remove them if necessary.
    WARNING!
    Only trained service technicians who have received training from the respective inverter or battery manufacturer are authorized to perform commissioning, maintenance, and service activities for inverters and batteries, and only within the scope of the technical regulations.
    Read the installation instructions and operating instructions from the respective manufacturer before installing and commissioning the equipment.
    WARNING!
    Danger from mains voltage and DC voltage from PV modules that are exposed to light, as well as batteries.
    All connection, maintenance and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and battery, and are de-energized.
    Only an authorized electrical engineer is permitted to make the connection to the public grid.
    WARNING!
    Danger from damaged and/or contaminated terminals.
    Prior to connection work, check the terminals for damage and contamination.
    Remove any contamination while the equipment is de-energized.
    Have defective terminals repaired by an authorized specialist.
    2. Preparing for the installation
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    Turn off the automatic circuit breaker. Set the DC disconnector to the "off" (OFF) switch position.
    Switch off the battery connected to the inverter.
    Wait for the capacitors of the inverter to discharge (2 minutes).
    Installation
    The Fronius Backup Switch can be mounted on a 35 mm DIN rail.
    Housing dimensions according to DIN 4388:
    • 7.2 TE (horizontal pitch) with left and right end tabs (corresponds to the delivery condition)
    • 6.1 TE without end tabs
    Before connecting the cables, the housing cover must be removed.
    Disassembly of the switch and the housing cover from the Backup Switch.
    1Set the switch to position "0".
    2Push the switch lock down.
    ✓The switch is now unlocked.
    3Remove the screw.
    ✓The switch and housing cover can now be removed.
    Stripping lengths
    14 mm (0.55 in.)
    11 mm (0.43 in.)
    8 mm (0.31 in.)
    1-pin installation
    WARNING!
    Danger from loose and/or incorrectly clamped single conductors in the terminal.
    Check that the single conductors are secure in the terminal.
    Make sure that the single conductor has been fully inserted into the terminal and that no single wires are protruding out of the terminal.
    1Before starting the connection work, strip all cables of their insulation in accordance with the specifications. See chapter Stripping lengths on page (→).
    Plug the single conductor (L1 ) coming from the grid into the terminal.
    Tighten the single conductor (L1 ) in the terminal. For permissible connection screws and torques, see Permitted connection screws on page (→).
    2. 1-pin installation
    WARNING!
    WARNING!
    Plug the single conductor (L1‘) coming from the backup power circuit into the terminal.
    Tighten the single conductor (L1‘) in the terminal. For permissible connection screws and torques, see Permitted connection screws on page (→).
    3-pin installation
    WARNING!
    Plug the single conductors (L1 , L2 , L3 ) coming from the grid into the terminal.
    Tighten the single conductors (L1 , L2 , L3 ) in the terminals. For permissible connection screws and torques, see Permitted connection screws on page (→).
    2. 3-pin installation
    WARNING!
    WARNING!
    Plug the singles conductor (L1‘, L2‘, L3‘) coming from the backup power circuit into the terminals.
    Tighten the single conductors (L1‘, L2‘, L3‘) in the terminals. For permissible connection screws and torques, see Permitted connection screws on page (→).
    Feedback switch in backup power position (IN6/IN7)
    When the Fronius Backup Switch is switched to backup power supply, the inverter checks the position of the switch. If this position is correct, the backup power supply of the connected loads in the backup power circuit is enabled.
    Communication Modbus Fronius Smart Meter (M+/M-)
    The communication between the inverter and the Fronius Smart Meter is interrupted via the contact. The interrupted communication prevents automatic termination of backup power mode. The inverter remains in backup power mode. Once a stable power supply from the grid is available again, the switch of the Fronius Backup Switch must be changed manually to grid operation.
    If backup power mode is to be automatically terminated once the public grid is available again, do not route the communication line via the Fronius Backup Switch.
    Wired Shut Down (WSD IN-/WSD IN+)
    In the "O" switch position, the WSD line is interrupted. The inverter switches off immediately. An asynchronous switchback to the grid is prevented.
    2. Connecting the data communication cables
    IMPORTANT!
    Observe the following information regarding connection of the data communication cables to the Backup Switch.
    • Use network cables of type CAT5 STP or higher.
    • Use a twisted cable pair for data communication cables that belong together.
    • Use double insulated or sheathed data communication cables when they are near to bare conductors.
    Connection overview of the data communication cables between the Fronius Smart Meter, Fronius Backup Switch, and Fronius GEN24 inverter.
    When using Modbus RTU, the power supply  of the Fronius Smart Meter IP is interrupted in backup power mode via the contacts 23/24. This prevents automatic termination of backup power mode when the public power grid is available again.
    Connection overview of the data communication cables between the Fronius Backup Switch and Fronius GEN24 inverter with Modbus TCP/IP with a Fronius Smart Meter IP data communication option.
    When using Modbus TCP/IP or MQTT, the neutral conductor and thus the power supply of the Fronius Smart Meter IP is interrupted in backup power mode via the contacts 23/24. This prevents automatic termination of backup power mode when the public power grid is available again.
    WARNING!
    Danger due to electrical voltage from missing or incorrectly fitted protective covers.
    Electric shocks can be fatal and/or cause serious property damage.
    Fit the protective covers immediately after installing the live cables
    Fit the protective covers correctly and check that they are secure.
    IMPORTANT!
    The protective covers are used for additional insulation of the live lines to the data transfer lines.
    Mount a top protective cover on the load disconnector 63 A. Fit using the screws supplied with the delivery.
    Mount a bottom protective cover on the load disconnector 63 A. Fit using the screws supplied with the delivery.
    2. Mounting the protective cover
    WARNING!
    IMPORTANT!
    Reinstall the housing cover and the switch and secure with the screw.
    2. Mounting housing cover and switch
    Commissioning
    Switch on the battery connected to the inverter.
    Set the DC disconnector to the "on" switch position. Turn on the automatic circuit breaker.
    2. Commissioning
    2. Commissioning
    General
    IMPORTANT!
    Settings in the Device configuration > Functions and I/Os menu item may only be implemented by a technical specialist! The technician password must be entered for the Device configuration menu item.
    2. Commissioning
    1Call up the user interface of the inverter.
    - Open web browser.
    - In the address bar of the browser, enter the IP address
    (WiFi: 192.168.250.181, LAN: 169.254.0.180) or enter and confirm the host and domain name of the inverter.
    ✓The user interface of the inverter is displayed.
    2Log in to the login area with user Technician and the technician password.
    3Activate the Backup Power function in the Device Configuration > Functions and I/Os menu area.
    4Select Full Backup mode in the Backup power mode drop-down list.
    5Click the Save button to save the settings.
    ✓The Full Backup power mode has been configured.
    2. Commissioning
    Testing backup power mode:
    • during first-time installation and configuration
    • after working on the switch cabinet
    • during ongoing operation (recommendation: at least every 6 months)
    A battery charge of min. 30% is recommended for test mode.
    A description of how to run the test mode can be found in the checklist – Backup power (https://www.fronius.com/de/download-center?searchword=42,0426,0365).
    2. Commissioning
    Failure to manually switch to backup power mode within the first 10 minutes of a public grid outage may cause the inverter and battery to be shut down automatically. In order to start backup power mode, the manual switchover must be carried out and, if necessary, a manual system start must be carried out.
    1Switch the switch of the Backup Switch to the "Backup power mode" setting.
    2Switch on the inverter and the battery (observe the switch-on sequence).
    IMPORTANT!
    Depending on the battery manufacturer, follow the switch-on sequence recommended by the manufacturer for system startup. Please refer to the inverter or battery operating instructions for further information.
    Technical data
    Technical data
    Technical data
    Technical data 1)
    Load disconnector
    63 A
    Load disconnector
    20 A
    Thermal rated operating current
    open Ith
    63 A
    20 A
    10 A
    encapsulated Ithe
    63 A
    20 A
    Rated insulation voltage Ui 2)
    690 V
    690 V
    690 V
    Breaking capacity Ieff
    3 x 220 - 440 V
    330 A
    160 A
    3 x 500 V
    330 A
    160 A
    3 x 660 - 690 V
    190 A
    80 A
    Utilization categories AC21A, AC21B
    Rated operating current Ie
    400 V
    63 A
    20 A
    Rated operating power
    220 - 240 V
    24 kW
    8 kW
    380 - 440 V
    42 kW
    13 kW
    3-phase 3-pin
    660 - 690 V
    72 kW
    23 kW
    Utilization categories AC23A, AC23B
    400 V
    45 A
    16 A
    220 - 240 V
    15 kW
    4 kW
    380 - 440 V
    22 kW
    7.5 kW
    660 - 690 V
    18.5 kW
    5.5 kW
    Fuse
    gL (gG)
    max. 63 A
    max. 25 A
    max. 20 A
    General data
    Weight
     421 g
    Permitted ambient temperature
    -40 to +60 °C
    Dimensions
    64 x 125.4 x 91 mm
    Protection class
    IP20 + KLAD
    Mains frequency
    50 - 60 Hz
    Nominal voltage
    3 - 230/400 V
    Grid disconnection
    1-pin or 3-pin
    Conditional rated short-circuit current Icc
    10 kA
    1) According to IEC 947-3, IEC 947-5-1, VDE 0660, EN 60947-3, EN 60947-5-1
    2) Applies to: Grids with grounded neutral point, overvoltage category I to III, pollution degree 3: Uimp = 6kV.
    1. Technical data
    Technical data
    Technical data
    Technical data 1)
    Load disconnector
    63 A
    Load disconnector
    20 A
    open Ith
    63 A
    20 A
    10 A
    encapsulated Ithe
    63 A
    20 A
    690 V
    690 V
    690 V
    3 x 220 - 440 V
    330 A
    160 A
    3 x 500 V
    330 A
    160 A
    3 x 660 - 690 V
    190 A
    80 A
    400 V
    63 A
    20 A
    220 - 240 V
    24 kW
    8 kW
    380 - 440 V
    42 kW
    13 kW
    3-phase 3-pin
    660 - 690 V
    72 kW
    23 kW
    400 V
    45 A
    16 A
    220 - 240 V
    15 kW
    4 kW
    380 - 440 V
    22 kW
    7.5 kW
    660 - 690 V
    18.5 kW
    5.5 kW
    Fuse
    gL (gG)
    max. 63 A
    max. 25 A
    max. 20 A
    General data
    Weight
     421 g
    -40 to +60 °C
    Dimensions
    64 x 125.4 x 91 mm
    Protection class
    IP20 + KLAD
    Mains frequency
    50 - 60 Hz
    Nominal voltage
    3 - 230/400 V
    Grid disconnection
    1-pin or 3-pin
    10 kA
    1. Technical data
    2. Technical data
    Technical data
    Technical data 1)
    Load disconnector
    63 A
    Load disconnector
    20 A
    open Ith
    63 A
    20 A
    10 A
    encapsulated Ithe
    63 A
    20 A
    690 V
    690 V
    690 V
    3 x 220 - 440 V
    330 A
    160 A
    3 x 500 V
    330 A
    160 A
    3 x 660 - 690 V
    190 A
    80 A
    400 V
    63 A
    20 A
    220 - 240 V
    24 kW
    8 kW
    380 - 440 V
    42 kW
    13 kW
    3-phase 3-pin
    660 - 690 V
    72 kW
    23 kW
    400 V
    45 A
    16 A
    220 - 240 V
    15 kW
    4 kW
    380 - 440 V
    22 kW
    7.5 kW
    660 - 690 V
    18.5 kW
    5.5 kW
    Fuse
    gL (gG)
    max. 63 A
    max. 25 A
    max. 20 A
    General data
    Weight
     421 g
    -40 to +60 °C
    Dimensions
    64 x 125.4 x 91 mm
    Protection class
    IP20 + KLAD
    Mains frequency
    50 - 60 Hz
    Nominal voltage
    3 - 230/400 V
    Grid disconnection
    1-pin or 3-pin
    10 kA
    Maintenance
    Maintenance and service work may only be carried out by a technical specialist.
    1. Service, warranty terms and conditions, and disposal
    Maintenance
    2. Service, warranty terms and conditions, and disposal
    Maintenance
    Detailed warranty conditions specific to your country can be found at www.fronius.com/solar/garantie .
    To secure the full warranty period for the newly installed Fronius product, it is necessary to register at www.solarweb.com .
    Disposal
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Crush cardboard boxes
    Circuit Diagrams
    1. Circuit Diagrams
    1. Circuit Diagrams
